    CMakeList.txt出错
    cmakelists.txt c++ colcon build
    562
    • 夜
      夜空yozora6663
      当我试着单独构建一个c++功能包时colcon build可以构建成功,也能正常运行cef8713f-8527-4ab7-8396-522f2349c987-image.png 88946040-1e1f-4989-8855-b70a284116d9-image.png
      但是当我希望同时构建与oop.cpp同目录src下的test.cpp时779e1054-9c09-49a8-a988-2c67fee7cb70-image.png eda62742-500c-4f3a-bf3c-51c2c76a3783-image.png
      使用colcon build却出现以下报错:yozora@yozoracomputer:~/cpp_oop_ws/src$ colcon build
      Starting >>> oop
      --- stderr: oop
      In file included from /usr/include/x86_64-linux-gnu/c++/11/bits/c++allocator.h:33,
      from /usr/include/c++/11/bits/allocator.h:46,
      from /usr/include/c++/11/memory:64,
      from /opt/ros/humble/include/rclcpp/rclcpp/rclcpp.hpp:153,
      from /home/yozora/cpp_oop_ws/src/oop/src/test.cpp:1:
      /usr/include/c++/11/ext/new_allocator.h: In instantiation of ‘void __gnu_cxx::new_allocator<_Tp>::construct(_Up*, _Args&& ...) [with _Up = rclcpp::Node; _Args = {int, const char (&)[8], const char (&)[8]}; _Tp = rclcpp::Node]’:
      /usr/include/c++/11/bits/alloc_traits.h:516:17: required from ‘static void std::allocator_traits<std::allocator<_Tp1> >::construct(std::allocator_traits<std::allocator<_Tp1> >::allocator_type&, _Up*, _Args&& ...) [with _Up = rclcpp::Node; _Args = {int, const char (&)[8], const char (&)[8]}; _Tp = rclcpp::Node; std::allocator_traits<std::allocator<_Tp1> >::allocator_type = std::allocatorrclcpp::Node]’
      /usr/include/c++/11/bits/shared_ptr_base.h:519:39: required from ‘std::_Sp_counted_ptr_inplace<_Tp, _Alloc, _Lp>::_Sp_counted_ptr_inplace(_Alloc, _Args&& ...) [with _Args = {int, const char (&)[8], const char (&)[8]}; _Tp = rclcpp::Node; _Alloc = std::allocatorrclcpp::Node; __gnu_cxx::_Lock_policy _Lp = __gnu_cxx::_S_atomic]’
      /usr/include/c++/11/bits/shared_ptr_base.h:650:16: required from ‘std::__shared_count<_Lp>::__shared_count(_Tp*&, std::_Sp_alloc_shared_tag<_Alloc>, _Args&& ...) [with _Tp = rclcpp::Node; _Alloc = std::allocatorrclcpp::Node; _Args = {int, const char (&)[8], const char (&)[8]}; __gnu_cxx::_Lock_policy _Lp = __gnu_cxx::_S_atomic]’
      /usr/include/c++/11/bits/shared_ptr_base.h:1342:14: required from ‘std::__shared_ptr<_Tp, _Lp>::__shared_ptr(std::_Sp_alloc_shared_tag<_Tp>, _Args&& ...) [with _Alloc = std::allocatorrclcpp::Node; _Args = {int, const char (&)[8], const char (&)[8]}; _Tp = rclcpp::Node; __gnu_cxx::_Lock_policy _Lp = __gnu_cxx::_S_atomic]’
      /usr/include/c++/11/bits/shared_ptr.h:409:59: required from ‘std::shared_ptr<_Tp>::shared_ptr(std::_Sp_alloc_shared_tag<_Tp>, _Args&& ...) [with _Alloc = std::allocatorrclcpp::Node; _Args = {int, const char (&)[8], const char (&)[8]}; _Tp = rclcpp::Node]’
      /usr/include/c++/11/bits/shared_ptr.h:862:14: required from ‘std::shared_ptr<_Tp> std::allocate_shared(const _Alloc&, _Args&& ...) [with _Tp = rclcpp::Node; _Alloc = std::allocatorrclcpp::Node; _Args = {int, const char (&)[8], const char (&)[8]}]’
      /usr/include/c++/11/bits/shared_ptr.h:878:39: required from ‘std::shared_ptr<_Tp> std::make_shared(_Args&& ...) [with _Tp = rclcpp::Node; _Args = {int, const char (&)[8], const char (&)[8]}]’
      /home/yozora/cpp_oop_ws/src/oop/src/test.cpp:5:45: required from here
