重要提示
未解决 一键安装ROS失败
root@DeepLearning:~# sudo apt install ros-noetic-desktop-full -y
Reading package lists... Done
Building dependency tree
The following information may help to resolve the situation:The following packages have unmet dependencies:
ros-noetic-desktop-full : Depends: ros-noetic-desktop but it is not going to be installed
Depends: ros-noetic-perception but it is not going to be installed
Depends: ros-noetic-simulators but it is not going to be installed
Depends: ros-noetic-urdf-sim-tutorial but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
root@DeepLearning:~# wget http://fishros.com/install -O fishros && . fishros
--2022-10-21 19:42:44-- http://fishros.com/install
Resolving fishros.com (fishros.com)... 139.9.131.171, 39.96.153.39, 39.96.153.59, ...
--2022-10-21 19:42:45-- http://fishros.com/install/
Length: 582 [application/octet-stream]
Saving to: ‘fishros’fishros 100%[===================>] 582 --.-KB/s in 0s
2022-10-21 19:42:45 (205 MB/s) - ‘fishros’ saved [582/582]
python3-distro is already the newest version (1.4.0-1).
python3-yaml is already the newest version (5.3.1-1ubuntu0.1).
0 upgraded, 0 newly installed, 0 to remove and 6 not upgraded.
sudo is already the newest version (1.8.31-1ubuntu1.2).
--2022-10-21 19:42:47-- http://fishros.com/install/install1s/tools/base.py
Length: 41972 (41K) [application/octet-stream]
Saving to: ‘/tmp/fishinstall/tools/base.py’/tmp/fishinstall/tools/base.py 100%[==================================================================================================>] 40.99K --.-KB/s in 0.07s
2022-10-21 19:42:48 (567 KB/s) - ‘/tmp/fishinstall/tools/base.py’ saved [41972/41972]
[-]Result:successRUN Choose Task:[请输入括号内的数字]
---众多工具,等君来用---
[6]:一键安装:nodejs
[7]:一键安装:VsCode开发工具
[8]:一键安装:Docker
[10]:一键安装:微信(可以在Linux上使用的微信)
[77]:测试模式:运行自定义工具测试
请输入[]内的数字以选择:1
--2022-10-21 19:42:54-- http://fishros.com/install/install1s/tools/tool_install_ros.py
Saving to: ‘/tmp/fishinstall/tools/tool_install_ros.py’/tmp/fishinstall/tools/tool_install_ros.py 100%[==================================================================================================>] 18.60K --.-KB/s in 0.06s
2022-10-21 19:42:54 (313 KB/s) - ‘/tmp/fishinstall/tools/tool_install_ros.py’ saved [19050/19050]
--2022-10-21 19:42:54-- http://fishros.com/install/install1s/tools/tool_config_rosenv.py
Saving to: ‘/tmp/fishinstall/tools/tool_config_rosenv.py’/tmp/fishinstall/tools/tool_config_rosenv.py 100%[==================================================================================================>] 2.40K --.-KB/s in 0s
2022-10-21 19:42:54 (358 MB/s) - ‘/tmp/fishinstall/tools/tool_config_rosenv.py’ saved [2457/2457]
--2022-10-21 19:42:54-- http://fishros.com/install/install1s/tools/tool_config_system_source.py
Saving to: ‘/tmp/fishinstall/tools/tool_config_system_source.py’/tmp/fishinstall/tools/tool_config_system_sour 100%[==================================================================================================>] 7.33K --.-KB/s in 0.02s
2022-10-21 19:42:54 (429 KB/s) - ‘/tmp/fishinstall/tools/tool_config_system_source.py’ saved [7511/7511]
小鱼:检测当前系统ubuntu20.04:focal 支持一键安装ROS
[1]:更换系统源再继续安装
[2]:不更换继续安装
请输入[]内的数字以选择:2
[-]Result:success --upgradable' to see them.eRun CMD Task:[sudo apt-cache search curl ]
[-]Result:success kage retrieves data from url-format files such as http://, ftp://, package:// file://, etc., and loads the data into memory..Run CMD Task:[sudo apt install curl -y]
[-]Result:success e and 6 not upgraded.Run CMD Task:[sudo apt-cache search gnupg2 ]
[-]Result:success eplacement (dummy transitional package)Run CMD Task:[sudo apt install gnupg2 -y]
[-]Result:success e and 6 not upgraded.Run CMD Task:[curl -s https://gitee.com/ohhuo/rosdistro/raw/master/ros.asc | sudo apt-key add -]
[-]Result:success --upgradable' to see them.eRun CMD Task:[sudo apt-cache search ros-base ]
[-]Result:success tends 'ros_core' and includes other basic functionalities like tf2 and urdf..namic reconfigure, nodelets, and pluginlib.l.恭喜,成功添加ROS源,接下来可以使用apt安装ROS或者使用[1]一键安装ROS安装!
