    Cartographer建图提示Filter dropping message: frame 'laser_link' 解决方案
    cartographer ros2
    2.6k
      小鱼 技术大佬
      问题描述:使用ROS2 Cartographer进行仿真建图的时候出现的错误,RVIZ2中图正常,但是map和base_footprint姿态差距非常大。
      同时终端提示以下内容:
      [rviz2]: Message Filter dropping message: frame 'laser_link' at time 322.559 for reason 'Unknown'
      系统信息如下:
      • Ubuntu20.04
      • foxy
      • cartographer: foxy分支
      • cartographer: dashing分支
      • Gazebo11
      URDF:
      <?xml version="1.0"?>
      <robot name="fishbot">
        <!-- Robot Footprint -->
        <link name="base_footprint"/>
          <child link="base_link"/>
          <origin xyz="0.0 0.0 0.076" rpy="0 0 0"/>
        </joint>
        <!-- base link -->
        <link name="base_link">
        	<visual>
            <geometry>
      		<cylinder length="0.12" radius="0.10"/>
            </geometry>
            <material name="blue">
            </material>
          </visual>
          <collision>
            <geometry>
            </geometry>
            </material>
          </collision>
          <inertial>
            <mass value="0.2"/>
            <inertia ixx="0.0122666" ixy="0" ixz="0" iyy="0.0122666" iyz="0" izz="0.02"/>
          </inertial>
        </link>
        <!-- laser link -->
        <link name="laser_link">
          <visual>
            <geometry>
            </geometry>
            <material name="black">
            </material>
          </visual>
          <collision>
            <geometry>
            </geometry>
            </material>
          </collision>
          <inertial>
          <mass value="0.1"/>
            <inertia ixx="0.000190416666667" ixy="0" ixz="0" iyy="0.0001904" iyz="0" izz="0.00036"/>
          </inertial>
        </link>
        <!-- laser joint -->
            <parent link="base_link" />
            <child link="laser_link" />
            <origin xyz="0 0 0.075" />
        </joint>
        <link name="imu_link">
        	<visual>
            <geometry>
      		    <box size="0.02 0.02 0.02"/>
            </geometry>
          </visual>
          <collision>
            <geometry>
            </geometry>
          </collision>
          <inertial>
            <mass value="0.1"/>
            </inertial>
        </link>
        <!-- imu joint -->
            <child link="imu_link" />
            <origin xyz="0 0 0.02" />
        </joint>
        <link name="left_wheel_link">
            <visual>
              <geometry>
                <cylinder length="0.04" radius="0.032"/>
              </geometry>
                </material>
            </visual>
            <collision>
              <geometry>
              </geometry>
                </material>
            </collision>
            <inertial>
              <mass value="0.2"/>
              </inertial>
        </link>
            <visual>
              <geometry>
              </geometry>
                </material>
            </visual>
            <collision>
              <geometry>
              </geometry>
                </material>
            </collision>
            <inertial>
            <mass value="0.2"/>
          </inertial>
        </link>
            <origin xyz="-0.02 0.10 -0.06" />
            <axis xyz="0 1 0" />
        </joint>
            <origin xyz="-0.02 -0.10 -0.06" />
        </joint>
        <link name="caster_link">
            <visual>
              <geometry>
                  <sphere radius="0.016"/>
              </geometry>
                </material>
            </visual>
            <collision>
              <geometry>
              </geometry>
                </material>
            </collision>
            <inertial>
            <mass value="0.02"/>
          </inertial>
        </link>
        <joint name="caster_joint" type="fixed">
            <child link="caster_link" />
            <origin xyz="0.06 0.0 -0.076" />
        </joint>
        <gazebo reference="caster_link">
        </gazebo>
          <mu1 value="0.0"/>
          <mu2 value="0.0"/>
          <kp value="1000000.0" />
          <kd value="10.0" />
          <!-- <fdir1 value="0 0 1"/> -->
        </gazebo>
        <gazebo>
                <ros>
                  <namespace>/</namespace>
                </ros>
                <update_rate>30</update_rate>
                <!-- wheels -->
                <!-- <left_joint>left_wheel_joint</left_joint> -->
                <!-- <right_joint>right_wheel_joint</right_joint> -->
                <!-- kinematics -->
                <!-- limits -->
                <!-- output -->
                <publish_wheel_tf>false</publish_wheel_tf>
            </plugin>
            <plugin name="fishbot_joint_state" filename="libgazebo_ros_joint_state_publisher.so">
              <ros>
                <remapping>~/out:=joint_states</remapping>
              </ros>
              <joint_name>right_wheel_joint</joint_name>
              <joint_name>left_wheel_joint</joint_name>
            </plugin>
            </gazebo>
            </gazebo>
          <gazebo reference="imu_link">
            <sensor name="imu_sensor" type="imu">
            <plugin filename="libgazebo_ros_imu_sensor.so" name="imu_plugin">
                <ros>
                  <remapping>~/out:=imu</remapping>
                </ros>
                <initial_orientation_as_reference>false</initial_orientation_as_reference>
              </plugin>
              <always_on>true</always_on>
              <update_rate>100</update_rate>
              <visualize>true</visualize>
              <imu>
                <angular_velocity>
                  <x>
                    <noise type="gaussian">
                      <mean>0.0</mean>
                      <stddev>2e-4</stddev>
                      <bias_mean>0.0000075</bias_mean>
                      <bias_stddev>0.0000008</bias_stddev>
                    </noise>
                  </x>
                  <y>
                      <mean>0.0</mean>
                    </noise>
                  </y>
                  <z>
                      <mean>0.0</mean>
                    </noise>
                  </z>
                </angular_velocity>
                <linear_acceleration>
                  <x>
                      <mean>0.0</mean>
                      <stddev>1.7e-2</stddev>
                      <bias_mean>0.1</bias_mean>
                      <bias_stddev>0.001</bias_stddev>
                    </noise>
                  </x>
                  <y>
                      <mean>0.0</mean>
                    </noise>
                  </y>
                  <z>
                      <mean>0.0</mean>
                    </noise>
                  </z>
                </linear_acceleration>
              </imu>
            </sensor>
          </gazebo>
            <sensor name="laser_sensor" type="ray">
            <update_rate>5</update_rate>
            <pose>0 0 0.075 0 0 0</pose>
            <ray>
                <scan>
                  <horizontal>
                    <samples>360</samples>
                    <resolution>1.000000</resolution>
                  </horizontal>
                </scan>
                <range>
                  <min>0.120000</min>
                  <max>3.5</max>
                  <resolution>0.015000</resolution>
                </range>
                <noise>
                  <type>gaussian</type>
                  <mean>0.0</mean>
                  <stddev>0.01</stddev>
                </noise>
            </ray>
              <ros>
                <!-- <namespace>/tb3</namespace> -->
              </ros>
            </plugin>
            </sensor>
          </gazebo>
      </robot>
        小鱼 技术大佬 @小鱼
        @小鱼 问题定位与解决方案:
        使用rqt_tf_tree查看tf是否正常,发现map到base_footprint之间时间差距非常大。
        问题原因:cartographer启动时为设置use_sim_time为True。
        解决方案:
        在launch后增加use_sim_time设置使用仿真时间源。
        use_sim_time:=True
        正确的TF如下:
        • 小鱼小 小鱼 将这个主题标记为已解决,在
        • D demo123 在 中 引用了 这个主题
