    雷神m10雷达humble安装遇到问题,编译通过了,运行还是报错,大佬们给看一下
    移动平台分享
    雷神m10 激光雷达 报错
    1.9k
    • 毛哥成山轮胎机油保养毛
      毛哥成山轮胎机油保养 活跃VIP
      最后由 毛哥成山轮胎机油保养 编辑
      CMakeLists.txt
      project(lsm10_v2)
      # Default to C++14
      if(NOT CMAKE_C_STANDARD)
        set(CMAKE_C_STANDARD 99)
      endif()
      # Default to C++14
      if(NOT CMAKE_CXX_STANDARD)
        set(CMAKE_CXX_STANDARD 14)
      endif()
      endif()
      find_package(rclcpp REQUIRED)
      find_package(rclpy REQUIRED)
      find_package(sensor_msgs REQUIRED)
      #find_package(dynamic_reconfigure REQUIRED)
      find_package(lsm10_v2 REQUIRED)
      find_package(Boost 1.65.1 REQUIRED COMPONENTS system filesystem thread)
      if(BUILD_TESTING)
      endif()
        "msg/Difop.msg"
        DEPENDENCIES std_msgs
        ADD_LINTER_TESTS
      include_directories(
        include
        src
        ${catkin_INCLUDE_DIRS}
        ${Eigen3_INCLUDE_DIRS}
      ament_export_dependencies(rosidl_default_runtime)
      add_executable(LSM10 src/lsiosr.cpp src/lsm10.cpp)
      include_directories(LSM10 ${Boost_INCLUDE_DIRS})
      link_directories(LSM10 ${Boost_LIBRARY_DIRS})
      target_link_libraries(LSM10 ${Boost_LIBRARIES})
      ament_target_dependencies(LSM10 rclcpp rclpy  std_msgs  sensor_msgs lsm10_v2 Boost)
      target_link_libraries(LSM10 ${Boost_PROGRAM_OPTIONS_LIBRARY})
      install(TARGETS
        LSM10
      install(
        DIRECTORY launch
        DESTINATION share/${PROJECT_NAME}
      ament_package()
      package.xml
      <?xml version="1.0"?>
      <package format="3">
        <name>lsm10_v2</name>
        <version>0.0.0</version>
        <description>The lsm10_v2 package--wheeltec@dongguan</description>
        <maintainer email="powrbv@gmail.com">tongsky</maintainer>
        <license>TODO</license>
        <test_depend>eigen</test_depend>
        <test_depend>boost</test_depend>
        <buildtool_depend>eigen3_cmake_module</buildtool_depend>
        <build_depend>rosidl_default_generators</build_depend>
        <exec_depend>rosidl_default_runtime</exec_depend>
        <build_depend>dynamic_reconfigure</build_depend>
        <exec_depend>dynamic_reconfigure</exec_depend>
        <build_depend>message_generation</build_depend>
        <exec_depend>message_runtime</exec_depend>
        <depend>rclcpp</depend>
        <depend>rclpy</depend>
        <depend>sensor_msgs</depend>
        <depend>std_msgs</depend>
        <depend>tf</depend>
        <depend>tf2</depend>
        <export>
        </export>
      </package>
      lsiosr.h
      @company: Copyright (C) 2021, Leishen Intelligent System, WHEELTEC (Dongguan) Co., Ltd
      @product: LSn10
      @filename: lsiosr.cpp
      @brief:
      @version:       date:       author:            comments:
      @v2.0           22-4-12      yao,Tues          ROS2
      #ifndef LSIOSR_H
      #define LSIOSR_H
      #include <memory>
      #include <sys/types.h>
      #include <sys/stat.h>
      #include <fcntl.h>
      #include <termios.h>
      #include <errno.h>
      #include <unistd.h>
      #include <string.h>
      #include <stdlib.h>
      #include <unistd.h>
      #include <stdint.h>
      #include <fstream>
      #include <iostream>
      //波特率
      #define     BAUD_2400       2400
      #define     BAUD_4800       4800
      #define     BAUD_9600       9600
      #define     BAUD_57600     	57600
      #define     BAUD_115200     115200
      #define	    BAUD_230400	    230400
      #define     BAUD_460800     460800
      //奇偶校验位
      #define     PARITY_ODD    	'O' //奇数
      #define     PARITY_EVEN   	'E' //偶数
      #define     PARITY_NONE   	'N' //无奇偶校验位
      //停止位
