    一键安装失败
    ubuntu18.04 arm
    639
    • 11941553201
      小小秋风
        小鱼 技术大佬 @1194155320
        @1194155320 确实失败了,为啥会失败呢,终端全部日志信息提供一下
        1. 不要截图,要复制粘贴,一定要代码块包裹
          用代码块包裹是为了更加美观,不会一个代码很长一段,不易阅读
        11941553201 1 条回复 最后回复 回复 引用 0
        • 11941553201
          小小秋风 @小鱼
          [-]Result:success                           managementrminal-based package managerrr
          [-]Result:success                           e and 7 not upgraded.
          Run CMD Task:[sudo aptitude install  ros-bouncy-ros-base -y]
            binutils{a} binutils-aarch64-linux-gnu{a} binutils-common{a} build-essential{a} cmake{a} cmake-data{a} cpp{a} cpp-7{a} cppcheck{a} default-libmysqlclient-dev{a} dh-python{a} docutils-common{a} dpkg-dev{a} fakeroot{a} g++{a} g++-7{a}
            gcc{a} gcc-7{a} gcc-7-base{a} google-mock{a} googletest{a} libalgorithm-diff-perl{a} libalgorithm-diff-xs-perl{a} libalgorithm-merge-perl{a} libarchive13{a} libasan4{a} libatomic1{a} libbinutils{a} libc-dev-bin{ab} libc6-dev{ab}
            libcc1-0{a} libdpkg-perl{a} libeigen3-dev{a} libexpat1-dev{a} libfakeroot{a} libfile-fcntllock-perl{a} libfreetype6{a} libgcc-7-dev{a} libglib2.0-0{a} libglib2.0-data{a} libgomp1{a} libgtest-dev{a} libicu60{a} libisl19{a} libitm1{a}
            libjbig0{a} libjpeg-turbo8{a} libjpeg8{a} libjsoncpp1{a} liblcms2-2{a} liblsan0{a} libltdl7{a} liblzo2-2{a} libmpc3{a} libmpfr6{a} libmysqlclient-dev{a} libmysqlclient20{a} libodbc1{a} libpaper-utils{a} libpaper1{a} libpcre16-3{a}
            libpcre3-dev{a} libpcre32-3{a} libpcrecpp0v5{a} libpng16-16{a} libpoco-dev{a} libpococrypto50{a} libpocodata50{a} libpocodatamysql50{a} libpocodataodbc50{a} libpocodatasqlite50{a} libpocofoundation50{a} libpocojson50{a}
            libpocomongodb50{a} libpoconet50{a} libpoconetssl50{a} libpocoredis50{a} libpocoutil50{a} libpocoxml50{a} libpocozip50{a} libpython-stdlib{a} libpython2.7-minimal{a} libpython2.7-stdlib{a} libpython3-dev{a} libpython3.6-dev{a}
            librhash0{a} libsqlite3-dev{a} libssl-dev{a} libstdc++-7-dev{a} libtiff5{a} libtinyxml-dev{a} libtinyxml2-6{a} libtinyxml2-dev{a} libtinyxml2.6.2v5{a} libtsan0{a} libubsan0{a} libuv1{a} libwebp6{a} libwebpdemux2{a} libwebpmux3{a}
            libxml2{a} libyaml-0-2{a} libyaml-dev{a} linux-libc-dev{a} make{a} manpages{a} manpages-dev{a} multiarch-support{a} mysql-common{a} patch{a} pkg-config{a} pydocstyle{a} pyflakes{a} pyflakes3{a} python{a} python-minimal{a}
            python-pkg-resources{a} python-pyflakes{a} python2.7{a} python2.7-minimal{a} python3-attr{a} python3-catkin-pkg-modules{a} python3-dateutil{a} python3-dev{ab} python3-docutils{a} python3-empy{a} python3-flake8{a} python3-mccabe{a}
            python3-olefile{a} python3-pil{ab} python3-pluggy{a} python3-py{a} python3-pycodestyle{a} python3-pydocstyle{a} python3-pyflakes{a} python3-pygments{a} python3-pyparsing{a} python3-pytest{a} python3-roman{a} python3-six{a}
            python3-snowballstemmer{a} python3-yaml{ab} python3.6{a} python3.6-dev{a} python3.6-minimal{a} ros-bouncy-actionlib-msgs{a} ros-bouncy-ament-cmake{a} ros-bouncy-ament-cmake-auto{a} ros-bouncy-ament-cmake-copyright{a}
            ros-bouncy-ament-cmake-core{a} ros-bouncy-ament-cmake-cppcheck{a} ros-bouncy-ament-cmake-cpplint{a} ros-bouncy-ament-cmake-export-definitions{a} ros-bouncy-ament-cmake-export-dependencies{a}
            ros-bouncy-ament-cmake-export-include-directories{a} ros-bouncy-ament-cmake-export-interfaces{a} ros-bouncy-ament-cmake-export-libraries{a} ros-bouncy-ament-cmake-export-link-flags{a} ros-bouncy-ament-cmake-flake8{a}