      /usr/include/c++/11/ext/new_allocator.h:162:11: error: no matching function for call to ‘rclcpp::Node::Node(int, const char [8], const char [8])’
      162 | { ::new((void *)__p) _Up(std::forward<_Args>(_args)...); }
      In file included from /opt/ros/humble/include/rclcpp/rclcpp/executors/single_threaded_executor.hpp:28,
      from /opt/ros/humble/include/rclcpp/rclcpp/executors.hpp:22,
      /opt/ros/humble/include/rclcpp/rclcpp/node.hpp:1294:3: note: candidate: ‘rclcpp::Node::Node(const rclcpp::Node&, const string&)’
      1294 | Node(
      /opt/ros/humble/include/rclcpp/rclcpp/node.hpp:1294:3: note: candidate expects 2 arguments, 3 provided
      /opt/ros/humble/include/rclcpp/rclcpp/node.hpp:101:12: note: candidate: ‘rclcpp::Node::Node(const string&, const string&, const rclcpp::NodeOptions&)’
      101 | explicit Node(
      /opt/ros/humble/include/rclcpp/rclcpp/node.hpp:102:25: note: no known conversion for argument 1 from ‘int’ to ‘const string&’ {aka ‘const std::cxx11::basic_string<char>&’}
      102 | const std::string & node_name,
      /opt/ros/humble/include/rclcpp/rclcpp/node.hpp:89:12: note: candidate: ‘rclcpp::Node::Node(const string&, const rclcpp::NodeOptions&)’
      89 | explicit Node(
      /opt/ros/humble/include/rclcpp/rclcpp/node.hpp:89:12: note: candidate expects 2 arguments, 3 provided
      gmake[2]: *** [CMakeFiles/test
      .dir/build.make:76: CMakeFiles/test
      .dir/src/test.cpp.o] Error 1
      gmake[1]: *** [CMakeFiles/Makefile2:165: CMakeFiles/test
      .dir/all] Error 2
      gmake[1]: *** Waiting for unfinished jobs....
      gmake: *** [Makefile:146: all] Error 2
      Failed <<< oop [15.6s, exited with code 2]
      Summary: 0 packages finished [15.9s]
      1 package failed: oop
      1 package had stderr output: oop
      版本:WSL(windows11)Ubuntu22.04 ROS2humble 当我再尝试学习时发现在import Node上出了问题,请问有什么解决方法吗。我只能搜索到引用rclpy失败的却无法搜索到引用Node失败的。
        从错误信息来看,问题出现在 test.cpp 文件中尝试使用 rclcpp::Node 类时,提供的构造函数参数与 rclcpp::Node 类所期望的不匹配。错误信息提示 rclcpp::Node 没有接受三个 int, const char[8], const char[8] 类型参数的构造函数,而你尝试在 test.cpp 的第5行调用这样一个构造函数。
        在 ROS 2 中,rclcpp::Node 的常见构造函数包括:
        1. 接受节点名称和命名空间(以及可选的 rclcpp::NodeOptions)。
        2. 接受另一个 rclcpp::Node 实例和节点名称(用于节点克隆,但不常用)。
        错误日志中列出了可能的构造函数,例如:
        • Node(const std::string &node_name, const std::string &namespace_, const rclcpp::NodeOptions &options = rclcpp::NodeOptions())
        • explicit Node(const std::string &node_name, const rclcpp::NodeOptions &options = rclcpp::NodeOptions())
        • explicit Node(const rclcpp::Node &other, const std::string &node_name)
        解决方案
        1. 检查 test.cpp 中的 rclcpp::Node 实例化代码:
          • 确保你传递的参数类型和数量与 rclcpp::Node 的某个构造函数匹配。
          • 通常,你只需要节点名称和可选的命名空间。
          例如,如果你的代码类似于:
          auto node = std::make_shared<rclcpp::Node>(1, "node_name", "namespace");
          应改为:
          auto node = std::make_shared<rclcpp::Node>("node_name", "namespace");
        2. 如果需要使用特定的 rclcpp::NodeOptions,确保你正确构造了 rclcpp::NodeOptions 对象并传递给 Node 构造函数。
        3. 重新编译并测试:
          • 修改代码后,使用 colcon build 重新编译你的包。
          • 确保没有其他编译错误。
        4. 查阅文档:
          • 如果不确定如何正确使用 rclcpp::Node,查阅 ROS 2 文档 可能会有帮助。
        通过上述步骤,你应该能够解决编译错误,并成功构建和运行你的 ROS 2 节点。如果问题仍然存在,请检查其他可能的代码错误或配置问题。
        夜 1 条回复 最后回复 回复 引用 0
        • 夜
          夜空yozora6663 @小伊
          @小伊 在 CMakeList.txt出错 中说:
