    yolo5 pipx
    yolov5 pipx
      2075605318 年度VIP
      lwb@Lwbr:~/lwb_ws$ ros2 run yolov5_ros2 yolo_detect_2d --ros-args -p device:=cpu -p image_topic:=/fishbot_camera_raw
      File "/home/lwb/lwb_ws/install/yolov5_ros2/lib/yolov5_ros2/yolo_detect_2d", line 33, in <module>
      sys.exit(load_entry_point('yolov5-ros2==0.0.0', 'console_scripts', 'yolo_detect_2d')())
      File "/home/lwb/lwb_ws/install/yolov5_ros2/lib/yolov5_ros2/yolo_detect_2d", line 25, in importlib_load_entry_point
      return next(matches).load()
      File "/usr/lib/python3.12/importlib/metadata/init.py", line 205, in load
      module = import_module(match.group('module'))
      File "/usr/lib/python3.12/importlib/init.py", line 90, in import_module
      File "<frozen importlib._bootstrap>", line 1387, in _gcd_import
      File "<frozen importlib._bootstrap>", line 1360, in _find_and_load
      File "<frozen importlib._bootstrap>", line 1331, in _find_and_load_unlocked
      File "<frozen importlib._bootstrap>", line 935, in _load_unlocked
      File "<frozen importlib._bootstrap_external>", line 995, in exec_module
      File "<frozen importlib._bootstrap>", line 488, in _call_with_frames_removed
      File "/home/lwb/lwb_ws/install/yolov5_ros2/lib/python3.12/site-packages/yolov5_ros2/yolo_detect_2d.py", line 3, in <module>
      from torch import imag
      ModuleNotFoundError: No module named 'torch'
      ubuntu2404 pipx 安装的yolo5 但它好像导入不进来
        小鱼 技术大佬 @2075605318
        @2075605318 在 yolo5 pipx 中说:
        感觉你用了gpu版本了好像,然后你的python版本是3.12 ,试试ubuntu22
