    如何去掉fishbot_gazebo_urdf中的雷达射线,
    以及更改gazebo的背景 改成黑色或者白色
    1.3k
    • 清水难养清
      清水难养
      https://fishros.org.cn/forum/assets/uploads/files/1658237161970-3d6e47bb-6490-4342-9b43-c05de4234d24-image-resized.png
      <?xml version="1.0"?>
      <robot name="fishbot">
        <!-- Robot Footprint -->
        <link name="base_footprint"/>
          <child link="base_link"/>
          <origin xyz="0.0 0.0 0.076" rpy="0 0 0"/>
        </joint>
        <!-- base link -->
        <link name="base_link">
        	<visual>
            <geometry>
      		<cylinder length="0.12" radius="0.10"/>
            </geometry>
            <material name="blue">
            </material>
          </visual>
          <collision>
            <geometry>
            </geometry>
            </material>
          </collision>
          <inertial>
            <mass value="0.2"/>
            <inertia ixx="0.0122666" ixy="0" ixz="0" iyy="0.0122666" iyz="0" izz="0.02"/>
          </inertial>
        </link>
        <!-- laser link -->
        <link name="laser_link">
          <visual>
            <geometry>
            </geometry>
            <material name="black">
            </material>
          </visual>
          <collision>
            <geometry>
            </geometry>
            </material>
          </collision>
          <inertial>
          <mass value="0.1"/>
            <inertia ixx="0.000190416666667" ixy="0" ixz="0" iyy="0.0001904" iyz="0" izz="0.00036"/>
          </inertial>
        </link>
        <!-- laser joint -->
            <parent link="base_link" />
            <child link="laser_link" />
            <origin xyz="0 0 0.075" />
        </joint>
        <link name="imu_link">
        	<visual>
            <geometry>
      		    <box size="0.02 0.02 0.02"/>
            </geometry>
          </visual>
          <collision>
            <geometry>
            </geometry>
          </collision>
          <inertial>
            <mass value="0.1"/>
            </inertial>
        </link>
        <!-- imu joint -->
            <child link="imu_link" />
            <origin xyz="0 0 0.02" />
        </joint>
        <link name="left_wheel_link">
            <visual>
              <geometry>
                <cylinder length="0.04" radius="0.032"/>
              </geometry>
                </material>
            </visual>
            <collision>
              <geometry>
              </geometry>
                </material>
            </collision>
            <inertial>
              <mass value="0.2"/>
              </inertial>
        </link>
            <visual>
              <geometry>
              </geometry>
                </material>
            </visual>
            <collision>
              <geometry>
              </geometry>
                </material>
            </collision>
            <inertial>
            <mass value="0.2"/>
          </inertial>
        </link>
            <origin xyz="-0.02 0.10 -0.06" />
            <axis xyz="0 1 0" />
        </joint>
            <origin xyz="-0.02 -0.10 -0.06" />
        </joint>
        <link name="caster_link">
            <visual>
              <geometry>
                  <sphere radius="0.016"/>
              </geometry>
                </material>
            </visual>
            <collision>
              <geometry>
              </geometry>
                </material>
            </collision>
            <inertial>
            <mass value="0.02"/>
          </inertial>
        </link>
            <child link="caster_link" />
            <origin xyz="0.06 0.0 -0.076" />
        </joint>
        <gazebo reference="caster_link">
        </gazebo>
          <mu1 value="0.0"/>
          <mu2 value="0.0"/>
          <kp value="1000000.0" />
          <kd value="10.0" />
          <!-- <fdir1 value="0 0 1"/> -->
        </gazebo>
        <gazebo>
                <ros>
                  <namespace>/</namespace>
                </ros>
                <update_rate>30</update_rate>
                <!-- wheels -->
                <!-- <left_joint>left_wheel_joint</left_joint> -->
                <!-- <right_joint>right_wheel_joint</right_joint> -->
                <!-- kinematics -->
                <wheel_diameter>0.065</wheel_diameter>
                <!-- limits -->
                <!-- output -->
                <publish_wheel_tf>false</publish_wheel_tf>
            </plugin>
            <plugin name="fishbot_joint_state" filename="libgazebo_ros_joint_state_publisher.so">
              <ros>
                <remapping>~/out:=joint_states</remapping>
              </ros>
              <joint_name>right_wheel_joint</joint_name>
              <joint_name>left_wheel_joint</joint_name>
            </plugin>
            </gazebo>
            <gazebo reference="laser_link">
            </gazebo>
          <gazebo reference="imu_link">
            <sensor name="imu_sensor" type="imu">
            <plugin filename="libgazebo_ros_imu_sensor.so" name="imu_plugin">
                <ros>
                  <remapping>~/out:=imu</remapping>
                </ros>
                <initial_orientation_as_reference>false</initial_orientation_as_reference>
              </plugin>
              <always_on>true</always_on>
              <update_rate>100</update_rate>
              <visualize>true</visualize>
              <imu>
                <angular_velocity>
                  <x>
                    <noise type="gaussian">
                      <mean>0.0</mean>
                      <stddev>2e-4</stddev>
                      <bias_mean>0.0000075</bias_mean>
                      <bias_stddev>0.0000008</bias_stddev>
                    </noise>
                  </x>
                  <y>
                      <mean>0.0</mean>
                    </noise>
                  </y>
                  <z>
                      <mean>0.0</mean>
                    </noise>
                  </z>
                </angular_velocity>
                <linear_acceleration>
                  <x>
                      <mean>0.0</mean>
                      <stddev>1.7e-2</stddev>
                      <bias_mean>0.1</bias_mean>
                      <bias_stddev>0.001</bias_stddev>
                    </noise>
                  </x>
                  <y>
                      <mean>0.0</mean>
                    </noise>
                  </y>
                  <z>
                      <mean>0.0</mean>
                    </noise>
                  </z>
                </linear_acceleration>
              </imu>
            </sensor>
          </gazebo>
            <sensor name="laser_sensor" type="ray">
            <update_rate>5</update_rate>
            <pose>0 0 0.075 0 0 0</pose>
            <ray>
                <scan>
                  <horizontal>
                    <samples>360</samples>
                    <resolution>1.000000</resolution>
                    <min_angle>0.000000</min_angle>
                    <max_angle>6.280000</max_angle>
                  </horizontal>
                </scan>
                <range>
                  <min>0.120000</min>
                  <max>3.5</max>
                  <resolution>0.015000</resolution>
                </range>
                <noise>
                  <type>gaussian</type>
                  <mean>0.0</mean>
                  <stddev>0.01</stddev>
                </noise>
            </ray>
            <plugin name="laserscan" filename="libgazebo_ros_ray_sensor.so">
              <ros>
                <!-- <namespace>/tb3</namespace> -->
                <remapping>~/out:=scan</remapping>
              </ros>
              <output_type>sensor_msgs/LaserScan</output_type>
              <frame_name>laser_link</frame_name>
            </plugin>
            </sensor>
          </gazebo>
      </robot>
        小鱼 技术大佬 @清水难养
        @清水难养 在 如何去掉fishbot_gazebo_urdf中的雷达射线, 中说:
        改成
        <visualize>false</visualize>
        即可
        1 条回复 最后回复 回复 引用 1
        • 清水难养清 清水难养 将这个主题标记为已解决,在
