    Service %s/spawn_entity unavailable. Was Gazebo started with GazeboRosFactory?
    ros2 humble urdf
    7.6k
      小鱼 技术大佬 @yudonghou123
      @yudonghou123 看一下gazebo启动指令,应该要有gazebo-ros-factory
      yudonghou123Y 2 条回复 最后回复 回复 引用 0
      • yudonghou123Y
        小猴同学 @小鱼
        @小鱼 在 Service %s/spawn_entity unavailable. Was Gazebo started with GazeboRosFactory? 中说:
        您好,非常感谢您的回复,鱼总,这个gazebo启动指令不是只要在launch文件中有以下节点描述就可以是吗:
        <node name="urdf_spawner" pkg="gazebo_ros" exec="spawn_entity.py" respawn="false" output="screen"
                  args="-gazebo_namespace /gazebo -x $(var x) -y $(var y) -z $(var z) -R $(var roll) -P $(var pitch) -Y $(var yaw) -entity $(var namespace) -file $(var generated_urdf)"/>
        或者您能说的详细一点吗,还是gazebo有时候会出现不识别urdf文件类型的问题,它启动的launch文件如下:
        <launch>
          <arg name="debug" default="0"/>
          <arg name="x" default="0"/>
          <arg name="y" default="0"/>
          <arg name="z" default="-20"/>
          <arg name="roll" default="0.0"/>
          <arg name="pitch" default="0.0"/>
          <arg name="yaw" default="0.0"/>
          <arg name="mode" default="default"/>
          <arg name="namespace" default="rexrov"/>
          <arg name="use_ned_frame" default="false"/>
          <arg name="generated_urdf" default="$(find-pkg-share uuv_descriptions)/robots/generated/$(var namespace)/robot_description"/>
          <arg name="cmd" default= "$(exec-in-pkg xacro xacro) '$(find-pkg-share uuv_descriptions)/robots/rexrov_$(var mode).xacro'
                  --inorder
                  debug:=$(var debug)
                  namespace:=$(var namespace)
                  inertial_reference_frame:=world_ned"/>
          <arg name="cmdUnless" default="xacro '$(find-pkg-share uuv_descriptions)/robots/rexrov_$(var mode).xacro'
                  debug:=$(var debug)
                  inertial_reference_frame:=world"/>
          <arg name="use_sim_time" default="true"/>
          <group>
            <push-ros-namespace namespace="$(var namespace)"/>
            <group if="$(var use_ned_frame)">
              <executable
                  cmd="$(var cmd)"
                  name="robot_description"
                  output="screen"
                  shell="true">
              </executable>
            </group>
            <group unless="$(var use_ned_frame)">
              <executable
                  cmd="$(var cmdUnless)"
                  cwd="$(find-pkg-prefix xacro)"
                  output="screen"
                  shell="true">
              </executable>
            </group>
            <!-- Run a python script to the send a service call to gazebo_ros to spawn a URDF robot -->
           <!--  <node name="urdf_spawner" pkg="uuv_descriptions" exec="spawn_model" respawn="false" output="screen"
                  args="-urdf -x $(var x) -y $(var y) -z $(var z) -R $(var roll) -P $(var pitch) -Y $(var yaw) -model $(var namespace) -file /home/user2/auv_ws/install/uuv_descriptions/share/uuv_descriptions/robots/generated/rexrov/robot_description"/> -->
            <!-- A joint state publisher plugin already is started with the model, no need to use the default joint state publisher -->
            <!-- Publish robot model for ROS -->
            <node name="robot_state_publisher" pkg="robot_state_publisher" exec="robot_state_publisher" respawn="true" output="screen"
              args="$(var generated_urdf)">
              <param name="use_sim_time" value="$(var use_sim_time)"/>
