    rviz显示marker不能实时更新
    rviz marker
    4.9k
    • 小丑汪小
      WOW995
      各位大佬,我想在保存的pcd地图里面用marker显示机器人的位置,我订阅了机器人的坐标形象,但是机器人移动位置变化后,marker位置不变,一直在初始位置;marker不能随机器人移动而更新,希望有了解的大佬帮忙解答一下。
      #include <ros/ros.h>
      #include <visualization_msgs/Marker.h>
      #include <nav_msgs/Odometry.h>
      #include <geometry_msgs/Point.h>
      double temp_x,temp_y,temp_z;
      double temp_or_x,temp_or_y,temp_or_z,temp_or_w;
      void record_point(const nav_msgs::Odometry::ConstPtr& odom)
          temp_x = odom->pose.pose.position.x;
          temp_y = odom->pose.pose.position.y;
          temp_z = odom->pose.pose.position.z;
          temp_or_w = odom->pose.pose.orientation.w;
          temp_or_x = odom->pose.pose.orientation.x;
          temp_or_y = odom->pose.pose.orientation.y;
          temp_or_z = odom->pose.pose.orientation.z;
      int main( int argc, char** argv )
        ros::init(argc, argv, "points_marker");
        ros::NodeHandle n;
        ros::Publisher marker_pub = n.advertise<visualization_msgs::Marker>("/robot_marker", 10);
        ros::Subscriber odom_pose = n.subscribe<nav_msgs::Odometry>("/aft_mapped_to_init",100,record_point);
        visualization_msgs::Marker points_marker;
        ros::Rate r(30);
        while (ros::ok())
          points_marker.header.frame_id ="/camera_init";
          points_marker.header.stamp =ros::Time::now();
          points_marker.ns ="points_marker";
          points_marker.action =visualization_msgs::Marker::ADD;
          points_marker.id = 0;
          points_marker.type = visualization_msgs::Marker::POINTS;
          geometry_msgs::Point obj;
          obj.x = temp_x;
          obj.y = temp_y;
          obj.z = temp_z;
          points_marker.pose.orientation.w = 1;
          // points_marker markers use x and y scale for width/height respectively
          points_marker.scale.x = 1;
          points_marker.scale.y = 1;
          points_marker.scale.z = 1;
          // points_marker are green
          points_marker.color.r = 0.0f;
          points_marker.color.g = 1.0f;
          points_marker.color.b = 0.0f;
          points_marker.color.a = 1.0f;
          points_marker.points.push_back(obj);
          points_marker.lifetime = ros::Duration(0.1); // 生命周期
          marker_pub.publish(points_marker);
          r.sleep();
      ![20220718.jpg](/forum/assets/uploads/files/1658153571513-20220718-resized.jpg)
      小丑汪小 小鱼小 3 条回复 最后回复 回复 引用 0
      • 小丑汪小
        WOW995 @小丑汪
        @小丑汪 图片没有传上去
          小鱼 技术大佬 @小丑汪
          @小丑汪 先用rostopic echo 对应话题,看看有没有数据先,毕竟rviz也只是将数据显示出来,这样就可以诊断出是哪边的问题了。
          小丑汪小 1 条回复 最后回复 回复 引用 0
          • 小丑汪小
            WOW995 @小鱼
            @小鱼 您好,我看了订阅的/aft_mapped_to_init和marker的话题/robot_marker,/aft_mapped_to_init数据是在更新的,/robot_marker数据一直没变。
              小鱼 技术大佬 @小丑汪
              @小丑汪 在 rviz显示marker不能实时更新 中说:
              问题大概就是发布的问题了,确认下这个回调函数是否进入了,可以加一些打印进去
              • 小丑汪小
                WOW995 @小鱼
                @小鱼 您好,我在回调函数和下面的ros::ok里面都打印输出了,回调函数没有调用,没有打印输出。我看了订阅和回调写的好像没什么问题
                  小鱼 技术大佬 @小丑汪
                  @小丑汪 没被回调肯定是哪里有问题,比如话题有没有搞错,仔细检查下,问题快找出来了
                  • 小丑汪小
                    WOW995 @小鱼
                    @小鱼 抱歉,我的。我没写ros::spinOnce()
                    小鱼小 1 条回复 最后回复 回复 引用 1
                      小鱼 技术大佬 @小丑汪
                      @小丑汪 好的👌🏻
                      • 小丑汪小 小丑汪 将这个主题标记为已解决,在