[-]Result:success tends 'ros_core' and includes other basic functionalities like tf2 and urdf..namic reconfigure, nodelets, and pluginlib.l.RUN Choose Task:[请输入括号内的数字]
[1]:noetic(ROS1)
[2]:foxy(ROS2)
[3]:galactic(ROS2)
[4]:rolling(ROS2)
请输入[]内的数字以选择:1
请选择安装的具体版本(如果不知道怎么选,请选1桌面版):
[1]:noetic(ROS1)桌面版
[2]:noetic(ROS1)基础版(小)
请输入[]内的数字以选择:1
[-]Result:success end for Debianfor C++ (development files)sionRun CMD Task:[sudo apt install aptitude -y]
[-]Result:success e and 6 not upgraded.Run CMD Task:[sudo apt-cache search aptitude ]
[-]Result:success e and 6 not upgraded.Run CMD Task:[sudo apt install ros-noetic-desktop-full -y]
[-]Result:code:100 etic-urdf-sim-tutorial but it is not going to be installed============================================================
确认了解情况,请输入回车继续安装n
Run CMD Task:[sudo aptitude install ros-noetic-desktop-full]
字数太多,删除看不懂的:
0 packages upgraded, 1006 newly installed, 0 to remove and 6 not upgraded.
Need to get 529 MB of archives. After unpacking 2773 MB will be used.
libmysqlclient-dev : Depends: libmysqlclient21 (= 8.0.30-0ubuntu0.20.04.2) but 8.0.30-0ubuntu0.20.04.3 is installed
libcurl4-gnutls-dev : Conflicts: libcurl4-openssl-dev but 7.68.0-1ubuntu2.13 is to be installed
libcurl4-openssl-dev : Conflicts: libcurl4-gnutls-dev but 7.68.0-1ubuntu2.13 is to be installed
libx11-dev : Depends: libx11-6 (= 2:1.6.9-2ubuntu1.2) but 2:1.6.9-2ubuntu1.3 is installed
The following actions will resolve these dependencies:Keep the following packages at their current version:
default-libmysqlclient-dev [Not Installed]
freeglut3-dev [Not Installed]
libcairo2-dev [Not Installed]
libcurl4-gnutls-dev [Not Installed]
libegl-dev [Not Installed]
libfltk1.3-dev [Not Installed]
libgazebo11-dev [Not Installed]
libgdal-dev [Not Installed]
libgdk-pixbuf2.0-dev [Not Installed]
libgl-dev [Not Installed]
libgl1-mesa-dev [Not Installed]
libgles-dev [Not Installed]
libglew-dev [Not Installed]
libglu1-mesa-dev [Not Installed]
libglvnd-dev [Not Installed]
libglx-dev [Not Installed]
libgtk2.0-dev [Not Installed]
libpango1.0-dev [Not Installed]
libpcl-dev [Not Installed]
libpoco-dev [Not Installed]
libqt5opengl5-dev [Not Installed]
libqt5webkit5-dev [Not Installed]
libsimbody-dev [Not Installed]
libvtk7-dev [Not Installed]
libvtk7-qt-dev [Not Installed]
libx11-dev [Not Installed]
libxcomposite-dev [Not Installed]
libxcursor-dev [Not Installed]
libxdamage-dev [Not Installed]
libxext-dev [Not Installed]
libxfixes-dev [Not Installed]
libxft-dev [Not Installed]
libxi-dev [Not Installed]
libxinerama-dev [Not Installed]
libxmu-dev [Not Installed]
libxmu-headers [Not Installed]
libxrandr-dev [Not Installed]
libxrender-dev [Not Installed]
libxss-dev [Not Installed]
libxt-dev [Not Installed]
qtbase5-dev [Not Installed]
qtdeclarative5-dev [Not Installed]
qttools5-dev [Not Installed]
qttools5-private-dev [Not Installed]
ros-noetic-camera-info-manager [Not Installed]
ros-noetic-class-loader [Not Installed]
ros-noetic-common-tutorials [Not Installed]
ros-noetic-compressed-depth-image-transport [Not Installed]
ros-noetic-compressed-image-transport [Not Installed]
ros-noetic-control-toolbox [Not Installed]
ros-noetic-controller-manager [Not Installed]
