    4.2.1自定义服务接口 编译chapt4_interfaces报错
    服务接口 编译报错 rosidl
    1.8k
    • 7
      739223875
      问题描述:
      跟随视频学习4.2.1自定义服务接口时,编译chapt4_interfaces时报错
      报错信息如下:
      xothschild@LAPTOP-LNO5LL2V:~/YuXiangROS2/chapt4/chatp4_ws$ colcon build
      Starting >>> chapt4_interfaces
      --- stderr: chapt4_interfaces
        execute_process(/usr/bin/python3 -m rosidl_adapter --package-name
        chapt4_interfaces --arguments-file
        /home/xothschild/YuXiangROS2/chapt4/chatp4_ws/build/chapt4_interfaces/rosidl_adapter__arguments__chapt4_interfaces.json
        --output-dir
        /home/xothschild/YuXiangROS2/chapt4/chatp4_ws/build/chapt4_interfaces/rosidl_adapter/chapt4_interfaces
        --output-file
        /home/xothschild/YuXiangROS2/chapt4/chatp4_ws/build/chapt4_interfaces/rosidl_adapter/chapt4_interfaces.idls)
        returned error code 1:
          File "/usr/lib/python3.10/runpy.py", line 196, in _run_module_as_main
          File "/usr/lib/python3.10/runpy.py", line 86, in _run_code
            exec(code, run_globals)
            sys.exit(main())
          File "/opt/ros/humble/local/lib/python3.10/dist-packages/rosidl_adapter/__init__.py", line 24, in convert_to_idl
            return convert_srv_to_idl(
          File "/opt/ros/humble/local/lib/python3.10/dist-packages/rosidl_adapter/srv/__init__.py", line 28, in convert_srv_to_idl
            srv = parse_service_string(package_name, input_file.stem, content)
          File "/opt/ros/humble/local/lib/python3.10/dist-packages/rosidl_adapter/parser.py", line 850, in parse_service_string
            raise InvalidServiceSpecification(
        rosidl_adapter.parser.InvalidServiceSpecification: Could not find separator
        '---' between request and response
        CMakeLists.txt:13 (rosidl_generate_interfaces)
      Failed   <<< chapt4_interfaces [1.30s, exited with code 1]
      Summary: 0 packages finished [1.46s]
        1 package failed: chapt4_interfaces
        1 package had stderr output: chapt4_interfaces
      查了一下论坛,路径中没有中文,代码也没有写错,想问一下这个怎么改?
      谢谢!
        从您提供的错误信息来看,问题出现在 rosidl_adapter 试图解析服务定义文件时,因为它没有找到分隔请求和响应部分的 --- 标记。这通常意味着您的服务定义文件(.srv 文件)格式可能不正确。
        在 ROS 2 中,服务定义文件(.srv 文件)必须严格遵循以下格式:
        # 请求部分
        int64 seq
        string data
        # 响应部分
        bool success
        string message
        这里的 --- 是必需的,它将请求参数和响应参数分隔开。
        解决步骤
        1. 检查服务定义文件:
          打开您的服务定义文件(通常在 chapt4_interfaces/srv/ 目录下),确保它包含正确的 --- 分隔符,并且格式正确。例如:
          # MyService.srv
          int64 seq
          string data
          bool success
          string message
        2. 检查文件名和路径:
          确保文件名和路径中没有特殊字符或不必要的空格,这可能会影响解析。
        3. 清理和重新构建:
          在您的工作空间中运行以下命令来清理旧的构建文件并重新构建:
          colcon build --packages-select chapt4_interfaces --packages-up-to chapt4_interfaces --cmake-clean-first
          这个命令会仅构建 chapt4_interfaces 包,并在构建前清理旧的 CMake 文件。
        4. 检查 ROS 2 环境:
          确保您的 ROS 2 环境设置正确,所有依赖项都已正确安装。
        5. 查看详细日志:
          如果问题仍然存在,尝试运行构建命令时添加更多的调试输出,以获取更多关于错误的信息:
          colcon build --packages-select chapt4_interfaces --packages-up-to chapt4_interfaces --cmake-verbose
        按照这些步骤操作后,您应该能够解决编译时遇到的问题。如果问题仍然存在,请仔细检查 .srv 文件的内容,确保没有语法错误或格式问题。
          小鱼 技术大佬 @739223875
          @739223875 完整代码贴出来看看
          7 1 条回复 最后回复 回复 引用 0
          • 7
            739223875 @小鱼
            FaceDetector.srv
            sensor_msgs/Image Image # 人脸图像
            --- # 横杠分割,上面是请求部分,下面是结果
            int16 number
            float32 use_time
            int32[] top
            int32[] right
            int32[] bottom
            int32[] left
            CMakeLists.txt
            project(chapt4_interfaces)
            endif()
            # find dependencies
              "srv/FaceDetector.srv"
              DEPENDENCIES sensor_msgs
            if(BUILD_TESTING)
              # comment the line when a copyright and license is added to all source files
              # comment the line when this package is in a git repo and when
              # a copyright and license is added to all source files
            endif()
            ament_package()
            package.xml
            <?xml version="1.0"?>
            <package format="3">
              <name>chapt4_interfaces</name>
              <version>0.0.0</version>
              <maintainer email="Jiahao.X@outlook.com">xothschild</maintainer>
              <license>Apache-2.0</license>
              <depend>sensor_msgs</depend>
              <depend>rosidl_default_generators</depend>
              <export>
              </export>
            </package>
              小鱼 技术大佬 @739223875
              @739223875 在 4.2.1自定义服务接口 编译chapt4_interfaces报错 中说:
              后面注释删掉
