    一键安装 ros2
    44.3k
    • 阿来呀阿
      阿来呀 @阿来呀
      @阿来呀 is not going to be installed
                                         Depends: ros-humble-image-transport but it is not going to be installed
                                         Depends: ros-humble-interactive-markers but it is not going to be installed
                                         Depends: ros-humble-laser-geometry but it is not going to be installed
                                         Depends: ros-humble-resource-retriever but it is not going to be installed
                                         Depends: ros-humble-rviz-common but it is not going to be installed
                                         Depends: ros-humble-rviz-rendering but it is not going to be installed
       ros-humble-rviz2 : Depends: libqt5core5a (>= 5.15.1) but it is not installable
                          Depends: libqt5widgets5 (>= 5.0.2) but it is not installable
                          Depends: ros-humble-rviz-ogre-vendor but it is not going to be installed
       ros-humble-sqlite3-vendor : Depends: libsqlite3-dev but it is not installable
       ros-humble-sros2 : Depends: python3-lxml but it is not installable
       ros-humble-tango-icons-vendor : Depends: tango-icon-theme but it is not installable
       ros-humble-teleop-twist-joy : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is not installable
       ros-humble-tf2 : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is not installable
                        Depends: libconsole-bridge-dev but it is not installable
                        Depends: ros-humble-console-bridge-vendor but it is not going to be installed
       ros-humble-tf2-bullet : Depends: libbullet-dev but it is not installable
       ros-humble-tf2-eigen : Depends: libeigen3-dev but it is not installable
       ros-humble-tf2-eigen-kdl : Depends: liborocos-kdl1.5 (>= 1.5.1) but it is not installable
       ros-humble-tf2-geometry-msgs : Depends: python3-numpy but it is not installable
       ros-humble-tf2-ros : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is not installable
       ros-humble-tf2-sensor-msgs : Depends: libeigen3-dev but it is not installable
       ros-humble-tf2-tools : Depends: graphviz but it is not installable
       ros-humble-tinyxml2-vendor : Depends: libtinyxml2-dev but it is not installable
       ros-humble-turtlesim : Depends: libqt5core5a (>= 5.15.1) but it is not installable
                              Depends: libqt5gui5 (>= 5.2.0) but it is not installable or
                                       libqt5gui5-gles (>= 5.2.0) but it is not installable
                              Depends: libqt5gui5 but it is not installable
       ros-humble-uncrustify-vendor : Depends: uncrustify but it is not installable
       ros-humble-urdf : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is not installable
                         Depends: libtinyxml2-9 (>= 8.0.0) but it is not installable
                         Depends: ros-humble-urdfdom but it is not going to be installed
       shim-signed : Depends: grub-efi-amd64-signed but it is not going to be installed or
                              grub-efi-arm64-signed but it is not installable
                     Depends: grub2-common (>= 2.04-1ubuntu24) but it is not going to be installed
       util-linux : PreDepends: libsystemd0 but it is not installable
                    PreDepends: libudev1 (>= 183) but it is not installable
      [-] python3-catkin-pkg-modules : Depends: python3-docutils but it is not install[/] ros-humble-action-tutorials-cpp : Depends: libconsole-bridge1.0 (>= 1.0.1+df[-]                               Depends: ros-humble-ament-package but it is no[/] ros-humble-ament-cmake-gmock : Depends: google-mock but it is not installabl[\] ros-humble-ament-cmake-gtest : Depends: libgtest-dev but it is not installab[|] ros-humble-ament-cmake-pytest : Depends: python3-pytest but it is not instal[-] ros-humble-class-loader : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but[/]                           Depends: libconsole-bridge-dev but it is not insta[\]                           Depends: ros-humble-console-bridge-vendor but it i[|] ros-humble-composition : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but [-] ros-humble-demo-nodes-cpp : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) b[/] ros-humble-demo-nodes-cpp-native : Depends: libconsole-bridge1.0 (>= 1.0.1+d[\]                                    Depends: ros-humble-fastrtps but it is no[|]                                    Depends: ros-humble-rmw-fastrtps-cpp but [-] ros-humble-depthimage-to-laserscan : Depends: libconsole-bridge1.0 (>= 1.0.1[/]                                      Depends: libopencv-core4.5d (>= 4.5.4+d[\]                                      Depends: libopencv-flann4.5d (>= 4.5.4+[|]                                      Depends: libopencv-dev but it is not in[-]                                      Depends: ros-humble-image-geometry but [/] ros-humble-examples-rclcpp-minimal-composition : Depends: libconsole-bridge1[\] ros-humble-examples-rclcpp-minimal-subscriber : Depends: libconsole-bridge1.[|] ros-humble-image-tools : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but [-]                          Depends: libopencv-core4.5d (>= 4.5.4+dfsg) but it [/]                          Depends: libopencv-highgui4.5d (>= 4.5.4+dfsg) but [\]                          Depends: libopencv-imgcodecs4.5d (>= 4.5.4+dfsg) bu[|]                          Depends: libopencv-imgproc4.5d (>= 4.5.4+dfsg) but [-]                          Depends: libopencv-videoio4.5d (>= 4.5.4+dfsg) but [\] ros-humble-intra-process-demo : Depends: libopencv-core4.5d (>= 4.5.4+dfsg) [|]                                 Depends: libopencv-highgui4.5d (>= 4.5.4+dfs[-]                                 Depends: libopencv-imgproc4.5d (>= 4.5.4+dfs[/]                                 Depends: libopencv-videoio4.5d (>= 4.5.4+dfs[\]                                 Depends: libopencv-dev but it is not install[|] ros-humble-joy : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is no[-]                  Depends: libsdl2-2.0-0 (>= 2.0.12) but it is not installabl[/]                  Depends: ros-humble-sdl2-vendor but it is not going to be i[\] ros-humble-kdl-parser : Depends: liborocos-kdl1.5 (>= 1.5.1) but it is not i[-] ros-humble-launch-testing : Depends: python3-pytest but it is not installabl[/] ros-humble-logging-demo : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but[\] ros-humble-orocos-kdl-vendor : Depends: libeigen3-dev but it is not installa[|]                                Depends: liborocos-kdl-dev but it is not inst[-] ros-humble-pcl-conversions : Depends: libeigen3-dev but it is not installabl[\] ros-humble-python-cmake-module : Depends: python3-dev but it is not installa[|] ros-humble-python-qt-binding : Depends: libpyside2-dev but it is not install[-]                                