      #define     STOP_BIT_1     	1
      #define     STOP_BIT_2     	2
      //数据位
      #define     DATA_BIT_7     	7
      #define     DATA_BIT_8     	8
      namespace ls
      class LSIOSR{
      public:
        static LSIOSR* instance(std::string name, int speed, int fd = 0);
        ~LSIOSR();
        /* 从串口中读取数据 */
        int read(char *buffer, int length, int timeout = 60);
        /* 向串口传数据 */
        int send(const char* buffer, int length, int timeout = 60);
        /* Empty serial port input buffer */
        void flushinput();
        /* 串口初始化 */
        int init();
        int close();
        /* 获取串口号 */
        std::string getPort();
        /* 设置串口号 */
        int setPortName(std::string name);
      private:
        LSIOSR(std::string name, int speed, int fd);
        int waitWritable(int millis);
        int waitReadable(int millis);
        /* 串口配置的函数 */
        int setOpt(int nBits, uint8_t nEvent, int nStop);
        std::string port_;
        int baud_rate_;
        int fd_;
      #endif
      lsm10.h
      @product: LSM10
      @filename: lsm10.h
      @brief:
      @v2.0           22-4-12      fu,Tues          ROS2
      #ifndef LSM10_H
      #define LSM10_H
      #include <boost/date_time/posix_time/posix_time.hpp>
      #include <boost/thread/thread.hpp>
      #include <iostream>
      #include <memory>
      #include <inttypes.h>
      #include <rcl/types.h>
      #include <string>
      #include "rclcpp/rclcpp.hpp"
      #include <sensor_msgs/msg/laser_scan.hpp>
      #include "lsm10_v2/lsiosr.h"
      #include "lsm10_v2/msg/difop.hpp"
      namespace ls {
      typedef struct {
          double degree;
          double range;
          double intensity;
      } ScanPoint;
      class LSM10 : public rclcpp::Node
      public:
        LSM10();
        ~LSM10();
          * 实例化雷达
          * port: 串口号,
          * baud_rate: 波特率 460800
          static LSM10* instance();
          * 获取雷达数据
          * poins: 雷达点的数据。类型为ScanPoint数组
          int getScan(std::vector<ScanPoint> &points, rclcpp::Time & scan_time, float &scan_duration);
          * 获取软件版本号
          * version: 返回版本号
          int getVersion(std::string &version);
          int getRate();
          double getRPM();
        private:
          void initParam();
          void recvThread();
          void pubScanThread();
          void thread_tmp();
          std::vector<ScanPoint> scan_points_;
          std::vector<ScanPoint> scan_points_bak_;
          LSIOSR * serial_;
          boost::thread *recv_thread_;
          boost::thread *pubscan_thread_;
          std::unique_ptr<boost::thread> test_thread_;
          std::unique_ptr<boost::thread> testscan_thread_;
          boost::mutex pubscan_mutex_;
          boost::mutex mutex_;
          boost::condition_variable pubscan_cond_;
          bool is_shutdown_;    // shutdown recvthread
          int data_len_;
          int points_size_;
          int rpm_;
          double real_rpm_;
          //ros::Time pre_time_;
          //ros::Time time_;
          rclcpp::Time pre_time_;
          rclcpp::Time time_;
          std::string serial_port_;
          int baud_rate_;
          std::string scan_topic_;
          std::string frame_id_;
          //ros::NodeHandle n_;
          //ros::Publisher pub_;
          rclcpp::Publisher<sensor_msgs::msg::LaserScan>::SharedPtr pub_;
          //ros::Publisher device_pub;
      	  rclcpp::Publisher<lsm10_v2::msg::Difop>::SharedPtr device_pub;
      #endif
      lsiosr.cpp
      @product: LSM10
      @brief:
      #include <lsm10_v2/lsiosr.h>
      using namespace std;
      //rclcpp::Node::SharedPtr nh_=nullptr;
      namespace ls {
