    fishbot上有IMU模块,但是第九章最后的小车代码没有IMU部分,想知道这部分代码如何编写
    fishbot imu
    19.2k
      1257261547 @小鱼
        1257261547 @1257261547
        @1257261547bringup.launch.py ```
        code_text
        import launch_ros
            fishbot_bringup_dir = get_package_share_directory(
                'xbwbot_bringup')
            ydlidar_ros2_dir = get_package_share_directory(
                'ydlidar')
            urdf2tf = launch.actions.IncludeLaunchDescription(
                    [fishbot_bringup_dir, '/launch', '/urdf2tf.launch.py']),
            microros_agent = launch_ros.actions.Node(
                package='micro_ros_agent',
                executable='micro_ros_agent',
                arguments=['udp4','--port','8888'],
                output='screen'
            ros_serail2wifi =  launch_ros.actions.Node(
                package='ros_serail2wifi',
                executable='tcp_server',
                parameters=[{'serial_port': '/tmp/tty_laser'}],
                output='screen'
            ydlidar = launch.actions.IncludeLaunchDescription(
                    [ydlidar_ros2_dir, '/launch', '/ydlidar_launch.py']),
            # 使用 TimerAction 启动后 5 秒执行 ydlidar 节点
            ydlidar_delay = launch.actions.TimerAction(period=5.0, actions=[ydlidar])
                urdf2tf,
                microros_agent,
                ros_serail2wifi,
                ydlidar_delay
        odom2tf.cpp
        code_text
        #include <rclcpp/rclcpp.hpp>
        #include <tf2/utils.h>
        #include <geometry_msgs/msg/transform_stamped.hpp>
        class OdomTopic2TF : public rclcpp::Node {
        public:
          OdomTopic2TF(std::string name) : Node(name) {
            // 创建 odom 话题订阅者,使用传感器数据的 Qos
                std::bind(&OdomTopic2TF::odom_callback_, this, std::placeholders::_1));
            tf_broadcaster_ = std::make_unique<tf2_ros::TransformBroadcaster>(this);
        private:
          // 回调函数,处理接收到的odom消息,并发布tf
          void odom_callback_(const nav_msgs::msg::Odometry::SharedPtr msg) {
            transform.header = msg->header; // 使用消息的时间戳和框架ID
            transform.child_frame_id = msg->child_frame_id;
            transform.transform.translation.x = msg->pose.pose.position.x;
            transform.transform.translation.y = msg->pose.pose.position.y;
            transform.transform.translation.z = msg->pose.pose.position.z;
            transform.transform.rotation.x = msg->pose.pose.orientation.x;
            transform.transform.rotation.y = msg->pose.pose.orientation.y;
            transform.transform.rotation.z = msg->pose.pose.orientation.z;
            transform.transform.rotation.w = msg->pose.pose.orientation.w;
            // 广播坐标变换信息
        int main(int argc, char **argv) {
          rclcpp::init(argc, argv);
          auto node = std::make_shared<OdomTopic2TF>("odom2tf");
          rclcpp::spin(node);
          rclcpp::shutdown();
          return 0;
        navigation2.launch.py
        code_text
        import launch
        import launch_ros
            # 获取与拼接默认路径
            fishbot_navigation2_dir = get_package_share_directory(
                'xbwbot_navigation2')
            rviz_config_dir = os.path.join(
                nav2_bringup_dir, 'rviz', 'nav2_default_view.rviz')
            # 创建 Launch 配置
            use_sim_time = launch.substitutions.LaunchConfiguration(
                'use_sim_time', default='true')
            map_yaml_path = launch.substitutions.LaunchConfiguration(
                'map', default=os.path.join(fishbot_navigation2_dir, 'maps', 'room.yaml'))
            nav2_param_path = launch.substitutions.LaunchConfiguration(
                'params_file', default=os.path.join(fishbot_navigation2_dir, 'config', 'nav2_params.yaml'))
                # 声明新的 Launch 参数
                launch.actions.DeclareLaunchArgument('use_sim_time', default_value=use_sim_time,
                                                     description='Use simulation (Gazebo) clock if true'),
                launch.actions.DeclareLaunchArgument('map', default_value=map_yaml_path,
                                                     description='Full path to map file to load'),
                launch.actions.DeclareLaunchArgument('params_file', default_value=nav2_param_path,
                                                     description='Full path to param file to load'),
