nav2导航出现Aborting handle错误
运行前提:
- 雷达hz数:
topic:scan hz是28hz
- tf列表如图:
- launch文件使用的是fishbot_navigation2里面的launch,launch文件里的内容把use_sim_time改成了flase,地图自己扫描的地图;然后launch文件调用参数配置文件的内容如下:
amcl:
ros__parameters:
use_sim_time: False
alpha1: 0.2
alpha2: 0.2
alpha3: 0.2
alpha4: 0.2
alpha5: 0.2
base_frame_id: "base_link"
beam_skip_distance: 0.5
beam_skip_threshold: 0.3
do_beamskip: false
global_frame_id: "map"
lambda_short: 0.1
laser_max_range: 100.0
laser_min_range: 0.1
max_beams: 60
max_particles: 2000
min_particles: 100
odom_frame_id: "odom"
pf_err: 0.05
pf_z: 0.99
recovery_alpha_fast: 0.0
recovery_alpha_slow: 0.0
resample_interval: 1
save_pose_rate: 0.5
sigma_hit: 0.2
tf_broadcast: true
transform_tolerance: 1.0
update_min_a: 0.2
update_min_d: 0.25
z_hit: 0.5
z_max: 0.05
z_rand: 0.5
z_short: 0.05
scan_topic: scan
bt_navigator:
ros__parameters:
use_sim_time: False
global_frame: map
robot_base_frame: base_link
odom_topic: /odom
bt_loop_duration: 10
default_server_timeout: 20
plugin_lib_names:
- nav2_spin_action_bt_node
- nav2_wait_action_bt_node
- nav2_assisted_teleop_action_bt_node
- nav2_back_up_action_bt_node
- nav2_recovery_node_bt_node
- nav2_single_trigger_bt_node
- nav2_goal_updated_controller_bt_node
- nav2_wait_cancel_bt_node
- nav2_spin_cancel_bt_node
- nav2_back_up_cancel_bt_node
- nav2_assisted_teleop_cancel_bt_node
- nav2_is_battery_charging_condition_bt_nodebt_navigator_navigate_through_poses_rclcpp_node:
ros__parameters:
use_sim_time: Falsebt_navigator_navigate_to_pose_rclcpp_node:
ros__parameters:
use_sim_time: Falsecontroller_server:
ros__parameters:
use_sim_time: False
controller_frequency: 10.0
min_y_velocity_threshold: 0.0
failure_tolerance: 300000.0
controller_plugins: ["FollowPath"]# Progress checker parameters progress_checker: plugin: "nav2_controller::SimpleProgressChecker" required_movement_radius: 0.5 movement_time_allowance: 3600.0 # Goal checker parameters #precise_goal_checker: # plugin: "nav2_controller::SimpleGoalChecker" # xy_goal_tolerance: 0.25 # yaw_goal_tolerance: 0.25 # stateful: True general_goal_checker: stateful: True plugin: "nav2_controller::SimpleGoalChecker" xy_goal_tolerance: 0.25 yaw_goal_tolerance: 0.25 # DWB parameters FollowPath: plugin: "dwb_core::DWBLocalPlanner" debug_trajectory_details: True min_vel_x: 0.0 min_vel_y: 0.0 max_vel_x: 0.46 max_vel_y: 0.0 max_vel_theta: 2.0 min_speed_xy: 0.0 max_speed_xy: 0.26 min_speed_theta: 0.0 # Add high threshold velocity for turtlebot 3 issue. # https://github.com/ROBOTIS-GIT/turtlebot3_simulations/issues/75 acc_lim_x: 2.5 acc_lim_y: 0.0 acc_lim_theta: 3.2 decel_lim_x: -2.5 decel_lim_y: 0.0 decel_lim_theta: -3.2 vx_samples: 5 vy_samples: 0 vtheta_samples: 5 sim_time: 1.7 linear_granularity: 0.05 angular_granularity: 0.025 transform_tolerance: 0.2 xy_goal_tolerance: 0.25 trans_stopped_velocity: 0.25 short_circuit_trajectory_evaluation: True stateful: True critics: ["RotateToGoal", "Oscillation", "BaseObstacle", "GoalAlign", "PathAlign", "PathDist", "GoalDist"] BaseObstacle.scale: 0.02 PathAlign.scale: 32.0 PathAlign.forward_point_distance: 0.1 GoalAlign.scale: 24.0 GoalAlign.forward_point_distance: 0.1 PathDist.scale: 32.0 GoalDist.scale: 24.0 RotateToGoal.scale: 32.0 RotateToGoal.slowing_factor: 5.0 RotateToGoal.lookahead_time: -1.0local_costmap:
local_costmap:
ros__parameters:
update_frequency: 5.0
publish_frequency: 2.0
global_frame: odom
use_sim_time: False
rolling_window: true
width: 3
height: 3
resolution: 0.05
robot_radius: 0.22
plugins: ["inflation_layer"]
inflation_layer:
cost_scaling_factor: 3.0
inflation_radius: 0.55
static_layer:
always_send_full_costmap: Trueglobal_costmap:
global_costmap:
ros__parameters:
update_frequency: 1.0
publish_frequency: 1.0
global_frame: map
use_sim_time: False
robot_radius: 0.22
resolution: 0.05
track_unknown_space: true
obstacle_layer:
enabled: True
observation_sources: scan
scan:
topic: /scan
max_obstacle_height: 2.0
clearing: True
marking: True
data_type: "LaserScan"
raytrace_max_range: 3.0
raytrace_min_range: 0.0
obstacle_max_range: 2.5
obstacle_min_range: 0.0
static_layer:
inflation_layer:
always_send_full_costmap: Truemap_server:
ros__parameters:
