    fishbot 机器人导航出错,无法初始化位置
    fishbot navigation2 初始化导航点
    38.0k
    • liusiyu_alex_nuaaL
      liusiyu_alex_nuaa @小鱼
      开启导航程序
      lsy@lsy:~/fishbot_nav$ source install/setup.bash
      ros2 launch fishbot_navigation2 navigation2.launch.py use_sim_time:=False
      [INFO] [launch]: All log files can be found below /home/lsy/.ros/log/2025-01-06-20-12-05-479988-lsy-10026
      [INFO] [component_container_isolated-1]: process started with pid [10039]
      [INFO] [rviz2-2]: process started with pid [10041]
      [component_container_isolated-1] [INFO] [1736165525.912177449] [nav2_container]: Load Library: /opt/ros/humble/lib/libmap_server_core.so
      [component_container_isolated-1] [INFO] [1736165525.917138493] [nav2_container]: Found class: rclcpp_components::NodeFactoryTemplate<nav2_map_server::CostmapFilterInfoServer>
      [component_container_isolated-1] [INFO] [1736165525.917153078] [nav2_container]: Found class: rclcpp_components::NodeFactoryTemplate<nav2_map_server::MapSaver>
      [component_container_isolated-1] [INFO] [1736165525.917155788] [nav2_container]: Found class: rclcpp_components::NodeFactoryTemplate<nav2_map_server::MapServer>
      [component_container_isolated-1] [INFO] [1736165525.917158799] [nav2_container]: Instantiate class: rclcpp_components::NodeFactoryTemplate<nav2_map_server::MapServer>
      [component_container_isolated-1] [INFO] [1736165525.921442975] [map_server]:
      [component_container_isolated-1] 	map_server lifecycle node launched.
      [component_container_isolated-1] 	Waiting on external lifecycle transitions to activate
      [component_container_isolated-1] 	See https://design.ros2.org/articles/node_lifecycle.html for more information.
      [component_container_isolated-1] [INFO] [1736165525.921478834] [map_server]: Creating
      [INFO] [launch_ros.actions.load_composable_nodes]: Loaded node '/map_server' in container '/nav2_container'
      [component_container_isolated-1] [INFO] [1736165525.922961218] [nav2_container]: Load Library: /opt/ros/humble/lib/libamcl_core.so
      [component_container_isolated-1] [INFO] [1736165525.925016980] [nav2_container]: Found class: rclcpp_components::NodeFactoryTemplate<nav2_amcl::AmclNode>
      [component_container_isolated-1] [INFO] [1736165525.925035113] [nav2_container]: Instantiate class: rclcpp_components::NodeFactoryTemplate<nav2_amcl::AmclNode>
      [component_container_isolated-1] [INFO] [1736165525.928725288] [amcl]:
      [component_container_isolated-1] 	amcl lifecycle node launched.
      [component_container_isolated-1] [INFO] [1736165525.928897319] [amcl]: Creating
      [INFO] [launch_ros.actions.load_composable_nodes]: Loaded node '/amcl' in container '/nav2_container'
      [component_container_isolated-1] [INFO] [1736165525.930066832] [nav2_container]: Load Library: /opt/ros/humble/lib/libnav2_lifecycle_manager_core.so
      [component_container_isolated-1] [INFO] [1736165525.930342146] [nav2_container]: Found class: rclcpp_components::NodeFactoryTemplate<nav2_lifecycle_manager::LifecycleManager>
      [component_container_isolated-1] [INFO] [1736165525.930348936] [nav2_container]: Instantiate class: rclcpp_components::NodeFactoryTemplate<nav2_lifecycle_manager::LifecycleManager>
      [component_container_isolated-1] [INFO] [1736165525.933359858] [lifecycle_manager_localization]: Creating
      [component_container_isolated-1] [INFO] [1736165525.934306745] [lifecycle_manager_localization]: Creating and initializing lifecycle service clients
      [INFO] [launch_ros.actions.load_composable_nodes]: Loaded node '/lifecycle_manager_localization' in container '/nav2_container'
      [component_container_isolated-1] [INFO] [1736165525.936201479] [lifecycle_manager_localization]: Starting managed nodes bringup...