                        [nav2_bringup_dir, '/launch', '/bringup_launch.py']),
                    # 使用 Launch 参数替换原有参数
                    launch_arguments={
                        'map': map_yaml_path,
                        'use_sim_time': use_sim_time,
                    package='rviz2',
                    executable='rviz2',
                    name='rviz2',
                    output='screen'),
        odom_ekf.launch.py
        code_text
        import launch
        import launch_ros
            package_name = 'xbwbot_navigation2'
            ld =  launch.LaunchDescription()
            pkg_share = launch_ros.substitutions.FindPackageShare(package=package_name).find(package_name)
            robot_localization_node = launch_ros.actions.Node(
                package='robot_localization',
                executable='ekf_node',
                name='ekf_filter_node',
                output='screen',
                parameters=[os.path.join(pkg_share, 'config/ekf.yaml'), {'use_sim_time': launch.substitutions.LaunchConfiguration('use_sim_time')}],
                remappings=[('odometry/filtered', 'odom')],
            ld.add_action(launch.actions.DeclareLaunchArgument(name='use_sim_time', default_value='True',
                                                        description='Flag to enable use_sim_time'))
            ld.add_action(robot_localization_node)
            return ld
          小鱼 技术大佬 @1257261547
          @1257261547 这个是电脑的发布的话题,不是小车发的,这样查不对
            小鱼 技术大佬 @1257261547
            @1257261547 你先切回不融合的导航,判断一下小车这边有没有问题
              1257261547 @小鱼
              启动bringup.launch.py后rqt图像,导航也不能正常运行
                code_text
                main.cpp
                #include <Arduino.h>
                #include <Esp32PcntEncoder.h>
                #include <Esp32McpwmMotor.h>
                #include <PidController.h>
                #include <Kinematics.h>
                #include <Warning.h>
                #include <ImuDriver.h>
                #include <WiFi.h>
                #include <rcl/rcl.h>
                #include <rclc/rclc.h>
                #include <rclc/executor.h>
                #include <geometry_msgs/msg/twist.h>
                #include <nav_msgs/msg/odometry.h>
                #include <sensor_msgs/msg/imu.h>
                rcl_allocator_t allocator;
                rclc_support_t support;
                rclc_executor_t executor;
                rcl_node_t node;
                rcl_subscription_t sub_cmd_vel;
                geometry_msgs__msg__Twist msg_cmd_vel;
                rcl_publisher_t pub_odom;
                nav_msgs__msg__Odometry msg_odom;
                rcl_timer_t timer;
                rcl_publisher_t pub_imu;
                sensor_msgs__msg__Imu msg_imu;
                Esp32PcntEncoder encoders[2]; // 创建一个数组用于存储两个编码器
                Esp32McpwmMotor motor;        // 创建一个名为motor的对象,用于控制电机
                PidController pid_controller[2];
                Kinematics kinematics;
                MPU6050 mpu(Wire);               // 初始化MPU6050对象
                ImuDriver imu(mpu);              // 初始化Imu对象
                imu_t imu_data;                  // IMU 数据对象
                float target_linear_speed = 20.0; // 单位 毫米每秒
                float target_angular_speed = 0.1; // 单位 弧度每秒
                float out_left_speed = 0.0;       // 输出的左右轮速度,不是反馈的左右轮速度
                float out_right_speed = 0.0;
                void start()
                    pinMode(TRIG, OUTPUT);
                    pinMode(ECHO, INPUT);
                    pinMode(WARN, OUTPUT);
                void timer_callback(rcl_timer_t* timer,int64_t last_call_time)
                    odom_t odom = kinematics.get_odom();
                    int64_t stamp = rmw_uros_epoch_millis();
                    msg_odom.header.stamp.sec = static_cast<int32_t>(stamp/1000);
                    msg_odom.header.stamp.nanosec = static_cast<int32_t>((stamp%1000)*1e6);
                    msg_odom.pose.pose.position.x = odom.x;
                    msg_odom.pose.pose.position.y = odom.y;
                    msg_odom.pose.pose.orientation.w = cos(odom.angle*0.5);
                    msg_odom.pose.pose.orientation.x = 0;
                    msg_odom.pose.pose.orientation.y = 0;
                    msg_odom.pose.pose.orientation.z = sin(odom.angle*0.5);
                    msg_odom.twist.twist.linear.x = odom.linear_speed;
