    vm虚拟机+ubuntu20+ros2,添加接口后报错,cmake过不去
    ros2 添加接口 cmake报错
    14.9k
    • 练剑的书生练
      练剑的书生 @小鱼
      @小鱼 下载下来编译还是这个样子,像是cmake环境有问题了
        小鱼 技术大佬 @练剑的书生
        @练剑的书生 你装的是桌面版的ROS2吗,我也怀疑编译工具问题,你在village_interfaces文件夹下试一下下面的语句
        mkdir build
        cd build
        cmake ..
        make
        练剑的书生练 1 条回复 最后回复 回复 引用 0
        • 练剑的书生练
          练剑的书生 @小鱼
          @小鱼 是桌面版
          -- The C compiler identification is GNU 9.4.0
          -- The CXX compiler identification is GNU 9.4.0
          -- Check for working C compiler: /usr/bin/cc
          -- Check for working C compiler: /usr/bin/cc -- works
          -- Check for working CXX compiler: /usr/bin/c++
          -- Check for working CXX compiler: /usr/bin/c++ -- works
          -- Found ament_cmake: 0.9.9 (/opt/ros/foxy/share/ament_cmake/cmake)
          -- Found PythonInterp: /usr/bin/python3 (found suitable version "3.8.10", minimum required is "3")
          -- Using PYTHON_EXECUTABLE: /usr/bin/python3
          -- Found sensor_msgs: 2.0.5 (/opt/ros/foxy/share/sensor_msgs/cmake)
          -- Found rosidl_adapter: 1.2.1 (/opt/ros/foxy/share/rosidl_adapter/cmake)
          -- Found OpenSSL: /usr/lib/x86_64-linux-gnu/libcrypto.so (found version "1.1.1f")
          -- Found FastRTPS: /opt/ros/foxy/include
          -- Found rosidl_default_generators: 1.0.1 (/opt/ros/foxy/share/rosidl_default_generators/cmake)
          -- Found PythonInterp: /usr/bin/python3 (found version "3.8.10")
          CMake Error at /opt/ros/foxy/share/rosidl_cmake/cmake/rosidl_generate_interfaces.cmake:240 (list):
          CMakeLists.txt:26 (rosidl_generate_interfaces)
          CMake Error at /opt/ros/foxy/share/rosidl_generator_c/cmake/rosidl_generator_c_generate_interfaces.cmake:65 (message):
          Target dependency
          '/src/examples/src/village_interfaces/build/rosidl_adapter/village_interfaces/msg/Novel.idl'
          does not exist
          /opt/ros/foxy/share/ament_cmake_core/cmake/core/ament_execute_extensions.cmake:48 (include)
          /opt/ros/foxy/share/rosidl_cmake/cmake/rosidl_generate_interfaces.cmake:286 (ament_execute_extensions)
          See also "/home/gsl/桌面/src/examples/src/village_interfaces/build/CMakeFiles/CMakeOutput.log".
            小鱼 技术大佬 @练剑的书生
            @练剑的书生 先去掉sensor_msgs依赖以及Novel.msg中的image字段试试
            • 练剑的书生练
              练剑的书生 @小鱼
              @小鱼 Starting >>> village_interfaces
              --- stderr: village_interfaces
              CMake Error at /opt/ros/foxy/share/rosidl_cmake/cmake/rosidl_generate_interfaces.cmake:162 (message):
              rosidl_generate_interfaces() the passed dependency 'sensor_msgs' has not
              been found before using find_package()
              Failed <<< village_interfaces [0.45s, exited with code 1]
              Summary: 0 packages finished [0.65s]
              1 package failed: village_interfaces
              1 package had stderr output: village_interfaces
              3 packages not processed
              小鱼小 练剑的书生练 2 条回复 最后回复 回复 引用 0
                小鱼 技术大佬 @练剑的书生
                @练剑的书生 在 vm虚拟机+ubuntu20+ros2,添加接口后报错,cmake过不去 中说:
                看到这个错误了,你把CMakeLists.txt中的find_package(sensor_msgs)去掉
                • 练剑的书生练
                  练剑的书生 @练剑的书生
                  @练剑的书生 屏蔽了之后编译是这样的
                    小鱼 技术大佬 @练剑的书生
                    @练剑的书生 贴一下你的CMakeLists.txt,应该是没删除干净
                    • 练剑的书生练
                      练剑的书生 @小鱼
                      @小鱼 cmake_minimum_required(VERSION 3.5)
                      project(village_interfaces)
                      Default to C99
                      if(NOT CMAKE_C_STANDARD)
                      set(CMAKE_C_STANDARD 99)
                      endif()
                      Default to C++14
                      if(NOT CMAKE_CXX_STANDARD)
                      set(CMAKE_CXX_STANDARD 14)
                      endif()
                      endif()
                      find dependencies
                      #find_package(sensor_msgs REQUIRED)
                      uncomment the following section in order to fill in
                      further dependencies manually.
                      find_package(<dependency> REQUIRED)
                      if(BUILD_TESTING)
                      the following line skips the linter which checks for copyrights
                      uncomment the line when a copyright and license is not present in all source files
                      uncomment the line when this package is not in a git repo
                      endif()
                      "msg/Novel.msg"
                      DEPENDENCIES sensor_msgs
                      ament_package()
                        小鱼 技术大佬 @练剑的书生
                        这里的也要删掉,另外记得用代码块包裹下
                        代码块
                        练剑的书生练 1 条回复 最后回复 回复 引用 1
                        • 练剑的书生练
                          练剑的书生 @小鱼
                          全部屏蔽了才正常