            ros-bouncy-ament-cmake-gmock{a} ros-bouncy-ament-cmake-gtest{a} ros-bouncy-ament-cmake-include-directories{a} ros-bouncy-ament-cmake-libraries{a} ros-bouncy-ament-cmake-lint-cmake{a} ros-bouncy-ament-cmake-pep257{a}
            ros-bouncy-ament-cmake-pytest{a} ros-bouncy-ament-cmake-python{a} ros-bouncy-ament-cmake-ros{a} ros-bouncy-ament-cmake-target-dependencies{a} ros-bouncy-ament-cmake-test{a} ros-bouncy-ament-cmake-uncrustify{a}
            ros-bouncy-ament-copyright{a} ros-bouncy-ament-cppcheck{a} ros-bouncy-ament-cpplint{a} ros-bouncy-ament-flake8{a} ros-bouncy-ament-index-cpp{a} ros-bouncy-ament-index-python{a} ros-bouncy-ament-lint-auto{a}
            ros-bouncy-ament-lint-cmake{a} ros-bouncy-ament-lint-common{a} ros-bouncy-ament-package{a} ros-bouncy-ament-pep257{a} ros-bouncy-ament-uncrustify{a} ros-bouncy-builtin-interfaces{a} ros-bouncy-class-loader{a}
            ros-bouncy-common-interfaces{a} ros-bouncy-console-bridge{a} ros-bouncy-diagnostic-msgs{a} ros-bouncy-fastcdr{a} ros-bouncy-fastrtps{a} ros-bouncy-fastrtps-cmake-module{a} ros-bouncy-geometry-msgs{a} ros-bouncy-gmock-vendor{a}
            ros-bouncy-gtest-vendor{a} ros-bouncy-kdl-parser{a} ros-bouncy-launch{a} ros-bouncy-launch-ros{a} ros-bouncy-libyaml-vendor{a} ros-bouncy-lifecycle-msgs{a} ros-bouncy-nav-msgs{a} ros-bouncy-orocos-kdl{a} ros-bouncy-osrf-pycommon{a}
            ros-bouncy-pluginlib{a} ros-bouncy-poco-vendor{a} ros-bouncy-python-cmake-module{a} ros-bouncy-rcl{a} ros-bouncy-rcl-interfaces{a} ros-bouncy-rcl-lifecycle{a} ros-bouncy-rcl-yaml-param-parser{a} ros-bouncy-rclcpp{a}
            ros-bouncy-rclcpp-lifecycle{a} ros-bouncy-rclpy{a} ros-bouncy-rcutils{a} ros-bouncy-rmw{a} ros-bouncy-rmw-fastrtps-cpp{a} ros-bouncy-rmw-implementation{a} ros-bouncy-rmw-implementation-cmake{a} ros-bouncy-robot-state-publisher{a}
            ros-bouncy-ros-base ros-bouncy-ros-core{a} ros-bouncy-ros-environment{a} ros-bouncy-ros-workspace{a} ros-bouncy-ros2cli{a} ros-bouncy-ros2launch{a} ros-bouncy-ros2lifecycle{a} ros-bouncy-ros2msg{a} ros-bouncy-ros2node{a}
            ros-bouncy-ros2param{a} ros-bouncy-ros2pkg{a} ros-bouncy-ros2run{a} ros-bouncy-ros2service{a} ros-bouncy-ros2srv{a} ros-bouncy-ros2topic{a} ros-bouncy-rosgraph-msgs{a} ros-bouncy-rosidl-cmake{a} ros-bouncy-rosidl-default-generators{a}
            ros-bouncy-rosidl-default-runtime{a} ros-bouncy-rosidl-generator-c{a} ros-bouncy-rosidl-generator-cpp{a} ros-bouncy-rosidl-generator-py{a} ros-bouncy-rosidl-parser{a} ros-bouncy-rosidl-typesupport-c{a}
            ros-bouncy-rosidl-typesupport-cpp{a} ros-bouncy-rosidl-typesupport-interface{a} ros-bouncy-rosidl-typesupport-introspection-c{a} ros-bouncy-rosidl-typesupport-introspection-cpp{a} ros-bouncy-sensor-msgs{a} ros-bouncy-shape-msgs{a}
            ros-bouncy-std-msgs{a} ros-bouncy-std-srvs{a} ros-bouncy-stereo-msgs{a} ros-bouncy-tf2{a} ros-bouncy-tf2-eigen{a} ros-bouncy-tf2-geometry-msgs{a} ros-bouncy-tf2-msgs{a} ros-bouncy-tf2-ros{a} ros-bouncy-tinyxml-vendor{a}
            ros-bouncy-tinyxml2-vendor{a} ros-bouncy-trajectory-msgs{a} ros-bouncy-uncrustify-vendor{a} ros-bouncy-urdf{a} ros-bouncy-urdfdom{a} ros-bouncy-urdfdom-headers{a} ros-bouncy-visualization-msgs{a} sgml-base{a} shared-mime-info{a}
            tzdata{a} ucf{a} xdg-user-dirs{a} xml-core{a} zlib1g-dev{a}
          0 packages upgraded, 271 newly installed, 0 to remove and 7 not upgraded.
          Need to get 125 MB of archives. After unpacking 463 MB will be used.