      [component_container_isolated-1] [INFO] [1736165525.936226987] [lifecycle_manager_localization]: Configuring map_server
      [component_container_isolated-1] [INFO] [1736165525.936305100] [map_server]: Configuring
      [component_container_isolated-1] [INFO] [1736165525.936337746] [map_io]: Loading yaml file: /home/lsy/fishbot_nav/install/fishbot_navigation2/share/fishbot_navigation2/maps/fishbot_map.yaml
      [component_container_isolated-1] [INFO] [1736165525.936448814] [map_io]: resolution: 0.05
      [component_container_isolated-1] [INFO] [1736165525.936451781] [map_io]: origin[0]: -4
      [component_container_isolated-1] [INFO] [1736165525.936453699] [map_io]: origin[1]: -1.55
      [component_container_isolated-1] [INFO] [1736165525.936455409] [map_io]: origin[2]: 0
      [component_container_isolated-1] [INFO] [1736165525.936457248] [map_io]: free_thresh: 0.25
      [component_container_isolated-1] [INFO] [1736165525.936458981] [map_io]: occupied_thresh: 0.65
      [component_container_isolated-1] [INFO] [1736165525.936461041] [map_io]: mode: trinary
      [component_container_isolated-1] [INFO] [1736165525.936463155] [map_io]: negate: 0
      [component_container_isolated-1] [INFO] [1736165525.936547457] [map_io]: Loading image_file: /home/lsy/fishbot_nav/install/fishbot_navigation2/share/fishbot_navigation2/maps/fishbot_map.pgm
      [component_container_isolated-1] [INFO] [1736165525.937786805] [map_io]: Read map /home/lsy/fishbot_nav/install/fishbot_navigation2/share/fishbot_navigation2/maps/fishbot_map.pgm: 194 X 142 map @ 0.05 m/cell
      [component_container_isolated-1] [INFO] [1736165525.938922537] [lifecycle_manager_localization]: Configuring amcl
      [component_container_isolated-1] [INFO] [1736165525.938980421] [amcl]: Configuring
      [component_container_isolated-1] [INFO] [1736165525.939036257] [amcl]: initTransforms
      [component_container_isolated-1] [INFO] [1736165525.944107718] [amcl]: initPubSub
      [component_container_isolated-1] [INFO] [1736165525.945817082] [amcl]: Subscribed to map topic.
      [component_container_isolated-1] [INFO] [1736165525.946986840] [lifecycle_manager_localization]: Activating map_server
      [component_container_isolated-1] [INFO] [1736165525.947029528] [map_server]: Activating
      [component_container_isolated-1] [INFO] [1736165525.947081968] [map_server]: Creating bond (map_server) to lifecycle manager.
      [component_container_isolated-1] [INFO] [1736165525.947109751] [amcl]: Received a 194 X 142 map @ 0.050 m/pix
      [component_container_isolated-1] [INFO] [1736165526.040265512] [nav2_container]: Load Library: /opt/ros/humble/lib/libcontroller_server_core.so
      [component_container_isolated-1] [INFO] [1736165526.041604574] [nav2_container]: Found class: rclcpp_components::NodeFactoryTemplate<nav2_controller::ControllerServer>
      [component_container_isolated-1] [INFO] [1736165526.041636712] [nav2_container]: Instantiate class: rclcpp_components::NodeFactoryTemplate<nav2_controller::ControllerServer>
      [component_container_isolated-1] [INFO] [1736165526.045048787] [controller_server]:
      [component_container_isolated-1] 	controller_server lifecycle node launched.
      [component_container_isolated-1] [INFO] [1736165526.046656219] [controller_server]: Creating controller server
      [component_container_isolated-1] [INFO] [1736165526.048238024] [lifecycle_manager_localization]: Server map_server connected with bond.
      [component_container_isolated-1] [INFO] [1736165526.048260862] [lifecycle_manager_localization]: Activating amcl
      [component_container_isolated-1] [INFO] [1736165526.048318951] [amcl]: Activating
      [component_container_isolated-1] [INFO] [1736165526.048334193] [amcl]: Creating bond (amcl) to lifecycle manager.
      [rviz2-2] [INFO] [1736165526.048991529] [rviz2]: Stereo is NOT SUPPORTED
      [rviz2-2] [INFO] [1736165526.049069126] [rviz2]: OpenGl version: 4.6 (GLSL 4.6)
      [component_container_isolated-1] [INFO] [1736165526.052556579] [local_costmap.local_costmap]:
      [component_container_isolated-1] 	local_costmap lifecycle node launched.
