    ros2-jazzy,启动gz_sim 的标准launch格式是咋样的,我这改如何修改
    gazebo gzsim launch文件
    1.0k
    • K
      kingking
      from launch.actions import IncludeLaunchDescription
      from launch.substitutions import PathJoinSubstitution
      import os
      import xacro
      share_dir = get_package_share_directory('robot_demo1_description')
      xacro_file = os.path.join(share_dir, 'urdf', 'robot_demo1.xacro')
      robot_description_config = xacro.process_file(xacro_file)
      robot_urdf = robot_description_config.toxml()
          name='robot_state_publisher',
          parameters=[
              {'robot_description': robot_urdf}
      joint_state_publisher_node = Node(
          package='joint_state_publisher',
          executable='joint_state_publisher',
          name='joint_state_publisher'
      gazebo_server = IncludeLaunchDescription(
          PythonLaunchDescriptionSource([
              PathJoinSubstitution([
                  FindPackageShare('gazebo_ros'),
                  'launch',
                  'gzserver.launch.py'
          launch_arguments={
              'pause': 'true'
          }.items()
      gazebo_client = IncludeLaunchDescription(
                  'launch',
                  'gzclient.launch.py'
      urdf_spawn_node = Node(
          package='gazebo_ros',
          executable='spawn_entity.py',
          arguments=[
              '-entity', 'robot_demo1',
              '-topic', 'robot_description'
          output='screen'
      return LaunchDescription([
          robot_state_publisher_node,
          joint_state_publisher_node,
          gazebo_server,
          gazebo_client,
          urdf_spawn_node,
      Y 1 条回复 最后回复 回复 引用 0
      • Y
        yuan_0 @kingking
        我目前接触到两种,一种是类似于tb3的那种,另一种直接借助ros-gz-sim启动后spawn