              <!-- <param name="robot_description" value="/$(var namespace)/robot_description" />
              <param name="publish_frequency" value="5" /> -->
            </node>
          </group>
          <include file="$(find-pkg-share uuv_assistants)/launch/message_to_tf.launch">
            <arg name="namespace" value="$(var namespace)"/>
            <arg name="world_frame" value="world"/>
            <arg name="child_frame_id" value="/$(var namespace)/base_link"/>
          </include>
        </launch>
        芜湖
        • 25007186052
          将就
          侯总您好,您在下载完开源码之后是怎么操作的呢?我colcon build之后终端输出报错如下:
          hao@hao-virtual-machine:~/ros2_ws$  colcon build --packages-up-to plankton
          Starting >>> plankton_utils
          Starting >>> uuv_gazebo_ros_plugins_msgs
          Starting >>> uuv_gazebo_plugins
          Starting >>> uuv_control_msgs
          Finished <<< plankton_utils [16.5s]
          Starting >>> uuv_assistants
          [Processing: uuv_assistants, uuv_control_msgs, uuv_gazebo_plugins, uuv_gazebo_ros_plugins_msgs]
          --- stderr: uuv_assistants
          In file included from /home/hao/ros2_ws/src/Plankton/uuv_assistants/src/message_to_tf.cpp:41:
          /opt/ros/humble/include/tf2_geometry_msgs/tf2_geometry_msgs/tf2_geometry_msgs.h:35:2: warning: #warning This header is obsolete, please include tf2_geometry_msgs/tf2_geometry_msgs.hpp instead [-Wcpp]
             35 | #warning This header is obsolete, please include tf2_geometry_msgs/tf2_geometry_msgs.hpp instead
          /home/hao/ros2_ws/src/Plankton/uuv_assistants/src/message_to_tf.cpp:78:22: error: redefinition of ‘void tf2::fromMsg(const Point&, tf2::Vector3&)’
             78 |   static inline void fromMsg(const geometry_msgs::msg::Point& msgIn, tf2::Vector3& out)
          In file included from /opt/ros/humble/include/tf2_geometry_msgs/tf2_geometry_msgs/tf2_geometry_msgs.h:37,
          /opt/ros/humble/include/tf2_geometry_msgs/tf2_geometry_msgs/tf2_geometry_msgs.hpp:241:6: note: ‘void tf2::fromMsg(const Point&, tf2::Vector3&)’ previously defined here
            241 | void fromMsg(const geometry_msgs::msg::Point & in, tf2::Vector3 & out)
          gmake[2]: *** [CMakeFiles/uuv_message_to_tf.dir/build.make:76: CMakeFiles/uuv_message_to_tf.dir/src/message_to_tf.cpp.o] Error 1
          gmake[1]: *** [CMakeFiles/Makefile2:140: CMakeFiles/uuv_message_to_tf.dir/all] Error 2
          gmake: *** [Makefile:146: all] Error 2
          Failed   <<< uuv_assistants [45.3s, exited with code 2]
          Aborted  <<< uuv_gazebo_ros_plugins_msgs [1min 9s]
          Aborted  <<< uuv_control_msgs [1min 48s]
          Aborted  <<< uuv_gazebo_plugins [2min 22s]
          Summary: 1 package finished [2min 22s]
            1 package failed: uuv_assistants
            3 packages aborted: uuv_control_msgs uuv_gazebo_plugins uuv_gazebo_ros_plugins_msgs
            2 packages had stderr output: uuv_assistants uuv_gazebo_plugins
            17 packages not processed
          不知道您是否有遇到或者正好懂得如何解决,感激不尽!
          yudonghou123Y 1 条回复 最后回复 回复 引用 0
          • yudonghou123Y
            小猴同学 @2500718605
            @2500718605 在 Service %s/spawn_entity unavailable. Was Gazebo started with GazeboRosFactory? 中说:
            哦哦,你这个问题是重复定义,就是两个拥有相同变量的函数定义了两次,你把其中一个注释掉应该就OK
            芜湖
            25007186052 1 条回复 最后回复 回复 引用 0
            • 25007186052
              将就 @yudonghou123
              @yudonghou123 侯总我爱你!!!