      LSIOSR * LSIOSR::instance(std::string name, int speed, int fd)
       // printf("jieru\n");
        static LSIOSR obj(name, speed, fd);
        return &obj;
      LSIOSR::LSIOSR(std::string port, int baud_rate, int fd):port_(port), baud_rate_(baud_rate), fd_(fd)
        printf("port = %s, baud_rate = %d\n", port.c_str(), baud_rate);
      LSIOSR::~LSIOSR()
        close();
      /* 串口配置的函数 */
      int LSIOSR::setOpt(int nBits, uint8_t nEvent, int nStop)
        struct termios newtio, oldtio;
        /*保存测试现有串口参数设置,在这里如果串口号等出错,会有相关的出错信息*/
        if (tcgetattr(fd_, &oldtio) != 0)
          perror("SetupSerial 1");
          return -1;
        bzero(&newtio, sizeof(newtio));
        /*步骤一,设置字符大小*/
        newtio.c_cflag |= CLOCAL;   //如果设置,modem 的控制线将会被忽略。如果没有设置,则 open()函数会阻塞直到载波检测线宣告 modem 处于摘机状态为止。
        newtio.c_cflag |= CREAD;    //使端口能读取输入的数据
        /*设置每个数据的位数*/
        switch (nBits)
        case 7:
          newtio.c_cflag |= CS7;
          break;
        case 8:
          newtio.c_cflag |= CS8;
          break;
        /*设置奇偶校验位*/
        switch (nEvent)
        case 'O': //奇数
          newtio.c_iflag |= (INPCK | ISTRIP);
          newtio.c_cflag |= PARENB;   //使能校验,如果不设PARODD则是偶校验
          newtio.c_cflag |= PARODD;   //奇校验
          break;
        case 'E': //偶数
          newtio.c_cflag &= ~PARODD;
          break;
        case 'N':  //无奇偶校验位
          newtio.c_cflag &= ~PARENB;
          break;
        /*设置波特率*/
        switch (baud_rate_)
        case 2400:
          cfsetispeed(&newtio, B2400);
          cfsetospeed(&newtio, B2400);
          break;
        case 4800:
          cfsetispeed(&newtio, B4800);
          cfsetospeed(&newtio, B4800);
          break;
        case 9600:
          cfsetispeed(&newtio, B9600);
          cfsetospeed(&newtio, B9600);
          break;
        case 115200:
          cfsetispeed(&newtio, B115200);
          cfsetospeed(&newtio, B115200);
          break;
        case 230400:
          cfsetispeed(&newtio, B230400);
          cfsetospeed(&newtio, B230400);
          break;
        case 460800:
          cfsetispeed(&newtio, B460800);
          cfsetospeed(&newtio, B460800);
          break;
        default:
          break;
         * 设置停止位
         * 设置停止位的位数, 如果设置,则会在每帧后产生两个停止位, 如果没有设置,则产生一个
         * 停止位。一般都是使用一位停止位。需要两位停止位的设备已过时了。
        if (nStop == 1)
          newtio.c_cflag &= ~CSTOPB;
        else if (nStop == 2)
          newtio.c_cflag |= CSTOPB;
        /*设置等待时间和最小接收字符*/
        newtio.c_cc[VTIME] = 0;
        newtio.c_cc[VMIN] = 0;
        /*处理未接收字符*/
        tcflush(fd_, TCIFLUSH);
        /*激活新配置*/
        if ((tcsetattr(fd_, TCSANOW, &newtio)) != 0)
          perror("serial set error");
          return -1;
        return 0;
      void LSIOSR::flushinput() {
      /* 从串口中读取数据 */
      int LSIOSR::read(char *buffer, int length, int timeout)
        //printf("portread \n");
        memset(buffer, 0, length);
        int totalBytesRead = 0;
        int rc;
        int unlink = 0;
        char* pb = buffer;
        if (timeout > 0)
          rc = waitReadable(timeout);
          if (rc <= 0)
            return (rc == 0) ? 0 : -1;
          int	retry = 3;
          while (length > 0)
            rc = ::read(fd_, pb, (size_t)length);
            if (rc > 0)
              length -= rc;
              pb += rc;
              totalBytesRead += rc;
              if (length == 0)
                break;
            else if (rc < 0)
              printf("error \n");
              retry--;
              if (retry <= 0)
                break;
      	  unlink++;
            rc = waitReadable(20);
      	  if(unlink > 10)
      		  return -1;
            if (rc <= 0)