           python3-dev : Depends: python3 (= 3.6.7-1~18.04) but 3.8.2-0ubuntu2 is installed
           libc6-dev : Depends: libc6 (= 2.27-3ubuntu1.5) but 2.31-0ubuntu9.7 is installed
           python3-pil : Depends: python3 (< 3.7) but 3.8.2-0ubuntu2 is installed
           python3-yaml : Depends: python3 (< 3.7) but 3.8.2-0ubuntu2 is installed
           libgcc-s1 : Breaks: libgcc-7-dev (< 7.5.0-4) but 7.5.0-3ubuntu1~18.04 is to be installed
           libc-dev-bin : Depends: libc6 (< 2.28) but 2.31-0ubuntu9.7 is installed
          open: 36; closed: 189; defer: 23; conflict: 40        OThe following actions will resolve these dependencies:
                Install the following packages:
          1)      bcc [0.16.17-3.3 (bionic)]
          2)      bin86 [0.16.17-3.3 (bionic)]
          3)      elks-libc [0.16.17-3.3 (bionic)]
          4)      build-essential [Not Installed]
          5)      default-libmysqlclient-dev [Not Installed]
          6)      g++ [Not Installed]
          7)      g++-7 [Not Installed]
          8)      gcc [Not Installed]
          9)      gcc-7 [Not Installed]
          10)     libc-dev-bin [Not Installed]
          11)     libc6-dev [Not Installed]
          12)     libexpat1-dev [Not Installed]
          13)     libgcc-7-dev [Not Installed]
          14)     libmysqlclient-dev [Not Installed]
          15)     libpcre3-dev [Not Installed]
          16)     libpoco-dev [Not Installed]
          17)     libpython3-dev [Not Installed]
          18)     libpython3.6-dev [Not Installed]
          19)     libsqlite3-dev [Not Installed]
          20)     libstdc++-7-dev [Not Installed]
          21)     python3-dev [Not Installed]
          22)     python3-pil [Not Installed]
          23)     python3-yaml [Not Installed]
          24)     python3.6-dev [Not Installed]
          25)     ros-bouncy-actionlib-msgs [Not Installed]
          26)     ros-bouncy-builtin-interfaces [Not Installed]
          27)     ros-bouncy-class-loader [Not Installed]
          28)     ros-bouncy-common-interfaces [Not Installed]
          29)     ros-bouncy-diagnostic-msgs [Not Installed]
          30)     ros-bouncy-geometry-msgs [Not Installed]
          31)     ros-bouncy-launch-ros [Not Installed]
          32)     ros-bouncy-lifecycle-msgs [Not Installed]
          33)     ros-bouncy-nav-msgs [Not Installed]
          34)     ros-bouncy-pluginlib [Not Installed]
          35)     ros-bouncy-poco-vendor [Not Installed]
          36)     ros-bouncy-python-cmake-module [Not Installed]
          37)     ros-bouncy-rcl [Not Installed]
          38)     ros-bouncy-rcl-interfaces [Not Installed]
          39)     ros-bouncy-rcl-lifecycle [Not Installed]
          40)     ros-bouncy-rclcpp [Not Installed]
          41)     ros-bouncy-rclcpp-lifecycle [Not Installed]
          42)     ros-bouncy-rclpy [Not Installed]
          43)     ros-bouncy-rmw-implementation [Not Installed]
          44)     ros-bouncy-robot-state-publisher [Not Installed]
          45)     ros-bouncy-ros-base [Not Installed]
          46)     ros-bouncy-ros-core [Not Installed]
          47)     ros-bouncy-ros2cli [Not Installed]
          48)     ros-bouncy-ros2launch [Not Installed]
          49)     ros-bouncy-ros2lifecycle [Not Installed]
          50)     ros-bouncy-ros2msg [Not Installed]
          51)     ros-bouncy-ros2node [Not Installed]
          52)     ros-bouncy-ros2param [Not Installed]
          53)     ros-bouncy-ros2pkg [Not Installed]
          54)     ros-bouncy-ros2run [Not Installed]
          55)     ros-bouncy-ros2service [Not Installed]
          56)     ros-bouncy-ros2srv [Not Installed]
          57)     ros-bouncy-ros2topic [Not Installed]
          58)     ros-bouncy-rosgraph-msgs [Not Installed]
          59)     ros-bouncy-rosidl-default-generators [Not Installed]
          60)     ros-bouncy-rosidl-default-runtime [Not Installed]
          61)     ros-bouncy-rosidl-generator-py [Not Installed]
          62)     ros-bouncy-rosidl-typesupport-c [Not Installed]
          63)     ros-bouncy-rosidl-typesupport-cpp [Not Installed]
          64)     ros-bouncy-sensor-msgs [Not Installed]
          65)     ros-bouncy-shape-msgs [Not Installed]
          66)     ros-bouncy-std-msgs [Not Installed]
          67)     ros-bouncy-std-srvs [Not Installed]
          68)     ros-bouncy-stereo-msgs [Not Installed]
          69)     ros-bouncy-tf2 [Not Installed]
          70)     ros-bouncy-tf2-eigen [Not Installed]
          71)     ros-bouncy-tf2-geometry-msgs [Not Installed]
          72)     ros-bouncy-tf2-msgs [Not Installed]
          73)     ros-bouncy-tf2-ros [Not Installed]
          74)     ros-bouncy-trajectory-msgs [Not Installed]
          75)     ros-bouncy-visualization-msgs [Not Installed]
          76)     zlib1g-dev [Not Installed]
                Leave the following dependencies unresolved:
          77)     python3-docutils recommends python3-pil
          78)     cmake recommends gcc
          79)     dpkg-dev recommends build-essential
          80)     libpython3.6-dev recommends libc6-dev | libc-dev
          81)     python3.6-dev recommends libc6-dev | libc-dev
          0 packages upgraded, 0 newly installed, 0 to remove and 7 not upgraded.
          Need to get 0 B of archives. After unpacking 0 B will be used.
