    如何在ROS2的环境下使用Pcl_ros以及pcl 功能包
    ros2 foxy 点云 pcl
    5
    7
    6.3k
    • richard491067290R
      richard491067290
      您好,
      我现在正在将一个项目从ROS像ROS2迁徙,在其中用到了PCL相关的功能包,但是我不知道该如何使用这些功能在ROS2中,
      十分期待您的回复!
      谢谢!
        小鱼 技术大佬 @richard491067290
        @richard491067290 之前分享过相关文章,你可以试试
        原文链接:https://mp.weixin.qq.com/s/_zp8pSJ9f766ZyATiiapVQ
        前置安装
        sudo apt install ros-你的ROS版本代号-pcl*
        CMakeLists配置
        project(ros2pcl_test)
        # find dependencies
        find_package(rclcpp REQUIRED)
        find_package(PCL REQUIRED COMPONENTS common io)
        link_directories(${PCL_LIBRARY_DIRS})
        add_definitions(${PCL_DEFINITIONS})
        add_executable(ros2pcl_test_sub
          src/subscription_pcl.cpp
        ament_target_dependencies(ros2pcl_test_sub
          rclcpp
          sensor_msgs
        target_link_libraries(ros2pcl_test_sub ${PCL_LIBRARIES})
        ament_package()
        点云订阅
        #include "rclcpp/rclcpp.hpp"
        #include "sensor_msgs/msg/point_cloud2.hpp"
        #include <iostream>
        #include <pcl/point_cloud.h>
        #include <pcl/point_types.h>
        #include <pcl/common/common.h>
        #include <pcl/io/pcd_io.h>
        #include <pcl_conversions/pcl_conversions.h>
        class PclSub : public rclcpp::Node
        public:
            PclSub(std::string name)
                : Node(name)
                sub_novel = this->create_subscription<sensor_msgs::msg::PointCloud2>("sexy_girl", 10, std::bind(&PclSub::topic_callback, this, std::placeholders::_1));
        private:
            rclcpp::Subscription<sensor_msgs::msg::PointCloud2>::SharedPtr sub_novel;
            void topic_callback(const sensor_msgs::msg::PointCloud2::SharedPtr msg)
                RCLCPP_INFO(this->get_logger(), "points_size(%d,%d)",msg->height,msg->width);
            rclcpp::init(argc, argv);
            auto node = std::make_shared<PclSub>("pclsub");
            rclcpp::spin(node);
            rclcpp::shutdown();
            return 0;
        点云转换(ROS2->PCL)
        在点云订阅代码中增加下面的代码即可。
             pcl::PointCloud<pcl::PointXYZRGB>::Ptr cloud =
             boost::make_shared<pcl::PointCloud<pcl::PointXYZRGB>>();
        	 pcl::fromROSMsg(*msg, *cloud);
        点云保存
        	 pcl::io::savePCDFileASCII ("asd.pcd", *cloud);
        点云生成PointCloud2迭代器
        使用PointCloud2迭代器赋值sensor_msgs::msg::PointCloud2 。
        #include "sensor_msgs/point_cloud2_iterator.hpp"
        sensor_msgs::msg::PointCloud2 msg;
        // Fill in the size of the cloud
        msg.height = 480;
        msg.width = 640;
        // Create the modifier to setup the fields and memory
        sensor_msgs::PointCloud2Modifier mod(msg);
        // Set the fields that our cloud will have
        mod.setPointCloud2FieldsByString(2, "xyz", "rgb");
        // Set up memory for our points
        mod.resize(msg.height * msg.width);
        // Now create iterators for fields
        sensor_msgs::PointCloud2Iterator<float> iter_x(cloud_msg, "x");
        sensor_msgs::PointCloud2Iterator<float> iter_y(cloud_msg, "y");
        sensor_msgs::PointCloud2Iterator<float> iter_z(cloud_msg, "z");
        sensor_msgs::PointCloud2Iterator<uint8_t> iter_r(cloud_msg, "r");
        sensor_msgs::PointCloud2Iterator<uint8_t> iter_g(cloud_msg, "g");
        sensor_msgs::PointCloud2Iterator<uint8_t> iter_b(cloud_msg, "b");
        for (; iter_x != iter_x.end(); ++iter_x, ++iter_y, ++iter_z, ++iter_r, ++iter_g, ++iter_b)
          *iter_x = 0.0;
