    安装ros2后由于ros与ros2共存导致source install/setup.bash失败的问题
    ros2 版本冲突
    6.8k
    • 24187608382
      ※辰坤星宇
      安装了ros2因为也安装过ros1,source install/setup.bash后就会出现这样的提示
      我把.bashrc中的noetic的source注释掉了
      但是还是一样,该怎么做啊
      .bashec文件的其他内容如下:
      ![~T56WDUL28%H%IK`1MB~4W.png](/forum/assets/uploads/files/1650121124458-t5-6wdul28-h-ik-96-1mb-4w.png)
![2{~VM0W]<a class=@R$MYH`NQ1RHCC3.png" class=" img-fluid img-markdown" />
        小鱼 技术大佬 @2418760838
        @2418760838 注意第119行,你把一个ros1的工作空间加入了bashrc
        24187608382 1 条回复 最后回复 回复 引用 0
        • 24187608382
          ※辰坤星宇 @小鱼
          我把119行注释掉了,再去source可还是一样
            小鱼 技术大佬 @2418760838
            @2418760838 你在bashrc中保留的应该是foxy版本,但你source的应该是ros1的工作空间吧。
            • 24187608382
              ※辰坤星宇 @小鱼
              @小鱼 不是呀,就是按照小鱼老师教程中3.4.1节中做的,用ros2 pkg创建的功能包,在那个工作空间目录下source的
                小鱼 技术大佬 @2418760838
                @2418760838 你补充一下你目前的bashrc(复制粘贴代码快包括),和source之后的错误提示
                24187608382 4 条回复 最后回复 回复 引用 0
                • 24187608382
                  ※辰坤星宇 @小鱼
                  • 24187608382
                    ※辰坤星宇 @小鱼
                    # ~/.bashrc: executed by bash(1) for non-login shells.
                    # see /usr6/doc/bash/examples×artup-files (in the package bash-doc)
                    # for examples
                    # If not running interactively, don't do anything
                    case $- in
                        *i*) ;;
                          *) return;;
                    esac
                    # don't put duplicate lines or lines starting with space in the history.
                    # See bash(1) for more options
                    HISTCONTROL=ignoreboth
                    # append to the history file, don't overwrite it
                    shopt -s histappend
                    # for setting history length see HISTSIZE and HISTFILESIZE in bash(1)
                    HISTSIZE=1000
                    HISTFILESIZE=2000
                    # check the window size after each command and, if necessary,
                    # update the values of LINES and COLUMNS.
                    shopt -s checkwinsize
                    # If set, the pattern "**" used in a pathname expansion context will
                    # match all files and zero or more directories and subdirectories.
                    #shopt -s globstar
                    # make less more friendly for non-text input files, see lesspipe(1)
                    [ -x /usr/bin/lesspipe ] && eval "$(SHELL=/binš lesspipe)"
                    # set variable identifying the chroot you work in (used in the prompt below)
                    if [ -z "${debian_chroot:-}" ] && [ -r /etc/debian_chroot ]; then
                        debian_chroot=$(cat /etc/debian_chroot)
                    fi
                    # set a fancy prompt (non-color, unless we know we "want" color)
                    case "$TERM" in
                        xterm-color|*-256color) color_prompt=yes;;
