    realsense订阅无法进入sub_camera_callback
    ros2 realsense
    892
    • R
      五谷鱼粉
      #!/usr/bin/env python3
      import time
      import message_filters
      import rclpy
      from rclpy.node import Node
      from example_interfaces.srv import AddTwoInts
      class MinimalService(Node):
          def __init__(self):
              super().__init__('minimal_service_node')
              self.srv = self.create_service(AddTwoInts, 'camera_sub_add_two_ints', self.add_two_ints_callback)
          def add_two_ints_callback(self, request, response):
              response.sum = request.a + request.b
              flag, rgb, depth = self.sub_camera()
              return response
          def sub_camera(self):
              rgb_subscriber = message_filters.Subscriber(self, Image, "/camera/color/image_raw")
              depth_subscriber = message_filters.Subscriber(self, Image, "/camera/depth/image_rect_raw")
              ts = message_filters.ApproximateTimeSynchronizer(
                  fs=[rgb_subscriber, depth_subscriber],
                  queue_size=20, slop=0.03)
              vision_rgb_data, vision_depth_data = None, None
              ts.registerCallback(self.sub_camera_callback, vision_rgb_data, vision_depth_data)
              subscription_deadline = time.time() + 3.0
              flag = True
              while not all([vision_rgb_data, vision_depth_data]):
                  time.sleep(0.05)
                  if time.time() >= subscription_deadline:
                      print('Vision data subscription timeout.')
                      flag = False
                      break
              del ts
              self.destroy_subscription(rgb_subscriber.sub)
              self.destroy_subscription(depth_subscriber.sub)
              print('Vision data subscription finished.')
              return flag, vision_rgb_data, vision_depth_data
          def sub_camera_callback(self, rgb_msg, depth_msg, vision_rgb_data, vision_depth_data):
              print("----------")
              vision_rgb_data = rgb_msg
              vision_depth_data = depth_msg
      def main(args=None):
          rclpy.init(args=args)
          minimal_service = MinimalService()
          rclpy.spin(minimal_service)
          rclpy.shutdown()
      if __name__ == '__main__':
      • R
        五谷鱼粉
        最后由 renpei 编辑
        想要做的是,client端请求一个服务,然后在服务中先去订阅realsense的rgbd数据;之前存在的问题是,如果频繁的去调用这个订阅图像的函数,就会发生订阅不到的情况,然后至此开始,再怎么请求这个服务,都没法同时订阅rgb和d的数据。
        然后我尝试先把这部分代码拆出来,结果发现现在上面的那段代码连订阅图像的那个call back函数都进不去了...可以确定的是,rgbd两个topic的名字是正确的。
        • R
          五谷鱼粉
          最后由 renpei 编辑
          命令行发这个就可以调用上面的服务
          ros2 service call /camera_sub_add_two_ints example_interfaces/srv/AddTwoInts "{a: 1, b: 2}"
            小鱼 技术大佬 @renpei
            @renpei 如果是高频率订阅数据,还是不要反复订阅销毁,这样消耗的资源会更多
            R 1 条回复 最后回复 回复 引用 0
            • R
              五谷鱼粉 @小鱼
              @小鱼 在 realsense订阅无法进入sub_camera_callback 中说:
              是不要反复订阅销毁,这样消耗的
              谢谢鱼总回复。你那边有realsense可以帮忙试试吗?另外一个就是,其实我自己尝试的时候,也就手动一秒一次这样调用这个服务,这算是比较频繁的调用吗?可能实际使用中不会这样。
              另外就是如果不做销毁的操作的话,好像就会主线程一直被rgbd两个话题的订阅操作所占用,没法进行之后的操作。
                小鱼 技术大佬 @renpei
                @renpei 我这边没有realsense哦,可以把数据接收用单独的callbackgroup
