10.4 Cartographer介绍与安装 中 编译出错
个好的提问不仅能够帮助自己理清楚问题,还有助于别人快速帮助到你。——提问的智慧
问题一定要描述清楚,终端打印一定复制粘贴(你可以在linux系统上打开浏览器进社区)
提问时一定要提供尽可能多的信息,包括你的目的,比如你其实想装装某个库遇到问题,不要只说这个问题,因为可能有更好的替代方案
尽量一句话说完,不要把社区当微信聊天一样用,每一个回复都尽量提供更多的的信息。 -
Starting >>> cartographer
Starting >>> cartographer_ros_msgs
--- stderr: cartographer
CMake Error at /lib/cmake/Ceres/CeresConfig.cmake:88 (message):
Failed to find Ceres - Ceres install root: /, determined from relative path
from CeresConfig.cmake install location: /lib/cmake/Ceres, does not contain
Ceres headers. Either the install directory was deleted, or the install
tree was only partially relocated outside of CMake after Ceres was built.
/lib/cmake/Ceres/CeresConfig.cmake:149 (ceres_report_not_found)
CMakeLists.txt:32 (find_package)CMake Error at CMakeLists.txt:32 (find_package):
Found package configuration file:/lib/cmake/Ceres/CeresConfig.cmakebut it set Ceres_FOUND to FALSE so package "Ceres" is considered to be NOT
FOUND.
Failed <<< cartographer [0.77s, exited with code 1]
Aborted <<< cartographer_ros_msgs [1.64s]Summary: 0 packages finished [1.86s]
1 package failed: cartographer
1 package aborted: cartographer_ros_msgs
1 package had stderr output: cartographer
1 package not processed
这是报错提示,请大家帮忙看看怎么解决 -
@744063846 系统版本,ros版本,源码分支log记录,前置操作
@小鱼 Ubuntu20.04 ros2 foxy
@744063846 代码是那个分支的?
@小鱼 按步骤一步步来的
@744063846 可以在工作空间下使用git branch -a指令查看分支,默认的分支是humble版本的,感觉你是搞错了分支