          [\]  binutils{a} binutils-aarch64-linux-gnu{a} binutils-common{a} build-essential{a} cmake{a} cmake-data{a} cpp{a} cpp-7{a} cppcheck{a} default-libmysqlclient-dev{a} dh-python{a} docutils-common{a} dpkg-dev{a} fakeroot{a} g++{a} g++-7{a} gcc{a} gcc-7{a} gcc-7-base{a} google-mock{a} googletest{a} libalgorithm-diff-perl{a} libalgorithm-diff-xs-perl{a} libalgorithm-merge-perl{a} libarchive13{a} libasan4{a} libatomic1{a} libbinutils{a} libc-dev-bin{ab} libc6-dev{ab} libcc1-0{a} libdpkg-perl{a} libeigen3-dev{a} libexpat1-dev{a} libfakeroot{a} libfile-fcntllock-perl{a} libfreetype6{a} libgcc-7-dev{a} libglib2.0-0{a} libglib2.0-data{a} libgomp1{a} libgtest-dev{a} libicu60{a} libisl19{a} libitm1{a} libjbig0{a} libjpeg-turbo8{a} libjpeg8{a} libjsoncpp1{a} liblcms2-2{a} liblsan0{a} libltdl7{a} liblzo2-2{a} libmpc3{a} libmpfr6{a} libmysqlclient-dev{a} libmysqlclient20{a} libodbc1{a} libpaper-utils{a} libpaper1{a} libpcre16-3{a} libpcre3-dev{a} libpcre32-3{a} libpcrecpp0v5{a} libpng16-16{a} libpoco-dev{a} libpococrypto50{a} libpocodata50{a} libpocodatamysql50{a} libpocodataodbc50{a} libpocodatasqlite50{a} libpocofoundation50{a} libpocojson50{a} libpocomongodb50{a} libpoconet50{a} libpoconetssl50{a} libpocoredis50{a} libpocoutil50{a} libpocoxml50{a} libpocozip50{a} libpython-stdlib{a} libpython2.7-minimal{a} libpython2.7-stdlib{a} libpython3-dev{a} libpython3.6-dev{a} librhash0{a} libsqlite3-dev{a} libssl-dev{a} libstdc++-7-dev{a} libtiff5{a} libtinyxml-dev{a} libtinyxml2-6{a} libtinyxml2-dev{a} libtinyxml2.6.2v5{a} libtsan0{a} libubsan0{a} libuv1{a} libwebp6{a} libwebpdemux2{a} libwebpmux3{a} libxml2{a} libyaml-0-2{a} libyaml-dev{a} linux-libc-dev{a} make{a} manpages{a} manpages-dev{a} multiarch-support{a} mysql-common{a} patch{a} pkg-config{a} pydocstyle{a} pyflakes{a} pyflakes3{a} python{a} python-minimal{a} python-pkg-resources{a} python-pyflakes{a} python2.7{a} python2.7-minimal{a} python3-attr{a} python3-catkin-pkg-modules{a} python3-dateutil{a} python3-dev{ab} python3-docutils{a} python3-empy{a} python3-flake8{a} python3-mccabe{a} python3-olefile{a} python3-pil{ab} python3-pluggy{a} python3-py{a} python3-pycodestyle{a} python3-pydocstyle{a} python3-pyflakes{a} python3-pygments{a} python3-pyparsing{a} python3-pytest{a} python3-roman{a} python3-six{a} python3-snowballstemmer{a} python3-yaml{ab} python3.6{a} python3.6-dev{a} python3.6-minimal{a} ros-bouncy-actionlib-msgs{a} ros-bouncy-ament-cmake{a} ros-bouncy-ament-cmake-auto{a} ros-bouncy-ament-cmake-copyright{a} ros-bouncy-ament-cmake-core{a} ros-bouncy-ament-cmake-cppcheck{a} ros-bouncy-ament-cmake-cpplint{a} ros-bouncy-ament-cmake-export-definitions{a} ros-bouncy-ament-cmake-export-dependencies{a} ros-bouncy-ament-cmake-export-include-directories{a} ros-bouncy-ament-cmake-export-interfaces{a} ros-bouncy-ament-cmake-export-libraries{a} ros-bouncy-ament-cmake-export-link-flags{a} ros-bouncy-ament-cmake-flake8{a} ros-bouncy-ament-cmake-gmock{a} ros-bouncy-ament-cmake-gtest{a} ros-bouncy-ament-cmake-include-directories{a} ros-bouncy-ament-cmake-libraries{a} ros-bouncy-ament-cmake-lint-cmake{a} ros-bouncy-ament-cmake-pep257{a} ros-bouncy-ament-cmake-pytest{a} ros-bouncy-ament-cmake-python{a} ros-bouncy-ament-cmake-ros{a} ros-bouncy-ament-cmake-target-dependencies{a} ros-bouncy-ament-cmake-test{a} ros-bouncy-ament-cmake-uncrustify{a} ros-bouncy-ament-copyright{a} ros-bouncy-ament-cppcheck{a} ros-bouncy-ament-cpplint{a} ros-bouncy-ament-flake8{a} ros-bouncy-ament-index-cpp{a} ros-bouncy-ament-index-python{a} ros-bouncy-ament-lint-auto{a} ros-bouncy-ament-lint-cmake{a} ros-bouncy-ament-lint-common{a} ros-bouncy-ament-package{a} ros-bouncy-ament-pep257{a} ros-bouncy-ament-uncrustify{a} ros-bouncy-builtin-interfaces{a} ros-bouncy-class-loader{a} ros-bouncy-common-interfaces{a} ros-bouncy-console-bridge{a} ros-bouncy-diagnostic-msgs{a} ros-bouncy-fastcdr{a} ros-bouncy-fastrtps{a} ros-bouncy-fastrtps-cmake-module{a} ros-bouncy-geometry-msgs{a} ros-bouncy-gmock-vendor{a} ros-bouncy-gtest-vendor{a} ros-bouncy-kdl-parser{a} ros-bouncy-launch{a} ros-bouncy-launch-ros{a} ros-bouncy-libyaml-vendor{a} ros-bouncy-lifecycle-msgs{a} ros-bouncy-nav-msgs{a} ros-bouncy-orocos-kdl{a} ros-bouncy-osrf-pycommon{a} ros-bouncy-pluginlib{a} ros-bouncy-poco-vendor{a} ros-bouncy-python-cmake-module{a} ros-bouncy-rcl{a} ros-bouncy-rcl-interfaces{a} ros-bouncy-rcl-lifecycle{a} ros-bouncy-rcl-yaml-param-parser{a} ros-bouncy-rclcpp{a} ros-bouncy-rclcpp-lifecycle{a} ros-bouncy-rclpy{a} ros-bouncy-rcutils{a} ros-bouncy-rmw{a} ros-bouncy-rmw-fastrtps-cpp{a} ros-bouncy-rmw-implementation{a} ros-bouncy-rmw-implementation-cmake{a} ros-bouncy-robot-state-publisher{a} ros-bouncy-ros-base