                    esac
                    # uncomment for a colored prompt, if the terminal has the capability; turned
                    # off by default to not distract the user: the focus in a terminal window
                    # should be on the output of commands, not on the prompt
                    #force_color_prompt=yes
                    if [ -n "$force_color_prompt" ]; then
                        if [ -x /usr/binut ] && tput setaf 1 >&/dev/null; then
                    	# We have color support; assume it's compliant with Ecma-48
                    	# (ISO/IEC-6429). (Lack of such support is extremely rare, and such
                    	# a case would tend to support setf rather than setaf.)
                    	color_prompt=yes
                        else
                    	color_prompt=
                        fi
                    fi
                    if [ "$color_prompt" = yes ]; then
                        PS1='${debian_chroot:+($debian_chroot)}\[\033[01;32m\]\u@\h\[\033[00m\]:\[\033[01;34m\]\w\[\033[00m\]\$ '
                    else
                        PS1='${debian_chroot:+($debian_chroot)}\u@\h:\w\$ '
                    fi
                    unset color_prompt force_color_prompt
                    # If this is an xterm set the title to user@host:dir
                    case "$TERM" in
                    xterm*|rxvt*)
                        PS1="\[\e]0;${debian_chroot:+($debian_chroot)}\u@\h: \w\a\]$PS1"
                    esac
                    # enable color support of ls and also add handy aliases
                    if [ -x /usr/bin/dircolors ]; then
                        test -r ~/.dircolors && eval "$(dircolors -b ~/.dircolors)" || eval "$(dircolors -b)"
                        alias ls='ls --color=auto'
                        #alias dir='dir --color=auto'
                        #alias vdir='vdir --color=auto'
                        alias grep='grep --color=auto'
                        alias fgrep='fgrep --color=auto'
                        alias egrep='egrep --color=auto'
                    fi
                    # colored GCC warnings and errors
                    #export GCC_COLORS='error=01;31:warning=01;35:note=01;36:caret=01;32:locus=01:quote=01'
                    # some more ls aliases
                    alias ll='ls -alF'
                    alias la='ls -A'
                    alias l='ls -CF'
                    # Add an "alert" alias for long running commands.  Use like so:
                    #   sleep 10; alert
                    alias alert='notify-send --urgency=low -i "$([ $? = 0 ] && echo terminal || echo error)" "$(history|tail -n1|sed -e '\''s/^\s*[0-9]\+\s*//;s/[;&|]\s*alert$//'\'')"'
                    # Alias definitions.
                    # You may want to put all your additions into a separate file like
                    # ~/.bash_aliases, instead of adding them here directly.
                    # See /usr6/doc/bash-doc/examples in the bash-doc package.
                    if [ -f ~/.bash_aliases ]; then
                        . ~/.bash_aliases
                    fi
                    # enable programmable completion features (you don't need to enable
                    # this, if it's already enabled in /etc/bash.bashrc and /etc/profile
                    # sources /etc/bash.bashrc).
                    if ! shopt -oq posix; then
                      if [ -f /usr6/bash-completion/bash_completion ]; then
                        . /usr6/bash-completion/bash_completion
                      elif [ -f /etc/bash_completion ]; then
                        . /etc/bash_completion
                      fi
                    fi
                    # source ~/catkin_ws/develtup.bash
                    # >>> fishros initialize >>>
                    echo "ros:foxy(1) noetic(2) ?"
                    read choose
                    case $choose in
                    1) source  /opt/ros/foxytup.bash;;
                    2) source  /opt/ros^etictup.bash;;
                    esac
                    # <<< fishros initialize <<<
                    • 24187608382
                      ※辰坤星宇 @小鱼
                      @小鱼 啊这,怎么字又大又小,井号注释符也消失了
                      • 24187608382
                        ※辰坤星宇 @小鱼
                        jin@jin-virtual-machine:~/桌面/towm_ws$ source install/setup.bash
                        ROS_DISTRO was set to 'foxy' before. Please make sure that the environment does not mix paths from different distributions.
                        ROS_DISTRO was set to 'noetic' before. Please make sure that the environment does not mix paths from different distributions.
                          小鱼 技术大佬 @2418760838
                          @2418760838 建议学一下markdown语法
                            小鱼 技术大佬 @2418760838
                            @2418760838 打开心终端会提示ros:foxy(1) noetic(2) ?吗?
                            这个符号看起来很奇怪
                            • 24187608382
                              ※辰坤星宇 @小鱼
                              @小鱼 会的,然后我输入foxy或者noetic就可以继续了
                              • 24187608382
                                ※辰坤星宇 @小鱼
                                @小鱼 好的,我去了解一下
                                  小鱼 技术大佬 @2418760838
                                  @2418760838 你应该输入1或者2,而不是版本的名称
                                  • 24187608382
                                    ※辰坤星宇 @小鱼
                                    @小鱼 输了1还是一样
                                      小鱼 技术大佬 @2418760838
                                      @2418760838 将你的工作空间除src外删除后再次编译
                                      • 24187608382
                                        ※辰坤星宇 @小鱼
                                        @小鱼 !不会报错了!谢谢小鱼老师
                                        • 24187608382 2418760838 将这个主题标记为已解决,在