Depends: libshiboken2-dev but it is not insta[\]                                Depends: python3-pyqt5 but it is not installa[|]                                Depends: python3-pyqt5.qtsvg but it is not in[-]                                Depends: python3-pyside2.qtsvg but it is not [/]                                Depends: python3-sip-dev but it is not instal[-] ros-humble-quality-of-service-demo-cpp : Depends: libconsole-bridge1.0 (>= 1[/] ros-humble-rcl-logging-spdlog : Depends: libspdlog1-fmt8 but it is not insta[\]                                 Depends: libspdlog-dev but it is not install[|]                                 Depends: ros-humble-spdlog-vendor but it is [-] ros-humble-rcl-yaml-param-parser : Depends: libyaml-dev but it is not instal[/] ros-humble-rclcpp-components : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2[|] ros-humble-robot-state-publisher : Depends: libconsole-bridge1.0 (>= 1.0.1+d[-]                                    Depends: liborocos-kdl1.5 (>= 1.5.1) but [-]                         Depends: python3-rosdistro-modules but it is not goi[|] ros-humble-rosbag2-compression : Depends: libconsole-bridge1.0 (>= 1.0.1+dfs[-]                                  Depends: libtinyxml2-9 (>= 8.0.0) but it is[/] ros-humble-rosbag2-compression-zstd : Depends: libconsole-bridge1.0 (>= 1.0.[\]                                       Depends: ros-humble-zstd-vendor but it[|] ros-humble-rosbag2-cpp : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but [-]                          Depends: libtinyxml2-9 (>= 8.0.0) but it is not ins[/] ros-humble-rosbag2-py : Depends: libtinyxml2-9 (>= 8.0.0) but it is not inst[\]                         Depends: libyaml-cpp0.7 (>= 0.7.0) but it is not ins[|]                         Depends: ros-humble-pybind11-vendor but it is not go[-] ros-humble-rosbag2-storage : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) [/]                              Depends: libtinyxml2-9 (>= 8.0.0) but it is not[\]                              Depends: libyaml-cpp0.7 (>= 0.7.0) but it is no[|]                              Depends: ros-humble-yaml-cpp-vendor but it is n[-] ros-humble-rosbag2-storage-default-plugins : Depends: libconsole-bridge1.0 ([/]                                              Depends: libyaml-cpp0.7 (>= 0.7[\]                                              Depends: ros-humble-yaml-cpp-ve[|] ros-humble-rosbag2-transport : Depends: libyaml-cpp0.7 (>= 0.7.0) but it is [-]                                Depends: ros-humble-yaml-cpp-vendor but it is[\]                           Depends: ros-humble-rosidl-adapter but it is not g[|]                           Depends: ros-humble-rosidl-parser but it is not go[-] ros-humble-rosidl-generator-c : Depends: python3-dev but it is not installab[/]                                 Depends: ros-humble-rosidl-cli but it is not[\]                                 Depends: ros-humble-rosidl-parser but it is [|] ros-humble-rosidl-generator-cpp : Depends: python3-dev but it is not install[-]                                   Depends: ros-humble-rosidl-cli but it is n[/]                                   Depends: ros-humble-rosidl-parser but it i[\] ros-humble-rosidl-generator-py : Depends: python3-numpy but it is not instal[|]                                  Depends: ros-humble-rosidl-cli but it is no[-]                                  Depends: ros-humble-rosidl-parser but it is[/] ros-humble-rosidl-runtime-py : Depends: python3-numpy but it is not installa[\]                                Depends: ros-humble-rosidl-parser but it is n[|] ros-humble-rosidl-typesupport-c : Depends: python3-dev but it is not install[-]                                   Depends: ros-humble-rosidl-cli but it is n[/] ros-humble-rosidl-typesupport-cpp : Depends: python3-dev but it is not insta[\]                                     Depends: ros-humble-rosidl-cli but it is[|] ros-humble-rosidl-typesupport-fastrtps-c : Depends: python3-dev but it is no[-]                                            Depends: ros-humble-rosidl-cli bu[/] ros-humble-rosidl-typesupport-fastrtps-cpp : Depends: python3-dev but it is [\]                                              Depends: ros-humble-rosidl-cli [|] ros-humble-rosidl-typesupport-introspection-c : Depends: python3-dev but it [-]                                                 Depends: ros-humble-rosidl-c[/]                                                 Depends: ros-humble-rosidl-p[\] ros-humble-rosidl-typesupport-introspection-cpp : Depends: python3-dev but i[|]                                                   Depends: ros-humble-rosidl[-]                                                   Depends: ros-humble-rosidl[/] ros-humble-rqt-image-view : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) b[\]                             Depends: libopencv-core4.5d (>= 4.5.4+dfsg) but [|]                             Depends: libopencv-imgproc4.5d (>= 4.5.4+dfsg) b[-]                             Depends: libqt5core5a (>= 5.15.1) but it is not [/]                             Depends: libqt5gui5 (>= 5.14.1) but it is not in[\]                                      libqt5gui5-gles (>= 5.14.1) but it is n[|]                             Depends: libqt5widgets5 (>= 5.0.2) but it is not[-]                             Depends: ros-humble-cv-bridge but it is not goin[/]                             Depends: ros-humble-image-transport but it is no[\]                             Depends: ros-humble-qt-gui-cpp but it is not goi[|]                             Depends: ros-humble-rqt-gui-cpp but it is not go[|] ros-humble-rviz-default-plugins : Depends: libconsole-bridge1.0 (>= 1.0.1+df[-]                                   Depends: liborocos-kdl1.5 (>= 1.5.1) but i[/]                                   Depends: libqt5core5a (>= 5.15.1) but it i[\]                                   Depends: libqt5gui5 (>= 5.2.0) but it is n[|]                                            libqt5gui5-gles (>= 5.2.0) but it[-]                                   Depends: libqt5widgets5 (>= 5.0.2) but it [/]                                   Depends: libtinyxml2-9 (>= 8.0.0) but it i[\]                                   Depends: ros-humble-rviz-ogre-vendor but i[|]                                   Depends: libqt5gui5 but it is not installa[-]                                   Depends: libqt5opengl5 but it is not insta[/]                                   Depends: ros-humble-ignition-math6-vendor [\]                                   Depends: ros-humble-image-transport but it[|]                                   Depends: ros-humble-interactive-markers bu[-]                                   Depends: ros-humble-laser-geometry but it [/]                                   Depends: ros-humble-resource-retriever but[\]                                   Depends: ros-humble-rviz-common but it is [|]                                   Depends: ros-humble-rviz-rendering but it [-] ros-humble-rviz2 : Depends: libqt5core5a (>= 5.15.1) but it is not installab[/]                    Depends: libqt5widgets5 (>= 5.0.2) but it is not installa[\]                    Depends: ros-humble-rviz-common but it is not going to be[|]                    Depends: ros-humble-rviz-ogre-vendor but it is not going [-] ros-humble-sqlite3-vendor : Depends: libsqlite3-dev but it is not installabl[\] ros-humble-tango-icons-vendor : Depends: tango-icon-theme but it is not inst[|] ros-humble-teleop-twist-joy : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2)[-] ros-humble-tf2 : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is no[\]                  Depends: ros-humble-console-bridge-vendor but it is not goi[/] ros-humble-tf2-eigen-kdl : Depends: liborocos-kdl1.5 (>= 1.5.1) but it is no[|] ros-humble-tf2-geometry-msgs : Depends: python3-numpy but it is not installa[-] ros-humble-tf2-ros : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it i[/] ros-humble-tf2-sensor-msgs : Depends: libeigen3-dev but it is not installabl[|] ros-humble-tinyxml2-vendor : Depends: libtinyxml2-dev but it is not installa[-] ros-humble-turtlesim : Depends: libqt5core5a (>= 5.15.1) but it is not insta[/]                        Depends: libqt5gui5 (>= 5.2.0) but it is not installa[\]                                 libqt5gui5-gles (>= 5.2.0) but it is not ins[|]                        Depends: libqt5widgets5 (>= 5.0.2) but it is not inst[\] ros-humble-urdf : Depends: libconsole-bridge1.0 (>= 1.0.1+dfsg2) but it is n[|]                   Depends: libtinyxml2-9 (>= 8.0.0) but it is not installabl[-]                   Depends: ros-humble-urdfdom but it is not going to be inst[/] shim-signed : Depends: grub-efi-amd64-signed but it is not going to be insta[|]               Depends: grub2-common (>= 2.04-1ubuntu24) but it is not going [-]Result:code:100                           ) but it is not installable
      确认了解情况,请输入回车继续安装
      Run CMD Task:[sudo aptitude install   ros-humble-desktop]
        ros-humble-desktop{b}
      0 packages upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
      Need to get 6,558 B of archives. After unpacking 46.1 kB will be used.
       ros-humble-desktop : Depends: ros-humble-action-tutorials-cpp but it is not installable
                            Depends: ros-humble-action-tutorials-interfaces but it is not installable
                            Depends: ros-humble-action-tutorials-py but it is not installable
                            Depends: ros-humble-angles but it is not installable
                            Depends: ros-humble-composition but it is not installable
                            Depends: ros-humble-demo-nodes-cpp but it is not installable
                            Depends: ros-humble-demo-nodes-cpp-native but it is not installable
                            Depends: ros-humble-demo-nodes-py but it is not installable
                            Depends: ros-humble-depthimage-to-laserscan but it is not installable
                            Depends: ros-humble-dummy-map-server but it is not installable
                            Depends: ros-humble-dummy-robot-bringup but it is not installable
                            Depends: ros-humble-dummy-sensors but it is not installable
                            Depends: ros-humble-examples-rclcpp-minimal-action-client but it is not installable
                            Depends: ros-humble-examples-rclcpp-minimal-action-server but it is not installable
                            Depends: ros-humble-examples-rclcpp-minimal-client but it is not installable
                            Depends: ros-humble-examples-rclcpp-minimal-composition but it is not installable
                            Depends: ros-humble-examples-rclcpp-minimal-publisher but it is not installable
                            Depends: ros-humble-examples-rclcpp-minimal-service but it is not installable
                            Depends: ros-humble-examples-rclcpp-minimal-subscriber but it is not installable
                            Depends: ros-humble-examples-rclcpp-minimal-timer but it is not installable
                            Depends: ros-humble-examples-rclcpp-multithreaded-executor but it is not installable
                            Depends: ros-humble-examples-rclpy-executors but it is not installable
                            Depends: ros-humble-examples-rclpy-minimal-action-client but it is not installable
                            Depends: ros-humble-examples-rclpy-minimal-action-server but it is not installable
                            Depends: ros-humble-examples-rclpy-minimal-client but it is not installable
                            Depends: ros-humble-examples-rclpy-minimal-publisher but it is not installable
                            Depends: ros-humble-examples-rclpy-minimal-service but it is not installable
                            Depends: ros-humble-examples-rclpy-minimal-subscriber but it is not installable
                            Depends: ros-humble-image-tools but it is not installable
                            Depends: ros-humble-intra-process-demo but it is not installable
                            Depends: ros-humble-joy but it is not installable
                            Depends: ros-humble-lifecycle but it is not installable
                            Depends: ros-humble-logging-demo but it is not installable
                            Depends: ros-humble-pcl-conversions but it is not installable
                            Depends: ros-humble-pendulum-control but it is not installable
                            Depends: ros-humble-pendulum-msgs but it is not installable
                            Depends: ros-humble-quality-of-service-demo-cpp but it is not installable
                            Depends: ros-humble-quality-of-service-demo-py but it is not installable
                            Depends: ros-humble-ros-base but it is not installable
                            Depends: ros-humble-rqt-common-plugins but it is not installable
                            Depends: ros-humble-rviz-default-plugins but it is not installable
                            Depends: ros-humble-teleop-twist-joy but it is not installable
                            Depends: ros-humble-teleop-twist-keyboard but it is not installable
                            Depends: ros-humble-tlsf but it is not installable
                            Depends: ros-humble-tlsf-cpp but it is not installable
                            Depends: ros-humble-topic-monitor but it is not installable
                            Depends: ros-humble-turtlesim but it is not installable
                            Depends: ros-humble-ros-workspace but it is not going to be installed
      Accept this solution? [Y/n/q/?] y
      0 packages upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
      Need to get 0 B of archives. After unpacking 0 B will be used.
