    move_group.launch文件启动时出现load_yaml()报错
    roslaunch loadyaml
    1.6k
    • 空白空
      空白
      我在调用一个从网上下载的包时,出现如下问题:
      pan@pan-System-Product-Name:~/moveit_test$ ros2 launch panda_moveit_config ex_fake_control.launch.py
      [INFO] [launch]: All log files can be found below /home/pan/.ros/log/2022-11-23-17-28-54-850085-pan-System-Product-Name-17014
      [ERROR] [launch]: Caught exception in launch (see debug for traceback): executed command showed stderr output. Command: /opt/ros/humble/bin/xacro /home/pan/moveit_test/install/panda_description/share/panda_description/urdf/panda.urdf.xacro name:=panda prefix:=panda_ gripper:=true collision_arm:=true collision_gripper:=true safety_limits:=true safety_position_margin:=0.15 safety_k_position:=100.0 safety_k_velocity:=40.0 ros2_control:=true ros2_control_plugin:=fake ros2_control_command_interface:=position gazebo_preserve_fixed_joint:=false
      Captured stderr output:
      warning: Using load_yaml() directly is deprecated. Use xacro.load_yaml() instead.
      在翻看源码时,定位到load_yaml,作者使用的是yaml.safe_load(file) 方法,仔细阅读了源码没有查到具体问题出现在哪,所以想请大家帮忙。
      源码如下:
      #!/usr/bin/env -S ros2 launch
      """Configure and setup move group for planning with MoveIt 2"""
      from os import path
      from typing import List
      import yaml
      from launch.conditions import IfCondition
      from launch.substitutions import (
          Command,
          FindExecutable,
          LaunchConfiguration,
          PathJoinSubstitution,
          PythonExpression,
          # Declare all launch arguments
          declared_arguments = generate_declared_arguments()
          # Get substitution for all arguments
          #description_package = LaunchConfiguration("description_package")
          #description_filepath = LaunchConfiguration("description_filepath")
          moveit_config_package = "panda_moveit_config"
          name = LaunchConfiguration("name")
          prefix = LaunchConfiguration("prefix")
          gripper = LaunchConfiguration("gripper")
          collision_arm = LaunchConfiguration("collision_arm")
          collision_gripper = LaunchConfiguration("collision_gripper")
          safety_limits = LaunchConfiguration("safety_limits")
          safety_position_margin = LaunchConfiguration("safety_position_margin")
          safety_k_position = LaunchConfiguration("safety_k_position")
          safety_k_velocity = LaunchConfiguration("safety_k_velocity")
          ros2_control = LaunchConfiguration("ros2_control")
          ros2_control_plugin = LaunchConfiguration("ros2_control_plugin")
          ros2_control_command_interface = LaunchConfiguration(
              "ros2_control_command_interface"
          gazebo_preserve_fixed_joint = LaunchConfiguration("gazebo_preserve_fixed_joint")
          enable_servo = LaunchConfiguration("enable_servo")
          enable_rviz = LaunchConfiguration("enable_rviz")
          rviz_config = LaunchConfiguration("rviz_config")
          use_sim_time = LaunchConfiguration("use_sim_time")
          log_level = LaunchConfiguration("log_level")
          # URDF
          _robot_description_xml = Command(
                  PathJoinSubstitution([FindExecutable(name="xacro")]),
                      [FindPackageShare("panda_description"), "urdf","panda.urdf.xacro",]
                  "name:=",
                  name,
                  "prefix:=",
                  prefix,
                  "gripper:=",
                  gripper,
                  "collision_arm:=",
                  collision_arm,
                  "collision_gripper:=",
                  collision_gripper,
                  "safety_limits:=",
                  safety_limits,
                  "safety_position_margin:=",
                  safety_position_margin,
                  "safety_k_position:=",
                  safety_k_position,
                  "safety_k_velocity:=",
                  safety_k_velocity,
                  "ros2_control:=",
                  ros2_control,
                  "ros2_control_plugin:=",
                  ros2_control_plugin,
                  "ros2_control_command_interface:=",
                  ros2_control_command_interface,
                  "gazebo_preserve_fixed_joint:=",
                  gazebo_preserve_fixed_joint,
          robot_description = {"robot_description": _robot_description_xml}
          # SRDF
          _robot_description_semantic_xml = Command(
                          FindPackageShare(moveit_config_package),
                          "srdf",
                          "panda.srdf.xacro",
                  "name:=",
                  name,
                  "prefix:=",
                  prefix,
          robot_description_semantic = {
              "robot_description_semantic": _robot_description_semantic_xml
          # Kinematics
          kinematics = load_yaml(
              moveit_config_package, path.join("config", "kinematics.yaml")
          # Joint limits
          joint_limits = {
              "robot_description_planning": load_yaml(
                  moveit_config_package, path.join("config", "joint_limits.yaml")
          # Servo
          servo_params = {
              "moveit_servo": load_yaml(
                  moveit_config_package, path.join("config", "servo.yaml")
          servo_params["moveit_servo"].update({"use_gazebo": use_sim_time})
          # Planning pipeline
          planning_pipeline = {
              "planning_pipelines": ["ompl"],
              "default_planning_pipeline": "ompl",
              "ompl": {
                  "planning_plugin": "ompl_interface/OMPLPlanner",
                  # TODO: Re-enable `default_planner_request_adapters/AddRuckigTrajectorySmoothing` once its issues are resolved
