    接收实时速度话题,发布odom话题
    移动平台分享
    odom c++
    1.4k
    • 毛哥成山轮胎机油保养毛
      毛哥成山轮胎机油保养 活跃VIP
      我买的机器人底盘轮毂电机控制板输出的是实时的速度话题,导航需要odom话题,经过2个多月的c++学习,终于大概看懂了底层代码的意思,用别的版本的代码拼凑了一个速度转odom的代码,让我写我还是写不出来(本人菜鸟一个,哈哈),只能抄别人的代码修改一下.
      pub_odom.cpp
      #include "rclcpp/rclcpp.hpp"
      #include <rclcpp/time.hpp>
      #include <math.h>
      #include <riki_msgs/msg/velocities.hpp>
      #include <nav_msgs/msg/odometry.hpp>
      #include <geometry_msgs/msg/twist.hpp>
      #include <tf2_ros/transform_broadcaster.h>
      #include <tf2/LinearMath/Quaternion.h>
      #include <riki_msgs/msg/battery.hpp>
      #include <sensor_msgs/msg/imu.hpp>
      using std::placeholders::_1;
      class Pub_odom : public rclcpp::Node
      public:
          Pub_odom(std::string name) : Node(name), imu_angular_z_(0.0),
                                       odom_theta_(0)
              //创建一个发布者用于发布odom
              odom_publisher_ = this->create_publisher<nav_msgs::msg::Odometry>("odom", 20);
              //创建一个订阅者用于订阅raw_vel话题
              velocity_sub_ = this->create_subscription<riki_msgs::msg::Velocities>("raw_vel", 20, std::bind(&Pub_odom::velCallback, this, _1));
              //创建一个订阅者用于订阅电池电量话题
              battery_sub_ = this->create_subscription<riki_msgs::msg::Battery>("battery", 1, std::bind(&Pub_odom::batteryCallback, this, _1));
              //创建一个订阅者用于订阅imu话题
              imu_sub_ = this->create_subscription<sensor_msgs::msg::Imu>("imu/data", 1, std::bind(&Pub_odom::ImuCallback, this, _1));
              odom_transform_broadcaster_ = std::make_shared<tf2_ros::TransformBroadcaster>(this);
              declare_parameter("linear_scale", 1.0);
              get_parameter("linear_scale", linear_scale_);
              declare_parameter("low_battery", 34.0);
              get_parameter("low_battery", low_battery_);
              last_odom_time_ = now();
              odom_.header.frame_id = "odom";
              odom_.child_frame_id = "base_footprint";
              odom_transform_.header.frame_id = "odom";
              odom_transform_.child_frame_id = "base_footprint";
              RCLCPP_INFO(this->get_logger(), "linear_scale_: %f", linear_scale_);
          ~Pub_odom()
              odom_transform_broadcaster_.reset();
              velocity_sub_.reset();
              odom_publisher_.reset();
              battery_sub_.reset();
      private:
          //声明一个发布者(成员变量),用于发布话题
          rclcpp::Publisher<nav_msgs::msg::Odometry>::SharedPtr odom_publisher_;
          //声明一个订阅者(成员变量),用于订阅话题
          rclcpp::Subscription<riki_msgs::msg::Velocities>::SharedPtr velocity_sub_;
          //声明一个订阅者(成员变量),用于订阅电池电量话题
          rclcpp::Subscription<riki_msgs::msg::Battery>::SharedPtr battery_sub_;
          //声明一个imu订阅者(成员变量),订阅imu话题
          rclcpp::Subscription<sensor_msgs::msg::Imu>::SharedPtr imu_sub_;
          std::shared_ptr<tf2_ros::TransformBroadcaster> odom_transform_broadcaster_;
          nav_msgs::msg::Odometry odom_;
          geometry_msgs::msg::TransformStamped odom_transform_;
          void euler_to_quat(float roll, float pitch, float yaw, float *q)
              float cy = cos(yaw * 0.5);
              float sy = sin(yaw * 0.5);
              float cp = cos(pitch * 0.5);
              float sp = sin(pitch * 0.5);
              float cr = cos(roll * 0.5);
              float sr = sin(roll * 0.5);
              q[0] = cy * cp * cr + sy * sp * sr;
              q[1] = cy * cp * sr - sy * sp * cr;
              q[2] = sy * cp * sr + cy * sp * cr;
              q[3] = sy * cp * cr - cy * sp * sr;
          void ImuCallback(const sensor_msgs::msg::Imu::SharedPtr imu)
              imu_angular_z_ = imu->angular_velocity.z;
          void batteryCallback(const riki_msgs::msg::Battery::SharedPtr bat)
              float cur_battery = bat->battery;