ros-bouncy-ros-core{a} ros-bouncy-ros-environment{a} ros-bouncy-ros-workspace{a} ros-bouncy-ros2cli{a} ros-bouncy-ros2launch{a} ros-bouncy-ros2lifecycle{a} ros-bouncy-ros2msg{a} ros-bouncy-ros2node{a} ros-bouncy-ros2param{a} ros-bouncy-ros2pkg{a} ros-bouncy-ros2run{a} ros-bouncy-ros2service{a} ros-bouncy-ros2srv{a} ros-bouncy-ros2topic{a} ros-bouncy-rosgraph-msgs{a} ros-bouncy-rosidl-cmake{a} ros-bouncy-rosidl-default-generators{a} ros-bouncy-rosidl-default-runtime{a} ros-bouncy-rosidl-generator-c{a} ros-bouncy-rosidl-generator-cpp{a} ros-bouncy-rosidl-generator-py{a} ros-bouncy-rosidl-parser{a} ros-bouncy-rosidl-typesupport-c{a} ros-bouncy-rosidl-typesupport-cpp{a} ros-bouncy-rosidl-typesupport-interface{a} ros-bouncy-rosidl-typesupport-introspection-c{a} ros-bouncy-rosidl-typesupport-introspection-cpp{a} ros-bouncy-sensor-msgs{a} ros-bouncy-shape-msgs{a} ros-bouncy-std-msgs{a} ros-bouncy-std-srvs{a} ros-bouncy-stereo-msgs{a} ros-bouncy-tf2{a} ros-bouncy-tf2-eigen{a} ros-bouncy-tf2-geometry-msgs{a} ros-bouncy-tf2-msgs{a} ros-bouncy-tf2-ros{a} ros-bouncy-tinyxml-vendor{a} ros-bouncy-tinyxml2-vendor{a} ros-bouncy-trajectory-msgs{a} ros-bouncy-uncrustify-vendor{a} ros-bouncy-urdf{a} ros-bouncy-urdfdom{a} ros-bouncy-urdfdom-headers{a} ros-bouncy-visualization-msgs{a} sgml-base{a} shared-mime-info{a} tzdata{a} ucf{a} xdg-user-dirs{[-]Result:success                           ing 0 B will be used.upgraded.ds to be installed
          Run CMD Task:[ls /opt/ros/bouncy/setup.bash]
          [-]Result:code:2
          [-]Result:code:2
          谢谢😁 😁
            小鱼 技术大佬 @1194155320
            @1194155320 在 一键安装失败 中说:
            尽量提供全部日志,都看不出来你的系统版本信息,另外你装一下完全版的。如果是ROS2建议用ubuntu20
            • 11941553201
              小小秋风 @小鱼
              @小鱼 Last login: Thu May 5 06:48:51 UTC 2022 on pts/1
              Euler:~ # docker attach f202b5787a46
              root@f202b5787a46:/tmp# sudo apt-get install curl && curl http://fishros.com/tools/install/ros-foxy | bash
              Reading package lists... Done
              Building dependency tree
              curl is already the newest version (7.68.0-1ubuntu2.10).
              0 upgraded, 0 newly installed, 0 to remove and 7 not upgraded.
              % Total % Received % Xferd Average Speed Time Time Time Current
              Dload Upload Total Spent Left Speed
              100 432 100 432 0 0 20571 0 --:--:-- --:--:-- --:--:-- 21600
              欢迎使用一键安装,检测到您目前使用的是旧版一键安装,请访问http://fishros.com 复制粘贴最新版
              也可以手敲下面代码:wget http://fishros.com/install -O fishros && bash fishros
              一键安装已开源请放心使用:https://github.com/fishros/install
              最后欢迎关注小鱼的公众号鱼香ROS.Nav2中文网即将上线,欢迎访问:http://nav2.fishros.com/
              root@f202b5787a46:/tmp# wget http://fishros.com/install -O fishros && bash fishros
              --2022-05-05 06:52:42-- http://fishros.com/install
              --2022-05-05 06:52:42-- http://fishros.com/install/
              Length: 336 [application/octet-stream]
              Saving to: 'fishros'
              fishros 100%[===========================================================================================================================================>] 336 --.-KB/s in 0s
              2022-05-05 06:52:42 (21.9 MB/s) - 'fishros' saved [336/336]
              python3-distro is already the newest version (1.4.0-1).
              sudo is already the newest version (1.8.31-1ubuntu1.2).
              --2022-05-05 06:52:56-- http://fishros.com/install/install1s/tools/base.py
              Length: 36752 (36K) [application/octet-stream]
              /tmp/fishinstall/tools/base.py 100%[===========================================================================================================================================>] 35.89K --.-KB/s in 0.009s
              2022-05-05 06:52:56 (3.92 MB/s) - ‘/tmp/fishinstall/tools/base.py’ saved [36752/36752]
              [-]Result:success
              基础检查通过...
              ---众多工具,等君来用---
              [6]:一键安装:nodejs
              [7]:一键安装:VsCode开发工具
              [8]:一键安装:Docker
              [10]:一键安装:微信(可以在Linux上使用的微信)
              [77]:测试模式:运行自定义工具测试
              请输入[]内的数字以选择:1
              --2022-05-05 06:53:03-- http://fishros.com/install/install1s/tools/tool_install_ros.py
              Length: 11916 (12K) [application/octet-stream]
              /tmp/fishinstall/tools/tool_install_ros.py 100%[===========================================================================================================================================>] 11.64K --.-KB/s in 0.001s
              2022-05-05 06:53:03 (21.0 MB/s) - ‘/tmp/fishinstall/tools/tool_install_ros.py’ saved [11916/11916]
              --2022-05-05 06:53:03-- http://fishros.com/install/install1s/tools/tool_config_rosenv.py
              Length: 2307 (2.3K) [application/octet-stream]
              /tmp/fishinstall/tools/tool_config_rosenv.py 100%[===========================================================================================================================================>] 2.25K --.-KB/s in 0s
              2022-05-05 06:53:03 (51.2 MB/s) - ‘/tmp/fishinstall/tools/tool_config_rosenv.py’ saved [2307/2307]
              --2022-05-05 06:53:03-- http://fishros.com/install/install1s/tools/tool_config_system_source.py
              Length: 9161 (8.9K) [application/octet-stream]
              /tmp/fishinstall/tools/tool_config_system_source.py 100%[===========================================================================================================================================>] 8.95K --.-KB/s in 0s
              2022-05-05 06:53:03 (35.8 MB/s) - ‘/tmp/fishinstall/tools/tool_config_system_source.py’ saved [9161/9161]
              [1]:更换系统源再继续安装
              [2]:不更换继续安装
              请输入[]内的数字以选择:1
              欢迎使用一键更换系统源,本工具由作者小鱼提供
              欢迎使用一键换源工具,本工具由[鱼香ROS]小鱼贡献..