                    msg_odom.twist.twist.angular.z = odom.angular_speed;
                    imu.getImuDriverData(imu_data);
                    msg_imu.header.stamp.sec = static_cast<int32_t>(stamp / 1000);              // 秒部分
                    msg_imu.header.stamp.nanosec = static_cast<uint32_t>((stamp % 1000) * 1e6); // 纳秒部分
                    msg_imu.angular_velocity.x = imu_data.angular_velocity.x;
                    msg_imu.angular_velocity.y = imu_data.angular_velocity.y;
                    msg_imu.angular_velocity.z = imu_data.angular_velocity.z;
                    msg_imu.linear_acceleration.x = imu_data.linear_acceleration.x;
                    msg_imu.linear_acceleration.y = imu_data.linear_acceleration.y;
                    msg_imu.linear_acceleration.z = imu_data.linear_acceleration.z;
                    msg_imu.orientation.x = imu_data.orientation.x;
                    msg_imu.orientation.y = imu_data.orientation.y;
                    msg_imu.orientation.z = imu_data.orientation.z;
                    msg_imu.orientation.w = imu_data.orientation.w;
                    if(rcl_publish(&pub_odom,&msg_odom,NULL)!=RCL_RET_OK)
                        Serial.printf("error: odom pub failed!");
                    if(rcl_publish(&pub_imu, &msg_imu, NULL)!=RCL_RET_OK)
                        Serial.printf("error: imu pub failed!");
                void twist_callback(const void * msg_in)
                    const geometry_msgs__msg__Twist* msg = (const geometry_msgs__msg__Twist*)msg_in;
                    target_linear_speed = msg->linear.x*1000;
                    target_angular_speed = msg->angular.z;
                    kinematics.kinematics_inverse(target_linear_speed, target_angular_speed, &out_left_speed, &out_right_speed);
                    Serial.printf("OUT:left_speed=%f,right_speed=%f\n", out_left_speed, out_right_speed);
                    pid_controller[0].update_target(out_left_speed);
                    pid_controller[1].update_target(out_right_speed);
                void microros_task(void* args)
                    IPAddress agent_ip;
                    agent_ip.fromString("192.168.188.93");
                    set_microros_wifi_transports("xbw_mi","Xbw159357",agent_ip,8888);
                    delay(2000);
                    rclc_support_init(&support,0,NULL,&allocator);
                    rclc_node_init_default(&node,"example_xbwbot_motion_control","",&support);
                    unsigned int num_handles = 3;
                    rclc_executor_init(&executor,&support.context,num_handles,&allocator);
                    rclc_subscription_init_best_effort(&sub_cmd_vel,&node,ROSIDL_GET_MSG_TYPE_SUPPORT(geometry_msgs,msg,Twist),"/cmd_vel");
                    rclc_executor_add_subscription(&executor,&sub_cmd_vel,&msg_cmd_vel,&twist_callback,ON_NEW_DATA);
                    msg_odom.header.frame_id = micro_ros_string_utilities_set(msg_odom.header.frame_id,"odom");
                    msg_odom.child_frame_id = micro_ros_string_utilities_set(msg_odom.child_frame_id,"base_footprint");
                    msg_imu.header.frame_id = micro_ros_string_utilities_set(msg_imu.header.frame_id,"imu");
                    rclc_publisher_init_best_effort(&pub_odom,&node,ROSIDL_GET_MSG_TYPE_SUPPORT(nav_msgs,msg,Odometry),"/odom");
                    rclc_publisher_init_best_effort(&pub_imu,&node,ROSIDL_GET_MSG_TYPE_SUPPORT(sensor_msgs, msg, Imu),"/imu");
                    rclc_timer_init_default(&timer,&support,RCL_MS_TO_NS(50),timer_callback);
                    rclc_executor_add_timer(&executor,&timer);
                    while(!rmw_uros_epoch_synchronized())
                        rmw_uros_sync_session(1000);
                        delay(10);
                    rclc_executor_spin(&executor);
                // v=wr r = v/w
                void setup()
                    // 初始化串口
                    Serial.begin(115200); // 初始化串口通信,设置通信速率为115200
                    // 初始化电机驱动器2
                    encoders[0].init(0, 32, 33); // 初始化第一个编码器,使用GPIO 32和33连接
                    encoders[1].init(1, 26, 25); // 初始化第二个编码器,使用GPIO 26和25连接
                    // 初始化PID控制器的参数
                    pid_controller[0].update_pid(0.625, 0.125, 0.0);
                    pid_controller[1].update_pid(0.625, 0.125, 0.0);
                    pid_controller[0].out_limit(-100, 100);
                    pid_controller[1].out_limit(-100, 100);