              if (cur_battery < low_battery_)
                  RCLCPP_WARN(this->get_logger(), "Current Voltage: %f ,Low Battery, Low Battery  Please Recharge!!", cur_battery);
          //收到话题数据的回调函数
          void velCallback(const riki_msgs::msg::Velocities::SharedPtr vel)
              rclcpp::Time current_time = now();
              //x线速度
              linear_velocity_x_ = vel->linear_x * linear_scale_;
              //y线速度
              linear_velocity_y_ = vel->linear_y * linear_scale_;
              //角速度
              angular_velocity_z_ = vel->angular_z;
              auto vel_dt_ = current_time - last_odom_time_;
              last_odom_time_ = current_time;
              double delta_heading = angular_velocity_z_ * vel_dt_.nanoseconds() / 1e9;                                                       //radians
              double delta_x = (linear_velocity_x_ * cos(odom_theta_) - linear_velocity_y_ * sin(odom_theta_)) * vel_dt_.nanoseconds() / 1e9; //m
              double delta_y = (linear_velocity_x_ * sin(odom_theta_) + linear_velocity_y_ * cos(odom_theta_)) * vel_dt_.nanoseconds() / 1e9; //m
              //calculate current position of the robot
              x_pos_ += delta_x;
              y_pos_ += delta_y;
              odom_theta_ += delta_heading;
              //以四元数计算机器人航向
              //ROS具有以四元数角计算偏航的功能
              float q[4];
              euler_to_quat(0, 0, odom_theta_, q);
              tf2::Quaternion odom_q;
              odom_q.setRPY(0, 0, odom_theta_);
              odom_.pose.pose.position.x = x_pos_;
              odom_.pose.pose.position.y = y_pos_;
              odom_.pose.pose.position.z = 0.0;
              odom_.pose.pose.orientation.x = (double)q[1];
              odom_.pose.pose.orientation.y = (double)q[2];
              odom_.pose.pose.orientation.z = (double)q[3];
              odom_.pose.pose.orientation.w = (double)q[0];
              odom_.pose.pose.orientation.x = odom_q.x();
              odom_.pose.pose.orientation.y = odom_q.y();
              odom_.pose.pose.orientation.z = odom_q.z();
              odom_.pose.pose.orientation.w = odom_q.w();
              odom_.twist.twist.linear.x = linear_velocity_x_;
              odom_.twist.twist.linear.y = linear_velocity_y_;
              //odom_.twist.twist.angular.z = angular_velocity_z_;
              //odom_.twist.twist.angular.z = imu_angular_z_;
              odom_.pose.covariance[0] = 0.001;
              odom_.pose.covariance[7] = 0.001;
              odom_.pose.covariance[35] = 0.001;
              odom_.header.stamp = now();
              odom_publisher_->publish(odom_);
              odom_transform_.header.stamp = last_odom_time_;
              odom_transform_.transform.translation.x = x_pos_;
              odom_transform_.transform.translation.y = y_pos_;
              odom_transform_.transform.rotation.x = odom_q.x();
              odom_transform_.transform.rotation.y = odom_q.y();
              odom_transform_.transform.rotation.z = odom_q.z();
              odom_transform_.transform.rotation.w = odom_q.w();
              odom_transform_broadcaster_->sendTransform(odom_transform_);
          float linear_scale_;
          float low_battery_;
          float steering_angle_;
          float linear_velocity_x_;
          float linear_velocity_y_;
          float angular_velocity_z_;
          float imu_angular_z_;
          rclcpp::Time last_odom_time_;
          float vel_dt_;
          float x_pos_;
          float y_pos_;
          float odom_theta_;
      int main(int argc, char const *argv[])
          rclcpp::init(argc, argv);
          rclcpp::spin(std::make_shared<Pub_odom>("pub_odom"));
          rclcpp::shutdown();
          return 0;
      • 毛哥成山轮胎机油保养毛
        毛哥成山轮胎机油保养 活跃VIP
        odom 话题有了,激光雷达的话题也有了,接下来要把他们组合在一起了,有没有志同道合的一起玩呀