use_sim_time: False
# Overridden in launch by the "map" launch configuration or provided default value.
# To use in yaml, remove the default "map" value in the tb3_simulation_launch.py file & provide full path to map below.
yaml_filename: ""map_saver:
ros__parameters:
use_sim_time: False
save_map_timeout: 5.0
free_thresh_default: 0.25
occupied_thresh_default: 0.65
map_subscribe_transient_local: Trueplanner_server:
ros__parameters:
expected_planner_frequency: 0.0
use_sim_time: False
GridBased:
tolerance: 0.1
use_astar: true
allow_unknown: falsesmoother_server:
ros__parameters:
use_sim_time: False
simple_smoother:
tolerance: 1.0e-10
max_its: 1000
do_refinement: Truebehavior_server:
ros__parameters:
cycle_frequency: 10.0
behavior_plugins: ["spin", "backup", "drive_on_heading", "assisted_teleop", "wait"]
spin:
plugin: "nav2_behaviors/Spin"
backup:
drive_on_heading:
wait:
plugin: "nav2_behaviors/Wait"
assisted_teleop:
plugin: "nav2_behaviors/AssistedTeleop"
global_frame: odom
transform_tolerance: 0.1
use_sim_time: false
simulate_ahead_time: 2.0
max_rotational_vel: 1.0
min_rotational_vel: 0.4
rotational_acc_lim: 3.2robot_state_publisher:
ros__parameters:
use_sim_time: Falsewaypoint_follower:
ros__parameters:
use_sim_time: False
loop_rate: 20
stop_on_failure: false
wait_at_waypoint:
enabled: True
waypoint_pause_duration: 200velocity_smoother:
ros__parameters:
use_sim_time: False
smoothing_frequency: 20.0
scale_velocities: False
feedback: "OPEN_LOOP"
max_velocity: [0.26, 0.0, 1.0]
min_velocity: [-0.26, 0.0, -1.0]
max_accel: [2.5, 0.0, 3.2]
max_decel: [-2.5, 0.0, -3.2]
odom_topic: "odom"
odom_duration: 0.1
deadband_velocity: [0.0, 0.0, 0.0]
velocity_timeout: 1.0开始运行:
出现问题1:discarding message:
问题2:在rviz2里面点击2D Pose Esti后又出现:odom, the timestamp earlier
问题3:点击Nav2 Goal一开始出现passing new path to controller的正确提示:
然后移动机器很容易出现Aborting handle的错误,这时候机器也不动,重新点Nav2 Goal也不动,不知道如何恢复和如何改这个错误:
这些问题困惑我好长时间,希望大神们给下指点,感谢感谢!!! - 雷达hz数:
@445808098 1.看地图有点乱,看日志规划超时了,改改规划时间试试,也可以更新下地图,搞个简单的,最好复制粘贴下日志,我好给你指出来。
针对您遇到的几个问题,我会逐一给出可能的解决思路和建议:
这通常表示ROS中的某个节点正在丢弃消息,可能是因为:
- 消息的时间戳与当前时间相差太大。
- 消息的主题订阅者已经停止工作或者没有正确初始化。
- 消息类型与订阅者期望的不匹配。
解决方法:
- 确保所有节点的
use_sim_time参数设置一致(如果使用的是模拟时间)。 - 检查消息发布者和订阅者的代码,确保它们之间的连接是正确的。
- 检查ROS的日志文件,看是否有更详细的错误信息可以帮助定位问题。
问题2:odom,the timestamp earlier
这个错误通常与tf(transform)变换有关,可能是
odom帧的更新频率比scan话题的频率慢,导致在尝试对齐tf变换时出现了时间戳不一致的问题。解决方法:
- 确保
odom话题的发布频率与scan话题的频率相匹配或更快。 - 检查tf变换的监听器(如
robot_state_publisher)是否正在运行,并且设置正确。 - 可以通过增加
transform_tolerance参数(在AMCL和其他相关节点中)来允许更大的时间差异。
问题3:Aborting handle
这个错误通常与导航堆栈中的某个行为或操作被中断有关。可能的原因包括:
- 路径规划失败。
- 控制器无法找到到达目标的有效路径。
- 机器人遇到无法克服的障碍。
- 机器人的状态与预期不符(如电池电量低、被卡住等)。
解决方法:
- 检查
planner_server和controller_server的日志输出,看是否有更详细的错误信息。 - 确保地图是准确的,并且机器人能够按照地图上的信息导航。
- 检查机器人的传感器数据(如激光雷达),确保它们能够正确感知环境。
- 如果可能,尝试在简化的环境中(如没有障碍物的空旷场地)运行导航堆栈,以排除环境因素的影响。
- 检查
bt_navigator配置,确保所有的行为和条件都设置正确,并且能够正确处理各种情况。
其他建议
- 确保所有节点都已正确启动,并且
use_sim_time参数设置一致。 - 在调试时,可以尝试简化配置,只运行最基本的导航堆栈,然后逐步添加其他功能。
- 使用ROS的调试工具(如
rosbag、rostopic、rosservice等)来捕获和分析数据。 - 查阅ROS和Nav2的官方文档,了解每个参数和组件的详细信息和最佳实践。
- 在ROS社区和论坛中寻求帮助,分享您的问题和日志信息,以获得更具体的指导。
@445808098 兄弟注意格式,你的tf图都没有连接map,定位估计有问题
此回复已被删除! -
小 小鱼 将这个主题标记为已解决,在
