进行gazebo仿真使用雷达、imu、相机插件时出现[ERROR] [gzserver-4]:
<?xml version="1.0"?>
<xacro:macro name="gazebo_sensor_plugin">
<gazebo reference="laser_link">
<sensor name="laserscan" type="ray">
<plugin name="laserscan" filename="libgazebo_ros_ray_sensor.so"><ros> <namespace>/</namespace> <remapping>~/out:=scan</remapping> </ros> <output_type>sensor_msgs/LaserScan</output_type> <frame_name>laser_link</frame_name> </plugin> <always_on>true</always_on> <visualize>true</visualize> <update_rate>5</update_rate> <pose>0 0 0 0 0 0</pose> <ray> <scan> <horizontal> <samples>360</samples> <resolution>1.000000</resolution> <min_angle>0.000000</min_angle> <max_angle>6.280000</max_angle> </horizontal> </scan> <range> <min>0.120000</min> <max>5.0</max> <resolution>0.015000</resolution> </range> <noise> <type>gaussian</type> <mean>0.0</mean> <stddev>0.01</stddev> </noise> </ray> </sensor> </gazebo> <!--IMU--> <!-- <gazebo reference="imu_link"> <sensor name="imu_sensor" type="imu"> <plugin name="imu_plugin" filename="libgazebo_ros_imu_sensor.so"> <ros> <namespace>/</namespace> <remapping>~/out:=imu</remapping> </ros> <initial_orientation_as_reference>false</initial_orientation_as_reference> </plugin> <update_rate>100</update_rate> <always_on>true</always_on> <imu> <angular_velocity> <x> <noise type="gaussian"> <mean>0.0</mean> <stddev>2e-4</stddev> <bias_mean>0.0000075</bias_mean> <bias_stddev>0.0000008</bias_stddev> </noise> </x> <y> <noise type="gaussian"> <mean>0.0</mean> <stddev>2e-4</stddev> <bias_mean>0.0000075</bias_mean> <bias_stddev>0.0000008</bias_stddev> </noise> </y> <z> <noise type="gaussian"> <mean>0.0</mean> <stddev>2e-4</stddev> <bias_mean>0.0000075</bias_mean> <bias_stddev>0.0000008</bias_stddev> </noise> </z> </angular_velocity> <linear_acceleration> <x> <noise type="gaussian"> <mean>0.0</mean> <stddev>1.7e-2</stddev> <bias_mean>0.1</bias_mean> <bias_stddev>0.001</bias_stddev> </noise> </x> <y> <noise type="gaussian"> <mean>0.0</mean> <stddev>1.7e-2</stddev> <bias_mean>0.1</bias_mean> <bias_stddev>0.001</bias_stddev> </noise> </y> <z> <noise type="gaussian"> <mean>0.0</mean> <stddev>1.7e-2</stddev> <bias_mean>0.1</bias_mean> <bias_stddev>0.001</bias_stddev> </noise> </z> </linear_acceleration> </imu> </sensor> </gazebo> --> <!--camera--> <gazebo reference="camera_link"> <sensor type="depth" name="camera_sensor"> <plugin name="depth_camera" filename="libgazebo_ros_camera.so"> <frame_name>camera_optical_link</frame_name> </plugin> <always_on>true</always_on> <update_rate>10</update_rate> <camera name="camera"> <horizontal_fov>1.5009831567</horizontal_fov> <image> <width>800</width> <height>600</height> <format>R8G8B8</format> </image> <distortion> <k1>0.0</k1> <k2>0.0</k2> <k3>0.0</k3> <p1>0.0</p1> <p2>0.0</p2> <center>0.5 0.5</center> </distortion> </camera> </sensor> </gazebo> </xacro:macro></robot>,然后问题“[ERROR] [gzserver-4]: process has died [pid 15574, exit code -11, cmd 'gzserver /home/wheeltec/chapt6/chapt6_ws/install/fishbot_description/share/fishbot_description/world/custom_room4.world --verbose -slibgazebo_ros_init.so -slibgazebo_ros_factory.so -slibgazebo_ros_force_system.so'].”经测试,注释imu部分后gazebo中正常显示,可能是imu频率高了,所以,想问是这个问题吗?然后这个频率设置多少合适?
@tutu 绝了,之前在报错后注释imu部分试了好几次编译然后打开gazebo,都没有什么错误,刚刚又报错啊
@tutu 然后单独使用相机部分,就没有任何问题,感觉主要是这个雷达插件