                    // 初始化运动学参数
                    kinematics.set_wheel_distance(175); // mm
                    kinematics.set_motor_param(0, 0.103657);
                    kinematics.set_motor_param(1, 0.103657);
                    // 测试下运动学逆解
                    xTaskCreate(microros_task,"microros_task",10240,NULL,1,NULL);
                    start();
                    imu.begin(18, 19);
                void loop()
                    digitalWrite(TRIG, HIGH);
                    delayMicroseconds(10);
                    digitalWrite(TRIG, LOW);
                    double delta_time = pulseIn(ECHO, HIGH);
                    float detect_distance = delta_time * 0.0343 / 2;
                    if(detect_distance<50)
                        digitalWrite(WARN,HIGH);
                    else
                        digitalWrite(WARN,LOW);
                    delayMicroseconds(9990);
                    kinematics.update_motor_speed(millis(), encoders[0].getTicks(), encoders[1].getTicks());
                    motor.updateMotorSpeed(0, pid_controller[0].update(kinematics.get_motor_speed(0)));
                    motor.updateMotorSpeed(1, pid_controller[1].update(kinematics.get_motor_speed(1)));
                    // Serial.printf("speed1=%d,speed2=%d\n",kinematics.get_motor_speed(0),kinematics.get_motor_speed(1));
                    // Serial.printf("x,y,yaw=%f,%f,%f\n",kinematics.get_odom().x,kinematics.get_odom().y,kinematics.get_odom().angle);
                    imu.update();
                我使用的main.cpp,PidController.h和PidController.h与第九章的代码相同,ImuDriver.h和.cpp是从https://github.dev/fishros/fishbot_motion_control_microros复制过来的。
                  @1257261547 rviz2-2] Start navigation
                  [rviz2-2] [INFO] [1745497363.868824195] [rviz_navigation_dialog_action_client]: NavigateToPose will be called using the BT Navigator's default behavior tree.
                  [component_container_isolated-1] [INFO] [1745497363.872257788] [bt_navigator]: Received goal preemption request
                  [component_container_isolated-1] [INFO] [1745497363.872403577] [bt_navigator]: Begin navigating from current location (0.00, -0.00) to (1.05, 0.00)
                  [component_container_isolated-1] [INFO] [1745497364.692875360] [controller_server]: Passing new path to controller.
                  [component_container_isolated-1] [INFO] [1745497365.742881062] [controller_server]: Passing new path to controller.
                  [component_container_isolated-1] [ERROR] [1745497366.442902586] [controller_server]: Failed to make progress
                  [component_container_isolated-1] [WARN] [1745497366.442952090] [controller_server]: [follow_path] [ActionServer] Aborting handle.
                  [component_container_isolated-1] [INFO] [1745497366.462306032] [local_costmap.local_costmap]: Received request to clear entirely the local_costmap
                  [component_container_isolated-1] [INFO] [1745497366.462780905] [controller_server]: Received a goal, begin computing control effort.
                  [component_container_isolated-1] [WARN] [1745497366.605222290] [controller_server]: Control loop missed its desired rate of 20.0000Hz
                  [component_container_isolated-1] [INFO] [1745497366.762580448] [controller_server]: Passing new path to controller.
                  [component_container_isolated-1] [INFO] [1745497367.805310394] [controller_server]: Passing new path to controller.
                  [component_container_isolated-1] [INFO] [1745497368.805358332] [controller_server]: Passing new path to controller.
                  [component_container_isolated-1] [INFO] [1745497369.855392133] [controller_server]: Passing new path to controller.
                  [component_container_isolated-1] [INFO] [1745497370.855281188] [controller_server]: Passing new path to controller.
                  [component_container_isolated-1] [INFO] [1745497371.905391343] [controller_server]: Passing new path to controller.
                  [component_container_isolated-1] [INFO] [1745497372.905353942] [controller_server]: Passing new path to controller.
                  [component_container_isolated-1] [INFO] [1745497373.955312447] [controller_server]: Passing new path to controller.
                  [component_container_isolated-1] [INFO] [1745497375.005326343] [controller_server]: Passing new path to controller.
