    nav2 stvl层配置后没有效果
    nav2 voxellayer
    • R
      realez 年度VIP
      环境是wsl fishbot gazebo模拟
      参考官方文档https://docs.nav2.org/tutorials/docs/navigation2_with_stvl.html和git仓库里的配置文件,配置以后没有任何效果,无法避开低于雷达高度的障碍物,在local_costmap中也没有现实障碍物,有人成功配置过或有参考配置吗
      尝试了多个配置方案,在global_costmap中也配置过
      local_costmap:
      local_costmap:
      ros__parameters:
      update_frequency: 5.0
      publish_frequency: 2.0
      global_frame: odom
      robot_base_frame: base_link
      use_sim_time: True
      rolling_window: true
      width: 3
      height: 3
      resolution: 0.05
      robot_radius: 0.12
      # plugins: ["voxel_layer", "stvl_layer","inflation_layer"]
      plugins: ["stvl_layer","inflation_layer"]
      stvl_layer:
      plugin: "spatio_temporal_voxel_layer/SpatioTemporalVoxelLayer"
      enabled: true
      voxel_decay: 15.0 # seconds if linear, e^n if exponential
      decay_model: 0 # 0=linear, 1=exponential, -1=persistent
      voxel_size: 0.02 # meters
      track_unknown_space: true # default space is known
      mark_threshold: 0 # voxel height
      update_footprint_enabled: true
      combination_method: 1 # 1=max, 0=override
      origin_z: 0.0 # meters
      publish_voxel_map: false # default off
      transform_tolerance: 0.5 # seconds
      mapping_mode: false # default off, saves map not for navigation
      map_save_duration: 60.0 # default 60s, how often to autosave
      observation_sources: rgbd1_mark rgbd1_clear
      rgbd1_mark:
      data_type: PointCloud2
      topic: /camera_sensor/points
      marking: true
      clearing: false
      obstacle_range: 3.0 # meters
      min_obstacle_height: 0.1 # default 0, meters
      max_obstacle_height: 2.0 # default 3, meters
      expected_update_rate: 0.0 # default 0, if not updating at this rate at least, remove from buffer
      observation_persistence: 0.0 # default 0, use all measurements taken during now-value, 0=latest
      inf_is_valid: false # default false, for laser scans
      filter: "passthrough" # default passthrough, apply "voxel", "passthrough", or no filter to sensor data, recommend on
      voxel_min_points: 0 # default 0, minimum points per voxel for voxel filter
      clear_after_reading: true # default false, clear the buffer after the layer gets readings from it
      rgbd1_clear:
      marking: false
      clearing: true
      max_z: 7.0 # default 0, meters
      min_z: 0.1 # default 10, meters
      vertical_fov_angle: 0.8745 # default 0.7, radians
      horizontal_fov_angle: 1.048 # default 1.04, radians
      decay_acceleration: 5.0 # default 0, 1/s^2. If laser scanner MUST be 0
      model_type: 0
      inflation_layer:
      cost_scaling_factor: 3.0
      inflation_radius: 0.55
      # voxel_layer:
      # plugin: "nav2_costmap_2d::VoxelLayer"
      # enabled: True
      # publish_voxel_map: True
      # origin_z: 0.0
      # z_resolution: 0.05
      # z_voxels: 16
      # max_obstacle_height: 2.0
      # mark_threshold: 0
      # observation_sources: scan
      # scan:
      # topic: /scan
      # clearing: True
      # marking: True
      # data_type: "LaserScan"
      # raytrace_max_range: 3.0
      # raytrace_min_range: 0.0
      # obstacle_max_range: 2.5
      # obstacle_min_range: 0.0
      # static_layer:
      # plugin: "nav2_costmap_2d::StaticLayer"
      # map_subscribe_transient_local: True
      ... other parameters ...