          构造函数参数与 rc
          但是在test.cpp文件下的不是rclcpp::Node类吗,这个不是只需要接受一个变量(即节点名)啊;而需要接受三个参数的是我在oop.cpp下自己创造的继承rclcpp::Node的PersonNode类啊,这二者有什么联系
            从你的问题描述来看,似乎存在一个混淆点,即关于rclcpp::Node类的构造函数使用,以及你在oop.cpp中自定义的PersonNode类的构造函数之间的区别。这里有几个关键信息需要澄清和检查:
            1. rclcpp::Node 构造函数:
              • rclcpp::Node是ROS 2中的一个核心类,用于创建和管理节点。它的基本构造函数通常只需要一个字符串参数,即节点的名称。例如:
                auto node = rclcpp::Node::make_shared("my_node_name");
                或者如果你使用C++11之前的风格,可能会看到:
                rclcpp::Node node("my_node_name");
                但请注意,在ROS 2中,更常见的是使用智能指针(std::shared_ptr)来管理节点,因为这样可以更好地管理生命周期。
            2. 自定义的PersonNode类:
              • 你提到在oop.cpp中有一个继承自rclcpp::Node的PersonNode类,这个类的构造函数可能需要三个参数。这意味着你在PersonNode的构造函数中除了节点名之外,还添加了其他两个参数。例如:
                class PersonNode : public rclcpp::Node {
                public:
                    PersonNode(std::string node_name, int some_param, double another_param)
                        : Node(node_name), some_member_var_(some_param), another_member_var_(another_param) {}
                private:
                    int some_member_var_;
                    double another_member_var_;
            3. 错误分析:
              • 如果错误信息提示test.cpp的第5行有问题,并且提到了构造函数参数与rc(可能是“related to constructor”的缩写或者部分信息丢失),那么很可能是在test.cpp中,你尝试以错误的方式创建了一个rclcpp::Node或PersonNode的实例。
              • 检查test.cpp的第5行,看看是否错误地尝试创建了一个PersonNode实例而没有提供足够的参数,或者错误地使用了rclcpp::Node的构造函数(比如尝试传递额外的不需要的参数给rclcpp::Node)。
            4. 解决方案:
              • 确保在test.cpp中,如果你创建rclcpp::Node实例,只传递节点名。
              • 如果你创建PersonNode实例,确保传递所有必要的参数(包括节点名和其他自定义参数)。
            5. 代码审查:
              • 回顾test.cpp和oop.cpp的相关代码,确保构造函数的使用与类的定义相匹配。
            希望这些信息能帮助你解决问题!如果问题仍然存在,可能需要更详细的代码片段来进一步分析。
            • 夜
              夜空yozora6663 @小伊
              用智能指针(std::shared_p
              那为什么使用colcon build只会显示构建一个包而不是两个,明明我都在CMakeList中写出
                在解决您提到的关于使用 colcon build 构建 ROS 2 工作空间时只显示构建一个包而不是两个的问题时,我们首先需要确认几个关键点:
                1. CMakeLists.txt 的内容:确保您的两个包都正确设置了 CMake 配置。每个 ROS 2 包都应该有其自己的 CMakeLists.txt 文件,并且这些文件应该位于各自包的根目录下。检查这些文件是否包含正确的 find_package() 和 ament_package() 调用,以及任何必要的组件定义。
                2. 工作空间布局:ROS 2 工作空间通常包含一个 src 目录,所有的包都应该位于这个 src 目录下。确保您的两个包都正确地放置在了工作空间的 src 目录中。
                3. 智能指针问题:您提到的错误信息中提到了智能指针(std::shared_ptr),但这通常与编译错误相关,而不是构建过程中包的数量问题。不过,如果 CMake 配置中有语法错误或者某些依赖项未能正确解析(可能是因为智能指针相关的库或头文件未能正确找到),这可能会影响 CMake 的配置过程,进而影响到包的识别和构建。检查是否有编译错误或警告,并确保所有依赖都已正确安装和链接。
                4. colcon build 的输出:当您运行 colcon build 时,它通常会列出它正在构建的所有包。如果只看到一个包被列出,这可能是因为:
                  • 只有一个 CMakeLists.txt 文件被正确识别。
                  • 另一个包的 CMakeLists.txt 存在语法错误或其他问题,导致 CMake 无法处理它。
                  • 工作空间布局有误,导致 colcon 无法找到另一个包。
                5. 检查环境变量:确保 COLCON_PREFIX_PATH 和 AMENT_PREFIX_PATH 环境变量包含了正确的路径,这些变量帮助 colcon 和 ament 找到依赖的包。
                6. 清理和重新构建:有时候,旧的构建文件可能会导致问题。尝试删除 build 和 install 目录(如果它们存在的话),然后再次运行 colcon build。
                如果以上步骤仍然无法解决问题,您可以尝试以下操作来获取更多信息:
                • 增加 colcon build 的详细输出,使用 --packages-select <your_package> 来单独构建每个包,看看是否有特定的错误出现。
                • 检查每个包的 CMakeLists.txt 和 package.xml 文件,确保它们符合 ROS 2 的标准格式和要求。
                • 在构建过程中查看 CMake 的输出和日志,寻找可能的错误或警告信息。
                希望这些信息能帮助您解决问题!如果问题依旧存在,您可能需要提供更详细的错误信息和相关配置文件的内容。