              请选择换源方式,如果不知道选什么请选2
              [1]:仅更换系统源
              [2]:更换系统源并清理第三方源
              请输入[]内的数字以选择:2
              [-]Result:success
              删除一个资源文件
              [-]Result:success
              [-]Result:success
              检测到当前系统架构为[arm64],正在为你更换对应源..
              替换完成,尝试第一次更新....
              [-]Result:success --upgradable' to see them.easee
              搞定了,不信你看,累死宝宝了,还不快去给小鱼点个赞~
              ['Hit:1 https://mirrors.ustc.edu.cn/ubuntu-ports bionic InRelease', 'Hit:2 https://mirrors.ustc.edu.cn/ubuntu-ports bionic-updates InRelease', 'Hit:3 https://mirrors.ustc.edu.cn/ubuntu-ports bionic-backports InRelease', 'Hit:4 https://mirrors.ustc.edu.cn/ubuntu-ports bionic-security InRelease', 'Reading package lists...', 'Building dependency tree...', 'Reading state information...', "7 packages can be upgraded. Run 'apt list --upgradable' to see them."]
              镜像修复完成.....
              [-]Result:success t for HTTPGI-Lang interface librariesling librariesr)d line
              [-]Result:success
              [-]Result:success
              Run CMD Task:[sudo mkdir -p /etc/apt/sources.list.d/]
              [-]Result:success
              [-]Result:success --upgradable' to see them.m64 Packages [771 kB]
              [-]Result:success xtends 'ros_core' and includes other basic functionalities like tf2 and urdf.ynamic reconfigure, nodelets, and pluginlib.
              [1]:melodic(ROS1)
              [2]:bouncy(ROS2)
              [3]:crystal(ROS2)
              [4]:dashing(ROS2)
              [5]:eloquent(ROS2)
              请输入[]内的数字以选择:2
              请选择安装的具体版本(如果不知道怎么选,请选1桌面版):
              [1]:bouncy(ROS2)桌面版
              [2]:bouncy(ROS2)基础版(小)
              请输入[]内的数字以选择:2
              open: 35; closed: 180; defer: 23; conflict: 40 .The following actions will resolve these dependencies:
              1.  bcc [0.16.17-3.3 (bionic)]
              2.  bin86 [0.16.17-3.3 (bionic)]
              3.  elks-libc [0.16.17-3.3 (bionic)]
              4.  build-essential [Not Installed]
              5.  default-libmysqlclient-dev [Not Installed]
              6.  g++ [Not Installed]
              7.  g++-7 [Not Installed]
              8.  gcc [Not Installed]
              9.  gcc-7 [Not Installed]
              10. libc-dev-bin [Not Installed]
              11. libc6-dev [Not Installed]
              12. libexpat1-dev [Not Installed]
              13. libgcc-7-dev [Not Installed]
              14. libmysqlclient-dev [Not Installed]
              15. libpcre3-dev [Not Installed]
              16. libpoco-dev [Not Installed]
              17. libpython3-dev [Not Installed]
              18. libpython3.6-dev [Not Installed]
              19. libsqlite3-dev [Not Installed]
              20. libstdc++-7-dev [Not Installed]
              21. python3-dev [Not Installed]
              22. python3-pil [Not Installed]
              23. python3-yaml [Not Installed]
              24. python3.6-dev [Not Installed]
              25. ros-bouncy-actionlib-msgs [Not Installed]
              26. ros-bouncy-builtin-interfaces [Not Installed]
              27. ros-bouncy-class-loader [Not Installed]
              28. ros-bouncy-common-interfaces [Not Installed]
              29. ros-bouncy-diagnostic-msgs [Not Installed]
              30. ros-bouncy-geometry-msgs [Not Installed]
              31. ros-bouncy-launch-ros [Not Installed]
              32. ros-bouncy-lifecycle-msgs [Not Installed]
              33. ros-bouncy-nav-msgs [Not Installed]
              34. ros-bouncy-pluginlib [Not Installed]
              35. ros-bouncy-poco-vendor [Not Installed]
              36. ros-bouncy-python-cmake-module [Not Installed]
              37. ros-bouncy-rcl [Not Installed]
              38. ros-bouncy-rcl-interfaces [Not Installed]
              39. ros-bouncy-rcl-lifecycle [Not Installed]
              40. ros-bouncy-rclcpp [Not Installed]
              41. ros-bouncy-rclcpp-lifecycle [Not Installed]
              42. ros-bouncy-rclpy [Not Installed]
              43. ros-bouncy-rmw-implementation [Not Installed]
              44. ros-bouncy-robot-state-publisher [Not Installed]
              45. ros-bouncy-ros-base [Not Installed]
