    驱动雷达报错
    雷达驱动 stdbadalloc
    10.8k
    • 7
      Jason @小鱼
      @小鱼 实体机,16G内存,256G硬盘,电脑通过网线连接路由器,可以PING通雷达。
      输入~$ ros2 topic list
      反馈:/parameter_events
      /rosout
      /scan
      这一步都是正常的
      再输入ros2 topic hz /scan
      雷达驱动的终端就报错了
      • 7
        Jason @小鱼
        @小鱼 换了两台电脑都这样
          小鱼 技术大佬 @763141425
          @763141425 报什么错呢
          7 1 条回复 最后回复 回复 引用 0
          • 7
            Jason @小鱼
            @小鱼 terminate called after throwing an instance of 'std::bad_alloc'
            what(): std::bad_alloc
            • 7
              Jason @763141425
              完整的代码:
              1. 驱动雷达
              2. 建图测试
              3. 退出
                #? 1
                Prepare to Accept connect!
                3 <socket.socket fd=6, family=AddressFamily.AF_INET, type=SocketKind.SOCK_STREAM, proto=0, laddr=('172.17.0.3', 8888), raddr=('192.168.0.105', 55719)> 4
                PTY: Opened /dev/pts/6 for 0.0.0.0:8888
                [YDLIDAR]:SDK Version: 1.4.5
                Firmware version: 1.5
                Hardware version: 1
                Model: S4
                Serial: 2021031700000035
                [YDLIDAR]:Fixed Size: 330
                [YDLIDAR]:Sample Rate: 3K
                ^CTraceback (most recent call last):
                File "/workspace/install/fishbot_laser_driver/lib/fishbot_laser_driver/laser_x2", line 33, in <module>
                sys.exit(load_entry_point('fishbot-laser-driver==0.0.0', 'console_scripts', 'laser_x2')())
                File "/workspace/install/fishbot_laser_driver/lib/python3.10/site-packages/fishbot_laser_driver/fishbot_laser_x2.py", line 83, in main
                SocketServer()
                File "/workspace/install/fishbot_laser_driver/lib/python3.10/site-packages/fishbot_laser_driver/fishbot_laser_x2.py", line 35, in init
                self.main()
                File "/workspace/install/fishbot_laser_driver/lib/python3.10/site-packages/fishbot_laser_driver/fishbot_laser_x2.py", line 68, in main
                os.write(write_fd, data)
                KeyboardInterrupt
                [ros2run]: Interrupt
                小鱼 技术大佬 @763141425
                @763141425 什么系统诶,
                不行试试这个:
                https://fishros.org.cn/forum/topic/1524/拓展3-fishbot-树莓派配置建图导航
                • 7
                  Jason @小鱼
                  系统是Ubuntu 24.04,ros2是jazzy。
                    小鱼 技术大佬 @763141425
                    @763141425 请使用humble
                    • 7
                      Jason @小鱼
                      一键安装好像只支持jazzy和rolling版本
                      ubuntu要换成22.04版本么
                        小鱼 技术大佬 @763141425
                        @763141425 是的,换22
