    [FishBotCamera]3.结合YOLO实现检测
    fishbotcamera yolo 检测
    19
    67
    103.6k
    • J
      jkr @小鱼
      @小鱼 重装了一边不太行
      • J
        jkr @小鱼
        @小鱼 (1) In PyTorch 2.6, we changed the default value of the weights_only argument in torch.load from False to True. Re-running torch.load with weights_only set to False will likely succeed, but it can result in arbitrary code execution. Do it only if you got the file from a trusted source.
        (2) Alternatively, to load with weights_only=True please check the recommended steps in the following error message.
        WeightsUnpickler error: Unsupported global: GLOBAL numpy.core.multiarray._reconstruct was not an allowed global by default. Please use torch.serialization.add_safe_globals([numpy.core.multiarray._reconstruct]) or the torch.serialization.safe_globals([numpy.core.multiarray._reconstruct]) context manager to allowlist this global if you trust this class/function.
        重运行完报这个错
        • zxcpjpZ
          zxcpjp
          最后由 zxcpjp 编辑
          要怎么调节阈值啊@小鱼
          zxcpjpZ 1 条回复 最后回复 回复 引用 0
          • zxcpjpZ
            zxcpjp @zxcpjp
            @小鱼 要怎么调节置信度阈值啊 @小鱼
            • zxcpjpZ
              zxcpjp @zxcpjp
              最后由 zxcpjp 编辑
              @zxcpjp 我知道了,是不是 ,修改代码为
                  mask = predictions[:, 4] >= 0.6
                  filtered_pred = predictions[mask]
                  # 使用过滤后的结果
                  boxes = filtered_pred[:, :4]
                  scores = filtered_pred[:, 4]
                  categories = filtered_pred[:, 5]
              这样就修改为0.6了 @小鱼
                2648226346 @小鱼
                @小鱼 334c9ce5-234e-43ea-8619-ab9241bcc812-image.png 这个包一直下载失败,怎么解决
                L 3 2 条回复 最后回复 回复 引用 0
                  luqixuan 年度VIP @2648226346
                  @2648226346 环境变量设置了吗
                    2648226346 @luqixuan
                    @luqixuan 我是按照网页一步步来的
                      2648226346 @2648226346
                      @2648226346 环境变量具体是哪一步?
                      • C
                        cru @小鱼
                        @小鱼 在 [FishBotCamera]3.结合YOLO实现检测 中说:
                        d ~/fishbot_ws/
                        source install/setup.b
                          31918 @2648226346
                          @2648226346 后来怎么解决de