      [component_container_isolated-1] [INFO] [1736165526.052788682] [local_costmap.local_costmap]: Creating Costmap
      [INFO] [launch_ros.actions.load_composable_nodes]: Loaded node '/controller_server' in container '/nav2_container'
      [component_container_isolated-1] [INFO] [1736165526.054151352] [nav2_container]: Load Library: /opt/ros/humble/lib/libsmoother_server_core.so
      [component_container_isolated-1] [INFO] [1736165526.054813122] [nav2_container]: Found class: rclcpp_components::NodeFactoryTemplate<nav2_smoother::SmootherServer>
      [component_container_isolated-1] [INFO] [1736165526.054821365] [nav2_container]: Instantiate class: rclcpp_components::NodeFactoryTemplate<nav2_smoother::SmootherServer>
      [component_container_isolated-1] [INFO] [1736165526.060887734] [smoother_server]:
      [component_container_isolated-1] 	smoother_server lifecycle node launched.
      [component_container_isolated-1] [INFO] [1736165526.062042238] [smoother_server]: Creating smoother server
      [INFO] [launch_ros.actions.load_composable_nodes]: Loaded node '/smoother_server' in container '/nav2_container'
      [component_container_isolated-1] [INFO] [1736165526.062980461] [nav2_container]: Load Library: /opt/ros/humble/lib/libplanner_server_core.so
      [component_container_isolated-1] [INFO] [1736165526.063581784] [nav2_container]: Found class: rclcpp_components::NodeFactoryTemplate<nav2_planner::PlannerServer>
      [component_container_isolated-1] [INFO] [1736165526.063594961] [nav2_container]: Instantiate class: rclcpp_components::NodeFactoryTemplate<nav2_planner::PlannerServer>
      [component_container_isolated-1] [INFO] [1736165526.067913204] [planner_server]:
      [component_container_isolated-1] 	planner_server lifecycle node launched.
      [component_container_isolated-1] [INFO] [1736165526.068636672] [planner_server]: Creating
      [component_container_isolated-1] [INFO] [1736165526.072326157] [global_costmap.global_costmap]:
      [component_container_isolated-1] 	global_costmap lifecycle node launched.
      [component_container_isolated-1] [INFO] [1736165526.072503205] [global_costmap.global_costmap]: Creating Costmap
      [INFO] [launch_ros.actions.load_composable_nodes]: Loaded node '/planner_server' in container '/nav2_container'
      [component_container_isolated-1] [INFO] [1736165526.074006990] [nav2_container]: Load Library: /opt/ros/humble/lib/libbehavior_server_core.so
      [component_container_isolated-1] [INFO] [1736165526.075243026] [nav2_container]: Found class: rclcpp_components::NodeFactoryTemplate<behavior_server::BehaviorServer>
      [component_container_isolated-1] [INFO] [1736165526.075253826] [nav2_container]: Instantiate class: rclcpp_components::NodeFactoryTemplate<behavior_server::BehaviorServer>
      [component_container_isolated-1] [INFO] [1736165526.079034730] [behavior_server]:
      [component_container_isolated-1] 	behavior_server lifecycle node launched.
      [rviz2-2] [INFO] [1736165526.080033040] [rviz2]: Stereo is NOT SUPPORTED
      [INFO] [launch_ros.actions.load_composable_nodes]: Loaded node '/behavior_server' in container '/nav2_container'
      [component_container_isolated-1] [INFO] [1736165526.080930356] [nav2_container]: Load Library: /opt/ros/humble/lib/libbt_navigator_core.so
      [component_container_isolated-1] [INFO] [1736165526.081689809] [nav2_container]: Found class: rclcpp_components::NodeFactoryTemplate<nav2_bt_navigator::BtNavigator>
      [component_container_isolated-1] [INFO] [1736165526.081697957] [nav2_container]: Instantiate class: rclcpp_components::NodeFactoryTemplate<nav2_bt_navigator::BtNavigator>
      [component_container_isolated-1] [INFO] [1736165526.086106307] [bt_navigator]:
      [component_container_isolated-1] 	bt_navigator lifecycle node launched.
      [component_container_isolated-1] [INFO] [1736165526.086131802] [bt_navigator]: Creating
      [INFO] [launch_ros.actions.load_composable_nodes]: Loaded node '/bt_navigator' in container '/nav2_container'
      [component_container_isolated-1] [INFO] [1736165526.087227724] [nav2_container]: Load Library: /opt/ros/humble/lib/libwaypoint_follower_core.so
      [component_container_isolated-1] [INFO] [1736165526.087521208] [nav2_container]: Found class: rclcpp_components::NodeFactoryTemplate<nav2_waypoint_follower::WaypointFollower>
      [component_container_isolated-1] [INFO] [1736165526.087527961] [nav2_container]: Instantiate class: rclcpp_components::NodeFactoryTemplate<nav2_waypoint_follower::WaypointFollower>
      [component_container_isolated-1] [INFO] [1736165526.091714054] [waypoint_follower]:
      [component_container_isolated-1] 	waypoint_follower lifecycle node launched.