              不过我又遇到了下面的问题😖
              Finished <<< uuv_gazebo_plugins [1.73s]
              Starting >>> uuv_sensor_ros_plugins_msgs
              Finished <<< uuv_gazebo_ros_plugins_msgs [3.93s]
              Starting >>> uuv_world_ros_plugins_msgs
              Finished <<< uuv_sensor_ros_plugins_msgs [2.76s]
              Starting >>> uuv_world_plugins
              Finished <<< uuv_world_plugins [0.49s]
              Finished <<< plankton_utils [5.77s]
              Finished <<< uuv_control_msgs [7.19s]
              Finished <<< uuv_world_ros_plugins_msgs [4.63s]
              Finished <<< uuv_gazebo [0.48s]
              Starting >>> uuv_gazebo_worlds
              Finished <<< uuv_gazebo_worlds [0.65s]
              Starting >>> uuv_auv_control_allocator
              Finished <<< uuv_auv_control_allocator [4.49s]
              Starting >>> uuv_control_cascaded_pid
              Finished <<< uuv_control_cascaded_pid [1.80s]
              --- stderr: uuv_gazebo_ros_plugins
              In file included from /home/hao/Plankton-master/uuv_gazebo_plugins/uuv_gazebo_ros_plugins/include/uuv_gazebo_ros_plugins/FinROSPlugin.h:31,
                               from /home/hao/Plankton-master/uuv_gazebo_plugins/uuv_gazebo_ros_plugins/src/FinROSPlugin.cpp:22:
              /opt/ros/humble/include/gazebo_ros/node.hpp:144:19: error: ‘Executor’ was not declared in this scope; did you mean ‘rclcpp::Executor’?
                144 |   std::shared_ptr<Executor> executor_;
                    |                   rclcpp::Executor
              In file included from /opt/ros/humble/include/rclcpp/rclcpp/executors/multi_threaded_executor.hpp:25,
                               from /opt/ros/humble/include/rclcpp/rclcpp/executors.hpp:21,
                               from /opt/ros/humble/include/rclcpp/rclcpp/rclcpp.hpp:155,
                               from /opt/ros/humble/include/gazebo_ros/node.hpp:18,
              /opt/ros/humble/include/rclcpp/rclcpp/executor.hpp:65:7: note: ‘rclcpp::Executor’ declared here
                 65 | class Executor
              /opt/ros/humble/include/gazebo_ros/node.hpp:144:27: error: template argument 1 is invalid
              /opt/ros/humble/include/gazebo_ros/node.hpp:156:24: error: ‘Executor’ was not declared in this scope; did you mean ‘rclcpp::Executor’?
                156 |   static std::weak_ptr<Executor> static_executor_;
                    |                        rclcpp::Executor
                 65 | class Executor
              /opt/ros/humble/include/gazebo_ros/node.hpp:156:32: error: template argument 1 is invalid
              /opt/ros/humble/include/gazebo_ros/node.hpp: In static member function ‘static gazebo_ros::Node::SharedPtr gazebo_ros::Node::CreateWithArgs(Args&& ...)’:
              /opt/ros/humble/include/gazebo_ros/node.hpp:182:38: error: request for member ‘lock’ in ‘gazebo_ros::Node::static_executor_’, which is of non-class type ‘int’
                182 |   node->executor_ = static_executor_.lock();
              /opt/ros/humble/include/gazebo_ros/node.hpp:186:40: error: ‘Executor’ was not declared in this scope; did you mean ‘rclcpp::Executor’?