      Run CMD Task:[sudo aptitude install   ros-humble-desktop -y]
      [\] ros-humble-desktop : Depends: ros-humble-action-tutorials-cpp but it is not [|]                      Depends: ros-humble-action-tutorials-interfaces but it [-]                      Depends: ros-humble-action-tutorials-py but it is not i[\]                      Depends: ros-humble-composition but it is not installab[|]                      Depends: ros-humble-demo-nodes-cpp but it is not instal[-]                      Depends: ros-humble-demo-nodes-cpp-native but it is not[/]                      Depends: ros-humble-demo-nodes-py but it is not install[\]                      Depends: ros-humble-depthimage-to-laserscan but it is n[|]                      Depends: ros-humble-dummy-map-server but it is not inst[-]                      Depends: ros-humble-dummy-robot-bringup but it is not i[/]                      Depends: ros-humble-dummy-sensors but it is not install[\]                      Depends: ros-humble-examples-rclcpp-minimal-action-clie[|]                      Depends: ros-humble-examples-rclcpp-minimal-action-serv[-]                      Depends: ros-humble-examples-rclcpp-minimal-client but [/]                      Depends: ros-humble-examples-rclcpp-minimal-composition[\]                      Depends: ros-humble-examples-rclcpp-minimal-publisher b[|]                      Depends: ros-humble-examples-rclcpp-minimal-service but[-]                      Depends: ros-humble-examples-rclcpp-minimal-subscriber [/]                      Depends: ros-humble-examples-rclcpp-minimal-timer but i[\]                      Depends: ros-humble-examples-rclcpp-multithreaded-execu[|]                      Depends: ros-humble-examples-rclpy-executors but it is [-]                      Depends: ros-humble-examples-rclpy-minimal-action-clien[/]                      Depends: ros-humble-examples-rclpy-minimal-action-serve[\]                      Depends: ros-humble-examples-rclpy-minimal-client but i[|]                      Depends: ros-humble-examples-rclpy-minimal-publisher bu[-]                      Depends: ros-humble-examples-rclpy-minimal-service but [/]                      Depends: ros-humble-examples-rclpy-minimal-subscriber b[\]                      Depends: ros-humble-image-tools but it is not installab[|]                      Depends: ros-humble-intra-process-demo but it is not in[\]                      Depends: ros-humble-logging-demo but it is not installa[|]                      Depends: ros-humble-pcl-conversions but it is not insta[-]                      Depends: ros-humble-pendulum-control but it is not inst[/]                      Depends: ros-humble-pendulum-msgs but it is not install[\]                      Depends: ros-humble-quality-of-service-demo-cpp but it [|]                      Depends: ros-humble-quality-of-service-demo-py but it i[/]                      Depends: ros-humble-rqt-common-plugins but it is not in[\]                      Depends: ros-humble-rviz-default-plugins but it is not [-]                      Depends: ros-humble-teleop-twist-joy but it is not inst[/]                      Depends: ros-humble-teleop-twist-keyboard but it is not[-]                      Depends: ros-humble-topic-monitor but it is not install[\]                      Depends: ros-humble-ros-workspace but it is not going t[-]Result:success                           ing 0 B will be used.upgraded.
      [\]python3-colcon-common-extensions - Meta package aggregating colcon-core and c[-]Result:success
      [-] python3-catkin-pkg-modules : Depends: python3-docutils but it is not install[/] python3-colcon-argcomplete : Depends: python3-argcomplete but it is not inst[|]                       Recommends: python3-pytest-cov but it is not installab[-] python3-colcon-notification : Depends: python3-notify2 but it is not install[/] python3-colcon-python-setup-py : Depends: python3-setuptools but it is not i[-]Result:code:100
      [-]Result:success
      [-]Result:success                           anager abstraction tool for ROS
      [-] python3-rosdep-modules : Depends: python3-rospkg-modules (>= 1.4.0) but it i[/]                          Depends: python3-catkin-pkg-modules (>= 0.4.0) but [\]                          Depends: python3-rosdistro-modules (>= 0.7.5) but i[|]                          Depends: python3-setuptools but it is not installab[-]Result:code:100
      [-]Result:code:2
      [-]Result:code:2
        小鱼 技术大佬 @阿来呀
        @阿来呀 我来给你改一个,你看下如何用代码块包裹哈
        • 阿来呀阿
          阿来呀 @小鱼
          @小鱼 我把所有的命令行分两次发的,麻烦你看一下。全部过程就在这
          • 阿来呀阿
            阿来呀
            @小鱼我刚刚重新试一下一键安装,之前选的不换源,我现在选择换源,接着换源方式应该选啥呢?
            [1]:更换系统源再继续安装
            [2]:不更换继续安装
            请输入[]内的数字以选择:1
            欢迎使用一键换源工具,本工具由[鱼香ROS]小鱼贡献..
            请选择换源方式,如果不知道选什么请选2
            [1]:仅更换系统源
            [2]:更换系统源并清理第三方源
            请输入[]内的数字以选择:
              小鱼 技术大佬 @阿来呀
              @阿来呀 我改了一下,你再试一次
              阿来呀阿 1 条回复 最后回复 回复 引用 0
              • 阿来呀阿
                阿来呀 @小鱼
                @小鱼 我现在要选择换源方式,我应该咋选
                  小鱼 技术大佬 @阿来呀
                  @阿来呀 建议换一下吧,你之前是不是手动安装过
                  阿来呀阿 2 条回复 最后回复 回复 引用 0
                  • 阿来呀阿
                    阿来呀 @小鱼
                    @小鱼 是的,之前是手动装过
                    • 阿来呀阿
                      阿来呀 @小鱼
                      @小鱼 请选择换源方式,如果不知道选什么请选2
                      [1]:仅更换系统源
                      [2]:更换系统源并清理第三方源
                      请输入[]内的数字以选择:
                      我是选1还是2呢
                        小鱼 技术大佬 @阿来呀
                        @阿来呀 应该是手动装没装好,产生了依赖问题,而且是一个比较奇怪的依赖,一键安装刚好没捕获它,我刚加了进去,现在应该可以捕获然后提供解决方案了
                          小鱼 技术大佬 @阿来呀
                          @阿来呀 选2就行,把你之前手动加的清除下
                          阿来呀阿 3 条回复 最后回复 回复 引用 0
                          • 阿来呀阿
                            阿来呀 @小鱼
                            @小鱼 前面一直未报错,怎么最后还是显示失败呢
                              小鱼 技术大佬 @阿来呀
                              @阿来呀 这个我也要看一下全部日志才知道
                              贴一下
                              • 阿来呀阿
                                阿来呀 @小鱼
                                @小鱼 ltl@ltl-pc:~$ wget http://fishros.com/install -O fishros && . fishros
                                --2022-07-07 09:48:20-- http://fishros.com/install
                                --2022-07-07 09:48:21-- http://fishros.com/install/
                                Saving to: ‘fishros’
                                fishros 100%[==============================================================================================>] 543 --.-KB/s in 0s
                                2022-07-07 09:48:21 (67.6 MB/s) - ‘fishros’ saved [543/543]
                                Reading package lists... Done
                                --2022-07-07 09:48:21-- http://fishros.com/install/install1s/tools/base.py
                                /tmp/fishinstall/tools/base.py 100%[==============================================================================================>] 41.01K --.-KB/s in 0.1s
                                2022-07-07 09:48:21 (392 KB/s) - ‘/tmp/fishinstall/tools/base.py’ saved [41998/41998]
                                [-]Result:success
                                基础检查通过...
