    安装ros2后由于ros与ros2共存导致source install/setup.bash失败的问题
    ros2 版本冲突
    8.2k
      小鱼 技术大佬 @2418760838
      @2418760838 你在bashrc中保留的应该是foxy版本,但你source的应该是ros1的工作空间吧。
      24187608382 1 条回复 最后回复 回复 引用 0
      • 24187608382
        ※辰坤星宇 @小鱼
        @小鱼 不是呀,就是按照小鱼老师教程中3.4.1节中做的,用ros2 pkg创建的功能包,在那个工作空间目录下source的
          小鱼 技术大佬 @2418760838
          @2418760838 你补充一下你目前的bashrc(复制粘贴代码快包括),和source之后的错误提示
          24187608382 4 条回复 最后回复 回复 引用 0
          • 24187608382
            ※辰坤星宇 @小鱼
            • 24187608382
              ※辰坤星宇 @小鱼
              # ~/.bashrc: executed by bash(1) for non-login shells.
              # see /usr6/doc/bash/examples×artup-files (in the package bash-doc)
              # for examples
              # If not running interactively, don't do anything
              case $- in
                  *i*) ;;
                    *) return;;
              esac
              # don't put duplicate lines or lines starting with space in the history.
              # See bash(1) for more options
              HISTCONTROL=ignoreboth
              # append to the history file, don't overwrite it
              shopt -s histappend
              # for setting history length see HISTSIZE and HISTFILESIZE in bash(1)
              HISTSIZE=1000
              HISTFILESIZE=2000
              # check the window size after each command and, if necessary,
              # update the values of LINES and COLUMNS.
              shopt -s checkwinsize
              # If set, the pattern "**" used in a pathname expansion context will
              # match all files and zero or more directories and subdirectories.
              #shopt -s globstar
              # make less more friendly for non-text input files, see lesspipe(1)
              [ -x /usr/bin/lesspipe ] && eval "$(SHELL=/binš lesspipe)"
              # set variable identifying the chroot you work in (used in the prompt below)
              if [ -z "${debian_chroot:-}" ] && [ -r /etc/debian_chroot ]; then
                  debian_chroot=$(cat /etc/debian_chroot)
              fi
              # set a fancy prompt (non-color, unless we know we "want" color)
              case "$TERM" in
                  xterm-color|*-256color) color_prompt=yes;;
              esac
              # uncomment for a colored prompt, if the terminal has the capability; turned
              # off by default to not distract the user: the focus in a terminal window
              # should be on the output of commands, not on the prompt
              #force_color_prompt=yes
              if [ -n "$force_color_prompt" ]; then
                  if [ -x /usr/binut ] && tput setaf 1 >&/dev/null; then
              	# We have color support; assume it's compliant with Ecma-48
              	# (ISO/IEC-6429). (Lack of such support is extremely rare, and such
              	# a case would tend to support setf rather than setaf.)
              	color_prompt=yes
                  else
              	color_prompt=
                  fi
              fi
              if [ "$color_prompt" = yes ]; then
                  PS1='${debian_chroot:+($debian_chroot)}\[\033[01;32m\]\u@\h\[\033[00m\]:\[\033[01;34m\]\w\[\033[00m\]\$ '
              else
                  PS1='${debian_chroot:+($debian_chroot)}\u@\h:\w\$ '
              fi
              unset color_prompt force_color_prompt
              # If this is an xterm set the title to user@host:dir
              case "$TERM" in
              xterm*|rxvt*)
                  PS1="\[\e]0;${debian_chroot:+($debian_chroot)}\u@\h: \w\a\]$PS1"
              esac
              # enable color support of ls and also add handy aliases
              if [ -x /usr/bin/dircolors ]; then
                  test -r ~/.dircolors && eval "$(dircolors -b ~/.dircolors)" || eval "$(dircolors -b)"
                  alias ls='ls --color=auto'
                  #alias dir='dir --color=auto'
                  #alias vdir='vdir --color=auto'
                  alias grep='grep --color=auto'
                  alias fgrep='fgrep --color=auto'
                  alias egrep='egrep --color=auto'
              fi
              # colored GCC warnings and errors
              #export GCC_COLORS='error=01;31:warning=01;35:note=01;36:caret=01;32:locus=01:quote=01'
              # some more ls aliases
              alias ll='ls -alF'
              alias la='ls -A'
              alias l='ls -CF'
              # Add an "alert" alias for long running commands.  Use like so:
              #   sleep 10; alert
              alias alert='notify-send --urgency=low -i "$([ $? = 0 ] && echo terminal || echo error)" "$(history|tail -n1|sed -e '\''s/^\s*[0-9]\+\s*//;s/[;&|]\s*alert$//'\'')"'
              # Alias definitions.
              # You may want to put all your additions into a separate file like
              # ~/.bash_aliases, instead of adding them here directly.
              # See /usr6/doc/bash-doc/examples in the bash-doc package.
              if [ -f ~/.bash_aliases ]; then
                  . ~/.bash_aliases
              fi
              # enable programmable completion features (you don't need to enable
              # this, if it's already enabled in /etc/bash.bashrc and /etc/profile
              # sources /etc/bash.bashrc).
              if ! shopt -oq posix; then
                if [ -f /usr6/bash-completion/bash_completion ]; then
                  . /usr6/bash-completion/bash_completion
                elif [ -f /etc/bash_completion ]; then
                  . /etc/bash_completion
                fi
              fi
              # source ~/catkin_ws/develtup.bash
              # >>> fishros initialize >>>
              echo "ros:foxy(1) noetic(2) ?"
              read choose
              case $choose in
              1) source  /opt/ros/foxytup.bash;;
              2) source  /opt/ros^etictup.bash;;
              esac
              # <<< fishros initialize <<<
              • 24187608382
                ※辰坤星宇 @小鱼
                @小鱼 啊这,怎么字又大又小,井号注释符也消失了
                • 24187608382
                  ※辰坤星宇 @小鱼
                  jin@jin-virtual-machine:~/桌面/towm_ws$ source install/setup.bash
                  ROS_DISTRO was set to 'foxy' before. Please make sure that the environment does not mix paths from different distributions.
                  ROS_DISTRO was set to 'noetic' before. Please make sure that the environment does not mix paths from different distributions.
                    小鱼 技术大佬 @2418760838
                    @2418760838 建议学一下markdown语法
                      小鱼 技术大佬 @2418760838
                      @2418760838 打开心终端会提示ros:foxy(1) noetic(2) ?吗?
                      这个符号看起来很奇怪
                      • 24187608382
                        ※辰坤星宇 @小鱼
                        @小鱼 会的,然后我输入foxy或者noetic就可以继续了
                        • 24187608382
                          ※辰坤星宇 @小鱼
                          @小鱼 好的,我去了解一下
                            小鱼 技术大佬 @2418760838
                            @2418760838 你应该输入1或者2,而不是版本的名称
                            • 24187608382
                              ※辰坤星宇 @小鱼
                              @小鱼 输了1还是一样
                                小鱼 技术大佬 @2418760838
                                @2418760838 将你的工作空间除src外删除后再次编译
                                • 24187608382
                                  ※辰坤星宇 @小鱼
                                  @小鱼 !不会报错了!谢谢小鱼老师
                                  • 24187608382 2418760838 将这个主题标记为已解决,在
