    vm虚拟机+ubuntu20+ros2,添加接口后报错,cmake过不去
    ros2 添加接口 cmake报错
    18.0k
      小鱼 技术大佬 @练剑的书生
      @练剑的书生 可以用复制粘贴的方式把报错贴一下吗,我好去检索下
      练剑的书生练 1 条回复 最后回复 回复 引用 0
      • 练剑的书生练
        练剑的书生 @小鱼
        gsl@gsl-virtual-machine:~/桌面/colcon_test/town_ws$ colcon build
        Starting >>> village_interfaces
        Starting >>> village_li
        --- stderr: village_interfaces
        CMake Error at /opt/ros/foxy/share/rosidl_cmake/cmake/rosidl_generate_interfaces.cmake:240 (list):
        CMake Error at /opt/ros/foxy/share/rosidl_generator_c/cmake/rosidl_generator_c_generate_interfaces.cmake:65 (message):
          Target dependency
          '/colcon_test/town_ws/build/village_interfaces/rosidl_adapter/village_interfaces/msg/Novel.idl'
          does not exist
          /opt/ros/foxy/share/ament_cmake_core/cmake/core/ament_execute_extensions.cmake:48 (include)
          /opt/ros/foxy/share/rosidl_cmake/cmake/rosidl_generate_interfaces.cmake:286 (ament_execute_extensions)
        make: *** [Makefile:222:cmake_check_build_system] 错误 1
        Failed   <<< village_interfaces [1.01s, exited with code 2]
        Aborted  <<< village_li [1.20s]
        Summary: 0 packages finished [1.42s]
          1 package failed: village_interfaces
          1 package aborted: village_li
          1 package had stderr output: village_interfaces
          1 package not processed
          小鱼 技术大佬 @练剑的书生
          @练剑的书生 我找了下源码测试下,发现没有问题,同foxy版本。
          root@097c0c2d6b66:/home/mouse/code/github/ros2_town# colcon build
          Finished <<< village_interfaces [6.30s]
          Starting >>> village_wang
          Starting >>> village_zhang
          Finished <<< village_li [0.89s]
          Finished <<< village_zhang [4.31s]
          Finished <<< village_wang [7.31s]
          Summary: 4 packages finished [13.7s]
          root@097c0c2d6b66:/home/mouse/code/github/ros2_town# echo $ROS_DISTRO
          foxy
          源码地址:https://github.com/fishros/ros2_town
          请你下载源码后直接编译看看,排除是代码问题
          • 练剑的书生练
            练剑的书生 @小鱼
            @小鱼 下载下来编译还是这个样子,像是cmake环境有问题了
              小鱼 技术大佬 @练剑的书生
              @练剑的书生 你装的是桌面版的ROS2吗,我也怀疑编译工具问题,你在village_interfaces文件夹下试一下下面的语句
              mkdir build
              cd build
              cmake ..
              make
              • 练剑的书生练
                练剑的书生 @小鱼
                @小鱼 是桌面版
                -- The C compiler identification is GNU 9.4.0
                -- The CXX compiler identification is GNU 9.4.0
                -- Check for working C compiler: /usr/bin/cc
                -- Check for working C compiler: /usr/bin/cc -- works
                -- Check for working CXX compiler: /usr/bin/c++
                -- Check for working CXX compiler: /usr/bin/c++ -- works
                -- Found ament_cmake: 0.9.9 (/opt/ros/foxy/share/ament_cmake/cmake)
                -- Found PythonInterp: /usr/bin/python3 (found suitable version "3.8.10", minimum required is "3")
                -- Using PYTHON_EXECUTABLE: /usr/bin/python3
                -- Found sensor_msgs: 2.0.5 (/opt/ros/foxy/share/sensor_msgs/cmake)
                -- Found rosidl_adapter: 1.2.1 (/opt/ros/foxy/share/rosidl_adapter/cmake)
                -- Found OpenSSL: /usr/lib/x86_64-linux-gnu/libcrypto.so (found version "1.1.1f")
                -- Found FastRTPS: /opt/ros/foxy/include
                -- Found rosidl_default_generators: 1.0.1 (/opt/ros/foxy/share/rosidl_default_generators/cmake)
                -- Found PythonInterp: /usr/bin/python3 (found version "3.8.10")
                CMakeLists.txt:26 (rosidl_generate_interfaces)
                Target dependency
                '/src/examples/src/village_interfaces/build/rosidl_adapter/village_interfaces/msg/Novel.idl'
                does not exist
                See also "/home/gsl/桌面/src/examples/src/village_interfaces/build/CMakeFiles/CMakeOutput.log".
                  小鱼 技术大佬 @练剑的书生
                  @练剑的书生 先去掉sensor_msgs依赖以及Novel.msg中的image字段试试
                  • 练剑的书生练
                    练剑的书生 @小鱼
                    @小鱼 Starting >>> village_interfaces
                    CMake Error at /opt/ros/foxy/share/rosidl_cmake/cmake/rosidl_generate_interfaces.cmake:162 (message):
                    rosidl_generate_interfaces() the passed dependency 'sensor_msgs' has not
                    been found before using find_package()
                    Failed <<< village_interfaces [0.45s, exited with code 1]
                    Summary: 0 packages finished [0.65s]
                    3 packages not processed
                    小鱼小 练剑的书生练 2 条回复 最后回复 回复 引用 0
                      小鱼 技术大佬 @练剑的书生
                      @练剑的书生 在 vm虚拟机+ubuntu20+ros2,添加接口后报错,cmake过不去 中说:
                      看到这个错误了,你把CMakeLists.txt中的find_package(sensor_msgs)去掉
                      • 练剑的书生练
                        练剑的书生 @练剑的书生
                        @练剑的书生 屏蔽了之后编译是这样的
                          小鱼 技术大佬 @练剑的书生
                          @练剑的书生 贴一下你的CMakeLists.txt,应该是没删除干净
                          • 练剑的书生练
                            练剑的书生 @小鱼
                            @小鱼 cmake_minimum_required(VERSION 3.5)
                            project(village_interfaces)
                            Default to C99
                            if(NOT CMAKE_C_STANDARD)
                            set(CMAKE_C_STANDARD 99)
                            endif()
                            Default to C++14
                            if(NOT CMAKE_CXX_STANDARD)
                            set(CMAKE_CXX_STANDARD 14)
                            endif()
                            endif()
                            find dependencies
                            #find_package(sensor_msgs REQUIRED)
                            uncomment the following section in order to fill in
                            further dependencies manually.
                            find_package(<dependency> REQUIRED)
                            if(BUILD_TESTING)
                            the following line skips the linter which checks for copyrights
                            uncomment the line when a copyright and license is not present in all source files
                            uncomment the line when this package is not in a git repo
                            endif()
                            "msg/Novel.msg"
                            DEPENDENCIES sensor_msgs
                            ament_package()
                              小鱼 技术大佬 @练剑的书生
                              这里的也要删掉,另外记得用代码块包裹下
                              代码块
                              练剑的书生练 1 条回复 最后回复 回复 引用 1
                              • 练剑的书生练
                                练剑的书生 @小鱼
                                全部屏蔽了才正常