                                ---众多工具,等君来用---
                                [6]:一键安装:nodejs
                                [7]:一键安装:VsCode开发工具
                                [8]:一键安装:Docker
                                [10]:一键安装:微信(可以在Linux上使用的微信)
                                [77]:测试模式:运行自定义工具测试
                                请输入[]内的数字以选择:1
                                --2022-07-07 09:48:45-- http://fishros.com/install/install1s/tools/tool_install_ros.py
                                /tmp/fishinstall/to 100%[===================>] 17.35K --.-KB/s in 0.06s
                                2022-07-07 09:48:45 (292 KB/s) - ‘/tmp/fishinstall/tools/tool_install_ros.py’ saved [17766/17766]
                                --2022-07-07 09:48:45-- http://fishros.com/install/install1s/tools/tool_config_rosenv.py
                                /tmp/fishinstall/to 100%[===================>] 2.40K --.-KB/s in 0s
                                2022-07-07 09:48:45 (410 MB/s) - ‘/tmp/fishinstall/tools/tool_config_rosenv.py’ saved [2457/2457]
                                --2022-07-07 09:48:45-- http://fishros.com/install/install1s/tools/tool_config_system_source.py
                                /tmp/fishinstall/to 100%[===================>] 7.33K --.-KB/s in 0s
                                2022-07-07 09:48:45 (183 MB/s) - ‘/tmp/fishinstall/tools/tool_config_system_source.py’ saved [7511/7511]
                                [1]:更换系统源再继续安装
                                [2]:不更换继续安装
                                请输入[]内的数字以选择:1
                                请选择换源方式,如果不知道选什么请选2
                                [1]:仅更换系统源
                                [2]:更换系统源并清理第三方源
                                请输入[]内的数字以选择:2
                                [-]Result:success
                                删除一个资源文件
                                [-]Result:success
                                [-]Result:success
                                [-]Result:success
                                检测到当前系统架构为[amd64:jammy],正在为你更换对应源..
                                替换完成,尝试第一次更新....
                                [/]Get:8 https://mirrors.ustc.edu.cn/ubuntu jammy/main amd64 DEP-11 Metadata [42[]Get:9 https://mirrors.ustc.edu.cn/ubuntu jammy/main DEP-11 48x48 Icons [100.0[|]Get:10 https://mirrors.ustc.edu.cn/ubuntu jammy/main DEP-11 64x64 Icons [148 [-]Get:11 https://mirrors.ustc.edu.cn/ubuntu jammy/main DEP-11 64x64@2 Icons [15[/]Get:12 https://mirrors.ustc.edu.cn/ubuntu jammy/main amd64 c-n-f Metadata [30[]Get:13 https://mirrors.ustc.edu.cn/ubuntu jammy/restricted amd64 Packages [12[|]Get:14 https://mirrors.ustc.edu.cn/ubuntu jammy/restricted i386 Packages [30.[-]Get:15 https://mirrors.ustc.edu.cn/ubuntu jammy/restricted Translation-en [18[/]Get:16 https://mirrors.ustc.edu.cn/ubuntu jammy/restricted amd64 c-n-f Metada[]Get:17 https://mirrors.ustc.edu.cn/ubuntu jammy/universe i386 Packages [7,474 kB]
                                [|]Get:18 https://mirrors.ustc.edu.cn/ubuntu jammy/universe amd64 Packages [14.1 MB]
                                [-]Result:success --upgradable' to see them.ckages [151 kB]adata [228 B]]]
                                搞定了,不信你看,累死宝宝了,还不快去给小鱼点个赞~
                                ['Get:1 https://mirrors.ustc.edu.cn/ubuntu jammy InRelease [270 kB]', 'Get:2 https://mirrors.ustc.edu.cn/ubuntu jammy-updates InRelease [114 kB]', 'Get:3 https://mirrors.ustc.edu.cn/ubuntu jammy-backports InRelease [99.8 kB]', 'Get:4 https://mirrors.ustc.edu.cn/ubuntu jammy-security InRelease [110 kB]', 'Get:5 https://mirrors.ustc.edu.cn/ubuntu jammy/main amd64 Packages [1,395 kB]', 'Get:6 https://mirrors.ustc.edu.cn/ubuntu jammy/main i386 Packages [1,040 kB]', 'Get:7 https://mirrors.ustc.edu.cn/ubuntu jammy/main Translation-en [510 kB]', 'Get:8 https://mirrors.ustc.edu.cn/ubuntu jammy/main amd64 DEP-11 Metadata [423 kB]', 'Get:9 https://mirrors.ustc.edu.cn/ubuntu jammy/main DEP-11 48x48 Icons [100.0 kB]', 'Get:10 https://mirrors.ustc.edu.cn/ubuntu jammy/main DEP-11 64x64 Icons [148 kB]', 'Get:11 https://mirrors.ustc.edu.cn/ubuntu jammy/main DEP-11 64x64@2 Icons [15.8 kB]', 'Get:12 https://mirrors.ustc.edu.cn/ubuntu jammy/main amd64 c-n-f Metadata [30.3 kB]', 'Get:13 https://mirrors.ustc.edu.cn/ubuntu jammy/restricted amd64 Packages [129 kB]', 'Get:14 https://mirrors.ustc.edu.cn/ubuntu