      [component_container_isolated-1] [INFO] [1736165526.092058436] [waypoint_follower]: Creating
      [INFO] [launch_ros.actions.load_composable_nodes]: Loaded node '/waypoint_follower' in container '/nav2_container'
      [component_container_isolated-1] [INFO] [1736165526.093178791] [nav2_container]: Load Library: /opt/ros/humble/lib/libvelocity_smoother_core.so
      [component_container_isolated-1] [INFO] [1736165526.093522349] [nav2_container]: Found class: rclcpp_components::NodeFactoryTemplate<nav2_velocity_smoother::VelocitySmoother>
      [component_container_isolated-1] [INFO] [1736165526.093528566] [nav2_container]: Instantiate class: rclcpp_components::NodeFactoryTemplate<nav2_velocity_smoother::VelocitySmoother>
      [component_container_isolated-1] [INFO] [1736165526.097814398] [velocity_smoother]:
      [component_container_isolated-1] 	velocity_smoother lifecycle node launched.
      [INFO] [launch_ros.actions.load_composable_nodes]: Loaded node '/velocity_smoother' in container '/nav2_container'
      [component_container_isolated-1] [INFO] [1736165526.098787361] [nav2_container]: Found class: rclcpp_components::NodeFactoryTemplate<nav2_lifecycle_manager::LifecycleManager>
      [component_container_isolated-1] [INFO] [1736165526.098804780] [nav2_container]: Instantiate class: rclcpp_components::NodeFactoryTemplate<nav2_lifecycle_manager::LifecycleManager>
      [component_container_isolated-1] [INFO] [1736165526.102342063] [lifecycle_manager_navigation]: Creating
      [INFO] [launch_ros.actions.load_composable_nodes]: Loaded node '/lifecycle_manager_navigation' in container '/nav2_container'
      [component_container_isolated-1] [INFO] [1736165526.103203303] [lifecycle_manager_navigation]: Creating and initializing lifecycle service clients
      [component_container_isolated-1] [INFO] [1736165526.110831644] [lifecycle_manager_navigation]: Starting managed nodes bringup...
      [component_container_isolated-1] [INFO] [1736165526.110854515] [lifecycle_manager_navigation]: Configuring controller_server
      [component_container_isolated-1] [INFO] [1736165526.110919628] [controller_server]: Configuring controller interface
      [component_container_isolated-1] [INFO] [1736165526.111033561] [controller_server]: getting goal checker plugins..
      [component_container_isolated-1] [INFO] [1736165526.111085975] [controller_server]: Controller frequency set to 20.0000Hz
      [component_container_isolated-1] [INFO] [1736165526.111102279] [local_costmap.local_costmap]: Configuring
      [component_container_isolated-1] [INFO] [1736165526.112681222] [local_costmap.local_costmap]: Using plugin "voxel_layer"
      [component_container_isolated-1] [INFO] [1736165526.114063194] [local_costmap.local_costmap]: Subscribed to Topics: scan
      [component_container_isolated-1] [INFO] [1736165526.116397648] [local_costmap.local_costmap]: Initialized plugin "voxel_layer"
      [component_container_isolated-1] [INFO] [1736165526.116411831] [local_costmap.local_costmap]: Using plugin "inflation_layer"
      [component_container_isolated-1] [INFO] [1736165526.116741469] [local_costmap.local_costmap]: Initialized plugin "inflation_layer"
      [component_container_isolated-1] [INFO] [1736165526.119832482] [controller_server]: Created progress_checker : progress_checker of type nav2_controller::SimpleProgressChecker
      [component_container_isolated-1] [INFO] [1736165526.120337215] [controller_server]: Created goal checker : general_goal_checker of type nav2_controller::SimpleGoalChecker
      [component_container_isolated-1] [INFO] [1736165526.120655514] [controller_server]: Controller Server has general_goal_checker  goal checkers available.
