@YJC 兄弟你复制粘贴下,我想复制下你出错的指令测试下
- 不要截图,要复制粘贴,一定要代码块包裹
用代码块包裹是为了更加美观,不会一个代码很长一段,不易阅读
@小鱼 OK,ros2 topic pub /chatter std_msgs/msg/String "{data:'aaaaaa'}"
@YJC 这样写就好了,你应该是少了个空格
ros2 topic pub /chatter std_msgs/msg/String "{data: 'aaaaaa'}" publisher: beginning loop publishing #1: std_msgs.msg.String(data='aaaaaa') publishing #2: std_msgs.msg.String(data='aaaaaa')
@YJC 可以把错误一起贴上来,这样下次遇到这个错误好检索哈
@小鱼 ok,的确是的。ros2 topic pub /chatter std_msgs/msg/String "{data:'aaaaaa'}"
Failed to populate field: 'String' object has no attribute 'data:'aaaaaa'' -
