    Cartographer Failed to find match for field 'intensity'.
    cartographer intensity
    1.2k
    • GeneG
      Gene
        自己系统是 ubuntu18.04 [amd64:bionic],ROS 版本是 melodic。安装cartographer完后, 。分别启动 lslidar + imu 节点和caro节点出现 Failed 信息和截图如下:
      [ WARN] [1660093530.789678768]: W0810 09:05:30.000000  4986 tf_bridge.cc:52] Lookup would require extrapolation into the past.  Requested time 1660093502.640984000 but the earliest data is at time 1660093520.794097900, when looking up transform from frame [lslidar_link] to frame [imu_link]
      [ WARN] [1660093530.789851594]: W0810 09:05:30.000000  4986 ordered_multi_queue.cc:155] Queue waiting for data: (0, scan)
      [ WARN] [1660093530.991417871]: W0810 09:05:30.000000  4986 tf_bridge.cc:52] Lookup would require extrapolation into the future.  Requested time 1660093602.690678900 but the latest data is at time 1660093530.894069910, when looking up transform from frame [lslidar_link] to frame [imu_link]
        roslaunch 运行的命令如下:
      roslaunch lslidar_c32_decoder 00_start_ls_lidar_imu.launch
      roslaunch cartographer_ros 00_lslidar_imu.launch
         查看 lslidar 发布的 数据信息和Rviz显示,个人认为lslidar有 intensity:
      header:
        seq: 5347
        stamp:
          secs: 1660089447
          nsecs: 807343000
        frame_id: "lslidar_link"
      height: 32
      width: 2244
      fields:
          offset: 0
          datatype: 7
          count: 1
          offset: 4
          datatype: 7
          count: 1
          offset: 8
          datatype: 7
          count: 1
          offset: 16
          datatype: 2
          count: 1
          offset: 17
          datatype: 2
          count: 1
          offset: 24
          datatype: 8
          count: 1
      is_bigendian: False
      point_step: 32
      row_step: 71808
      data: [252, 0, 121, ... ,0, 0, 0]
      is_dense: False
         还请大佬指点哪里没有注意到设置,哪里出现的问题,非常感谢!
      PS: carto 自定义的两个launch 文件如下:
      00_lslidar_imu.launch:
      <launch>
        <param name="/use_sim_time" value="false" />
        <include file="$(find cartographer_ros)/launch/01_backpack_3d.launch" />
        <node name="rviz" pkg="rviz" type="rviz" required="true"
            args="-d $(find cartographer_ros)/configuration_files/01_xcmg_carto.rviz" />
      </launch>
      01_backpack_3d.launch:
      <launch>
        <param name="robot_description"
          textfile="$(find cartographer_ros)/urdf/00_backpack_3d.urdf" />
        <node name="joint_state_publisher" pkg="joint_state_publisher"   type="joint_state_publisher" />
        <node name="robot_state_publisher" pkg="robot_state_publisher"   type="robot_state_publisher" />
        <node name="cartographer_node" pkg="cartographer_ros"
            type="cartographer_node" args="
                -configuration_directory $(find cartographer_ros)/configuration_files
                -configuration_basename 00_laser_imu_3d.lua"
            output="screen">
          <remap from="points2" to="/lslidar_point_cloud" />
          <remap from="imu" to="handsfree/imu" />
        </node>
        <node name="cartographer_occupancy_grid_node" pkg="cartographer_ros"  type="cartographer_occupancy_grid_node" args="-resolution 0.05" />
      </launch>
      </launch>
        小鱼 技术大佬 @Gene
        @Gene 还没试过多线雷达建图,WARN那个我遇到过,但依然可以建图,所以错误估计在那个Failed to find match for field 上了,我能想到的是先跑一下数据集,对比下数据集数据和你的数据区别.