      [component_container_isolated-1] [INFO] [1736165526.121454793] [controller_server]: Created controller : FollowPath of type dwb_core::DWBLocalPlanner
      [component_container_isolated-1] [INFO] [1736165526.122236125] [controller_server]: Setting transform_tolerance to 0.200000
      [component_container_isolated-1] [INFO] [1736165526.127303965] [controller_server]: Using critic "RotateToGoal" (dwb_critics::RotateToGoalCritic)
      [component_container_isolated-1] [INFO] [1736165526.127558306] [controller_server]: Critic plugin initialized
      [component_container_isolated-1] [INFO] [1736165526.127610890] [controller_server]: Using critic "Oscillation" (dwb_critics::OscillationCritic)
      [component_container_isolated-1] [INFO] [1736165526.127870959] [controller_server]: Critic plugin initialized
      [component_container_isolated-1] [INFO] [1736165526.128001651] [controller_server]: Using critic "BaseObstacle" (dwb_critics::BaseObstacleCritic)
      [component_container_isolated-1] [INFO] [1736165526.128180062] [controller_server]: Critic plugin initialized
      [component_container_isolated-1] [INFO] [1736165526.128281202] [controller_server]: Using critic "GoalAlign" (dwb_critics::GoalAlignCritic)
      [component_container_isolated-1] [INFO] [1736165526.128584908] [controller_server]: Critic plugin initialized
      [component_container_isolated-1] [INFO] [1736165526.128694741] [controller_server]: Using critic "PathAlign" (dwb_critics::PathAlignCritic)
      [component_container_isolated-1] [INFO] [1736165526.129081396] [controller_server]: Critic plugin initialized
      [component_container_isolated-1] [INFO] [1736165526.129173143] [controller_server]: Using critic "PathDist" (dwb_critics::PathDistCritic)
      [component_container_isolated-1] [INFO] [1736165526.129304721] [controller_server]: Critic plugin initialized
      [component_container_isolated-1] [INFO] [1736165526.129364325] [controller_server]: Using critic "GoalDist" (dwb_critics::GoalDistCritic)
      [component_container_isolated-1] [INFO] [1736165526.129466876] [controller_server]: Critic plugin initialized
      [component_container_isolated-1] [INFO] [1736165526.129474779] [controller_server]: Controller Server has FollowPath  controllers available.
      [component_container_isolated-1] [INFO] [1736165526.134081910] [lifecycle_manager_navigation]: Configuring smoother_server
      [component_container_isolated-1] [INFO] [1736165526.134144749] [smoother_server]: Configuring smoother server
      [component_container_isolated-1] [INFO] [1736165526.136860117] [smoother_server]: Created smoother : simple_smoother of type nav2_smoother::SimpleSmoother
      [component_container_isolated-1] [INFO] [1736165526.137235675] [smoother_server]: Smoother Server has simple_smoother  smoothers available.
      [component_container_isolated-1] [INFO] [1736165526.139122775] [lifecycle_manager_navigation]: Configuring planner_server
      [component_container_isolated-1] [INFO] [1736165526.139173382] [planner_server]: Configuring
      [component_container_isolated-1] [INFO] [1736165526.139197077] [global_costmap.global_costmap]: Configuring
      [component_container_isolated-1] [WARN] [1736165526.139383760] [amcl]: New subscription discovered on topic '/particle_cloud', requesting incompatible QoS. No messages will be sent to it. Last incompatible policy: RELIABILITY_QOS_POLICY
      [component_container_isolated-1] [INFO] [1736165526.141244541] [global_costmap.global_costmap]: Using plugin "static_layer"
      [component_container_isolated-1] [INFO] [1736165526.141752206] [global_costmap.global_costmap]: Subscribing to the map topic (/map) with transient local durability
      [component_container_isolated-1] [INFO] [1736165526.142176625] [global_costmap.global_costmap]: Initialized plugin "static_layer"
      [component_container_isolated-1] [INFO] [1736165526.142193470] [global_costmap.global_costmap]: Using plugin "obstacle_layer"
      [component_container_isolated-1] [INFO] [1736165526.142830741] [global_costmap.global_costmap]: Subscribed to Topics: scan
      [component_container_isolated-1] [INFO] [1736165526.145291798] [global_costmap.global_costmap]: Initialized plugin "obstacle_layer"
      [component_container_isolated-1] [INFO] [1736165526.145314737] [global_costmap.global_costmap]: Using plugin "inflation_layer"
      [component_container_isolated-1] [INFO] [1736165526.146095161] [global_costmap.global_costmap]: Initialized plugin "inflation_layer"
      [component_container_isolated-1] [INFO] [1736165526.150609911] [lifecycle_manager_localization]: Server amcl connected with bond.
