gazebo仿真的时候转向怎么控制的顺滑
我在进行铲车仿真的时候,控制转向角的时候模型反应比较慢,置0的时候不能回到0位,转向运动的时候模型发生抖动。各位大佬看看是什么原因
<!-- motors and transmissions for the two rear wheels --> <transmission name="tran1"> <type>transmission_interface/SimpleTransmission</type> <joint name="back_right_wheel2base_link"> <hardwareInterface>hardware_interface/VelocityJointInterface</hardwareInterface> </joint> <actuator name="motor1"> <hardwareInterface>hardware_interface/VelocityJointInterface</hardwareInterface> <mechanicalReduction>1</mechanicalReduction> </actuator> </transmission> <transmission name="tran2"> <type>transmission_interface/SimpleTransmission</type> <joint name="back_left_wheel2base_link"> <hardwareInterface>hardware_interface/VelocityJointInterface</hardwareInterface> </joint> <actuator name="motor2"> <hardwareInterface>hardware_interface/VelocityJointInterface</hardwareInterface> <mechanicalReduction>1</mechanicalReduction> </actuator> </transmission> <!-- EPS and transmissions for the front steering --> <transmission name="tran3"> <type>transmission_interface/SimpleTransmission</type> <joint name="steering_hinge2base_link"> <hardwareInterface>hardware_interface/EffortJointInterface</hardwareInterface> </joint> <actuator name="eps"> <hardwareInterface>hardware_interface/EffortJointInterface</hardwareInterface> <mechanicalReduction>1</mechanicalReduction> </actuator> </transmission> <transmission name="tran4"> <type>transmission_interface/SimpleTransmission</type> <joint name="front_right_wheel2steering_hinge"> <hardwareInterface>hardware_interface/VelocityJointInterface</hardwareInterface> </joint> <actuator name="motor3"> <hardwareInterface>hardware_interface/VelocityJointInterface</hardwareInterface> <mechanicalReduction>1</mechanicalReduction> </actuator> </transmission> <transmission name="tran5"> <type>transmission_interface/SimpleTransmission</type> <joint name="front_left_wheel2steering_hinge"> <hardwareInterface>hardware_interface/VelocityJointInterface</hardwareInterface> </joint> <actuator name="motor4"> <hardwareInterface>hardware_interface/VelocityJointInterface</hardwareInterface> <mechanicalReduction>1</mechanicalReduction> </actuator> </transmission> <!-- Friction Parametres --> <gazebo reference="back_right_wheel"> <mu1>2.0</mu1> <mu2>2.0</mu2> <kp>10000000</kp> <kd>1</kd> </gazebo> <gazebo reference="back_left_wheel"> <mu1>2.0</mu1> <mu2>2.0</mu2> <kp>10000000</kp> <kd>1</kd> </gazebo> <gazebo reference="front_right_wheel"> <mu1>2.0</mu1> <mu2>2.0</mu2> <kp>10000000</kp> <kd>1</kd> </gazebo> <gazebo reference="front_left_wheel"> <mu1>2.0</mu1> <mu2>2.0</mu2> <kp>10000000</kp> <kd>1</kd> </gazebo>控制的ymal文件
xul307a: # controls the rear two tires based on individual motors # Publish all joint states ----------------------------------- joint_state_controller: type: joint_state_controller/JointStateController publish_rate: 50 back_right_velocity_controller: type: velocity_controllers/JointVelocityController joint: back_right_wheel2base_link pid: {p: 100.0, i: 0.01, d: 10.0} back_left_velocity_controller: type: velocity_controllers/JointVelocityController joint: back_left_wheel2base_link pid: {p: 100.0, i: 0.01, d: 10.0} steering_position_controller: type: effort_controllers/JointPositionController joint: steering_hinge2base_link pid: {p: 25000, i: 0, d: 10.0} front_right_velocity_controller: type: velocity_controllers/JointVelocityController joint: front_right_wheel2steering_hinge pid: {p: 100.0, i: 0.01, d: 10.0} front_left_velocity_controller: type: velocity_controllers/JointVelocityController joint: front_left_wheel2steering_hinge pid: {p: 100.0, i: 0.01, d: 10.0} -
@小丑汪 仿真的FPS很低,先排除视觉效果的影响。不过RTF还蛮高的,能到1
