    编译cartographer时cmake .. -G Ninja时出错
    rosmelodic cartographer 报错 cmake报错
    626
    • 2372795282
      Te amo X
      Ubuntu版本18.04,ros版本melodic,按照csdn教程cartographer安装教程(超详细 保姆级教程)
      安装cartographer源码时进行到cmake .. -G Ninja时出错:报错内容如下:
      替代文字
      CMake Error at CMakeLists.txt:32 (find_package): By not providing "Findabsl.cmake" in CMAKE_MODULE_PATH this project has asked CMake to find a package configuration file provided by "absl", but CMake did not find one. Could not find a package configuration file provided by "absl" with any of the following names: abslConfig.cmake absl-config.cmake Add the installation prefix of "absl" to CMAKE_PREFIX_PATH or set "absl_DIR" to a directory containing one of the above files. If "absl" provides a separate development package or SDK, be sure it has been installed.
      不知道怎么解决这个问题😖求助😭
        小鱼 技术大佬 @237279528
        @237279528 应该是absl没有装好,前面的步骤出错了。
        看看这个:https://zhuanlan.zhihu.com/p/266550407
        另外图片有点问题,没有显示出来
        2372795282 1 条回复 最后回复 回复 引用 0
        • 2372795282
          Te amo X @小鱼
          @小鱼 谢谢小鱼!刚刚这个解决了后面运行ninja命令时候又发生错误,提示ninja:build stooped:subcommand failed 这个应该咋解决呀
            小鱼 技术大佬 @237279528
            @237279528 这个错误我也没有遇到过,最好用一个干净的系统来装,前面步骤不要出错,不然后面出问题都不知道怎么整,看错误提示,因该是前面某一步出错了,仔细检查下。
            • 2372795282
              Te amo X @小鱼
              @小鱼 好的谢谢