jammy/restricted i386 Packages [30.4 kB]', 'Get:15 https://mirrors.ustc.edu.cn/ubuntu jammy/restricted Translation-en [18.6 kB]', 'Get:16 https://mirrors.ustc.edu.cn/ubuntu jammy/restricted amd64 c-n-f Metadata [488 B]', 'Get:17 https://mirrors.ustc.edu.cn/ubuntu jammy/universe i386 Packages [7,474 kB]', 'Get:18 https://mirrors.ustc.edu.cn/ubuntu jammy/universe amd64 Packages [14.1 MB]', 'Get:19 https://mirrors.ustc.edu.cn/ubuntu jammy/universe Translation-en [5,652 kB]', 'Get:20 https://mirrors.ustc.edu.cn/ubuntu jammy/universe amd64 DEP-11 Metadata [3,559 kB]', 'Get:21 https://mirrors.ustc.edu.cn/ubuntu jammy/universe DEP-11 48x48 Icons [3,447 kB]', 'Get:22 https://mirrors.ustc.edu.cn/ubuntu jammy/universe DEP-11 64x64 Icons [7,609 kB]', 'Get:23 https://mirrors.ustc.edu.cn/ubuntu jammy/universe DEP-11 64x64@2 Icons [69.3 kB]', 'Get:24 https://mirrors.ustc.edu.cn/ubuntu jammy/universe amd64 c-n-f Metadata [286 kB]', 'Get:25 https://mirrors.ustc.edu.cn/ubuntu jammy/multiverse i386 Packages [112 kB]', 'Get:26 https://mirrors.ustc.edu.cn/ubuntu jammy/multiverse amd64 Packages [217 kB]', 'Get:27 https://mirrors.ustc.edu.cn/ubuntu jammy/multiverse Translation-en [112 kB]', 'Get:28 https://mirrors.ustc.edu.cn/ubuntu jammy/multiverse amd64 DEP-11 Metadata [42.1 kB]', 'Get:29 https://mirrors.ustc.edu.cn/ubuntu jammy/multiverse DEP-11 48x48 Icons [42.7 kB]', 'Get:30 https://mirrors.ustc.edu.cn/ubuntu jammy/multiverse DEP-11 64x64 Icons [193 kB]', 'Get:31 https://mirrors.ustc.edu.cn/ubuntu jammy/multiverse DEP-11 64x64@2 Icons [214 B]', 'Get:32 https://mirrors.ustc.edu.cn/ubuntu jammy/multiverse amd64 c-n-f Metadata [8,372 B]', 'Get:33 https://mirrors.ustc.edu.cn/ubuntu jammy-updates/main amd64 Packages [340 kB]', 'Get:34 https://mirrors.ustc.edu.cn/ubuntu jammy-updates/main i386 Packages [151 kB]', 'Ign:34 https://mirrors.ustc.edu.cn/ubuntu jammy-updates/main i386 Packages', 'Get:35 https://mirrors.ustc.edu.cn/ubuntu jammy-updates/main Translation-en [85.7 kB]', 'Get:36 https://mirrors.ustc.edu.cn/ubuntu jammy-updates/main amd64 DEP-11 Metadata [90.9 kB]', 'Get:37 https://mirrors.ustc.edu.cn/ubuntu jammy-updates/main DEP-11 48x48 Icons [26.2 kB]', 'Get:38 https://mirrors.ustc.edu.cn/ubuntu jammy-updates/main DEP-11 64x64 Icons [38.2 kB]', 'Get:39 https://mirrors.ustc.edu.cn/ubuntu jammy-updates/main DEP-11 64x64@2 Icons [29 B]', 'Get:40 https://mirrors.ustc.edu.cn/ubuntu jammy-updates/main amd64 c-n-f Metadata [6,172 B]', 'Get:41 https://mirrors.ustc.edu.cn/ubuntu jammy-updates/restricted amd64 Packages [215 kB]', 'Get:42 https://mirrors.ustc.edu.cn/ubuntu jammy-updates/restricted i386 Packages [22.1 kB]', 'Get:43 https://mirrors.ustc.edu.cn/ubuntu jammy-updates/restricted Translation-en [32.8 kB]', 'Get:44 https://mirrors.ustc.edu.cn/ubuntu jammy-updates/restricted amd64 c-n-f Metadata [536 B]', 'Get:45 https://mirrors.ustc.edu.cn/ubuntu jammy-updates/universe i386 Packages [70.1 kB]', 'Get:46 https://mirrors.ustc.edu.cn/ubuntu jammy-updates/universe amd64 Packages [141 kB]', 'Get:47 https://mirrors.ustc.edu.cn/ubuntu jammy-updates/universe Translation-en [50.8 kB]', 'Get:48 https://mirrors.ustc.edu.cn/ubuntu jammy-updates/universe amd64 DEP-11 Metadata [95.0 kB]', 'Get:49 https://mirrors.ustc.edu.cn/ubuntu jammy-updates/universe DEP-11 48x48 Icons [38.0 kB]', 'Get:50 https://mirrors.ustc.edu.cn/ubuntu jammy-updates/universe DEP-11 64x64 Icons [50.5 kB]', 'Get:51 https://mirrors.ustc.edu.cn/ubuntu jammy-updates/universe DEP-11 64x64@2 Icons [29 B]', 'Get:52 https://mirrors.ustc.edu.cn/ubuntu jammy-updates/universe amd64 c-n-f Metadata [2,960 B]', 'Get:53 https://mirrors.ustc.edu.cn/ubuntu jammy-updates/multiverse amd64 Packages [7,032 B]', 'Get:54 https://mirrors.ustc.edu.cn/ubuntu jammy-updates/multiverse i386 Packages [1,460 B]', 'Get:55 https://mirrors.ustc.edu.cn/ubuntu jammy-updates/multiverse Translation-en [2,112 B]', 'Get:56 https://mirrors.ustc.edu.cn/ubuntu jammy-updates/multiverse amd64 DEP-11 Metadata [940 B]', 'Get:57 https://mirrors.ustc.edu.cn/ubuntu jammy-updates/multiverse DEP-11 48x48 Icons [1,867 B]', 'Get:58 https://mirrors.ustc.edu.cn/ubuntu jammy-updates/multiverse DEP-11 64x64 Icons [2,497 B]', 'Get:59 https://mirrors.ustc.edu.cn/ubuntu jammy-updates/multiverse DEP-11 64x64@2 Icons [29 B]', 'Get:60 https://mirrors.ustc.edu.cn/ubuntu jammy-updates/multiverse amd64 c-n-f