ros-noetic-controller-manager-msgs [Not Installed]
ros-noetic-depth-image-proc [Not Installed]
ros-noetic-desktop [Not Installed]
ros-noetic-desktop-full [Not Installed]
ros-noetic-diagnostic-aggregator [Not Installed]
ros-noetic-diagnostic-analysis [Not Installed]
ros-noetic-diagnostic-common-diagnostics [Not Installed]
ros-noetic-diagnostics [Not Installed]
ros-noetic-diff-drive-controller [Not Installed]
ros-noetic-dynamic-reconfigure [Not Installed]
ros-noetic-executive-smach [Not Installed]
ros-noetic-filters [Not Installed]
ros-noetic-gazebo-dev [Not Installed]
ros-noetic-gazebo-plugins [Not Installed]
ros-noetic-gazebo-ros [Not Installed]
ros-noetic-gazebo-ros-control [Not Installed]
ros-noetic-gazebo-ros-pkgs [Not Installed]
ros-noetic-geometry [Not Installed]
ros-noetic-geometry-tutorials [Not Installed]
ros-noetic-image-common [Not Installed]
ros-noetic-image-pipeline [Not Installed]
ros-noetic-image-proc [Not Installed]
ros-noetic-image-publisher [Not Installed]
ros-noetic-image-rotate [Not Installed]
ros-noetic-image-transport [Not Installed]
ros-noetic-image-transport-plugins [Not Installed]
ros-noetic-image-view [Not Installed]
ros-noetic-interactive-marker-tutorials [Not Installed]
ros-noetic-joint-limits-interface [Not Installed]
ros-noetic-kdl-parser [Not Installed]
ros-noetic-laser-assembler [Not Installed]
ros-noetic-laser-filters [Not Installed]
ros-noetic-laser-geometry [Not Installed]
ros-noetic-laser-pipeline [Not Installed]
ros-noetic-librviz-tutorial [Not Installed]
ros-noetic-nodelet [Not Installed]
ros-noetic-nodelet-core [Not Installed]
ros-noetic-nodelet-topic-tools [Not Installed]
ros-noetic-nodelet-tutorial-math [Not Installed]
ros-noetic-pcl-conversions [Not Installed]
ros-noetic-pcl-ros [Not Installed]
ros-noetic-perception [Not Installed]
ros-noetic-perception-pcl [Not Installed]
ros-noetic-pluginlib [Not Installed]
ros-noetic-pluginlib-tutorials [Not Installed]
ros-noetic-polled-camera [Not Installed]
ros-noetic-qt-gui-cpp [Not Installed]
ros-noetic-robot [Not Installed]
ros-noetic-robot-state-publisher [Not Installed]
ros-noetic-ros-base [Not Installed]
ros-noetic-ros-comm [Not Installed]
ros-noetic-ros-core [Not Installed]
ros-noetic-rosbag [Not Installed]
ros-noetic-rosbag-storage [Not Installed]
ros-noetic-rosmsg [Not Installed]
ros-noetic-rosnode [Not Installed]
ros-noetic-rosservice [Not Installed]
ros-noetic-rostopic [Not Installed]
ros-noetic-roswtf [Not Installed]
ros-noetic-rqt-action [Not Installed]
ros-noetic-rqt-bag [Not Installed]
ros-noetic-rqt-bag-plugins [Not Installed]
ros-noetic-rqt-common-plugins [Not Installed]
ros-noetic-rqt-console [Not Installed]
ros-noetic-rqt-dep [Not Installed]
ros-noetic-rqt-graph [Not Installed]
ros-noetic-rqt-gui-cpp [Not Installed]
ros-noetic-rqt-image-view [Not Installed]
ros-noetic-rqt-launch [Not Installed]
ros-noetic-rqt-logger-level [Not Installed]
ros-noetic-rqt-moveit [Not Installed]
ros-noetic-rqt-msg [Not Installed]
ros-noetic-rqt-nav-view [Not Installed]
ros-noetic-rqt-plot [Not Installed]
ros-noetic-rqt-pose-view [Not Installed]
ros-noetic-rqt-publisher [Not Installed]
ros-noetic-rqt-py-common [Not Installed]