                  "request_adapters": "default_planner_request_adapters/AddTimeOptimalParameterization default_planner_request_adapters/ResolveConstraintFrames default_planner_request_adapters/FixWorkspaceBounds default_planner_request_adapters/FixStartStateBounds default_planner_request_adapters/FixStartStateCollision default_planner_request_adapters/FixStartStatePathConstraints",
                  # TODO: Reduce start_state_max_bounds_error once spawning with specific joint configuration is enabled
                  "start_state_max_bounds_error": 0.31416,
          _ompl_yaml = load_yaml(
              moveit_config_package, path.join("config", "ompl_planning.yaml")
          planning_pipeline["ompl"].update(_ompl_yaml)
          # Planning scene
          planning_scene_monitor_parameters = {
              "publish_planning_scene": True,
              "publish_geometry_updates": True,
              "publish_state_updates": True,
              "publish_transforms_updates": True,
          # MoveIt controller manager
          moveit_controller_manager_yaml = load_yaml(
              moveit_config_package, path.join("config", "moveit_controller_manager.yaml")
          moveit_controller_manager = {
              "moveit_controller_manager": "moveit_simple_controller_manager/MoveItSimpleControllerManager",
              "moveit_simple_controller_manager": moveit_controller_manager_yaml,
          # Trajectory execution
          trajectory_execution = {
              "allow_trajectory_execution": True,
              "moveit_manage_controllers": False,
              "trajectory_execution.allowed_execution_duration_scaling": 1.2,
              "trajectory_execution.allowed_goal_duration_margin": 0.5,
              "trajectory_execution.allowed_start_tolerance": 0.01,
          # Controller parameters
          declared_arguments.append(
              DeclareLaunchArgument(
                  "__controller_parameters_basename",
                  default_value=["controllers_", ros2_control_command_interface, ".yaml"],
          controller_parameters = PathJoinSubstitution(
                  "config",
                  LaunchConfiguration("__controller_parameters_basename"),
          # List of nodes to be launched
          nodes = [
              # robot_state_publisher
              Node(
                  package="robot_state_publisher",
                  executable="robot_state_publisher",
                  output="log",
                  arguments=["--ros-args", "--log-level", log_level],
                  parameters=[
                      robot_description,
                          "publish_frequency": 50.0,
                          "frame_prefix": "",
                          "use_sim_time": use_sim_time,
              # ros2_control_node (only for fake controller)
              Node(
                  package="controller_manager",
                  executable="ros2_control_node",
                  output="log",
                  parameters=[
                      robot_description,
                      controller_parameters,
                      {"use_sim_time": use_sim_time},
                  condition=(
                      IfCondition(
                          PythonExpression(
                                  "'fake'",
              # move_group (with execution)
              Node(
                  package="moveit_ros_move_group",
                  executable="move_group",
                  output="log",
                  parameters=[
                      robot_description,
                      robot_description_semantic,
                      kinematics,
                      joint_limits,
                      planning_pipeline,
                      trajectory_execution,
                      planning_scene_monitor_parameters,
                      moveit_controller_manager,
              # move_servo
              Node(
                  package="moveit_servo",
                  executable="servo_node_main",
                  output="log",
                  parameters=[
                      robot_description,
                      kinematics,
                      joint_limits,
                      planning_pipeline,
                      servo_params,
                  condition=IfCondition(enable_servo),
              # rviz2
              Node(
                  package="rviz2",
                  executable="rviz2",
                  output="log",
                  arguments=[
                      "--display-config",
                      rviz_config,
                      "--ros-args",
                      "--log-level",
                      log_level,
                  parameters=[
                      robot_description,
                      kinematics,
                      planning_pipeline,
                      joint_limits,
                  condition=IfCondition(enable_rviz),
          # Add nodes for loading controllers
          for controller in moveit_controller_manager_yaml["controller_names"] + [
              "joint_state_broadcaster"
              nodes.append(
                  # controller_manager_spawner
                  Node(
                      executable="spawner",
                      output="log",
                      arguments=[controller, "--ros-args", "--log-level", log_level],
                      parameters=[{"use_sim_time": use_sim_time}],
          return LaunchDescription(declared_arguments + nodes)
      def load_yaml(package_name: str, file_path: str):
          Load yaml configuration based on package name and file path relative to its share.