Metadata [420 B]', 'Get:61 https://mirrors.ustc.edu.cn/ubuntu jammy-backports/main amd64 c-n-f Metadata [112 B]', 'Get:62 https://mirrors.ustc.edu.cn/ubuntu jammy-backports/restricted amd64 c-n-f Metadata [116 B]', 'Get:63 https://mirrors.ustc.edu.cn/ubuntu jammy-backports/universe amd64 Packages [5,404 B]', 'Get:64 https://mirrors.ustc.edu.cn/ubuntu jammy-backports/universe i386 Packages [3,840 B]', 'Get:65 https://mirrors.ustc.edu.cn/ubuntu jammy-backports/universe Translation-en [8,160 B]', 'Get:66 https://mirrors.ustc.edu.cn/ubuntu jammy-backports/universe amd64 DEP-11 Metadata [12.5 kB]', 'Get:67 https://mirrors.ustc.edu.cn/ubuntu jammy-backports/universe DEP-11 48x48 Icons [2,686 B]', 'Get:68 https://mirrors.ustc.edu.cn/ubuntu jammy-backports/universe DEP-11 64x64 Icons [7,651 B]', 'Get:69 https://mirrors.ustc.edu.cn/ubuntu jammy-backports/universe DEP-11 64x64@2 Icons [29 B]', 'Get:70 https://mirrors.ustc.edu.cn/ubuntu jammy-backports/universe amd64 c-n-f Metadata [236 B]', 'Get:71 https://mirrors.ustc.edu.cn/ubuntu jammy-backports/multiverse amd64 c-n-f Metadata [116 B]', 'Get:72 https://mirrors.ustc.edu.cn/ubuntu jammy-security/main i386 Packages [68.4 kB]', 'Get:73 https://mirrors.ustc.edu.cn/ubuntu jammy-security/main amd64 Packages [197 kB]', 'Get:74 https://mirrors.ustc.edu.cn/ubuntu jammy-security/main Translation-en [48.8 kB]', 'Get:75 https://mirrors.ustc.edu.cn/ubuntu jammy-security/main amd64 DEP-11 Metadata [11.4 kB]', 'Get:76 https://mirrors.ustc.edu.cn/ubuntu jammy-security/main DEP-11 48x48 Icons [5,952 B]', 'Get:77 https://mirrors.ustc.edu.cn/ubuntu jammy-security/main DEP-11 64x64 Icons [8,219 B]', 'Get:78 https://mirrors.ustc.edu.cn/ubuntu jammy-security/main DEP-11 64x64@2 Icons [29 B]', 'Get:79 https://mirrors.ustc.edu.cn/ubuntu jammy-security/main amd64 c-n-f Metadata [3,336 B]', 'Get:80 https://mirrors.ustc.edu.cn/ubuntu jammy-security/restricted amd64 Packages [177 kB]', 'Get:81 https://mirrors.ustc.edu.cn/ubuntu jammy-security/restricted i386 Packages [21.8 kB]', 'Get:82 https://mirrors.ustc.edu.cn/ubuntu jammy-security/restricted Translation-en [26.2 kB]', 'Get:83 https://mirrors.ustc.edu.cn/ubuntu jammy-security/restricted amd64 c-n-f Metadata [512 B]', 'Get:84 https://mirrors.ustc.edu.cn/ubuntu jammy-security/universe amd64 Packages [79.6 kB]', 'Get:85 https://mirrors.ustc.edu.cn/ubuntu jammy-security/universe i386 Packages [36.2 kB]', 'Get:86 https://mirrors.ustc.edu.cn/ubuntu jammy-security/universe Translation-en [28.4 kB]', 'Get:87 https://mirrors.ustc.edu.cn/ubuntu jammy-security/universe amd64 DEP-11 Metadata [608 B]', 'Get:88 https://mirrors.ustc.edu.cn/ubuntu jammy-security/universe DEP-11 48x48 Icons [29 B]', 'Get:89 https://mirrors.ustc.edu.cn/ubuntu jammy-security/universe DEP-11 64x64 Icons [29 B]', 'Get:90 https://mirrors.ustc.edu.cn/ubuntu jammy-security/universe DEP-11 64x64@2 Icons [29 B]', 'Get:91 https://mirrors.ustc.edu.cn/ubuntu jammy-security/universe amd64 c-n-f Metadata [1,700 B]', 'Get:92 https://mirrors.ustc.edu.cn/ubuntu jammy-security/multiverse i386 Packages [1,032 B]', 'Get:93 https://mirrors.ustc.edu.cn/ubuntu jammy-security/multiverse amd64 Packages [4,192 B]', 'Get:94 https://mirrors.ustc.edu.cn/ubuntu jammy-security/multiverse Translation-en [900 B]', 'Get:95 https://mirrors.ustc.edu.cn/ubuntu jammy-security/multiverse amd64 c-n-f Metadata [228 B]', 'Get:34 https://mirrors.ustc.edu.cn/ubuntu jammy-updates/main i386 Packages [151 kB]', 'Fetched 49.5 MB in 7min 3s (117 kB/s)', 'Reading package lists...', 'Building dependency tree...', 'Reading state information...', "3 packages can be upgraded. Run 'apt list --upgradable' to see them."]
                                镜像修复完成.....
                                [-]Result:success s for HTTPer dock appIolsceic typesmentation)slyt source code3 moree-system-lib-on-osx"
                                [-]Result:success e and 3 not upgraded.
                                [-]Result:success ...2.1_all.deb ...stalled.) gnupg2 all 2.2.27-3ubuntu2.1 [5,548 B]
                                [-]Result:success
                                [-]Result:success
                                [-]Result:success --upgradable' to see them.64 Packages [643 kB]
                                [-]Result:success tends 'ros_core' and includes other basic functionalities like tf2 and urdf.