      local_costmap:
      local_costmap:
      ros__parameters:
      global_frame: odom
      robot_base_frame: base_link # Ensure this matches your robot's TF
      use_sim_time: True
      width: 3
      height: 3
      resolution: 0.05
      robot_radius: 0.12 # Or use footprint parameter
      transform_tolerance: 0.5 # Increased tolerance can help with timing issues
      # List both layers here, plus inflation
      plugins: ["scan_voxel_layer", "inflation_layer"]
      # Configuration for the standard VoxelLayer (using LaserScan)
      scan_voxel_layer:
      enabled: True
      publish_voxel_map: True # Publishes to /local_costmap/scan_voxel_layer/voxel_grid (namespaced)
      origin_z: 0.0
      z_resolution: 0.05
      z_voxels: 16
      mark_threshold: 0
      observation_sources: scan # Source name for this layer
      scan: # Configuration for the 'scan' source
      topic: /scan
      clearing: True
      marking: True
      # Configuration for the Spatio-Temporal Voxel Layer (using PointCloud2)
      # stvl_layer:
      # plugin: "spatio_temporal_voxel_layer/SpatioTemporalVoxelLayer"
      # enabled: true
      # publish_voxel_map: true # Publishes to /local_costmap/stvl_layer/voxel_map (namespaced)
      # voxel_decay: 10.0 # Shorter decay for local map
      # decay_model: 0 # 0=linear
      # voxel_size: 0.05 # Match resolution if desired
      # track_unknown_space: true
      # mark_threshold: 0
      # update_footprint_enabled: true
      # combination_method: 1 # 1=max
      # origin_z: 0.0
      # transform_tolerance: 0.5 # Increased tolerance
      # mapping_mode: false
      # observation_sources: pointcloud # Source name for this layer
      # pointcloud: # Configuration for the 'pointcloud' source
      # data_type: PointCloud2
      # topic: /camera_sensor/points
      # marking: true
      # clearing: true # STVL can often use a single source for marking/clearing PointCloud2
      # obstacle_range: 3.0
      # min_obstacle_height: 0.05 # Catch low obstacles
      # expected_update_rate: 0.0
      # observation_persistence: 0.0
      # inf_is_valid: false
      # filter: "passthrough"
      # voxel_min_points: 1
      # # Consider adding separate mark/clear sources if clearing isn't effective
      # Configuration for the InflationLayer (runs last)
      inflation_layer:
      inflation_radius: 0.55 # Adjust based on robot size and environment
      always_send_full_costmap: True # Useful for debugging
      local_costmap:
      local_costmap:
      ros__parameters:
      use_sim_time: True
      global_frame: odom
      width: 8
      height: 8
      resolution: 0.05
      # footprint: "[ [0.254, 0.2159], [0.254, -0.2159], [-0.254, -0.2159], [-0.254, 0.2159] ]"
      # footprint_padding: 0.1
      robot_radius: 0.12
      track_unknown_space: false
      plugins: ["spatio_temporal_voxel_layer", "inflation_layer"]
      inflation_layer:
      spatio_temporal_voxel_layer:
      enabled: true
      voxel_decay: 15.
      decay_model: 0
      voxel_size: 0.05
      unknown_threshold: 15
      mark_threshold: 0
      origin_z: 0.0
      transform_tolerance: 0.2
      mapping_mode: false
      observation_sources: depth_cam
      # # lidar:
      # topic: /sensors/lidar_0/segmented_points
      # marking: true
      # clearing: true
      # obstacle_range: 8.0
      # min_obstacle_height: 0.254
      # max_obstacle_height: 0.8
      # filter: "voxel"
      # voxel_min_points: 0
      # clear_after_reading: true
      # max_z: 8.0
      # min_z: 0.3
      # vertical_fov_angle: 0.785398
      # vertical_fov_padding: 0.05
      # horizontal_fov_angle: 6.29
      # decay_acceleration: 15.0
      # model_type: 1
      depth_cam:
      marking: true
      clearing: true
      obstacle_range: 2.0
      min_obstacle_height: 0.1524
      inf_is_valid: false
      filter: "voxel"
      voxel_min_points: 0
      max_z: 2.0
      min_z: 0.2
      vertical_fov_angle: 1.047
      horizontal_fov_angle: 1.221
      model_type: 0
        小鱼 技术大佬 @realez
        @realez 暂时我也没测试过这个,蹲后续
