    cartographer 双雷达定位
    cartographer定位 laser
    1.1k
    • 小丑汪小
      WOW995
      我将两个单线激光雷达的数据传入cartographer,设置了num_laser_scans = 2,将话题进行了重映射,小车静止不动,定位结果也会乱飞,这个是什么问题?
      小丑汪小 1 条回复 最后回复 回复 引用 0
      • 小丑汪小
        WOW995 @小丑汪
        @小丑汪 ```
        options = {
        map_builder = MAP_BUILDER_DEFAULT,
        trajectory_builder = TRAJECTORY_BUILDER_DEFAULT,
        map_builders = {
        [1] = MAP_BUILDER_DEFAULT,
        [2] = MAP_BUILDER_ELEVATOR,
        trajectory_builders = {
        [1] = TRAJECTORY_BUILDER_DEFAULT,
        [2] = TRAJECTORY_BUILDER_ELEVATOR,
        map_frame = "map",
        tracking_frame = "base_footprint",
        published_frame = "odom",
        odom_frame = "odom",
        scan_frame_id = "laser_front",
        provide_odom_frame = false,
        publish_raw_odom_tf = false,
        publish_frame_projected_to_2d = true,
        use_pose_extrapolator = true,
        log_delay_histogram = false,
        use_odometry = true,
        use_nav_sat = false,
        use_landmarks = false,
        num_subdivisions_per_laser_scan = 1,
        num_point_clouds = 0,
        submap_publish_period_sec = 0.3,
        pose_publish_period_sec = 0.02,
        localization_score_threshold_good = 0.7,
        localization_score_threshold_medium = 0.5,
        localization_score_threshold_weak = 0.3,
        score_warp_polynomial = "0.54563,-1.76587,2.14732,0.00000",
        odometry_sampling_ratio = 1.,
        imu_sampling_ratio = 1.,
        publish_tracked_pose = true,
        tracking_localization_score_pub_ratio = 10,
        start_new_trajectory_relocalization_score = 0.0,
        initial_localization_configuration_dir = "/share/cartographer_ros/localization_config/config",
        initial_localization_configuration_file = "localization_without_odom.lua",
        initial_localization_map = "/share/cartographer_ros/localization_config/maps/1.pbstream",
        --离群点阈值和曲率阈值
        cloudcurvature_threshold = 1000000,
        outlier_threshold = 0.0001,
        TRAJECTORY_BUILDER_2D.submaps.grid_options_2d.resolution = 0.05
        POSE_GRAPH.optimize_every_n_nodes = 20
        MAP_BUILDER.num_background_threads = 8
        return options