                                [1]:humble(ROS2)
                                [2]:rolling(ROS2)
                                请输入[]内的数字以选择:1
                                请选择安装的具体版本(如果不知道怎么选,请选1桌面版):
                                [1]:humble(ROS2)桌面版
                                [2]:humble(ROS2)基础版(小)
                                请输入[]内的数字以选择:1
                                [-]Result:success end for Debian/Ubuntu (development files)sion
                                dconf-gsettings-backend : Depends: dconf-service (< 0.40.0-3.1~)
                                Depends: dconf-service (>= 0.40.0-3)
                                init : PreDepends: systemd-sysv
                                libcolord2 : Depends: libudev1 (>= 196) but it is not installable
                                libdbus-1-3 : Depends: libsystemd0 but it is not installable
                                Recommends: dbus
                                libhwloc15 : Depends: libudev1 (>= 183) but it is not installable
                                libignition-cmake2-dev : Depends: cmake
                                libopenmpi-dev : Depends: openmpi-bin (>= 3.0.0-1)
                                Recommends: libcoarrays-openmpi-dev but it is not going to be installed
                                libopenni2-0 : Depends: libudev1 (>= 183) but it is not installable
                                libpulse0 : Depends: libsystemd0 but it is not installable
                                libqt5designer5 : Depends: libqt5gui5 (>= 5.14.1) but it is not installable or
                                libqt5designercomponents5 : Depends: libqt5gui5 (>= 5.14.1) but it is not installable or
                                libqt5help5 : Depends: libqt5gui5 (>= 5.0.2) but it is not installable or
                                libqt5gui5-gles (>= 5.0.2) but it is not installable
                                libqt5printsupport5 : Depends: libqt5gui5 (>= 5.14.1) but it is not installable or
                                libqt5quickshapes5 : Depends: libqt5gui5 (>= 5.14.1) but it is not installable or
                                Depends: libqt5quick5 (>= 5.14.1) but it is not installable or
                                libqt5quick5-gles (>= 5.14.1) but it is not installable
                                libqt5quicktest5 : Depends: libqt5gui5 (>= 5.12.2) but it is not installable or
                                libqt5gui5-gles (>= 5.12.2) but it is not installable
                                Depends: libqt5quick5 (>= 5.0.2) but it is not installable or
                                libqt5quick5-gles (>= 5.0.2) but it is not installable
                                libqt5quickwidgets5 : Depends: libqt5gui5 (>= 5.10.0) but it is not installable or
                                libqt5gui5-gles (>= 5.10.0) but it is not installable
                                Depends: libqt5quick5 (>= 5.15.1) but it is not installable or
                                libqt5quick5-gles (>= 5.15.1) but it is not installable
                                libqt5svg5 : Depends: libqt5gui5 (>= 5.15.3+dfsg~) but it is not installable or
                                libqt5gui5-gles (>= 5.15.3+dfsg~) but it is not installable
                                libqt5webkit5 : Depends: libqt5gui5 (>= 5.14.1) but it is not installable or
                                Depends: libqt5quick5 (>= 5.15.3+dfsg~) but it is not installable or
                                libqt5quick5-gles (>= 5.15.3+dfsg~) but it is not installable
                                libqt5widgets5 : Depends: libqt5gui5 (>= 5.15.1) but it is not installable or
                                libqt5gui5-gles (>= 5.15.1) but it is not installable
                                libudev-dev : Depends: libudev1 (= 249.11-0ubuntu3) but it is not installable
                                libusb-1.0-0 : Depends: libudev1 (>= 183) but it is not installable
                                libvtk9-qt-dev : Depends: libqt5opengl5-dev but it is not installable
                                libvtk9.1-qt : Depends: libqt5gui5 (>= 5.11.0~rc1) but it is not installable or
                                libqt5gui5-gles (>= 5.11.0~rc1) but it is not installable
                                mpi-default-bin : Depends: openmpi-bin
                                python3-pyqt5 : Depends: libqt5gui5 (>= 5.1.0) but it is not installable
                                python3-pyqt5.qtsvg : Depends: libqt5gui5 (>= 5.0.2) but it is not installable or
                                python3-pyside2.qtgui : Depends: libqt5gui5 (>= 5.15) but it is not installable
                                  小鱼 技术大佬 @阿来呀
                                  @阿来呀 关键信息还在下面
                                    小鱼 技术大佬 @小鱼
                                    @小鱼 这个错误应该被捕获,然后一键安装会提出解决方案
                                    • 阿来呀阿
                                      阿来呀 @小鱼
                                      [-]Result:success
                                      基础检查通过...
                                      ---众多工具,等君来用---
                                      [6]:一键安装:nodejs
                                      [7]:一键安装:VsCode开发工具
                                      [8]:一键安装:Docker
                                      [77]:测试模式:运行自定义工具测试
                                      请输入[]内的数字以选择:1
                                      [1]:更换系统源再继续安装
                                      [2]:不更换继续安装
                                      请输入[]内的数字以选择:1
                                      请选择换源方式,如果不知道选什么请选2
                                      [1]:仅更换系统源
                                      [2]:更换系统源并清理第三方源
                                      请输入[]内的数字以选择:2
                                      [-]Result:success
                                      删除一个资源文件
                                      [-]Result:success
                                      [-]Result:success
                                      [-]Result:success
                                      替换完成,尝试第一次更新....
                                      [/]Get:8 https://mirrors.ustc.edu.cn/ubuntu jammy/main amd64 DEP-11 Metadata [42[\]Get:9 https://mirrors.ustc.edu.cn/ubuntu jammy/main DEP-11 48x48 Icons [100.0[|]Get:10 https://mirrors.ustc.edu.cn/ubuntu jammy/main DEP-11 64x64 Icons [148 [-]Get:11 https://mirrors.ustc.edu.cn/ubuntu jammy/main DEP-11 64x64@2 Icons [15[/]Get:12 https://mirrors.ustc.edu.cn/ubuntu jammy/main amd64 c-n-f Metadata [30[\]Get:13 https://mirrors.ustc.edu.cn/ubuntu jammy/restricted amd64 Packages [12[|]Get:14 https://mirrors.ustc.edu.cn/ubuntu jammy/restricted i386 Packages [30.[-]Get:15 https://mirrors.ustc.edu.cn/ubuntu jammy/restricted Translation-en [18[/]Get:16 https://mirrors.ustc.edu.cn/ubuntu jammy/restricted amd64 c-n-f Metada[\]Get:17 https://mirrors.ustc.edu.cn/ubuntu jammy/universe i386 Packages [7,474 kB]
                                      镜像修复完成.....
                                      [-]Result:success
                                      [-]Result:success
                                      [1]:humble(ROS2)
                                      [2]:rolling(ROS2)
                                      请输入[]内的数字以选择:1
                                      [1]:humble(ROS2)桌面版
                                      请输入[]内的数字以选择:1
                                                     Recommends: dbus
                                        小鱼 技术大佬 @阿来呀
                                        @阿来呀 在 一键安装ros2显示没有找到包:python3-argcomplete 中说:
                                        这个下面的东西嘞,按理说这后面应该会暂停检测错误的,你有看到 吗
                                        • 阿来呀阿
                                          阿来呀 @小鱼
                                          @小鱼 刚刚重新试一下,前面一直没报错,但是最后还是显示不成功,我还是重新装一下Ubuntu22.04,然后再试一下一键安装
                                            小鱼 技术大佬 @阿来呀
                                            @阿来呀 这个错误我遇到过很多次了,一键安装也是能自动解决的,你这个关键日志一直贴不上,我也没办法帮你看,那你重装下吧。