              46. ros-bouncy-ros-core [Not Installed]
              47. ros-bouncy-ros2cli [Not Installed]
              48. ros-bouncy-ros2launch [Not Installed]
              49. ros-bouncy-ros2lifecycle [Not Installed]
              50. ros-bouncy-ros2msg [Not Installed]
              51. ros-bouncy-ros2node [Not Installed]
              52. ros-bouncy-ros2param [Not Installed]
              53. ros-bouncy-ros2pkg [Not Installed]
              54. ros-bouncy-ros2run [Not Installed]
              55. ros-bouncy-ros2service [Not Installed]
              56. ros-bouncy-ros2srv [Not Installed]
              57. ros-bouncy-ros2topic [Not Installed]
              58. ros-bouncy-rosgraph-msgs [Not Installed]
              59. ros-bouncy-rosidl-default-generators [Not Installed]
              60. ros-bouncy-rosidl-default-runtime [Not Installed]
              61. ros-bouncy-rosidl-generator-py [Not Installed]
              62. ros-bouncy-rosidl-typesupport-c [Not Installed]
              63. ros-bouncy-rosidl-typesupport-cpp [Not Installed]
              64. ros-bouncy-sensor-msgs [Not Installed]
              65. ros-bouncy-shape-msgs [Not Installed]
              66. ros-bouncy-std-msgs [Not Installed]
              67. ros-bouncy-std-srvs [Not Installed]
              68. ros-bouncy-stereo-msgs [Not Installed]
              69. ros-bouncy-tf2 [Not Installed]
              70. ros-bouncy-tf2-eigen [Not Installed]
              71. ros-bouncy-tf2-geometry-msgs [Not Installed]
              72. ros-bouncy-tf2-msgs [Not Installed]
              73. ros-bouncy-tf2-ros [Not Installed]
              74. ros-bouncy-trajectory-msgs [Not Installed]
              75. ros-bouncy-visualization-msgs [Not Installed]
              76. zlib1g-dev [Not Installed]
              77. python3-docutils recommends python3-pil
              78. cmake recommends gcc
              79. dpkg-dev recommends build-essential
              80. libpython3.6-dev recommends libc6-dev | libc-dev
              81. python3.6-dev recommends libc6-dev | libc-dev
              [] binutils{a} binutils-aarch64-linux-gnu{a} binutils-common{a} build-essential{a} cmake{a} cmake-data{a} cpp{a} cpp-7{a} cppcheck{a} default-libmysqlclient-dev{a} dh-python{a} docutils-common{a} dpkg-dev{a} fakeroot{a} g++{a} g++-7{a} gcc{a} gcc-7{a} gcc-7-base{a} google-mock{a} googletest{a} libalgorithm-diff-perl{a} libalgorithm-diff-xs-perl{a} libalgorithm-merge-perl{a} libarchive13{a} libasan4{a} libatomic1{a} libbinutils{a} libc-dev-bin{ab} libc6-dev{ab} libcc1-0{a} libdpkg-perl{a} libeigen3-dev{a} libexpat1-dev{a} libfakeroot{a} libfile-fcntllock-perl{a} libfreetype6{a} libgcc-7-dev{a} libglib2.0-0{a} libglib2.0-data{a} libgomp1{a} libgtest-dev{a} libicu60{a} libisl19{a} libitm1{a} libjbig0{a} libjpeg-turbo8{a} libjpeg8{a} libjsoncpp1{a} liblcms2-2{a} liblsan0{a} libltdl7{a} liblzo2-2{a} libmpc3{a} libmpfr6{a} libmysqlclient-dev{a} libmysqlclient20{a} libodbc1{a} libpaper-utils{a} libpaper1{a} libpcre16-3{a} libpcre3-dev{a} libpcre32-3{a} libpcrecpp0v5{a} libpng16-16{a} libpoco-dev{a} libpococrypto50{a} libpocodata50{a} libpocodatamysql50{a} libpocodataodbc50{a} libpocodatasqlite50{a} libpocofoundation50{a} libpocojson50{a} libpocomongodb50{a} libpoconet50{a} libpoconetssl50{a} libpocoredis50{a} libpocoutil50{a} libpocoxml50{a} libpocozip50{a} libpython-stdlib{a} libpython2.7-minimal{a} libpython2.7-stdlib{a} libpython3-dev{a} libpython3.6-dev{a} librhash0{a} libsqlite3-dev{a} libssl-dev{a} libstdc++-7-dev{a} libtiff5{a} libtinyxml-dev{a} libtinyxml2-6{a} libtinyxml2-dev{a} libtinyxml2.6.2v5{a} libtsan0{a} libubsan0{a} libuv1{a} libwebp6{a} libwebpdemux2{a} libwebpmux3{a} libxml2{a} libyaml-0-2{a} libyaml-dev{a} linux-libc-dev{a} make{a} manpages{a} manpages-dev{a} multiarch-support{a} mysql-common{a} patch{a} pkg-config{a} pydocstyle{a} pyflakes{a} pyflakes3{a} python{a} python-minimal{a} python-pkg-resources{a} python-pyflakes{a} python2.7{a} python2.7-minimal{a} python3-attr{a} python3-catkin-pkg-modules{a} python3-dateutil{a} python3-dev{ab} python3-docutils{a} python3-empy{a} python3-flake8{a} python3-mccabe{a} python3-olefile{a} python3-pil{ab} python3-pluggy{a} python3-py{a} python3-pycodestyle{a} python