    使用imu_utils标定,拥有了db3文件了,使用ros2 launch启动编译好的imu_an节点报错,启动不了
    imuutils,ros2 ros2 humble
    14.2k
      yuan @小鱼
      @小鱼 ```
      Starting program: /home/ysh/ros2_ws/install/imu_utils/lib/imu_utils/imu_an --ros-args --params-file /home/ysh/ros2_ws/src/param.yaml
      [Thread debugging using libthread_db enabled]
      Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
      [New Thread 0x7ffff4dff640 (LWP 126145)]
      [New Thread 0x7ffff45fe640 (LWP 126146)]
      [New Thread 0x7ffff3dfd640 (LWP 126147)]
      [New Thread 0x7ffff35fc640 (LWP 126148)]
      [New Thread 0x7ffff2dfb640 (LWP 126149)]
      [New Thread 0x7ffff25fa640 (LWP 126150)]
      [New Thread 0x7ffff1df9640 (LWP 126151)]
      [New Thread 0x7ffff15f8640 (LWP 126152)]
      [New Thread 0x7ffff0df7640 (LWP 126153)]
      [INFO] [1722937129.258907543] [n]: Waiting for IMU data...
      [ERROR] [1722937129.259067701] [n]: Failed to load imu_topic
      [ERROR] [1722937129.259904065] [n]: Failed to load imu_name
      [ERROR] [1722937129.259961287] [n]: Failed to load data_save_path
      [ERROR] [1722937129.260008229] [n]: Failed to load max_time_min
      [ERROR] [1722937129.260054711] [n]: Failed to load max_cluster
      terminate called after throwing an instance of 'rclcpp::exceptions::RCLError'
      what(): could not create subscription: rcl node's context is invalid, at ./src/rcl/node.c:428
      [Thread 0x7ffff4dff640 (LWP 126145) exited]
      Thread 1 "imu_an" received signal SIGABRT, Aborted.
      __pthread_kill_implementation (no_tid=0, signo=6, threadid=140737322031168) at ./nptl/pthread_kill.c:44
      44 ./nptl/pthread_kill.c: 没有那个文件或目录.
        小鱼 技术大佬 @yuan
        @yuan 在 使用imu_utils标定,拥有了db3文件了,使用ros2 launch启动编译好的imu_an节点报错,启动不了 中说:
        ros_utils::readParamstd::string
        这个函数怎么写的
        Y 2 条回复 最后回复 回复 引用 0
          yuan @小鱼
            yuan @小鱼
            template< typename T >
            T
            readParam( rclcpp::Node& n, std::string name )
                T ans;
                if ( n.get_parameter( name, ans ) )
                    RCLCPP_INFO_STREAM(n.get_logger(), "Loaded " << name << ": " << ans );
                else
                    RCLCPP_ERROR_STREAM(n.get_logger(), "Failed to load " << name );
                    rclcpp::shutdown();
                return ans;
              小鱼 技术大佬 @yuan
              rclcpp::shutdown();
              这里这里,你给shutdown() 干啥!!!!!
              删掉!!!!!
                yuan @小鱼
                @小鱼 没有呀,现在是这个样子的
                int
                main( int argc, char** argv )
                    rclcpp::init( argc, argv);
                    //rclcpp::Node n( "~" );
                    auto node = std::make_shared<rclcpp::Node>("n");
                    //rclcpp::Logger( ROSCONSOLE_DEFAULT_NAME, ros::console::levels::Debug );
                    RCLCPP_INFO(node->get_logger(), "Waiting for IMU data...");
                    std::string IMU_TOPIC;
                    std::string IMU_NAME;
                    int max_cluster;
                    IMU_TOPIC      = ros_utils::readParam<std::string>(*node, "imu_topic");
                    IMU_NAME       = ros_utils::readParam<std::string>(*node, "imu_name");
                    data_save_path = ros_utils::readParam<std::string>(*node, "data_save_path");
                    max_time_min   = ros_utils::readParam<int>(*node, "max_time_min");
                    max_cluster    = ros_utils::readParam<int>(*node, "max_cluster");
                    // rclcpp::Subscription sub_imu = n->create_subscription( IMU_TOPIC, //
                    //                                        20000000,
                    //                                        imu_callback,
                    //                                        ros::TransportHints( ).tcpNoDelay( ) );
                    //    rclcpp::Publisher pub = n.advertise< geometry_msgs::Vector3Stamped >( ALLAN_TOPIC,
                    //    2000 );
                    auto sub_imu = node->create_subscription<sensor_msgs::msg::Imu>(
                    IMU_TOPIC, 10, imu_callback);
                    auto gyr_x = std::make_shared<imu::AllanGyr>("gyr x", max_cluster);
                    auto gyr_y = std::make_shared<imu::AllanGyr>("gyr y", max_cluster);
                    auto gyr_z = std::make_shared<imu::AllanGyr>("gyr z", max_cluster);
                    auto acc_x = std::make_shared<imu::AllanAcc>("acc x", max_cluster);
                    auto acc_y = std::make_shared<imu::AllanAcc>("acc y", max_cluster);
                    auto acc_z = std::make_shared<imu::AllanAcc>("acc z", max_cluster);
                    std::cout << "wait for imu data." << std::endl;
                    rclcpp::WallRate loop( 100 );
                    //    ros::spin( );
                    while ( !end )
                        loop.sleep( );
                        rclcpp::spin_some(node);
                        //rclcpp::spin(n);
                Y 1 条回复 最后回复 回复 引用 0
                  yuan @yuan
                  @yuan
                  你的意思是read文件里面吗
                    yuan @小鱼
                    删掉重新编译还是一样的鱼哥
                    ysh@ysh:~/ros2_ws$ ros2 run imu_utils imu_an
                    [INFO] [1723018093.544028406] [n]: Waiting for IMU data...
                    [ERROR] [1723018093.544215273] [n]: Failed to load imu_topic
                    [ERROR] [1723018093.544802558] [n]: Failed to load imu_name
                    [ERROR] [1723018093.544864169] [n]: Failed to load data_save_path
                    [ERROR] [1723018093.544946202] [n]: Failed to load max_time_min
                    [ERROR] [1723018093.544995910] [n]: Failed to load max_cluster
                    [ros2run]: Aborted
                      小鱼 技术大佬 @yuan
                          rclcpp::shutdown();
                      这里,兄弟,你获取失败为什么要shutdown,就算不执行了,你也要直接抛出异常推出
                        yuan @小鱼
                        @小鱼 他源码是这样的,我把它删掉还是报错了呀
                          小鱼 技术大佬 @yuan
                          @yuan 删掉重新构建,你现在没办法给我证明你现在运行的是之前的程序,还是你删除之后的
                            yuan @小鱼
                            您能远程帮我看下吗,孩子都要重装系统了,磕头感谢😣