              break;
        else
          if (rc > 0)
          else if ((rc < 0) && (errno != EINTR) && (errno != EAGAIN))
            printf("read error\n");
            return -1;
        return totalBytesRead;
      int LSIOSR::waitReadable(int millis)
        if (fd_ < 0)
          return -1;
        int serial = fd_;
        fd_set fdset;
        struct timeval tv;
        int rc = 0;
        while (millis > 0)
          if (millis < 5000)
            tv.tv_usec = millis % 1000 * 1000;
            tv.tv_sec  = millis / 1000;
            millis = 0;
          else
            tv.tv_usec = 0;
            tv.tv_sec  = 5;
            millis -= 5000;
          FD_ZERO(&fdset);
          FD_SET(serial, &fdset);
          rc = select(serial + 1, &fdset, NULL, NULL, &tv);
          if (rc > 0)
            rc = (FD_ISSET(serial, &fdset)) ? 1 : -1;
            break;
          else if (rc < 0)
            rc = -1;
            break;
        return rc;
      int LSIOSR::waitWritable(int millis)
        if (fd_ < 0)
          return -1;
        int serial = fd_;
        fd_set fdset;
        struct timeval tv;
        int rc = 0;
        while (millis > 0)
          if (millis < 5000)
            millis = 0;
          else
            tv.tv_usec = 0;
            tv.tv_sec  = 5;
            millis -= 5000;
          FD_ZERO(&fdset);
          rc = select(serial + 1, NULL, &fdset, NULL, &tv);
          if (rc > 0)
            break;
          else if (rc < 0)
            rc = -1;
            break;
        return rc;
      /* 向串口中发送数据 */
      int LSIOSR::send(const char* buffer, int length, int timeout)
        if (fd_ < 0)
          return -1;
        if ((buffer == 0) || (length <= 0))
          return -1;
        int	totalBytesWrite = 0;
        int rc;
        char* pb = (char*)buffer;
        if (timeout > 0)
          rc = waitWritable(timeout);
          if (rc <= 0)
          int	retry = 3;
          while (length > 0)
            rc = write(fd_, pb, (size_t)length);
            if (rc > 0)
              length -= rc;
              pb += rc;
              totalBytesWrite += rc;
              if (length == 0)
                break;
            else
              retry--;
              if (retry <= 0)
                break;
            rc = waitWritable(50);
            if (rc <= 0)
              break;
        else
          if (rc > 0)
            return -1;
        return totalBytesWrite;
      int LSIOSR::init()
      	int error_code = 0;
      	fd_ = open(port_.c_str(), O_RDWR|O_NOCTTY|O_NDELAY);
      	if (0 < fd_)
      		error_code = 0;
      		setOpt(DATA_BIT_8, PARITY_NONE, STOP_BIT_1);//设置串口参数
      		printf("open_port %s  OK !\n", port_.c_str());
      	else
      		error_code = -1;
      		printf("open_port %s ERROR !\n", port_.c_str());
      	printf("LSM10::Init\n");
      	return error_code;
      int LSIOSR::close()
        ::close(fd_);
      std::string LSIOSR::getPort()
        return port_;
      int LSIOSR::setPortName(std::string name)
        port_ = name;
        return 0;
      lsm10.cpp
      @product: LSM10
      @filename: lsm10.cpp
      @brief:
      #include "lsm10_v2/lsm10.h"
      #include <stdio.h>
      #include <signal.h>
      using std::placeholders::_1;
      namespace ls{
      LSM10 * LSM10::instance()
        static LSM10 obj;
        return &obj;
      LSM10::LSM10():rclcpp::Node ("m10lidar")
        int code = 0;
        initParam();
        pub_ = create_publisher<sensor_msgs::msg::LaserScan>("scan", 3);
        device_pub = create_publisher<lsm10_v2::msg::Difop>("difop_information", 100);
        serial_ = LSIOSR::instance("/dev/wheeltec_lidar", 460800);