3-pydocstyle{a} python3-pyflakes{a} python3-pygments{a} python3-pyparsing{a} python3-pytest{a} python3-roman{a} python3-six{a} python3-snowballstemmer{a} python3-yaml{ab} python3.6{a} python3.6-dev{a} python3.6-minimal{a} ros-bouncy-actionlib-msgs{a} ros-bouncy-ament-cmake{a} ros-bouncy-ament-cmake-auto{a} ros-bouncy-ament-cmake-copyright{a} ros-bouncy-ament-cmake-core{a} ros-bouncy-ament-cmake-cppcheck{a} ros-bouncy-ament-cmake-cpplint{a} ros-bouncy-ament-cmake-export-definitions{a} ros-bouncy-ament-cmake-export-dependencies{a} ros-bouncy-ament-cmake-export-include-directories{a} ros-bouncy-ament-cmake-export-interfaces{a} ros-bouncy-ament-cmake-export-libraries{a} ros-bouncy-ament-cmake-export-link-flags{a} ros-bouncy-ament-cmake-flake8{a} ros-bouncy-ament-cmake-gmock{a} ros-bouncy-ament-cmake-gtest{a} ros-bouncy-ament-cmake-include-directories{a} ros-bouncy-ament-cmake-libraries{a} ros-bouncy-ament-cmake-lint-cmake{a} ros-bouncy-ament-cmake-pep257{a} ros-bouncy-ament-cmake-pytest{a} ros-bouncy-ament-cmake-python{a} ros-bouncy-ament-cmake-ros{a} ros-bouncy-ament-cmake-target-dependencies{a} ros-bouncy-ament-cmake-test{a} ros-bouncy-ament-cmake-uncrustify{a} ros-bouncy-ament-copyright{a} ros-bouncy-ament-cppcheck{a} ros-bouncy-ament-cpplint{a} ros-bouncy-ament-flake8{a} ros-bouncy-ament-index-cpp{a} ros-bouncy-ament-index-python{a} ros-bouncy-ament-lint-auto{a} ros-bouncy-ament-lint-cmake{a} ros-bouncy-ament-lint-common{a} ros-bouncy-ament-package{a} ros-bouncy-ament-pep257{a} ros-bouncy-ament-uncrustify{a} ros-bouncy-builtin-interfaces{a} ros-bouncy-class-loader{a} ros-bouncy-common-interfaces{a} ros-bouncy-console-bridge{a} ros-bouncy-diagnostic-msgs{a} ros-bouncy-fastcdr{a} ros-bouncy-fastrtps{a} ros-bouncy-fastrtps-cmake-module{a} ros-bouncy-geometry-msgs{a} ros-bouncy-gmock-vendor{a} ros-bouncy-gtest-vendor{a} ros-bouncy-kdl-parser{a} ros-bouncy-launch{a} ros-bouncy-launch-ros{a} ros-bouncy-libyaml-vendor{a} ros-bouncy-lifecycle-msgs{a} ros-bouncy-nav-msgs{a} ros-bouncy-orocos-kdl{a} ros-bouncy-osrf-pycommon{a} ros-bouncy-pluginlib{a} ros-bouncy-poco-vendor{a} ros-bouncy-python-cmake-module{a} ros-bouncy-rcl{a} ros-bouncy-rcl-interfaces{a} ros-bouncy-rcl-lifecycle{a} ros-bouncy-rcl-yaml-param-parser{a} ros-bouncy-rclcpp{a} ros-bouncy-rclcpp-lifecycle{a} ros-bouncy-rclpy{a} ros-bouncy-rcutils{a} ros-bouncy-rmw{a} ros-bouncy-rmw-fastrtps-cpp{a} ros-bouncy-rmw-implementation{a} ros-bouncy-rmw-implementation-cmake{a} ros-bouncy-robot-state-publisher{a} ros-bouncy-ros-base ros-bouncy-ros-core{a} ros-bouncy-ros-environment{a} ros-bouncy-ros-workspace{a} ros-bouncy-ros2cli{a} ros-bouncy-ros2launch{a} ros-bouncy-ros2lifecycle{a} ros-bouncy-ros2msg{a} ros-bouncy-ros2node{a} ros-bouncy-ros2param{a} ros-bouncy-ros2pkg{a} ros-bouncy-ros2run{a} ros-bouncy-ros2service{a} ros-bouncy-ros2srv{a} ros-bouncy-ros2topic{a} ros-bouncy-rosgraph-msgs{a} ros-bouncy-rosidl-cmake{a} ros-bouncy-rosidl-default-generators{a} ros-bouncy-rosidl-default-runtime{a} ros-bouncy-rosidl-generator-c{a} ros-bouncy-rosidl-generator-cpp{a} ros-bouncy-rosidl-generator-py{a} ros-bouncy-rosidl-parser{a} ros-bouncy-rosidl-typesupport-c{a} ros-bouncy-rosidl-typesupport-cpp{a} ros-bouncy-rosidl-typesupport-interface{a} ros-bouncy-rosidl-typesupport-introspection-c{a} ros-bouncy-rosidl-typesupport-introspection-cpp{a} ros-bouncy-sensor-msgs{a} ros-bouncy-shape-msgs{a} ros-bouncy-std-msgs{a} ros-bouncy-std-srvs{a} ros-bouncy-stereo-msgs{a} ros-bouncy-tf2{a} ros-bouncy-tf2-eigen{a} ros-bouncy-tf2-geometry-msgs{a} ros-bouncy-tf2-msgs{a} ros-bouncy-tf2-ros{a} ros-bouncy-tinyxml-vendor{a} ros-bouncy-tinyxml2-vendor{a} ros-bouncy-trajectory-msgs{a} ros-bouncy-uncrustify-vendor{a} ros-bouncy-urdf{a} ros-bouncy-urdfdom{a} ros-bouncy-urdfdom-headers{a} ros-bouncy-visualization-msgs{a} sgml-base{a} shared-mime-info{a} tzdata{a} ucf{a} xdg-user-dirs{[-]Result:success ing 0 B will be used.upgraded.ds to be installed
              [-]Result:code:2
              [-]Result:code:2
              这个是完整的日志,我不知道您说的完整版ROS是哪个版本😁 😁 😁
                小鱼 技术大佬 @1194155320
                @1194155320 兄弟,格式,格式!
                  小鱼 技术大佬 @1194155320
                  @1194155320 ROS2建议安装dashing版本,虽然已经EOL了