          package_path = get_package_share_directory(package_name)
          absolute_file_path = path.join(package_path, file_path)
          return parse_yaml(absolute_file_path)
      def parse_yaml(absolute_file_path: str):
          Parse yaml from file, given its absolute file path.
          try:
              with open(absolute_file_path, "r") as file:
                  return yaml.safe_load(file)
          except EnvironmentError:
              return None
      def generate_declared_arguments() -> List[DeclareLaunchArgument]:
          Generate list of all launch arguments that are declared for this launch script.
          return [
              # Locations of robot resources
                  "description_package",
                  default_value="panda_description",
                  description="Custom package with robot description.",
                  "description_filepath",
                  default_value=path.join("urdf", "panda.urdf.xacro"),
                  description="Path to xacro or URDF description of the robot, relative to share of `description_package`.",
              # Naming of the robot
                  "name",
                  default_value="panda",
                  description="Name of the robot.",
                  "prefix",
                  default_value="panda_",
                  description="Prefix for all robot entities. If modified, then joint names in the configuration of controllers must also be updated.",
              # Gripper
                  "gripper",
                  default_value="true",
                  description="Flag to enable default gripper.",
              # Collision geometry
                  "collision_arm",
                  description="Flag to enable collision geometry for manipulator's arm.",
                  "collision_gripper",
                  description="Flag to enable collision geometry for manipulator's gripper (hand and fingers).",
              # Safety controller
                  "safety_limits",
                  description="Flag to enable safety limits controllers on manipulator joints.",
                  "safety_position_margin",
                  default_value="0.15",
                  description="Lower and upper margin for position limits of all safety controllers.",
                  "safety_k_position",
                  default_value="100.0",
                  description="Parametric k-position factor of all safety controllers.",
                  "safety_k_velocity",
                  default_value="40.0",
                  description="Parametric k-velocity factor of all safety controllers.",
              # ROS 2 control
                  "ros2_control",
                  description="Flag to enable ros2 controllers for manipulator.",
                  "ros2_control_plugin",
                  default_value="ign",
                  description="The ros2_control plugin that should be loaded for the manipulator ('fake', 'ign', 'real' or custom).",
                  "ros2_control_command_interface",
                  default_value="effort",
                  description="The output control command interface provided by ros2_control ('position', 'velocity', 'effort' or certain combinations 'position,velocity').",
              # Gazebo
                  "gazebo_preserve_fixed_joint",
                  default_value="false",
                  description="Flag to preserve fixed joints and prevent lumping when generating SDF for Gazebo.",
              # Servo
                  "enable_servo",
                  description="Flag to enable MoveIt2 Servo for manipulator.",
              # Miscellaneous
                  "enable_rviz", default_value="true", description="Flag to enable RViz2."
                  "rviz_config",
                      get_package_share_directory("panda_moveit_config"),
                      "rviz",
                      "moveit.rviz",
                  description="Path to configuration for RViz2.",
                  "use_sim_time",
                  description="If true, use simulated clock.",
                  "log_level",
                  default_value="warn",
                  description="The level of logging that is applied to all ROS 2 nodes launched by this script.",
      重点涉及到load_yaml部分为
          try:
              return None
      不知是这个用法不行,还是配置的launch文件有问题?
      LorryL 2 条回复 最后回复 回复 引用 0
      • LorryL
        Lorry @空白
        @空白 直接替换一个load_yaml函数行不?
        • LorryL
          Lorry @空白
          @空白 我看了一下我用的ros2包
          def load_yaml(package_name, *file_path):
              absolute_file_path = os.path.join(package_path, *file_path)
              if not os.path.exists(absolute_file_path):
                  return {}
              try:
                  with open(absolute_file_path, 'r') as file:
              except EnvironmentError:  # parent of IOError, OSError *and* WindowsError where available
                  return {}
              except:
                  return {}
          不过也用到了yaml.safe_load(file),这样能加载到配置文件
          空白空 2 条回复 最后回复 回复 引用 0
          • 空白空
            空白 @Lorry
            @Lorry 好的,谢谢,我试试吧。感觉本质上应该没有问题的,我查了下这个yaml的库也可以这样用,所以我有点怀疑是不是有别的地方没有配置好😵
            • 空白空
              空白 @Lorry
              @Lorry 解决问题了,不是这个源码上面load_yaml的问题,是我下载的功能包里面一个在panda.ros2_contral的配置中对于xacro的描述里面出现了load_yaml,将其改为xacro.load_yaml即可,这是在humble上面新出现的问题(特性),之前的功能包适用于galactic,所以没意识到,谢谢了
              LorryL 1 条回复 最后回复 回复 引用 0
              • 空白空 空白 将这个主题标记为已解决,在
              • LorryL
                Lorry @空白
                @空白 能解决就好