        code = serial_->init();
        if(code != 0)
          RCLCPP_INFO(this->get_logger(),"rclcpp is down.");
      	  rclcpp::shutdown();
      	  exit(0);
        recv_thread_ = new boost::thread(boost::bind(&LSM10::recvThread, this));
        //test_thread_.reset( new boost::thread(boost::bind(&LSM10::recvThread, this)));
       // testscan_thread_.reset( new boost::thread(boost::bind(&LSM10::pubScanThread, this)));
         pubscan_thread_ = new boost::thread(boost::bind(&LSM10::pubScanThread, this));
      LSM10::~LSM10()
        printf("start LSM10::~LSM10()\n");
        is_shutdown_ = true;
        test_thread_->interrupt();
        test_thread_->join();
        test_thread_ = NULL;
        //delete pubscan_thread_;
        testscan_thread_->interrupt();
        testscan_thread_->join();
        testscan_thread_ = NULL;
        pubscan_thread_->interrupt();
        pubscan_thread_->join();
        //printf("1end LSM10::~LSM1000()\n");
        pubscan_thread_ = NULL;
        //printf("2end LSM10::~LSM1000()\n");
        recv_thread_->interrupt();
        recv_thread_->join();
        //printf("3end LSM10::~LSM1000()\n");
        recv_thread_ = NULL;
        delete recv_thread_;
        //printf("4end LSM10::~LSM1000()\n");
        serial_->close();
        serial_ = NULL;
        delete serial_;
        printf("end LSM10::~LSM10()\n");
      void LSM10::thread_tmp()
        int test_rmp=0;
        printf("test thread\n");
      void LSM10::initParam()
        pre_time_ = rclcpp::Node::now();
        std::string scan_topic_ = "/scan";
        std::string frame_id_ = "laser";
        std::string serial_port_ = "/dev/wheeltec_lidar";
        this->declare_parameter<std::string>("scan_topic", scan_topic_);
        this->get_parameter<std::string>("scan", scan_topic_);
        this->declare_parameter<std::string>("laser", "laser");
        this->get_parameter<std::string>("laser", frame_id_);
        this->declare_parameter<std::string>("serial_port", "/dev/wheeltec_lidar");
        this->get_parameter<std::string>("serial_port", serial_port_);
        this->declare_parameter<int>("baud_rate", 406800);
        this->get_parameter<int>("baud_rate", baud_rate_);
        this->declare_parameter<int>("rpm", 600);
        this->get_parameter<int>("rpm", rpm_);
        is_shutdown_ = false;
        data_len_ = 180;
        points_size_ = 360 * 42 / 15;
        scan_points_.resize(points_size_);
      int LSM10::getScan(std::vector<ScanPoint> &points, rclcpp::Time & scan_time, float &scan_duration)
        boost::unique_lock<boost::mutex> lock(mutex_);
        points.assign(scan_points_bak_.begin(), scan_points_bak_.end());
        scan_time = pre_time_;
        scan_duration = (time_ - pre_time_).seconds();
      int LSM10::getVersion(std::string &version)
        version = "lsm10_v1_0";
        return 0;
      double LSM10::getRPM()
        return real_rpm_;
      void LSM10::recvThread()
        char * packet_bytes = new char[data_len_];
        int idx = 0;
        double degree;
        boost::posix_time::ptime t1,t2;
        t1 = boost::posix_time::microsec_clock::universal_time();
        //printf("rec\n");
        while(!is_shutdown_&&rclcpp::ok()){
      	int count = serial_->read(packet_bytes, 90);
        //printf("rec2\n");
      	for (int i = 0; i < count; i++)
      		int k = packet_bytes[i];
      		k < 0 ? k += 256 : k;
      		int y = packet_bytes[i + 1];
      		y < 0 ? y += 256 : y;
      		int k_1 = packet_bytes[i + 2];
      		k_1 < 0 ? k_1 += 256 : k_1;
      		int y_1 = packet_bytes[i + 3];
      		y_1 < 0 ? y_1 += 256 : y_1;
      		if (k == 0xA5 && y == 0x5A)					 //应答距离
      			if(i != 0)
