    moveit2在colcon build --cmake-args -DCMAKE_BUILD_TYPE=Release遇到ros_testing无法找到
    机械臂运动规划
    moveit2安装 moveit2安装出错 动手学moveit2
    • G
      goat
      由于我的虚拟机没有代理,不好使用
      vcs import < moveit2_tutorials/moveit2_tutorials.repos
      所以,我在另外一个双系统的有代理的linux下运行后,拷贝过来,编译发现了如下问题
      Starting >>> moveit_resources_panda_description
      Starting >>> moveit_common
      Finished <<< moveit_common [0.77s]
      Starting >>> moveit_resources_pr2_description
      Finished <<< moveit_resources_panda_description [1.26s]
      Starting >>> srdfdom
      Finished <<< moveit_resources_pr2_description [1.10s]
      Starting >>> moveit_resources_panda_moveit_config
      Finished <<< moveit_resources_panda_moveit_config [0.93s]
      Starting >>> launch_param_builder
      Finished <<< launch_param_builder [1.59s]
      Starting >>> moveit_resources_fanuc_description
      Finished <<< moveit_resources_fanuc_description [1.64s]
      Starting >>> moveit_resources_fanuc_moveit_config
      Finished <<< moveit_resources_fanuc_moveit_config [1.57s]
      Starting >>> moveit_resources_prbt_support
      Finished <<< moveit_resources_prbt_support [1.58s]
      Starting >>> moveit_task_constructor_msgs
      Finished <<< srdfdom [23.4s]
      Starting >>> moveit_core
      [Processing: moveit_core, moveit_task_constructor_msgs]
      Finished <<< moveit_task_constructor_msgs [52.4s]
      Starting >>> moveit_configs_utils
      Finished <<< moveit_configs_utils [1.16s]
      Starting >>> rviz_marker_tools
      Finished <<< rviz_marker_tools [11.4s]
      Starting >>> rosparam_shortcuts
      --- stderr: rosparam_shortcuts
      CMake Error at CMakeLists.txt:97 (find_package):
        By not providing "Findros_testing.cmake" in CMAKE_MODULE_PATH this project
        has asked CMake to find a package configuration file provided by
        "ros_testing", but CMake did not find one.
        Could not find a package configuration file provided by "ros_testing" with
        any of the following names:
          ros_testingConfig.cmake
          ros_testing-config.cmake
        Add the installation prefix of "ros_testing" to CMAKE_PREFIX_PATH or set
        "ros_testing_DIR" to a directory containing one of the above files.  If
        "ros_testing" provides a separate development package or SDK, be sure it
        has been installed.
      Failed   <<< rosparam_shortcuts [1.89s, exited with code 1]
      Aborted  <<< moveit_core [7min 52s]
      Summary: 12 packages finished [8min 17s]
        1 package failed: rosparam_shortcuts
        1 package aborted: moveit_core
        1 package had stderr output: rosparam_shortcuts
        41 packages not processed
      请问大家有什么好办法解决吗?
