    ROS关于编写节点时无法同时订阅和发布
    ros节点间通讯 rosrun
    1.3k
    • 30536533793
      火海一舟
      我在编写ROS节点的时候发现冲突,不能同时订阅和发布了,但屏蔽pub之后能完美打印2了,这是为什么?
      这时我的节点文件
      def callback(msg):
      pad_id = msg.data
      if pad_id == 2:
      rospy.loginfo('2')
      pub.publish('two')
      if name == "main":
      rospy.init_node('pad_to_led', anonymous=False)
      sub = rospy.Subscriber('mission_pad_id', UInt8, callback)
      pub = rospy.Publisher('mled', String, queue_size=10)
      rospy.spin()
      然后这是报错
      Exception in thread Thread-9:
      File "/opt/ros/noetic/lib/python3/dist-packages/std_msgs/msg/_UInt8.py", line 54, in serialize
      buff.write(_get_struct_B().pack(_x))
      struct.error: ubyte format requires 0 <= number <= 255
      File "/opt/ros/noetic/lib/python3/dist-packages/rospy/topics.py", line 882, in publish
      self.impl.publish(data)
      File "/opt/ros/noetic/lib/python3/dist-packages/rospy/topics.py", line 1066, in publish
      serialize_message(b, self.seq, message)
      File "/opt/ros/noetic/lib/python3/dist-packages/rospy/msg.py", line 152, in serialize_message
      msg.serialize(b)
      File "/opt/ros/noetic/lib/python3/dist-packages/std_msgs/msg/_UInt8.py", line 55, in serialize
      except struct.error as se: self._check_types(struct.error("%s: '%s' when writing '%s'" % (type(se), str(se), str(locals().get('_x', self)))))
      File "/opt/ros/noetic/lib/python3/dist-packages/genpy/message.py", line 393, in _check_types
      check_type(n, t, getattr(self, n))
      File "/opt/ros/noetic/lib/python3/dist-packages/genpy/message.py", line 267, in check_type
      raise SerializationError('field %s must be unsigned integer type' % field_name)
      genpy.message.SerializationError: field data must be unsigned integer type
      File "/usr/lib/python3.8/threading.py", line 932, in _bootstrap_inner
      self.run()
      File "/opt/ros/noetic/lib/python3/dist-packages/rospy/timer.py", line 237, in run
      self._callback(TimerEvent(last_expected, last_real, current_expected, current_real, last_duration))
      File "rmtt_core.py", line 317, in rmtt_core_dev.scripts.rmtt_core.RoboMasterTelloTalent._drone_info_handler
      File "rmtt_core.py", line 395, in rmtt_core_dev.scripts.rmtt_core.RoboMasterTelloTalent._drone_info_publisher
      File "/opt/ros/noetic/lib/python3/dist-packages/rospy/topics.py", line 886, in publish
      raise ROSSerializationException(str(e))
      rospy.exceptions.ROSSerializationException: field data must be unsigned integer type
      查找了一群资料也不知道为什么,求大神帮助
        小鱼 技术大佬 @3053653379
        @3053653379 注意格式哈
        @3053653379 在 ROS关于编写节点时无法同时订阅和发布 中说:
        看起来像是收到的数据类型有问题,贴下完成代码和操作,你这个看不太出缩进
