    ROS2 3Dslam建图 cartographer
    ros2 3d激光雷达 建图 slam
    2.2k
    • liusiyu_alex_nuaaL
      liusiyu_alex_nuaa
      最近有个项目用的是宇树雷达L1进行3D建图,按照网上的教程打算用cartographer算法来搞,但是运行起来从rviz来看只有2维地图,点云和imu的数据都是有的
      • cartographer.launch.py
      import os
          # 定位到功能包的地址
          pkg_share = FindPackageShare(package='robot_cartographer').find('robot_cartographer')
          #=====================运行节点需要的配置=======================================================================
          # 是否使用仿真时间
          use_sim_time = LaunchConfiguration('use_sim_time', default='false')
          # 地图的分辨率
          resolution = LaunchConfiguration('resolution', default='0.05')
          # 地图的发布周期
          publish_period_sec = LaunchConfiguration('publish_period_sec', default='1.0')
          # 配置文件夹路径
          configuration_directory = LaunchConfiguration('configuration_directory',default= os.path.join(pkg_share, 'config') )
          # 配置文件
          configuration_basename = LaunchConfiguration('configuration_basename', default='robot_3d.lua')
          rviz_config_dir = LaunchConfiguration('rviz_config_dir',default= os.path.join(pkg_share, 'rviz') )
          #=====================声明三个节点,cartographer/occupancy_grid_node/rviz_node=================================
          cartographer_node = Node(
              package='cartographer_ros',
              executable='cartographer_node',
              name='cartographer_node',
              output='screen',
              arguments=['-configuration_directory', configuration_directory,
                         '-configuration_basename', configuration_basename],
              remappings = [
                  ('points2', 'cloud')],)
          occupancy_grid_node = Node(
              executable='cartographer_occupancy_grid_node',
              name='occupancy_grid_node',
              output='screen',
              arguments=['-resolution', resolution, '-publish_period_sec', publish_period_sec])
          rviz_node = Node(
              package='rviz2',
              executable='rviz2',
              name='rviz2',
              output='screen')
          #===============================================定义启动文件========================================================
          ld = LaunchDescription()
          ld.add_action(cartographer_node)
          ld.add_action(occupancy_grid_node)
          ld.add_action(rviz_node)
          return ld
      • robot_3d.lua
      -- Copyright 2016 The Cartographer Authors
      -- Licensed under the Apache License, Version 2.0 (the "License");
      -- you may not use this file except in compliance with the License.
      -- You may obtain a copy of the License at
      --      http://www.apache.org/licenses/LICENSE-2.0
      -- Unless required by applicable law or agreed to in writing, software
      -- distributed under the License is distributed on an "AS IS" BASIS,
      -- WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
      -- See the License for the specific language governing permissions and
      -- limitations under the License.
      include "map_builder.lua"
      include "trajectory_builder.lua"
      options = {
        map_builder = MAP_BUILDER,
        map_frame = "map",
        tracking_frame = "imu_link",
        published_frame = "base_link",
        odom_frame = "odom",
        provide_odom_frame = false,
        publish_frame_projected_to_2d = false,
        -- use_pose_extrapolator = true,
        use_odometry = false,
        use_nav_sat = false,
        use_landmarks = false,
        num_laser_scans = 0,
        num_subdivisions_per_laser_scan = 1,
        num_point_clouds = 1,
        submap_publish_period_sec = 0.3,
        odometry_sampling_ratio = 1.,
        imu_sampling_ratio = 1.,
      TRAJECTORY_BUILDER_3D.num_accumulated_range_data = 160
      MAP_BUILDER.use_trajectory_builder_3d = true
      MAP_BUILDER.num_background_threads = 7
      POSE_GRAPH.optimization_problem.huber_scale = 5e2
      POSE_GRAPH.optimize_every_n_nodes = 320
      POSE_GRAPH.constraint_builder.sampling_ratio = 0.03
      POSE_GRAPH.optimization_problem.ceres_solver_options.max_num_iterations = 10
      POSE_GRAPH.constraint_builder.min_score = 0.62
      POSE_GRAPH.constraint_builder.global_localization_min_score = 0.66
      return options
      • 机器人urdf文件
      <robot name="cartographer_backpack_3d">
        <material name="orange">
          <color rgba="1.0 0.5 0.2 1" />
        </material>
        <material name="gray">
          <color rgba="0.2 0.2 0.2 1" />
        </material>
        <!-- IMU or 底盘 (可以描述尺寸大小也可以不描述) -->
        <link name="base_link" />
        <link name="imu_link" />
        <joint name="imu_link_joint" type="fixed">
          <parent link="base_link" />
          <child link="imu_link" />
          <origin xyz="0 0 0" rpy="0 0 0" />
        </joint>
        <!-- 描述雷达的尺寸大小、颜色 -->
        <link name="laser_link">
          <visual>
            <origin xyz="0.0 0.0 0.0" />
            <geometry>
              <cylinder length="0.07" radius="0.05" />
            </geometry>
            <material name="gray" />
          </visual>
        </link>
        <!-- 描述 雷达和IMU/底盘 的相对位姿 -->
        <joint name="laser_link_joint" type="fixed">
          <parent link="imu_link" />
          <child link="laser_link" />
          <origin xyz="0.007698 0.014655 -0.00667" rpy="0 0 0" />
        </joint>
      </robot>
      • 所有话题
      robot@ubuntu:~$ ros2 topic list
      /clicked_point
      /cloud
      /constraint_list
      /goal_pose
      /initialpose
      /joint_states
      /landmark_poses_list
      /map
      /map_updates
      /parameter_events
      /robot_description
      /rosout
      /scan_matched_points2
      /submap_list
      /tf
      /tf_static
      /trajectory_node_list
      • rqt的节点图
      • rviz界面
        大佬,解决了没有,同问