          *iter_y = 0.0;
          *iter_z = 0.0;
          *iter_r = 0;
          *iter_g = 255;
          *iter_b = 0;
        点云转换(PCL->ROS2)
        #include "pcl_conversions/pcl_conversions.h"
        pcl::PointCloud<pcl::PointXYZRGB>::Ptr cloud;
        pcl::toROSMsg(*cloud, msg);
        cloud_publisher->publish(msg);
        • richard491067290R
          richard491067290
          谢谢回复!我之前也看到这个帖子了,但是```
          code_text
          #include <iostream>
          #include <vector>
          #include <Eigen/Core>
          #include <ros/ros.h>
          #include <sensor_msgs/PointCloud2.h>
          #include <geometry_msgs/Point.h>
          #include <geometry_msgs/Pose.h>
          #include <geometry_msgs/PoseArray.h>
          #include <geometry_msgs/TransformStamped.h>
          #include <pcl_ros/impl/transforms.hpp>
          #include <pcl_ros/point_cloud.h>
          #include <pcl/common/transforms.h>
          #include <pcl/filters/crop_hull.h>
          #include <pcl/filters/statistical_outlier_removal.h>
          #include <pcl/visualization/cloud_viewer.h>
          #include <pcl/surface/concave_hull.h>
          #include <pcl/filters/passthrough.h>
          #include <tf/transform_listener.h>
          #include <tf/transform_broadcaster.h>
          #include "tf2_ros/static_transform_broadcaster.h"
          class PCHandler
          protected:
              ros::NodeHandle m_nh;
              sensor_msgs::PointCloud2 m_cloud;
              sensor_msgs::PointCloud2 m_cropped_cloud;
              geometry_msgs::PointStamped m_bottle_center;
              Eigen::Vector4f m_centroid;
          public:
              ros::Subscriber m_pointcloud_sub, m_center_sub;
              ros::Publisher m_croppedcloud_pub, m_goalpose_pub;
              tf::TransformListener* m_tf_listener = NULL;
              tf2_ros::StaticTransformBroadcaster m_br;
          PCHandler(void)
              m_pointcloud_sub = m_nh.subscribe("/camera/depth/color/points", 1, &PCHandler::getPC, this);
              m_center_sub = m_nh.subscribe("/point_in_3d", 1, &PCHandler::getCenter, this);
              m_goalpose_pub = m_nh.advertise<geometry_msgs::PoseStamped>("/bottle_detection/goalpose", 1);
              //Initialize tf_listener for pointcloud transformation
              m_tf_listener = new(tf::TransformListener);
              m_tf_listener->waitForTransform("/base_link", "/camera_depth_optical_frame", ros::Time::now(), ros::Duration(5.0));
              ROS_INFO("Transform to camera found.");
          ~PCHandler(void)
          void getPC(const sensor_msgs::PointCloud2::ConstPtr& msg)
              m_cloud = *msg;
              ROS_INFO("successfully get PointCloud");
              m_tf_listener->waitForTransform("/base_link", m_cloud.header.frame_id, m_cloud.header.stamp, ros::Duration(3.0));
              pcl_ros::transformPointCloud("base_link", m_cloud, m_cloud, *m_tf_listener);
          void getCenter(const geometry_msgs::PointStamped::ConstPtr& msg)
              m_bottle_center = *msg;
              pcl::PointCloud<pcl::PointXYZ>::Ptr pointcloud_ptr (new pcl::PointCloud<pcl::PointXYZ>);
              pcl::fromROSMsg(m_cloud, *pointcloud_ptr);
              ROS_INFO("size of original PointCloud: %lu", pointcloud_ptr->size());
              ////define a 3d volume around bottle
              float d = 0.1;
              pcl::PointCloud<pcl::PointXYZ>::Ptr boundingbox_ptr (new pcl::PointCloud<pcl::PointXYZ>);
