realsense订阅无法进入sub_camera_callback
#!/usr/bin/env python3 import time import message_filters import rclpy from rclpy.node import Node from sensor_msgs.msg import Image from example_interfaces.srv import AddTwoInts class MinimalService(Node): def __init__(self): super().__init__('minimal_service_node') self.srv = self.create_service(AddTwoInts, 'camera_sub_add_two_ints', self.add_two_ints_callback) def add_two_ints_callback(self, request, response): response.sum = request.a + request.b flag, rgb, depth = self.sub_camera() return response def sub_camera(self): rgb_subscriber = message_filters.Subscriber(self, Image, "/camera/color/image_raw") depth_subscriber = message_filters.Subscriber(self, Image, "/camera/depth/image_rect_raw") ts = message_filters.ApproximateTimeSynchronizer( fs=[rgb_subscriber, depth_subscriber], queue_size=20, slop=0.03) vision_rgb_data, vision_depth_data = None, None ts.registerCallback(self.sub_camera_callback, vision_rgb_data, vision_depth_data) subscription_deadline = time.time() + 3.0 flag = True while not all([vision_rgb_data, vision_depth_data]): time.sleep(0.05) if time.time() >= subscription_deadline: print('Vision data subscription timeout.') flag = False break del ts self.destroy_subscription(rgb_subscriber.sub) self.destroy_subscription(depth_subscriber.sub) print('Vision data subscription finished.') return flag, vision_rgb_data, vision_depth_data def sub_camera_callback(self, rgb_msg, depth_msg, vision_rgb_data, vision_depth_data): print("----------") vision_rgb_data = rgb_msg vision_depth_data = depth_msg def main(args=None): rclpy.init(args=args) minimal_service = MinimalService() rclpy.spin(minimal_service) rclpy.shutdown() if __name__ == '__main__': main()
想要做的是,client端请求一个服务,然后在服务中先去订阅realsense的rgbd数据;之前存在的问题是,如果频繁的去调用这个订阅图像的函数,就会发生订阅不到的情况,然后至此开始,再怎么请求这个服务,都没法同时订阅rgb和d的数据。
然后我尝试先把这部分代码拆出来,结果发现现在上面的那段代码连订阅图像的那个call back函数都进不去了...可以确定的是,rgbd两个topic的名字是正确的。
命令行发这个就可以调用上面的服务
ros2 service call /camera_sub_add_two_ints example_interfaces/srv/AddTwoInts "{a: 1, b: 2}"
@renpei 如果是高频率订阅数据,还是不要反复订阅销毁,这样消耗的资源会更多
@小鱼 在 realsense订阅无法进入sub_camera_callback 中说:
是不要反复订阅销毁,这样消耗的
谢谢鱼总回复。你那边有realsense可以帮忙试试吗?另外一个就是,其实我自己尝试的时候,也就手动一秒一次这样调用这个服务,这算是比较频繁的调用吗?可能实际使用中不会这样。
另外就是如果不做销毁的操作的话,好像就会主线程一直被rgbd两个话题的订阅操作所占用,没法进行之后的操作。
@renpei 我这边没有realsense哦,可以把数据接收用单独的callbackgroup
