    gazebo中显示多个机器人模型
    多机器人 gazebo
    • B
      benz
      请问我在gazebo.launch文件中修改了一个机器人模型,但是命名空间是不起作用还是咋了
      一直停留在[robot3.spawn_entity]:Waiting for entity xml on robot1/robot_description不显示机器人模型
      具体launch修改代码如下:
      import launch
      import launch_ros
      import os
      import launch_ros.parameter_descriptions
      import launch.launch_description_sources
      # 获取功能包的share路径
      urdf_package_path = get_package_share_directory('fishbot_description')
      default_xacro_path = os.path.join(urdf_package_path, 'urdf', 'fishbot', 'fishbot.urdf.xacro')
      default_gazebo_world_path = os.path.join(urdf_package_path, 'world', 'custom_room.world')
      # 声明一个urdf目录参数,方便修改
          name='model', default_value=str(default_xacro_path), description='加载的模型文件路径'
      # 处理三个机器人的URDF
      robot1_desc = launch.substitutions.Command(['xacro ', default_xacro_path, ' prefix:=robot1/'])
      robot2_desc = launch.substitutions.Command(['xacro ', default_xacro_path, ' prefix:=robot2/'])
      robot3_desc = launch.substitutions.Command(['xacro ', default_xacro_path, ' prefix:=robot3/'])
      # 第一个机器人状态发布器
      robot1_state_publisher = launch_ros.actions.Node(
          namespace='robot1',
          parameters=[{
              'robot_description': launch_ros.parameter_descriptions.ParameterValue(robot1_desc, value_type=str),
              'frame_prefix': 'robot1/'
      # 第二个机器人状态发布器
      robot2_state_publisher = launch_ros.actions.Node(
          namespace='robot2',
          parameters=[{
              'robot_description': launch_ros.parameter_descriptions.ParameterValue(robot2_desc, value_type=str),
              'frame_prefix': 'robot2/'
      # 第三个机器人状态发布器
      robot3_state_publisher = launch_ros.actions.Node(
          namespace='robot3',
          parameters=[{
              'robot_description': launch_ros.parameter_descriptions.ParameterValue(robot3_desc, value_type=str),
              'frame_prefix': 'robot3/'
      # 启动 Gazebo 仿真环境
      action_launch_gazebo = launch.actions.IncludeLaunchDescription(
          launch.launch_description_sources.PythonLaunchDescriptionSource(
              os.path.join(get_package_share_directory('gazebo_ros'), 'launch', 'gazebo.launch.py')
          launch_arguments=[('world', default_gazebo_world_path), ('verbose', 'true')]
      # 将机器人1加载到 Gazebo
      action_spawn_robot1 = launch_ros.actions.Node(
          package='gazebo_ros',
          executable='spawn_entity.py',
          namespace='robot1',
          arguments=[
              '-topic', 'robot1/robot_description',
              '-entity', 'robot1',
              '-x', '0.4',
              '-y', '0',
              '-z', '0'
          output='screen'
      # 将机器人2加载到 Gazebo
      action_spawn_robot2 = launch_ros.actions.Node(
          namespace='robot2',
          arguments=[
              '-topic', 'robot2/robot_description',
              '-entity', 'robot2',
              '-x', '-0.4',
              '-y', '0',
              '-z', '0'
          output='screen'
      # 将机器人3加载到 Gazebo
      action_spawn_robot3 = launch_ros.actions.Node(
          namespace='robot3',
          arguments=[
              '-topic', 'robot3/robot_description',
              '-entity', 'robot3',
              '-x', '0',
              '-y', '0',
              '-z', '0'
          output='screen'
          action_declare_arg_mode_path,
          robot1_state_publisher,
          robot2_state_publisher,
          robot3_state_publisher,
          action_launch_gazebo,
          action_spawn_robot1,
          action_spawn_robot2,
          action_spawn_robot3
      • B
        benz
        我是想在gazebo中显示三个机器人模型,fishbot可以显示,但是三个就显示不了
        B 1 条回复 最后回复 回复 引用 0
        • B
          benz @benz
          @小鱼我这样做机器人模型xacro还需要更改嘛?