ros-noetic-rqt-reconfigure [Not Installed]
ros-noetic-rqt-robot-dashboard [Not Installed]
ros-noetic-rqt-robot-monitor [Not Installed]
ros-noetic-rqt-robot-plugins [Not Installed]
ros-noetic-rqt-robot-steering [Not Installed]
ros-noetic-rqt-rviz [Not Installed]
ros-noetic-rqt-service-caller [Not Installed]
ros-noetic-rqt-srv [Not Installed]
ros-noetic-rqt-tf-tree [Not Installed]
ros-noetic-rqt-topic [Not Installed]
ros-noetic-rviz [Not Installed]
ros-noetic-rviz-plugin-tutorials [Not Installed]
ros-noetic-rviz-python-tutorial [Not Installed]
ros-noetic-simulators [Not Installed]
ros-noetic-smach-ros [Not Installed]
ros-noetic-stage [Not Installed]
ros-noetic-stage-ros [Not Installed]
ros-noetic-stereo-image-proc [Not Installed]
ros-noetic-tf [Not Installed]
ros-noetic-tf-conversions [Not Installed]
ros-noetic-theora-image-transport [Not Installed]
ros-noetic-transmission-interface [Not Installed]
ros-noetic-turtle-tf [Not Installed]
ros-noetic-urdf [Not Installed]
ros-noetic-urdf-sim-tutorial [Not Installed]
ros-noetic-urdf-tutorial [Not Installed]
ros-noetic-visualization-tutorials [Not Installed]
ros-noetic-viz [Not Installed]
tk-dev [Not Installed]
tk8.6-dev [Not Installed]
Leave the following dependencies unresolved:
fluid recommends libfltk1.3-dev
Accept this solution? [Y/n/q/?] y
0 packages upgraded, 0 newly installed, 0 to remove and 6 not upgraded.
Need to get 0 B of archives. After unpacking 0 B will be used.Run CMD Task:[sudo aptitude install ros-noetic-desktop-full -y]
- 字数太多,删除一部分看不懂的:~~**
[] cmake{a} cmake-data{a} comerr-dev{a} cython3{a} default-libmysqlclient-dev{a} fltk1.3-doc{a} fluid{a} fonts-lato{a} fonts-lyx{a} freeglut3{a} freeglut3-dev{a} gazebo11{a} gazebo11-common{a} gazebo11-plugin-base{a} gdal-data{a} gir1.2-gtk-2.0{a} gir1.2-harfbuzz-0.0{a} google-mock{a} googletest{a} graphviz{a} integration{a} sbcl{a} sdformat9-sdf{a} shiboken2{a} sip-dev{a} tcl{a} tcl-dev{a} tcl-vtk7{a} tcl8.6-dev{a} tk{a} tk-dev{a} tk8.6-dev{a} ttf-dejavu-core{a} unixodbc-dev{a} uuid-dev{a} va-driver-all{a} vdpau-driver-all{a} vtk7{a} x11proto-core-dev{a} x11p[-]Result:success ing 0 B will be used.upgraded.ntu1.3 is installedtalled20.04.3 is installeda-dev{a} xorg-sgml-doctools{a} xtrans-dev{a} zlib1g-dev{a}
Run CMD Task:[sudo apt-cache search python3-catkin-tools ]
[-]Result:success for working with catkin.Run CMD Task:[sudo apt install python3-catkin-tools -y]
[-]Result:success e and 6 not upgraded.Run CMD Task:[sudo apt-cache search python3-rosdep ]
[-]Result:success anager abstraction tool for ROSPython 3)Run CMD Task:[sudo apt install python3-rosdep -y]
[-]Result:success e and 6 not upgraded.Run CMD Task:[ls /opt/ros/noetic/setup.bash]
[-]Result:code:2 -
@295714153 在 一键安装ROS失败 中说:
确认了解情况,请输入回车继续安装n看提示你并没有按照提示先n后y.
No packages will be installed, upgraded, or removed. -
确认了解情况,请输入回车继续安装先按回车
Accept this solution? [Y/n/q/?] n
再输入n
161) fluid recommends libfltk1.3-devAccept this solution? [Y/n/q/?] y
Need to get 0 B of archives. After unpacking 0 B will be used.再输入y
没错 啊
[1]:更换系统源再继续安装
[2]:不更换继续安装
请输入[]内的数字以选择:2速度慢一定要选国内源,这里提示要换,你没有换哦
@295714153 代码一定要用代码块包裹,不太好看
不要截图,要复制粘贴,一定要代码块包裹
用代码块包裹是为了更加美观,不会一个代码很长一段,不易阅读
