    使用move_base导航 地图加载偏移
    移动机器人制作
    ros 导航
    1.9k
    • 追逐我的明天追
      追逐我的明天
      最后由 追逐我的明天 编辑
      ubuntu2004+ROS Noetic
      求助:gmapping建图后使用movebase导航,加载地图时整体地图发生偏移(图中没开激光雷达)。
      movebase直接移植的开源包,tf_tree没有问题。
      [ WARN] [1674890883.810470182]: Using deprecated map server interface. Please switch to new interface.
      [ WARN] [1674890885.333145954]: global_costmap: Parameter "plugins" not provided, loading pre-Hydro parameters
      [ INFO] [1674890885.382116964]: global_costmap: Using plugin "static_layer"
      [ INFO] [1674890885.404428357]: Requesting the map...
      [ INFO] [1674890885.614653929]: Resizing costmap to 1120 X 1056 at 0.025000 m/pix
      [ INFO] [1674890885.711666042]: Received a 1120 X 1056 map at 0.025000 m/pix
      [ INFO] [1674890885.724882480]: global_costmap: Using plugin "obstacle_layer"
      [ INFO] [1674890885.735170558]: Subscribed to Topics: scan
      [ INFO] [1674890885.784227516]: global_costmap: Using plugin "inflation_layer"
      [ WARN] [1674890885.938028227]: Map update loop missed its desired rate of 15.0000Hz... the loop actually took 0.0702 seconds
      [ WARN] [1674890885.938843818]: local_costmap: Parameter "plugins" not provided, loading pre-Hydro parameters
      [ INFO] [1674890885.981046736]: local_costmap: Using plugin "obstacle_layer"
      [ INFO] [1674890885.989153352]: Subscribed to Topics: scan
      [ INFO] [1674890886.033495043]: local_costmap: Using plugin "inflation_layer"
      [ INFO] [1674890886.152708856]: Created local_planner base_local_planner/TrajectoryPlannerROS
      [ INFO] [1674890886.180344821]: Sim period is set to 0.05
      [ WARN] [1674890886.205214696]: Trajectory Rollout planner initialized with param meter_scoring not set. Set it to true to make your settings robust against changes of costmap resolution.
      [ INFO] [1674890886.474983374]: Recovery behavior will clear layer 'obstacles'
      [ INFO] [1674890886.500605534]: Recovery behavior will clear layer 'obstacles'
      [ INFO] [1674890886.630005796]: odom received!
      追逐我的明天追 1 条回复 最后回复 回复 引用 0
      • 追逐我的明天追
        追逐我的明天 @追逐我的明天
        @追逐我的明天 应该是AMCL发布map与odom tf的问题
          小鱼 技术大佬 @追逐我的明天
          @追逐我的明天 把tf贴出来
