    运行demo_revo_lds.launch报错cartographer_node_1*log
    cartographer 程序死掉
    • 22308033622
      八杯水
      zhaoyang@zydubuntu:~$ roslaunch gazebo_map demo_revo_lds.launch
      ... logging to /home/zhaoyang/.ros/log/d1331bc4-0d51-11ed-aea9-94e23c42dc13/roslaunch-zydubuntu-5974.log
      Press Ctrl-C to interrupt
      started roslaunch server http://zydubuntu:42245/
      SUMMARY
      PARAMETERS
       * /rosdistro: melodic
       * /rosversion: 1.14.13
       * /use_sim_time: True
      NODES
          cartographer_node (cartographer_ros/cartographer_node)
          cartographer_occupancy_grid_node (cartographer_ros/cartographer_occupancy_grid_node)
          rviz (rviz/rviz)
      ROS_MASTER_URI=http://localhost:11311
      process[cartographer_node-1]: started with pid [5989]
      process[cartographer_occupancy_grid_node-2]: started with pid [5990]
      process[rviz-3]: started with pid [5991]
      [ INFO] [1658888067.765558627]: I0727 10:14:27.000000  5989 configuration_file_resolver.cc:41] Found '/home/zhaoyang/gazebo_test_ws/src/gazebo_map/cfg/revo_lds.lua' for 'revo_lds.lua'.
      F0727 10:14:27.766356  5989 lua_parameter_dictionary.cc:83] Check failed: status == 0 (3 vs. 0) [string "-- Copyright 2016 The Cartographer Authors..."]:63: unexpected symbol near '='
      第一个错误:[FATAL] [1658888067.766559699]: F0727 10:14:27.000000  5989 lua_parameter_dictionary.cc:83] Check failed: status == 0 (3 vs. 0) [string "-- Copyright 2016 The Cartographer Authors..."]:63: unexpected symbol near '='
      *** Check failure stack trace: ***
          @     0x7f334cc750cd  google::LogMessage::Fail()
          @     0x7f334cc76f33  google::LogMessage::SendToLog()
          @     0x7f334cc74c28  google::LogMessage::Flush()
          @     0x7f334cc77999  google::LogMessageFatal::~LogMessageFatal()
          @     0x561410bdb6a7  (unknown)
          @     0x561410bdc5cc  (unknown)
          @     0x561410bdc82d  (unknown)
          @     0x561410bc5171  (unknown)
          @     0x561410b98131  (unknown)
          @     0x561410b964b4  (unknown)
          @     0x7f3349bc2c87  __libc_start_main
          @     0x561410b97e0a  (unknown)
      第二个错误:[cartographer_node-1] process has died [pid 5989, exit code -6, cmd /opt/ros/melodic/lib/cartographer_ros/cartographer_node -configuration_directory /home/zhaoyang/gazebo_test_ws/src/gazebo_map/cfg -configuration_basename revo_lds.lua scan:=scan __name:=cartographer_node __log:=/home/zhaoyang/.ros/log/d1331bc4-0d51-11ed-aea9-94e23c42dc13/cartographer_node-1.log].
      log file: /home/zhaoyang/.ros/log/d1331bc4-0d51-11ed-aea9-94e23c42dc13/cartographer_node-1*.log
        小鱼 技术大佬 @2230803362
        @2230803362 在 运行demo_revo_lds.launch报错cartographer_node_1*log 中说:
        看错误是你的lua配置文件有问题哦,仔细检查下,应该是基本的语法错误