      [component_container_isolated-1] [INFO] [1736165526.150631920] [lifecycle_manager_localization]: Managed nodes are active
      [component_container_isolated-1] [INFO] [1736165526.150637972] [lifecycle_manager_localization]: Creating bond timer...
      [component_container_isolated-1] [INFO] [1736165526.150703562] [planner_server]: Created global planner plugin GridBased of type nav2_navfn_planner/NavfnPlanner
      [component_container_isolated-1] [INFO] [1736165526.150718931] [planner_server]: Configuring plugin GridBased of type NavfnPlanner
      [component_container_isolated-1] [INFO] [1736165526.150980175] [planner_server]: Planner Server has GridBased  planners available.
      [component_container_isolated-1] [INFO] [1736165526.155926548] [lifecycle_manager_navigation]: Configuring behavior_server
      [component_container_isolated-1] [INFO] [1736165526.155990808] [behavior_server]: Configuring
      [component_container_isolated-1] [INFO] [1736165526.159366231] [behavior_server]: Creating behavior plugin spin of type nav2_behaviors/Spin
      [component_container_isolated-1] [INFO] [1736165526.160021416] [behavior_server]: Configuring spin
      [component_container_isolated-1] [INFO] [1736165526.163080438] [behavior_server]: Creating behavior plugin backup of type nav2_behaviors/BackUp
      [component_container_isolated-1] [INFO] [1736165526.163475008] [behavior_server]: Configuring backup
      [component_container_isolated-1] [INFO] [1736165526.165744606] [behavior_server]: Creating behavior plugin drive_on_heading of type nav2_behaviors/DriveOnHeading
      [component_container_isolated-1] [INFO] [1736165526.166364731] [behavior_server]: Configuring drive_on_heading
      [component_container_isolated-1] [INFO] [1736165526.169293159] [behavior_server]: Creating behavior plugin assisted_teleop of type nav2_behaviors/AssistedTeleop
      [component_container_isolated-1] [INFO] [1736165526.170015375] [behavior_server]: Configuring assisted_teleop
      [component_container_isolated-1] [INFO] [1736165526.174198357] [behavior_server]: Creating behavior plugin wait of type nav2_behaviors/Wait
      [component_container_isolated-1] [INFO] [1736165526.174576700] [behavior_server]: Configuring wait
      [component_container_isolated-1] [INFO] [1736165526.177096902] [lifecycle_manager_navigation]: Configuring bt_navigator
      [component_container_isolated-1] [INFO] [1736165526.177156115] [bt_navigator]: Configuring
      [component_container_isolated-1] [INFO] [1736165526.196164715] [amcl]: createLaserObject
      [rviz2-2] [INFO] [1736165526.210291827] [rviz2]: Trying to create a map of size 194 x 142 using 1 swatches
      [component_container_isolated-1] [INFO] [1736165526.210521296] [lifecycle_manager_navigation]: Configuring waypoint_follower
      [component_container_isolated-1] [INFO] [1736165526.210571665] [waypoint_follower]: Configuring
      [component_container_isolated-1] [INFO] [1736165526.212095044] [global_costmap.global_costmap]: StaticLayer: Resizing costmap to 194 X 142 at 0.050000 m/pix
      [component_container_isolated-1] [INFO] [1736165526.215522723] [waypoint_follower]: Created waypoint_task_executor : wait_at_waypoint of type nav2_waypoint_follower::WaitAtWaypoint
      [component_container_isolated-1] [INFO] [1736165526.215833340] [lifecycle_manager_navigation]: Configuring velocity_smoother
      [component_container_isolated-1] [INFO] [1736165526.215905475] [velocity_smoother]: Configuring velocity smoother
      [component_container_isolated-1] [INFO] [1736165526.218132737] [lifecycle_manager_navigation]: Activating controller_server
      [component_container_isolated-1] [INFO] [1736165526.218184472] [controller_server]: Activating
      [component_container_isolated-1] [INFO] [1736165526.218201437] [local_costmap.local_costmap]: Activating
      [component_container_isolated-1] [INFO] [1736165526.218207618] [local_costmap.local_costmap]: Checking transform
      [component_container_isolated-1] [INFO] [1736165526.218257537] [local_costmap.local_costmap]: start
      [component_container_isolated-1] [INFO] [1736165526.468671355] [controller_server]: Creating bond (controller_server) to lifecycle manager.