      				serial_->read(packet_bytes + 90 - i, i);
      			int s = packet_bytes[i + 2];
      			s < 0 ? s += 256 : s;
      			int z = packet_bytes[i + 3];
      			z < 0 ? z += 256 : z;
      			//if ((s * 256 + z) / 100.f > 360)
      			//	degree = 0;
      			//else
      			degree = (s * 256 + z) / 100.f;
      			//转速
      			lsm10_v2::msg::Difop Difop_data;
      			s = packet_bytes[i + 4];
      			z = packet_bytes[i + 5];
      			Difop_data.motorspeed = float(2500000.0 / (s * 256 + z));
      			device_pub->publish(Difop_data);
      			int invalidValue = 0;
      			for (size_t num = 2; num < 86; num+=2)
      				int s = packet_bytes[i + num + 4];
      				int z = packet_bytes[i + num + 5];
      				if ((s * 256 + z) != 0xFFFF)
      					scan_points_[idx].range = double(s * 256 + (z)) / 1000.f;
      					scan_points_[idx].intensity = 0;
      					idx++;
      				else
      					invalidValue++;
      			invalidValue = 42 - invalidValue;
      			for (size_t i = 0; i < invalidValue; i++)
      				if ((degree + (15.0 / invalidValue * i)) > 360)
      					scan_points_[idx-invalidValue+i].degree = degree + (15.0 / invalidValue * i) - 360;
      				else
      					scan_points_[idx-invalidValue+i].degree = degree + (15.0 / invalidValue * i);
      			lock.unlock();
      			if (degree > 359.5)
      				idx = 0;
      				t2 = boost::posix_time::microsec_clock::universal_time();
      				boost::posix_time::millisec_posix_time_system_config::time_duration_type t_elapse;
      				t_elapse = t2 - t1;
      				real_rpm_ = 1000000.0 / t_elapse.ticks();
      				t1 = t2;
      				scan_points_bak_.resize(scan_points_.size());
      				scan_points_bak_.assign(scan_points_.begin(), scan_points_.end());
      				for(int k=0; k<scan_points_.size(); k++)
      					scan_points_[k].range = 0;
      					scan_points_[k].degree = 0;
      				pre_time_ = time_;
      				lock.unlock();
      				pubscan_cond_.notify_one();
      				time_ = this->now();
      		else if (k == 0xA5 && y == 0xFF && k_1 == 00 && y_1 == 0x5A)
      			printf("elseif");
      			/*lsm10_v2::difopPtr Difop_data = lsm10_v2::difopPtr(
      						new lsm10_v2::difop());
      			//温度
      			int s = packet_bytes[i + 12];
      			int z = packet_bytes[i + 13];
      			Difop_data->Temperature = (float(s * 256 + z) / 4096 * 330 - 50);
      			//高压
      			s = packet_bytes[i + 14];
      			z = packet_bytes[i + 15];
      			Difop_data->HighPressure = (float(s * 256 + z) / 4096 * 3.3 * 101);
      			//转速
      			s = packet_bytes[i + 16];
      			z = packet_bytes[i + 17];
      			Difop_data->MotorSpeed = (float(1000000 / (s * 256 + z) / 24));
      			device_pub.publish(Difop_data);*/
        if (packet_bytes)
          packet_bytes = NULL;
          delete packet_bytes;
      void LSM10::pubScanThread()
        //printf("pubscan0");
        bool wait_for_wake = true;
        boost::unique_lock<boost::mutex> lock(pubscan_mutex_);
        while (!is_shutdown_&&rclcpp::ok())
          while (wait_for_wake)
            pubscan_cond_.wait(lock);
            wait_for_wake = false;
           //printf("pubscan1");
          std::vector<ScanPoint> points;
          rclcpp::Time start_time;
          float scan_time;
          this->getScan(points, start_time, scan_time);
          int count = points.size();
          if (count <= 0)
            continue;
          sensor_msgs::msg::LaserScan msg;
          msg.header.frame_id = "laser";
          msg.header.stamp = start_time;
          msg.angle_min = 0.0;
          msg.angle_max = 2 * M_PI;
          msg.angle_increment = (msg.angle_max - msg.angle_min) / count;
          msg.range_min = 0.02;
