    docker安装ros后怎么apt-get install ros-包
    docker apt存在问题
    846
    • SpeikeS
      Speike
      speike@ss-ub22:~$ noetic1
      请输入指令控制noetic1: 重启(r) 进入(e) 启动(s) 关闭(c) 删除(d) 测试(t):
      e
      root@17cffc92086f:/home/speike# sudo apt-get install ros-noetic-teleop-twist-keyboard
      Reading package lists... Done
      Building dependency tree
      E: Unable to locate package ros-noetic-teleop-twist-keyboard
      ubuntu22.04使用docker安装noetic后,容器内外都无法安装ros包
        小鱼 技术大佬 @Speike
        @Speike 需要先dudo apt update 下,就像新电脑一样
        SpeikeS 1 条回复 最后回复 回复 引用 0
        • SpeikeS
          Speike @小鱼
          sudo apt update后这样:
          e
          root@17cffc92086f:/home/speike# sudo apt update
          Ign:1 http://mirrors.tuna.tsinghua.edu.cn/ros/ubuntu focal InRelease
          Hit:2 https://mirrors.ustc.edu.cn/ubuntu focal InRelease
          Get:3 http://mirrors.tuna.tsinghua.edu.cn/ros2/ubuntu focal InRelease [4679 B]
          Hit:4 https://mirrors.ustc.edu.cn/ubuntu focal-updates InRelease
          Get:5 http://mirrors.tuna.tsinghua.edu.cn/ros/ubuntu focal Release [3794 B]
          Hit:6 https://mirrors.ustc.edu.cn/ubuntu focal-backports InRelease
          Get:7 http://mirrors.tuna.tsinghua.edu.cn/ros/ubuntu focal Release.gpg [833 B]
          Hit:8 https://mirrors.ustc.edu.cn/ubuntu focal-security InRelease
          Get:9 http://192.168.111.241:8081/IXC6ce55d137e7d52efd957279f09784e94_218.197.192.224/ros2/ubuntu focal/main amd64 Packages [1093 kB]
          Err:9 http://192.168.111.241:8081/IXC6ce55d137e7d52efd957279f09784e94_218.197.192.224/ros2/ubuntu focal/main amd64 Packages
            File has unexpected size (1079790 != 1092928). Mirror sync in progress? [IP: 192.168.111.241 8081]
            Hashes of expected file:
             - Filesize:1092928 [weak]
             - SHA256:399489b1137d48ad19917f0f55c395a01cf8b2a9653c573ada099bccaffcdf2e
             - SHA1:e4c6e9e39176f3385ef4bd56ebe78e4e60fee11a [weak]
             - MD5Sum:e3c5c5b8bc863ab11413cc4d22d697bf [weak]
            Release file created at: Sat, 16 Jul 2022 00:56:46 +0000
          Get:10 http://mirrors.tuna.tsinghua.edu.cn/ros/ubuntu focal/main amd64 Packages [698 kB]
          Get:11 http://packages.ros.org/ros2/ubuntu focal InRelease [4679 B]
          Get:12 http://192.168.111.241:8081/IXCab54c6e78e30452664e287da766c009c_218.197.192.224/ros2/ubuntu focal/main amd64 Packages [1093 kB]
          Err:12 http://192.168.111.241:8081/IXCab54c6e78e30452664e287da766c009c_218.197.192.224/ros2/ubuntu focal/main amd64 Packages
            File has unexpected size (1042131 != 1092936). Mirror sync in progress? [IP: 192.168.111.241 8081]
             - Filesize:1092936 [weak]
             - SHA256:7f861c69c71d187c7f62875b2823fc3088d4404386bd369accb39e64d3b1f648
             - SHA1:0944df3f929630d6ba741d5763b52087b39f8df8 [weak]
             - MD5Sum:e3d9c7646c74f262afc286fcc4556bb0 [weak]
            Release file created at: Mon, 18 Jul 2022 22:09:28 +0000
          Fetched 704 kB in 3s (202 kB/s)
          E: Failed to fetch http://192.168.111.241:8081/IXC6ce55d137e7d52efd957279f09784e94_218.197.192.224/ros2/ubuntu/dists/focal/main/binary-amd64/Packages.gz  File has unexpected size (1079790 != 1092928). Mirror sync in progress? [IP: 192.168.111.241 8081]
          E: Failed to fetch http://192.168.111.241:8081/IXCab54c6e78e30452664e287da766c009c_218.197.192.224/ros2/ubuntu/dists/focal/main/binary-amd64/Packages.gz  File has unexpected size (1042131 != 1092936). Mirror sync in progress? [IP: 192.168.111.241 8081]
          E: Some index files failed to download. They have been ignored, or old ones used instead.
            小鱼 技术大佬 @Speike
            @Speike 你可以继续install,应该没影响,不放心可以运行一下一键安装的一键换源。
            卜上人间卜 1 条回复 最后回复 回复 引用 1
            • SpeikeS Speike 将这个主题标记为已解决,在
            • 卜上人间卜
              Dob @小鱼
              @小鱼 借个帖子,一键安装后,进到docker里边运行
              错误打印:
              qt.qpa.xcb: could not connect to display
                小鱼 技术大佬 @卜上人间
                @卜上人间 在主机端运行 xhost + 应该就可以了