      [component_container_isolated-1] [INFO] [1736165526.570545667] [lifecycle_manager_navigation]: Server controller_server connected with bond.
      [component_container_isolated-1] [INFO] [1736165526.570567917] [lifecycle_manager_navigation]: Activating smoother_server
      [component_container_isolated-1] [INFO] [1736165526.570688258] [smoother_server]: Activating
      [component_container_isolated-1] [INFO] [1736165526.570707246] [smoother_server]: Creating bond (smoother_server) to lifecycle manager.
      [component_container_isolated-1] [INFO] [1736165526.672567314] [lifecycle_manager_navigation]: Server smoother_server connected with bond.
      [component_container_isolated-1] [INFO] [1736165526.672592003] [lifecycle_manager_navigation]: Activating planner_server
      [component_container_isolated-1] [INFO] [1736165526.672758423] [planner_server]: Activating
      [component_container_isolated-1] [INFO] [1736165526.672871822] [global_costmap.global_costmap]: Activating
      [component_container_isolated-1] [INFO] [1736165526.672884287] [global_costmap.global_costmap]: Checking transform
      [component_container_isolated-1] [INFO] [1736165526.672888472] [global_costmap.global_costmap]: Timed out waiting for transform from base_link to map to become available, tf error: Invalid frame ID "map" passed to canTransform argument target_frame - frame does not exist
      [component_container_isolated-1] [INFO] [1736165527.172989469] [global_costmap.global_costmap]: Timed out waiting for transform from base_link to map to become available, tf error: Invalid frame ID "map" passed to canTransform argument target_frame - frame does not exist
      [component_container_isolated-1] [ERROR] [1736165527.198757538] [amcl]: Couldn't transform from laser_frame to base_footprint, even though the message notifier is in use: (Could not find a connection between 'base_footprint' and 'laser_frame' because they are not part of the same tree.Tf has two or more unconnected trees.)
      [component_container_isolated-1] [INFO] [1736165527.198839246] [amcl]: Message Filter dropping message: frame 'laser_frame' at time 1736165525.825 for reason 'the timestamp on the message is earlier than all the data in the transform cache'
      [component_container_isolated-1] [INFO] [1736165527.198861696] [amcl]: Message Filter dropping message: frame 'laser_frame' at time 1736165525.949 for reason 'the timestamp on the message is earlier than all the data in the transform cache'
      [component_container_isolated-1] [INFO] [1736165527.198893029] [amcl]: createLaserObject
      [rviz2-2] [INFO] [1736165527.413713513] [rviz2]: Message Filter dropping message: frame 'laser_frame' at time 1736165526.068 for reason 'discarding message because the queue is full'
      [rviz2-2] [INFO] [1736165527.541350810] [rviz2]: Message Filter dropping message: frame 'laser_frame' at time 1736165526.196 for reason 'discarding message because the queue is full'
      [rviz2-2] [INFO] [1736165527.669900293] [rviz2]: Message Filter dropping message: frame 'laser_frame' at time 1736165526.321 for reason 'discarding message because the queue is full'
      [component_container_isolated-1] [INFO] [1736165527.672985186] [global_costmap.global_costmap]: Timed out waiting for transform from base_link to map to become available, tf error: Invalid frame ID "map" passed to canTransform argument target_frame - frame does not exist
      [rviz2-2] [INFO] [1736165527.861174277] [rviz2]: Message Filter dropping message: frame 'laser_frame' at time 1736165526.432 for reason 'discarding message because the queue is full'
      [rviz2-2] [INFO] [1736165527.925488046] [rviz2]: Message Filter dropping message: frame 'laser_frame' at time 1736165526.558 for reason 'discarding message because the queue is full'
      [rviz2-2] [INFO] [1736165528.053612196] [rviz2]: Message Filter dropping message: frame 'laser_frame' at time 1736165526.690 for reason 'discarding message because the queue is full'
      [component_container_isolated-1] [INFO] [1736165528.172944087] [global_costmap.global_costmap]: Timed out waiting for transform from base_link to map to become available, tf error: Invalid frame ID "map" passed to canTransform argument target_frame - frame does not exist
      [rviz2-2] [INFO] [1736165528.181670689] [rviz2]: Message Filter dropping message: frame 'laser_frame' at time 1736165526.806 for reason 'discarding message because the queue is full'
      [component_container_isolated-1] [ERROR] [1736165528.210180786] [amcl]: Couldn't transform from laser_frame to base_footprint, even though the message notifier is in use: (Could not find a connection between 'base_footprint' and 'laser_frame' because they are not part of the same tree.Tf has two or more unconnected trees.)