              boundingbox_ptr->push_back(pcl::PointXYZ(m_bottle_center.point.x-d, m_bottle_center.point.y-d, m_bottle_center.point.z+0.3));
              boundingbox_ptr->push_back(pcl::PointXYZ(m_bottle_center.point.x+d, m_bottle_center.point.y-d, m_bottle_center.point.z+0.3));
              boundingbox_ptr->push_back(pcl::PointXYZ(m_bottle_center.point.x-d, m_bottle_center.point.y+d, m_bottle_center.point.z+0.3));
              boundingbox_ptr->push_back(pcl::PointXYZ(m_bottle_center.point.x+d, m_bottle_center.point.y+d, m_bottle_center.point.z+0.3));
              boundingbox_ptr->push_back(pcl::PointXYZ(m_bottle_center.point.x-d, m_bottle_center.point.y-d, m_bottle_center.point.z-0.1));
              boundingbox_ptr->push_back(pcl::PointXYZ(m_bottle_center.point.x+d, m_bottle_center.point.y-d, m_bottle_center.point.z-0.1));
              boundingbox_ptr->push_back(pcl::PointXYZ(m_bottle_center.point.x-d, m_bottle_center.point.y+d, m_bottle_center.point.z-0.1));
              boundingbox_ptr->push_back(pcl::PointXYZ(m_bottle_center.point.x+d, m_bottle_center.point.y+d, m_bottle_center.point.z-0.1));
              pcl::ConvexHull<pcl::PointXYZ> hull;
              hull.setInputCloud(boundingbox_ptr);
              hull.setDimension(3);
              std::vector<pcl::Vertices> polygons;
              pcl::PointCloud<pcl::PointXYZ>::Ptr surface_hull (new pcl::PointCloud<pcl::PointXYZ>);
              hull.reconstruct(*surface_hull, polygons);
              pcl::PointCloud<pcl::PointXYZ>::Ptr objects (new pcl::PointCloud<pcl::PointXYZ>);
              pcl::CropHull<pcl::PointXYZ> bb_filter;
              bb_filter.setDim(3);
              bb_filter.setInputCloud(pointcloud_ptr);
              bb_filter.setHullIndices(polygons);
              bb_filter.setHullCloud(surface_hull);
              bb_filter.filter(*objects);
          //test, get the maximun and minimun of a pointcloud
              pcl::PointXYZ minPt, maxPt;
              pcl::getMinMax3D(*objects, minPt, maxPt);
          //filter out points which belongs to the bottle cap
              pcl::PassThrough<pcl::PointXYZ> pass;
              pass.setInputCloud(objects);
              pass.setFilterFieldName("z");
              pass.setFilterLimits(maxPt.z-0.005, maxPt.z);
              pass.filter(*objects);
              ROS_INFO("size of cap cloud: %lu", objects->size());
          //calculate centroid of bottle cap
              if(objects->size()>300){
              pcl::compute3DCentroid(*objects, m_centroid);
              ROS_INFO("center of the point cloud: %f, %f, %f", m_centroid(0), m_centroid(1), m_centroid(2));
          //broadcast frame of goalpose
              // static tf::TransformBroadcaster br;
              // br.sendTransform(
              //     tf::StampedTransform(
              //         tf::Transform(tf::Quaternion(0,0,0,1), tf::Vector3(m_centroid[0], m_centroid[1], m_centroid[2])),
              //         ros::Time::now(), "base_link", "cap_frame"));
          //publish goalpose
             tf2::Quaternion q;
             q.setRPY(-3.1415926/2, 0, 0);
             if(m_centroid(2)>=0.20 && m_centroid(2)<=0.40){
             geometry_msgs::PoseStamped goalpose;
             goalpose.pose.orientation.x = q.x();
             goalpose.pose.orientation.y = q.y();
             goalpose.pose.orientation.z = q.z();
             goalpose.pose.orientation.w = q.w();
             goalpose.pose.position.x = m_centroid[0];
             goalpose.pose.position.y = m_centroid[1];
             goalpose.pose.position.z = 0.4;
