    RVIZ2 找不到QT平台插件 Could not find the Qt platform plugin "wayland" in ""
    rviz2 qt出错
    • 12067683721
      Harry橙
      下面是完整的报错信息
      ros2@ros2-virtual-machine:~/d2lros/chapt8/fishbot_ws$ ros2 launch fishbot_description display_rviz2.launch.py
      [INFO] [launch]: All log files can be found below /home/ros2/.ros/log/2022-08-18-13-44-13-635600-ros2-virtual-machine-5560
      [INFO] [robot_state_publisher-1]: process started with pid [5572]
      [INFO] [joint_state_publisher_gui-2]: process started with pid [5574]
      [INFO] [rviz2-3]: process started with pid [5576]
      [rviz2-3] qt.qpa.plugin: Could not find the Qt platform plugin "wayland" in ""
      [robot_state_publisher-1] [WARN] [1660801457.094932948] [robot_state_publisher]: No robot_description parameter, but command-line argument available.  Assuming argument is name of URDF file.  This backwards compatibility fallback will be removed in the future.
      [robot_state_publisher-1] Link laser_link had 0 children
      [robot_state_publisher-1] [INFO] [1660801457.720892835] [robot_state_publisher]: got segment base_link
      [robot_state_publisher-1] [INFO] [1660801457.720969078] [robot_state_publisher]: got segment laser_link
      [rviz2-3] [INFO] [1660801458.613988022] [rviz2]: Stereo is NOT SUPPORTED
      [rviz2-3] [INFO] [1660801458.614231508] [rviz2]: OpenGl version: 4.1 (GLSL 4.1)
      [rviz2-3] [INFO] [1660801458.957211916] [rviz2]: Stereo is NOT SUPPORTED
      [joint_state_publisher_gui-2] qt.qpa.plugin: Could not find the Qt platform plugin "wayland" in ""
      [joint_state_publisher_gui-2] [INFO] [1660801460.875772212] [joint_state_publisher_gui]: Centering
      12067683721 小鱼小 2 条回复 最后回复 回复 引用 0
      • 12067683721
        Harry橙 @1206768372
        @1206768372
        程序是找小鱼的复制黏贴的
        launch文件
        import os
            urdf_name = "fishbot_base.urdf"
            ld = LaunchDescription()
            #robot_state_publisher_node负责发布机器人模型信息robot_description,并将joint_states数据转换tf信息发布
                arguments=[urdf_model_path]
            #负责发布机器人关节数据信息,通过joint_states话题发布
                package='joint_state_publisher_gui',
                executable='joint_state_publisher_gui',
                name='joint_state_publisher_gui',
            rviz2_node = Node(
                package='rviz2',
                executable='rviz2',
                name='rviz2',
                output='screen',
            ld.add_action(rviz2_node)
            return ld
        setup文件
        from setuptools import setup
        from glob import glob##
        import os##
        setup(
            name=package_name,
            version='0.0.0',
            packages=[package_name],
            data_files=[
                (os.path.join('share', package_name, 'launch'), glob('launch/*.launch.py')),##
                (os.path.join('share', package_name, 'urdf'), glob('urdf/**')),##
            zip_safe=True,
            maintainer='root',
            maintainer_email='root@todo.todo',
            license='TODO: License declaration',
            tests_require=['pytest'],
            entry_points={
                'console_scripts': [
          小鱼 技术大佬 @1206768372
          @1206768372 网上搜了下,这个错误好像是vscode中环境配置造成的,你试试直接在电脑的终端里运行程序看看.
          • 小鱼小 小鱼 从 中的 动手学ROS2 移动了该主题