      [component_container_isolated-1] [INFO] [1736165528.210261831] [amcl]: createLaserObject
      [rviz2-2] [INFO] [1736165528.277591852] [rviz2]: Message Filter dropping message: frame 'laser_frame' at time 1736165526.920 for reason 'discarding message because the queue is full'
      [rviz2-2] [INFO] [1736165528.405278718] [rviz2]: Message Filter dropping message: frame 'laser_frame' at time 1736165527.051 for reason 'discarding message because the queue is full'
      [rviz2-2] [INFO] [1736165528.437762437] [rviz2]: Message Filter dropping message: frame 'odom' at time 1736165526.369 for reason 'discarding message because the queue is full'
        小鱼 技术大佬 @liusiyu_alex_nuaa
        @liusiyu_alex_nuaa 你的操作系统版本和ROS2的版本?
        liusiyu_alex_nuaaL 1 条回复 最后回复 回复 引用 0
          小鱼 技术大佬 @小鱼
          @小鱼 开启导航后再给我看看 rqt_tf_tree的样子
            @小鱼 对的,ROS2 humble Ubuntu22.04 前面一直跟着教程做的
              小鱼 技术大佬 @小鱼
              @小鱼 在 fishbot 机器人导航出错,无法初始化位置 中说:
                  @liusiyu_alex_nuaa 这个urdf模型在哪里
                    @小鱼 是你的例程
                    ~/fishbot_nav/src/fishbot_description/urdf
                      @liusiyu_alex_nuaa 内容
                        <?xml version="1.0"?>
                        <robot name="fishbot">
                          <link name="base_footprint" />
                          <!-- base link -->
                          <link name="base_link">
                          <visual>
                            <origin xyz="0 0 0.0" rpy="0 0 0" />
                            <geometry>
                              <cylinder length="0.12" radius="0.10" />
                            </geometry>
                            <material name="blue">
                            </material>
                          </visual>
                          </link>
                            <parent link="base_footprint" />
                            <child link="base_link" />
                            <origin xyz="0.0 0.0 0.076" rpy="0 0 0" />
                          </joint>
                          <!-- laser link -->
                          <link name="laser_link">
                          <visual>
                            <origin xyz="0 0 0" rpy="0 0 0" />
                            <geometry>
                              <cylinder length="0.02" radius="0.02" />
                            </geometry>
                            <material name="black">
                            </material>
                          </visual>
                          </link>
                            <parent link="base_link" />
                            <child link="laser_link" />
                            <origin xyz="0 0 0.075" rpy="0 0 0" />
                          </joint>
                          <!-- laser link -->
                          <link name="laser_frame">
                          <visual>
                            <geometry>
                            </geometry>
                            </material>
                          </visual>
                          </link>
                          <joint name="laser_frame_joint" type="fixed">
                            <child link="laser_frame" />
                          </joint>
                        </robot>
                          @liusiyu_alex_nuaa 使用的是哪个分支的文件
                            @小鱼 用这个代码从github上下载的
                            git clone https://github.com/fishros/fishbot_nav.git --depth=1
                              @liusiyu_alex_nuaa 小车的固件版本是?
                                电机驱动版本
                                https://fishros.org.cn/forum/assets/uploads/files/1732182619815-fishbot_motion_control_v1.7.0.beta.241121.bin
                                雷达驱动版本
                                都是配置工具默认的
                                  liusiyu_alex_nuaa @liusiyu_alex_nuaa
                                  @liusiyu_alex_nuaa 在 fishbot 机器人导航出错,无法初始化位置 中说:
                                  ot_motion_contro
                                  雷达的驱动写错了
                                  https://fishros.org.cn/forum/assets/uploads/files/1735192057607-fishbot_laser_control_v1.3.0.alpha.241226.bin
                                    @liusiyu_alex_nuaa 看主控板的
                                        @liusiyu_alex_nuaa 稍等一下,我给你一个新版本的固件
                                          @liusiyu_alex_nuaa https://github.fishros.org/https://github.com/fishros/fishbot_motion_control_microros/releases/download/v1.7.2.alpha/fishbot_motion_control_v1.7.2.alpha.241229.bin
                                            小鱼 技术大佬 @小鱼
                                            @小鱼 用这个固件试试,固件地址填写这个
                                            liusiyu_alex_nuaaL 2 条回复 最后回复 回复 引用 0