             goalpose.header.frame_id = "base_link";
             goalpose.header.stamp = ros::Time::now();
             m_goalpose_pub.publish(goalpose);
             ROS_INFO("goal pose is published!");
          //Publish transform
             geometry_msgs::TransformStamped transform;
             transform.header.stamp = ros::Time::now();
             transform.header.frame_id = "base_link";
             transform.child_frame_id = "goal_position_0";
             transform.transform.translation.x = goalpose.pose.position.x;
             transform.transform.translation.y = goalpose.pose.position.y;
             transform.transform.translation.z = goalpose.pose.position.z;
             transform.transform.rotation.x = goalpose.pose.orientation.x;
             transform.transform.rotation.y = goalpose.pose.orientation.y;
             transform.transform.rotation.z = goalpose.pose.orientation.z;
             transform.transform.rotation.w = goalpose.pose.orientation.w;
             m_br.sendTransform(transform);
          //visualize the result
              // pcl::PointCloud<pcl::PointXYZ>::Ptr centroid_ptr (new pcl::PointCloud<pcl::PointXYZ>);
              // centroid_ptr->push_back(pcl::PointXYZ(m_centroid(0), m_centroid(1), m_centroid(2)));
              // pcl::visualization::PCLVisualizer viewer("Centroid example");
              // pcl::visualization::PointCloudColorHandlerCustom<pcl::PointXYZ> source_cloud_color_handler(objects,255, 255, 255);
              // viewer.addPointCloud(objects, source_cloud_color_handler, "original_cloud");
              // pcl::visualization::PointCloudColorHandlerCustom<pcl::PointXYZ> centroid_cloud_color_handler(centroid_ptr,230, 20, 20);
              // viewer.addPointCloud(centroid_ptr, centroid_cloud_color_handler, "cap_centroid");
              // //viewer.addCoordinateSystem(1.0, "cloud", 0);
              // viewer.setBackgroundColor(0.05, 0.05, 0.05, 0);
              // viewer.setPointCloudRenderingProperties (pcl::visualization::PCL_VISUALIZER_POINT_SIZE, 2, "original_cloud");
              // viewer.setPointCloudRenderingProperties (pcl::visualization::PCL_VISUALIZER_POINT_SIZE, 2, "cap_centroid");
              // while (!viewer.wasStopped ()) { // Display the visualiser until 'q' key is pressed
              // viewer.spinOnce ();
              ros::init(argc, argv, "pc_handle_node");
              ros::NodeHandle nh("~");
              PCHandler pc_handler;
              ros::spin();
              return 0;
          但是在我ROS1的版本中我运用了例如PCl_ros包和PCl包中的一些功能,我不知道该如何改写这些功能?是否能请您给我一个相关的改写例子或者其他的指导呢?万分感谢!!
            @richard491067290 不知道是否解决了哈,ros2中方法类似
            https://github.com/ros-perception/perception_pcl/blob/ros2/pcl_ros/src/transforms.cpp
            template void pcl_ros::transformPointCloud<pcl::PointXYZ>(
              const pcl::PointCloud<pcl::PointXYZ> &,
              const geometry_msgs::msg::TransformStamped &);
            14002765871 1 条回复 最后回复 回复 引用 0
            • 小鱼小 小鱼 将这个主题标记为已解决,在
            • 14002765871
              庙堂不见江湖见 @小鱼
              @小鱼 大佬请问一下有完整的工作空间可以提供学习一下吗,按照您这个流程编写功能包无法正常编译,会报几个类似下面的warning
              ** WARNING ** io features related to openni2 will be disabled
              然后无法通过正常编译
              我的ros2版本是foxy,非常感谢!!!
              9297856399 1 条回复 最后回复 回复 引用 0
              • 9297856399
                GENE @1400276587
                @1400276587 同样的问题,请问解决了吗?
                • 11573543821
                  大预言家·福尔摩斯·睿