          msg.range_max = 50;
          msg.ranges.resize(count);
          msg.intensities.resize(count);
          msg.scan_time = scan_time;
          msg.time_increment = scan_time / (double)(count - 1);
      	for(int k=0; k<count; k++)
      		msg.ranges[k] = std::numeric_limits<float>::infinity();
              msg.intensities[k] = 0;
      	for (int i = 0; i < count; i++) {
      		int point_idx = 1008 - points[i].degree * 42 / 15;
      		if(point_idx < 0 || point_idx > 1007)
      			continue;
            if (points[i].range == 0.0) {
              msg.ranges[point_idx] = std::numeric_limits<float>::infinity();
              msg.intensities[point_idx] = 0;
           // printf("pubscan2");
            else {
              double dist = points[i].range;
              msg.ranges[point_idx] = (float) dist;
              msg.intensities[point_idx] = points[i].intensity;
           // printf("pubscan3");
          pub_->publish(msg);
           // printf("pubscan4");
      void handleSig(int signo)
        rclcpp::shutdown();
        exit(0);
      int main(int argc, char *argv[])
        rclcpp::init(argc, argv);
        signal(SIGINT, handleSig);
        signal(SIGTERM, handleSig);
        ls::LSM10* lsm10 = ls::LSM10::instance();
        //auto node=std::make_shared<ls::LSM10>();
        auto node = rclcpp::Node::make_shared("lidar10");
        rclcpp::spin(node);
        return 0;
      ls_m10.launch.py
      #!/usr/bin/env python3
      @company: Copyright (C) 2022, WHEELTEC (Dongguan) Co., Ltd
      @product: LSM10
      @filename: ls_m10.launch.py
      @brief:
      @v2.0           22-4-12      Tues          ROS2
      import os
      from launch.actions import LogInfo
      import launch_ros.actions
          frequency = LaunchConfiguration('frequency', default='5.5')
          serial_port_ = LaunchConfiguration('port', default='/dev/wheeltec_lidar')
          baud_rate_ = LaunchConfiguration('baud_rate_', default='460800')
          frame_id_ = LaunchConfiguration('frame_id', default='laser_link')
          scan_topic = LaunchConfiguration('scan_topic', default='scan')
          return LaunchDescription([
              DeclareLaunchArgument('serial_port_', default_value=serial_port_,
                  description='Specifying port to connected lidar'),
              DeclareLaunchArgument('baud_rate_', default_value=baud_rate_,
                  description='Specifying serial baudrate to connected lidar'),
              DeclareLaunchArgument('frame_id_', default_value=frame_id_,
                  description='Specifying frame_id of lidar. Default frame_id is \'laser\''),
              DeclareLaunchArgument('frequency', default_value=frequency,
                  description='Specifying frequency property of lidar'),
              DeclareLaunchArgument('scan_topic', default_value=scan_topic,
                  description='Specifying scan_topic property of lidar'),
              launch_ros.actions.Node(
                  package='lsm10_v2',
                  executable='LSM10',
                  output='screen'),
      雷达的代码都在这里了,以前在ros2 foxy版本编译好了就行,现在在foxy编译报错
      一开始humble版本编译也报同样的错误,不知道为什么后来编译不报错了,但是运行还是报错
        小鱼 技术大佬 @毛哥成山轮胎机油保养
        @毛哥成山轮胎机油保养 在 雷神m10雷达humble安装遇到问题,编译通过了,运行还是报错,大佬们给看一下 中说:
        install(TARGETS
        LSM10
        检查下报错目录中是否存在可执行文件, /home/m/jtbot_ws/install/lsm10_v2/lib/lsm10_v2
        • 毛哥成山轮胎机油保养毛
          毛哥成山轮胎机油保养 活跃VIP @小鱼
          @小鱼 当时我看了,确实没有可执行文件,但是原来这个驱动在foxy运行是正常的,这次装完系统我特意装了一个foxy虚拟机,在foxy上试了也不行,说明有些东西升级了,原来的东西不配套了。雷达售后给我又发了一个驱动,安装成功了,我把原来的humble 卸载了用一键装ros又装了一遍,没有问题,说明你的一键装ros也是正常的。
            小鱼 技术大佬 @毛哥成山轮胎机油保养
            @毛哥成山轮胎机油保养 👍
