    请问这个问题应该怎么解决
    ros2 ros2 linux
    1.3k
      最后由 3249098553 编辑
      报错是[{
      "resource": "/home/lzx/桌面/chapt7/damo_pkg_cpp/src/cpp_node.cpp",
      "owner": "C/C++: IntelliSense",
      "code": "1696",
      "severity": 8,
      "message": "检测到 #include 错误。请更新 includePath。已为此翻译单元(/home/lzx/桌面/chapt7/damo_pkg_cpp/src/cpp_node.cpp)禁用波形曲线。",
      "source": "C/C++",
      "startLineNumber": 3,
      "startColumn": 1,
      "endLineNumber": 3,
      "endColumn": 33
      "code": "1696",
      "severity": 8,
      "message": "无法打开 源 文件 "cv_bridge/cv_bridge.h"",
      "source": "C/C++",
      "startColumn": 1,
      "endLineNumber": 3,
      "endColumn": 33
      程序是```
      #include "rclcpp/rclcpp.hpp"
      #include "sensor_msgs/msg/image.hpp"
      #include "cv_bridge/cv_bridge.h"
      #include "opencv2/opencv.hpp"
      #include "image_transport/image_transport.hpp"
      class TextOverlay : public rclcpp::Node
      public:
          TextOverlay() : Node("cpp_node")
              publisher_ = image_transport::create_publisher(this, "/turtlesim/sim_with_text");
              subscription_ = image_transport::create_subscription
                  this,
                  "/turtlesim/sim",
                  [this](const sensor_msgs::msg::Image::ConstSharedPtr& msg)
                      this->image_callback(msg);
                  "raw"
      private:
          void image_callback(const sensor_msgs::msg::Image::ConstSharedPtr& msg)
              try
                  cv_bridge::CvImagePtr cv_ptr = cv_bridge::toCvCopy(msg, "bgr8");
                  cv::putText(
                      cv_ptr->image,
                      "2024214969",
                      cv::Point(50, 50),
                      cv::FONT_HERSHEY_SIMPLEX,
                      1.0,
                      cv::Scalar(0, 0, 255),
                  publisher_.publish(cv_ptr->toImageMsg());
              catch (const cv_bridge::Exception& e)
                  RCLCPP_ERROR(this->get_logger(), "cv_bridge error: %s", e.what());
          image_transport::Publisher publisher_;
          image_transport::Subscriber subscription_;
      int main(int argc, char** argv)
          rclcpp::init(argc, argv);
          auto node = std::make_shared<TextOverlay>();
          rclcpp::spin(node);
          rclcpp::shutdown();
          return 0;
      CMAKE是
      project(damo_pkg_cpp)
      if(NOT CMAKE_CXX_STANDARD)
        set(CMAKE_CXX_STANDARD 14)
      endif()
      # find dependencies
      find_package(OpenCV REQUIRED)
      find_package(rclcpp REQUIRED)
      find_package(sensor_msgs REQUIRED)
      find_package(cv_bridge REQUIRED)
      find_package(image_transport REQUIRED)
      add_executable(cpp_node src/cpp_node.cpp)
      target_include_directories
        cpp_node PRIVATE
        ${rclcpp_INCLUDE_DIRS}
        ${OpenCV_INCLUDE_DIRS}
        ${sensor_msgs_INCLUDE_DIRS}
        ${image_transport_INCLUDE_DIRS}
        ${cv_bridge_INCLUDE_DIRS}
      target_link_libraries
        cpp_node
        ${rclcpp_LIBRARIES}
        ${sensor_msgs_LIBRARIES}
        ${image_transport_LIBRARIES}
        ${cv_bridge_LIBRARIES}
        ${OpenCV_LIBRARIES}
      install(TARGETS cpp_node
      if(BUILD_TESTING)
      endif()
      ament_package()
      json是```
          "configurations": [
                  "name": "Linux",
                  "includePath": [
                      "${workspaceFolder}/**",
                      "/opt/ros/jazzy/include/**",
                      "/usr/include/**",
                      "/usr/include/opencv4/**"
                  "defines": [],
                  "compilerPath": "/usr/bin/g++",
                  "cStandard": "c17",
                  "cppStandard": "gnu++14",
                  "intelliSenseMode": "linux-gcc-x64"
          "version": 4
      3 1 条回复 最后回复 回复 引用 0
        3249098553 @3249098553
