ros2 launch urg_node2 urg_node2.launch.py运行时报错
@3152079070 看提示,生命周期转换错误,可以通过 ros2 lifecycle进行检查
ros2 lifecycle usage: ros2 lifecycle [-h] Call `ros2 lifecycle <command> -h` for more detailed usage. ... Various lifecycle related sub-commands optional arguments: -h, --help show this help message and exit Commands: get Get lifecycle state for one or more nodes list Output a list of available transitions nodes Output a list of nodes with lifecycle set Trigger lifecycle state transition Call `ros2 lifecycle <command> -h` for more detailed usage.
@小鱼 在 ros2 launch urg_node2 urg_node2.launch.py运行时报错 中说:ros2 lifecycle set: error: the following arguments are required: node_name, transition(缺少节点名称和transition)我在Wiki的教程上下的北洋urg_node2的功能包, 程序应该是没问题的,是不是我的环境或者设备的问题呢?
ros2 lifecycle
3 3152079070 将这个主题标记为已解决,在
