    使用imu_utils标定,拥有了db3文件了,使用ros2 launch启动编译好的imu_an节点报错,启动不了
    imuutils,ros2 ros2 humble
    14.2k
      yuan @小鱼
        yuan @小鱼
        @小鱼 ```
        Starting program: /home/ysh/ros2_ws/install/imu_utils/lib/imu_utils/imu_an --ros-args --params-file /home/ysh/ros2_ws/src/param.yaml
        [Thread debugging using libthread_db enabled]
        Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
        [New Thread 0x7ffff4dff640 (LWP 126145)]
        [New Thread 0x7ffff45fe640 (LWP 126146)]
        [New Thread 0x7ffff3dfd640 (LWP 126147)]
        [New Thread 0x7ffff35fc640 (LWP 126148)]
        [New Thread 0x7ffff2dfb640 (LWP 126149)]
        [New Thread 0x7ffff25fa640 (LWP 126150)]
        [New Thread 0x7ffff1df9640 (LWP 126151)]
        [New Thread 0x7ffff15f8640 (LWP 126152)]
        [New Thread 0x7ffff0df7640 (LWP 126153)]
        [INFO] [1722937129.258907543] [n]: Waiting for IMU data...
        [ERROR] [1722937129.259067701] [n]: Failed to load imu_topic
        [ERROR] [1722937129.259904065] [n]: Failed to load imu_name
        [ERROR] [1722937129.259961287] [n]: Failed to load data_save_path
        [ERROR] [1722937129.260008229] [n]: Failed to load max_time_min
        [ERROR] [1722937129.260054711] [n]: Failed to load max_cluster
        terminate called after throwing an instance of 'rclcpp::exceptions::RCLError'
        what(): could not create subscription: rcl node's context is invalid, at ./src/rcl/node.c:428
        [Thread 0x7ffff4dff640 (LWP 126145) exited]
        Thread 1 "imu_an" received signal SIGABRT, Aborted.
        __pthread_kill_implementation (no_tid=0, signo=6, threadid=140737322031168) at ./nptl/pthread_kill.c:44
        44 ./nptl/pthread_kill.c: 没有那个文件或目录.
          小鱼 技术大佬 @yuan
          @yuan 在 使用imu_utils标定,拥有了db3文件了,使用ros2 launch启动编译好的imu_an节点报错,启动不了 中说:
          ros_utils::readParamstd::string
          这个函数怎么写的
          Y 2 条回复 最后回复 回复 引用 0
            yuan @小鱼
              yuan @小鱼
              template< typename T >
              T
              readParam( rclcpp::Node& n, std::string name )
                  T ans;
                  if ( n.get_parameter( name, ans ) )
                      RCLCPP_INFO_STREAM(n.get_logger(), "Loaded " << name << ": " << ans );
                  else
                      RCLCPP_ERROR_STREAM(n.get_logger(), "Failed to load " << name );
                      rclcpp::shutdown();
                  return ans;
                小鱼 技术大佬 @yuan
                rclcpp::shutdown();
                这里这里,你给shutdown() 干啥!!!!!
                删掉!!!!!
                  yuan @小鱼
                  @小鱼 没有呀,现在是这个样子的
                  int
                  main( int argc, char** argv )
                      rclcpp::init( argc, argv);
                      //rclcpp::Node n( "~" );
                      auto node = std::make_shared<rclcpp::Node>("n");
                      //rclcpp::Logger( ROSCONSOLE_DEFAULT_NAME, ros::console::levels::Debug );
                      RCLCPP_INFO(node->get_logger(), "Waiting for IMU data...");
                      std::string IMU_TOPIC;
                      std::string IMU_NAME;
                      int max_cluster;
                      IMU_TOPIC      = ros_utils::readParam<std::string>(*node, "imu_topic");
                      IMU_NAME       = ros_utils::readParam<std::string>(*node, "imu_name");
                      data_save_path = ros_utils::readParam<std::string>(*node, "data_save_path");
                      max_time_min   = ros_utils::readParam<int>(*node, "max_time_min");
                      max_cluster    = ros_utils::readParam<int>(*node, "max_cluster");
                      // rclcpp::Subscription sub_imu = n->create_subscription( IMU_TOPIC, //
                      //                                        20000000,
                      //                                        imu_callback,
                      //                                        ros::TransportHints( ).tcpNoDelay( ) );
                      //    rclcpp::Publisher pub = n.advertise< geometry_msgs::Vector3Stamped >( ALLAN_TOPIC,
                      //    2000 );
                      auto sub_imu = node->create_subscription<sensor_msgs::msg::Imu>(
                      IMU_TOPIC, 10, imu_callback);
                      auto gyr_x = std::make_shared<imu::AllanGyr>("gyr x", max_cluster);
                      auto gyr_y = std::make_shared<imu::AllanGyr>("gyr y", max_cluster);
                      auto gyr_z = std::make_shared<imu::AllanGyr>("gyr z", max_cluster);
                      auto acc_x = std::make_shared<imu::AllanAcc>("acc x", max_cluster);
                      auto acc_y = std::make_shared<imu::AllanAcc>("acc y", max_cluster);
                      auto acc_z = std::make_shared<imu::AllanAcc>("acc z", max_cluster);
                      std::cout << "wait for imu data." << std::endl;
                      rclcpp::WallRate loop( 100 );
                      //    ros::spin( );
                      while ( !end )
                          loop.sleep( );
                          rclcpp::spin_some(node);
                          //rclcpp::spin(n);
                  Y 1 条回复 最后回复 回复 引用 0
                    yuan @yuan
                    @yuan
                    你的意思是read文件里面吗
                      yuan @小鱼
                      删掉重新编译还是一样的鱼哥
                      ysh@ysh:~/ros2_ws$ ros2 run imu_utils imu_an
                      [INFO] [1723018093.544028406] [n]: Waiting for IMU data...
                      [ERROR] [1723018093.544215273] [n]: Failed to load imu_topic
                      [ERROR] [1723018093.544802558] [n]: Failed to load imu_name
                      [ERROR] [1723018093.544864169] [n]: Failed to load data_save_path
                      [ERROR] [1723018093.544946202] [n]: Failed to load max_time_min
                      [ERROR] [1723018093.544995910] [n]: Failed to load max_cluster
                      [ros2run]: Aborted
                        小鱼 技术大佬 @yuan
                            rclcpp::shutdown();
                        这里,兄弟,你获取失败为什么要shutdown,就算不执行了,你也要直接抛出异常推出
                          yuan @小鱼
                          @小鱼 他源码是这样的,我把它删掉还是报错了呀
                            小鱼 技术大佬 @yuan
                            @yuan 删掉重新构建,你现在没办法给我证明你现在运行的是之前的程序,还是你删除之后的
                              yuan @小鱼
                              您能远程帮我看下吗,孩子都要重装系统了,磕头感谢😣