                  [component_container_isolated-1] [INFO] [1745497376.005308559] [controller_server]: Passing new path to controller.
                  [component_container_isolated-1] [ERROR] [1745497376.605300615] [controller_server]: Failed to make progress
                  [component_container_isolated-1] [WARN] [1745497376.605337470] [controller_server]: [follow_path] [ActionServer] Aborting handle.
                  [component_container_isolated-1] [INFO] [1745497376.622371024] [local_costmap.local_costmap]: Received request to clear entirely the local_costmap
                  [component_container_isolated-1] [INFO] [1745497376.622500163] [global_costmap.global_costmap]: Received request to clear entirely the global_costmap
                  [component_container_isolated-1] [WARN] [1745497376.963242230] [planner_server]: Planner loop missed its desired rate of 20.0000 Hz. Current loop rate is 2.9370 Hz
                  [component_container_isolated-1] [INFO] [1745497376.982935132] [controller_server]: Received a goal, begin computing control effort.
                  [component_container_isolated-1] [INFO] [1745497378.033336652] [controller_server]: Passing new path to controller.
                  [component_container_isolated-1] [INFO] [1745497379.083338474] [controller_server]: Passing new path to controller.
                  [component_container_isolated-1] [INFO] [1745497380.083353905] [controller_server]: Passing new path to controller.
                  [component_container_isolated-1] [INFO] [1745497381.133347869] [controller_server]: Passing new path to controller.
                  [component_container_isolated-1] [INFO] [1745497382.133331860] [controller_server]: Passing new path to controller.
                  [component_container_isolated-1] [INFO] [1745497383.183344989] [controller_server]: Passing new path to controller.
                  [component_container_isolated-1] [INFO] [1745497384.183333075] [controller_server]: Passing new path to controller.
                  [component_container_isolated-1] [INFO] [1745497385.233355170] [controller_server]: Passing new path to controller.
                  [component_container_isolated-1] [INFO] [1745497386.233343583] [controller_server]: Passing new path to controller.
                  [component_container_isolated-1] [ERROR] [1745497386.983379433] [controller_server]: Failed to make progress
                  [component_container_isolated-1] [WARN] [1745497386.983441386] [controller_server]: [follow_path] [ActionServer] Aborting handle.
                  [component_container_isolated-1] [INFO] [1745497387.002286852] [local_costmap.local_costmap]: Received request to clear entirely the local_costmap
                  [component_container_isolated-1] [INFO] [1745497387.002565414] [controller_server]: Received a goal, begin computing control effort.
                  [component_container_isolated-1] [WARN] [1745497387.205118703] [controller_server]: Control loop missed its desired rate of 20.0000Hz
                  [component_container_isolated-1] [INFO] [1745497387.257316611] [controller_server]: Passing new path to controller.
                  [component_container_isolated-1] [INFO] [1745497388.305240840] [controller_server]: Passing new path to controller.
                  [component_container_isolated-1] [INFO] [1745497389.305246853] [controller_server]: Passing new path to controller.
                  [component_container_isolated-1] [INFO] [1745497390.355189344] [controller_server]: Passing new path to controller.
                  [component_container_isolated-1] [INFO] [1745497391.405191109] [controller_server]: Passing new path to controller.
                  [component_container_isolated-1] [INFO] [1745497392.405226643] [controller_server]: Passing new path to controller.
                  [component_container_isolated-1] [INFO] [1745497393.455190198] [controller_server]: Passing new path to controller.
                  [component_container_isolated-1] [INFO] [1745497394.455174699] [controller_server]: Passing new path to controller.
                  [component_container_isolated-1] [INFO] [1745497395.505252445] [controller_server]: Passing new path to controller.
                  [component_container_isolated-1] [INFO] [1745497396.555201464] [controller_server]: Passing new path to controller.
                  [component_container_isolated-1] [ERROR] [1745497397.205337698] [controller_server]: Failed to make progress
                  [component_container_isolated-1] [WARN] [1745497397.205551926] [controller_server]: [follow_path] [ActionServer] Aborting handle.
