使用slam_toolbox建图时候出现的问题
如题,这边在进行建图的时候执行命令一直在刷错误的日志
[async_slam_toolbox_node-1] [INFO] [1700478030.455096736] [slam_toolbox]: Message Filter dropping message: frame 'laser_frame' at time 1700478030.330 for reason 'discarding message because the queue is full'
[async_slam_toolbox_node-1] [INFO] [1700478030.580651700] [slam_toolbox]: Message Filter dropping message: frame 'laser_frame' at time 1700478030.455 for reason 'discarding message because the queue is full'
[async_slam_toolbox_node-1] [INFO] [1700478030.705320594] [slam_toolbox]: Message Filter dropping message: frame 'laser_frame' at time 1700478030.580 for reason 'discarding message because the queue is full'
[async_slam_toolbox_node-1] [INFO] [1700478030.830646019] [slam_toolbox]: Message Filter dropping message: frame 'laser_frame' at time 1700478030.705 for reason 'discarding message because the queue is full'
[async_slam_toolbox_node-1] [INFO] [1700478030.955252392] [slam_toolbox]: Message Filter dropping message: frame 'laser_frame' at time 1700478030.830 for reason 'discarding message because the queue is full'
[async_slam_toolbox_node-1] [INFO] [1700478031.080491511] [slam_toolbox]: Message Filter dropping message: frame 'laser_frame' at time 1700478030.955 for reason 'discarding message because the queue is full'
话题也能正常出现
然后打开rviz也没有出现地图
请问有遇到过类似情况的吗 雷达那些都是正常 就map的时候不正常这个是bringup的打印
求大神解答
@小鱼 已经处理好了 重新编译一下底盘代码就ok了
@1014535185 您好,我遇到了和您一样的问题,您最后重新编译底盘代码就好了么?为什么呢?单独编译底盘代码么?我的报错、topic list以及rviz显示和您一模一样,还望您有时间为我解答一下困惑
