    当前apt存在问题 无法下载 文件尺寸不符(1079790 != 1095911)。您使用的镜像正在同步中?
    ros 换源
    1.2k
    • 日落龙舌兰日
      日落龙舌兰
      [|]获取:6 http://mirrors.tuna.tsinghua.edu.cn/ros2/ubuntu focal InRelease [4,679[/]获取:8 http://mirrors.tuna.tsinghua.edu.cn/ros/ubuntu focal Release.gpg [833 []获取:9 http://mirrors.tuna.tsinghua.edu.cn/ros2/ubuntu focal/main amd64 Packa[|]错误:9 http://mirrors.tuna.tsinghua.edu.cn/ros2/ubuntu
      文件尺寸不符(1092936 != 1095911)。您使用的镜像正在同步中? [IP: 101.6.15.13[|]获取:10
      http://mirrors.tuna.tsinghua.edu.cn/ros/ubuntu focal/main amd64 Packa[-]Result:code:100
      当前apt存在问题,推荐使用一键换源处理...若无法处理,请将下列错误信息告知小鱼...,['\n', 'WARNING: apt does not have a stable CLI interface. Use with caution in scripts.\n', '\n', 'E: 无法下载 http://mirrors.tuna.tsinghua.edu.cn/ros2/ubuntu/dists/focal/main/binary-amd64/Packages.gz 文件尺寸不符(1092936 != 1095911)。您使用的镜像正在同步中? [IP: 101.6.15.130 80]\n', ' Hashes of expected file:\n', ' - Filesize:1095911 [weak]\n', ' - SHA256:b41bf3aad3e480fc199a461fb9db189507ccf29ab6a5b069e17840a25cae9b65\n', ' - SHA1:393c0322cff0c5b6181a2373ec67ceb864cfa602 [weak]\n', ' - MD5Sum:b5dc5b2c8b1bbd6609f08344f7f738b4 [weak]\n', ' Release file created at: Fri, 05 Aug 2022 15:53:18 +0000\n', 'E: 部分索引文件下载失败。如果忽略它们,那将转而使用旧的索引文件。\n']
      [-]Result:success
      []获取:9 https://repo.huaweicloud.com/ros2/ubuntu
      文件尺寸不符(1079790 != 1095911)。您使用的镜像正在同步中? [IP: 58.215.92.7[|]获取:10
      https://repo.huaweicloud.com/ros/ubuntu focal/main amd64 Packages [70[-]Result:code:100
      当前apt存在问题,推荐使用一键换源处理...若无法处理,请将下列错误信息告知小鱼...,['\n', 'WARNING: apt does not have a stable CLI interface. Use with caution in scripts.\n', '\n', 'E: 无法下载 https://repo.huaweicloud.com/ros2/ubuntu/dists/focal/main/binary-amd64/Packages.gz 文件尺寸不符(1079790 != 1095911)。您使用的镜像正在同步中? [IP: 58.215.92.70 443]\n', ' Hashes of expected file:\n', ' - Filesize:1095911 [weak]\n', ' - SHA256:b41bf3aad3e480fc199a461fb9db189507ccf29ab6a5b069e17840a25cae9b65\n', ' - SHA1:393c0322cff0c5b6181a2373ec67ceb864cfa602 [weak]\n', ' - MD5Sum:b5dc5b2c8b1bbd6609f08344f7f738b4 [weak]\n', ' Release file created at: Fri, 05 Aug 2022 15:53:18 +0000\n', 'E: 部分索引文件下载失败。如果忽略它们,那将转而使用旧的索引文件。\n']
      [-]Result:success
      [/]获取:8 http://packages.ros.org/ros2/ubuntu focal/main amd64 Packages [1,096 k[-]Result:success -upgradable’ 来查看它们。
      • 小鱼小 小鱼 将这个主题转为问答主题,在
      • 小鱼小 小鱼 从 中的 社区&开源 移动了该主题
        小鱼 技术大佬 @日落龙舌兰
        @日落龙舌兰 在 当前apt存在问题 无法下载 文件尺寸不符(1079790 != 1095911)。您使用的镜像正在同步中? 中说:
        最后成功了就行,一键安装会根据你的系统情况,多次尝试更换ROS2的源,直到成功为止。
