    自定义接口build失败
    接口 ubuntu18.04
    • 守护最好的佩奇守
      守护最好的佩奇
      我在复制粘贴提供的自定义接口,build后出现以下错误:
      CMake Error at /opt/ros/dashing/share/rosidl_cmake/cmake/rosidl_generate_interfaces.cmake:240 (list):
        list index: 1 out of range (-1, 0)
        CMakeLists.txt:35 (rosidl_generate_interfaces)
      CMake Error at /opt/ros/dashing/share/rosidl_typesupport_c/cmake/rosidl_typesupport_c_generate_interfaces.cmake:50 (message):
        Target dependency
        '/topic_test/build/ros2_interfaces/rosidl_adapter/ros2_interfaces/msg/RobotPose.idl'
        does not exist
        /opt/ros/dashing/share/ament_cmake_core/cmake/core/ament_execute_extensions.cmake:48 (include)
        /opt/ros/dashing/share/rosidl_cmake/cmake/rosidl_generate_interfaces.cmake:286 (ament_execute_extensions)
      Failed   <<< ros2_interfaces [4.88s, exited with code 1]
      然后我在社区搜索相关解决方案,将CMake.list中的代码修改为以下:
      project(ros2_interfaces)
      # Default to C99
      if(NOT CMAKE_C_STANDARD)
        set(CMAKE_C_STANDARD 99)
      endif()
      # Default to C++14
      if(NOT CMAKE_CXX_STANDARD)
        set(CMAKE_CXX_STANDARD 14)
      endif()
      endif()
      # find dependencies
      # find_package(geometry_msgs REQUIRED)
      if(BUILD_TESTING)
        # uncomment the line when a copyright and license is not present in all source files
        #set(ament_cmake_copyright_FOUND TRUE)
        # uncomment the line when this package is not in a git repo
        #set(ament_cmake_cpplint_FOUND TRUE)
      endif()
      # rosidl_generate_interfaces(${PROJECT_NAME}
      #   "msg/RobotPose.msg"
      #   "msg/RobotStatus.msg"
      #   "srv/MoveRobot.srv"
      #   # DEPENDENCIES geometry_msgs
      ament_package()
      可以build成功,但是我在调用时,提示我以下报错
        File "/home/xh/桌面/topic_test/install/example_topic/lib/example_topic/example_interfaces_robot_02", line 11, in <module>
          load_entry_point('example-topic==0.0.0', 'console_scripts', 'example_interfaces_robot_02')()
        File "/usr/lib/python3/dist-packages/pkg_resources/__init__.py", line 480, in load_entry_point
          return get_distribution(dist).load_entry_point(group, name)
        File "/usr/lib/python3/dist-packages/pkg_resources/__init__.py", line 2693, in load_entry_point
          return ep.load()
        File "/usr/lib/python3/dist-packages/pkg_resources/__init__.py", line 2324, in load
          return self.resolve()
        File "/usr/lib/python3/dist-packages/pkg_resources/__init__.py", line 2330, in resolve
          module = __import__(self.module_name, fromlist=['__name__'], level=0)
        File "/home/xh/桌面/topic_test/install/example_topic/lib/python3.6/site-packages/example_topic/example_robot.py", line 7, in <module>
          from ros2_interfaces.msg import RobotStatus
      ModuleNotFoundError: No module named 'ros2_interfaces'
      而且在install文件夹内并没有出现文中所述的C++和Python环境,想问小鱼这是什么原因。
      我安装的Ros2版本是dashing桌面版本,Ubuntu系统是18.04
      小鱼小 S 2 条回复 最后回复 回复 引用 0
        小鱼 技术大佬 @守护最好的佩奇
        @守护最好的佩奇 估计和你的ROS版本有关系,18实在太老了,建议换新版本使用,差距还是挺大的
        • S
          s212633 @守护最好的佩奇
          @守护最好的佩奇 我也遇到了报错,你解决了么? 我是ubuntu20.04+foxy
            小鱼 技术大佬 @s212633
            @s212633 贴一下具体的错误和文件看看
            • 小鱼小 小鱼 从 中的 社区&开源 移动了该主题