                186 |     node->executor_ = std::make_shared<Executor>();
                    |                                        rclcpp::Executor
                 65 | class Executor
              /opt/ros/humble/include/gazebo_ros/node.hpp:225:18: error: base operand of ‘->’ is not a pointer
                225 |   node->executor_->add_node(node);
              In file included from /opt/ros/humble/include/rclcpp/rclcpp/logging.hpp:24,
                               from /opt/ros/humble/include/rclcpp/rclcpp/client.hpp:40,
                               from /opt/ros/humble/include/rclcpp/rclcpp/callback_group.hpp:23,
                               from /opt/ros/humble/include/rclcpp/rclcpp/any_executable.hpp:20,
                               from /opt/ros/humble/include/rclcpp/rclcpp/memory_strategy.hpp:25,
                               from /opt/ros/humble/include/rclcpp/rclcpp/memory_strategies.hpp:18,
                               from /opt/ros/humble/include/rclcpp/rclcpp/executor_options.hpp:20,
                               from /opt/ros/humble/include/rclcpp/rclcpp/executor.hpp:37,
              /home/hao/Plankton-master/uuv_gazebo_plugins/uuv_gazebo_ros_plugins/src/FinROSPlugin.cpp: In member function ‘virtual void uuv_simulator_ros::FinROSPlugin::Load(gazebo::physics::ModelPtr, sdf::v9::ElementPtr)’:
              /home/hao/Plankton-master/uuv_gazebo_plugins/uuv_gazebo_ros_plugins/src/FinROSPlugin.cpp:122:69: error: cannot convert ‘std::__cxx11::basic_string<char>’ to ‘const char*’
                122 | CLCPP_INFO(myRosNode->get_logger(), "[FinROSPlugin] Namespace: " + std::string(myRosNode->get_namespace()));
              In file included from /opt/ros/humble/include/rmw/rmw/types.h:28,
                               from /opt/ros/humble/include/rcl/rcl/types.h:20,
                               from /opt/ros/humble/include/rcl/rcl/log_level.h:22,
                               from /opt/ros/humble/include/rcl/rcl/arguments.h:21,
                               from /opt/ros/humble/include/rcl/rcl/context.h:28,
                               from /opt/ros/humble/include/rcl/rcl/guard_condition.h:26,
                               from /opt/ros/humble/include/rclcpp/rclcpp/executor.hpp:30,
              /opt/ros/humble/include/rcutils/rcutils/logging.h:479:16: note:   initializing argument 4 of ‘void rcutils_log(const rcutils_log_location_t*, int, const char*, const char*, ...)’
                479 |   const char * format,
              gmake[2]: *** [CMakeFiles/uuv_fin_ros_plugin.dir/build.make:76: CMakeFiles/uuv_fin_ros_plugin.dir/src/FinROSPlugin.cpp.o] Error 1
              gmake[1]: *** [CMakeFiles/Makefile2:149: CMakeFiles/uuv_fin_ros_plugin.dir/all] Error 2
              Failed   <<< uuv_gazebo_ros_plugins [29.4s, exited with code 2]
              Aborted  <<< uuv_assistants [31.5s]
              Aborted  <<< uuv_sensor_ros_plugins [30.5s]
              Aborted  <<< uuv_world_ros_plugins [21.9s]
              Summary: 11 packages finished [38.2s]
                1 package failed: uuv_gazebo_ros_plugins
                3 packages aborted: uuv_assistants uuv_sensor_ros_plugins uuv_world_ros_plugins
                4 packages had stderr output: uuv_assistants uuv_gazebo_ros_plugins uuv_sensor_ros_plugins uuv_world_ros_plugins
              个人感觉应该是路径问题?不知道该如何下手去改了😵
              希望您不吝赐教!
              • yudonghou123Y
                小猴同学 @2500718605
                @2500718605 你这个可能是C++语言的问题,慢慢对这要求改就行,应该是有的符号没识别出来
                芜湖
                • yudonghou123Y
                  小猴同学 @小鱼
                  您好,我又换了一个模型,还是这样的问题,我以为是gazebo_ros的问题,于是运行humble/share/gazebo_ros中的文件发现能够运行,libgazebo_ros_factory.so也存在这样的依赖包,我是通过launch文件启动的
                  芜湖
                  • yudonghou123Y yudonghou123 删除了该主题于
                    @yudonghou123 我觉得可能是gazebo启动的问题,自带的launch那个可能没有加gazebo_factory,你试试这样启动gazebo
                            cmd=['gazebo', '--verbose','-s', 'libgazebo_ros_init.so', '-s', 'libgazebo_ros_factory.so'],
                            output='screen')
                    • yudonghou123Y yudonghou123 将这个主题标记为已解决,在
                    • yudonghou123Y yudonghou123 恢复了该主题于
                    • yudonghou123Y
                      小猴同学 @小鱼
                      最后由 yudonghou123 编辑
                      @小鱼 非常感激您的解答,原因是我陈列service时发现其对应的服务名称不对,程序调用的是前面加了一个命名空间,所以没有查找到对应的服务,我把多加的命名空间删除后,就可以了,已经改正过来了,模型也都能加载到gazebo环境中了,非常感激您,祝您身体健康😊
                      芜湖
                      25920604782 1 条回复 最后回复 回复 引用 0
                      • 25920604782
                        封月洞天的诺言 @ ROS2开发者 @yudonghou123
                        @yudonghou123
                        有详细步骤吗
