    ROS2使用控制器控制小车控制器始终显示找不到轮子怎么解决
    ros2 controlmanager
    • H
      HANOOOOOO1
      这是我的控制器yaml文件
      controller_manager:
      ros__parameters:
      update_rate: 10
      diff_drive_controller:
        type: diff_drive_controller/DiffDriveController
        left_wheel_names: ['front_left_wheel_joint', 'back_left_wheel_joint']
        right_wheel_names: ['front_right_wheel_joint', 'back_right_wheel_joint']
        publish_odom: true
        publish_odom_tf: true
        odom_frame_id: odom
        base_frame_id: base_link
        wheel_separation: 0.36
        wheel_radius: 0.01 在运行display.launch.py后[ros2_control_node-4] [INFO] [1743602048.822259030] [controller_manager]: Configuring controller 'diff_drive_controller'
        [ros2_control_node-4] [ERROR] [1743602048.822347027] [diff_drive_controller]: Wheel names parameters are empty!
        [ros2_control_node-4] [ERROR] [1743602048.822394510] [controller_manager]: After configuring, controller 'diff_drive_controller' is in state 'finalized' , expected inactive.
      不知道为什么怎么修改都一直显示Wheel names parameters are empty!,我的ros2版本是foxy,求助大佬这是为什么