                  [component_container_isolated-1] [INFO] [1745497397.222854104] [behavior_server]: Running spin
                  [component_container_isolated-1] [INFO] [1745497397.223028066] [behavior_server]: Turning 1.57 for spin behavior
                  现在rqt显示正常但是执行导航时报错
                    @1257261547 ros2 topic echo /imu --once
                    header:
                    stamp:
                    sec: 1745497834
                    nanosec: 466000000
                    frame_id: imu
                    orientation:
                    x: -0.0013860630569979548
                    y: 2.695150215004105e-05
                    z: -0.4447702169418335
                    w: 0.8956436514854431
                    orientation_covariance:
                    • 0.0
                    • 0.0
                    • 0.0
                    • 0.0
                    • 0.0
                    • 0.0
                    • 0.0
                    • 0.0
                    • 0.0
                      angular_velocity:
                      x: -0.14848875999450684
                      y: -0.1138010025024414
                      z: -0.09535890817642212
                      angular_velocity_covariance:
                    • 0.0
                    • 0.0
                    • 0.0
                    • 0.0
                    • 0.0
                    • 0.0
                    • 0.0
                    • 0.0
                    • 0.0
                      linear_acceleration:
                      x: -0.006431763060390949
                      y: 0.0023521725088357925
                      z: 1.0046474933624268
                      linear_acceleration_covariance:
                    • 0.0
                    • 0.0
                    • 0.0
                    • 0.0
                    • 0.0
                    • 0.0
                    • 0.0
                    • 0.0
                    • 0.0
                    fishros@fishros-linux:~/chapt9/xbwbot_ws$ ros2 topic echo /odom --once
                    header:
                    stamp:
                    sec: 1745497879
                    nanosec: 265000000
                    frame_id: odom
                    pose:
                    pose:
                    position:
                    x: 0.0
                    y: 0.0
                    z: 0.0
                    orientation:
                    x: 0.0
                    y: 0.0
                    z: -8.742278000372475e-08
                    w: -0.9999999999999962
                    covariance:
                    • 0.0
                    • 0.0
                    • 0.0
                    • 0.0
                    • 0.0
                    • 0.0
                    • 0.0
                    • 0.0
                    • 0.0
                    • 0.0
                    • 0.0
                    • 0.0
                    • 0.0
                    • 0.0
                    • 0.0
                    • 0.0
                    • 0.0
                    • 0.0
                    • 0.0
                    • 0.0
                    • 0.0
                    • 0.0
                    • 0.0
                    • 0.0
                    • 0.0
                    • 0.0
                    • 0.0
                    • 0.0
                    • 0.0
                    • 0.0
                    • 0.0
                    • 0.0
                    • 0.0
                    • 0.0
                    • 0.0
                    • 0.0
                      twist:
                      twist:
                      linear:
                      x: 0.0
                      y: 0.0
                      z: 0.0
                      angular:
                      x: 0.0
                      y: 0.0
                      z: 0.0
                      covariance:
                    • 0.0
                    • 0.0
                    • 0.0
                    • 0.0
                    • 0.0
                    • 0.0
                    • 0.0
                    • 0.0
                    • 0.0
                    • 0.0
                    • 0.0
                    • 0.0
                    • 0.0
                    • 0.0
                    • 0.0
                    • 0.0
                    • 0.0
                    • 0.0
                    • 0.0
                    • 0.0
                    • 0.0
                    • 0.0
                    • 0.0
                    • 0.0
                    • 0.0
                    • 0.0
                    • 0.0
                    • 0.0
                    • 0.0
                    • 0.0
                    • 0.0
                    • 0.0
                    • 0.0
                    • 0.0
                    • 0.0
                    • 0.0
                    fishros@fishros-linux:~/chapt9/xbwbot_ws$ ros2 topic echo /cmd_vel --once
                    linear:
                    x: 0.125
                    y: 0.0
                    z: 0.0
                    angular:
                    x: 0.0
                    y: 0.0
                    z: -0.16
                    linear:
                    x: 0.24631578947368427
                    y: 0.0
                    z: 0.0
                    angular:
                    x: 0.0
                    y: 0.0
                    z: -0.26315789473684215
                      main.cpp里有一段超声波测距的代码是用于实现小车距离障碍过近时蜂鸣器告警的。
                        小鱼 技术大佬 @1257261547
                        @1257261547 你用我编译好的固件,用配置助手直接下载,先排除固件问题
                          1257261547 @小鱼
                          大佬,启用了robot_localization之后启动导航,但是odom的漂移还是非常明显,这是正常的吗?有什么办法减小这种漂移吗?
                            小鱼 技术大佬 @1257261547
                            @1257261547 看起来像是地图问题,有点乱,检查检查雷达和网络连接,fishbot的里程计本身还是蛮稳定的
